[U-Boot] [PATCH v6 1/4] MX5: Make the weim structure complete
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: - No changes Changes since v4: - Change the definition of WEIM single-bit field Changes since v3: - No changes Changes since v2: - Add CS1_BASE_ADDR for MX51 - Add WEIM Registers arch/arm/include/asm/arch-mx5/imx-regs.h | 131 ++++++++++++++++++++++++++++-- 1 files changed, 125 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index a1849f8..e136607 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -32,6 +32,7 @@ #define CSD0_BASE_ADDR 0x90000000 #define CSD1_BASE_ADDR 0xA0000000 #define NFC_BASE_ADDR_AXI 0xCFFF0000 +#define CS1_BASE_ADDR 0xB8000000 #elif defined(CONFIG_MX53) #define IPU_CTRL_BASE_ADDR 0x18000000 #define SPBA0_BASE_ADDR 0x50000000 @@ -41,6 +42,7 @@ #define CSD1_BASE_ADDR 0xB0000000 #define NFC_BASE_ADDR_AXI 0xF7FF0000 #define IRAM_BASE_ADDR 0xF8000000 +#define CS1_BASE_ADDR 0xF4000000 #else #error "CPU_TYPE not defined" #endif @@ -129,6 +131,90 @@ #define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000)
/* + * WEIM CSnGCR1 + */ +#define CSEN 1 +#define SWR (1 << 1) +#define SRD (1 << 2) +#define MUM (1 << 3) +#define WFL (1 << 4) +#define RFL (1 << 5) +#define CRE (1 << 6) +#define CREP (1 << 7) +#define BL(x) (((x) & 0x7) << 8) +#define WC (1 << 11) +#define BCD(x) (((x) & 0x3) << 12) +#define BCS(x) (((x) & 0x3) << 14) +#define DSZ(x) (((x) & 0x7) << 16) +#define SP (1 << 19) +#define CSREC(x) (((x) & 0x7) << 20) +#define AUS (1 << 23) +#define GBC(x) (((x) & 0x7) << 24) +#define WP (1 << 27) +#define PSZ(x) (((x) & 0x0f << 28) + +/* + * WEIM CSnGCR2 + */ +#define ADH(x) (((x) & 0x3)) +#define DAPS(x) (((x) & 0x0f << 4) +#define DAE (1 << 8) +#define DAP (1 << 9) +#define MUX16_BYP (1 << 12) + +/* + * WEIM CSnRCR1 + */ +#define RCSN(x) (((x) & 0x7)) +#define RCSA(x) (((x) & 0x7) << 4) +#define OEN(x) (((x) & 0x7) << 8) +#define OEA(x) (((x) & 0x7) << 12) +#define RADVN(x) (((x) & 0x7) << 16) +#define RAL (1 << 19) +#define RADVA(x) (((x) & 0x7) << 20) +#define RWSC(x) (((x) & 0x3f) << 24) + +/* + * WEIM CSnRCR2 + */ +#define RBEN(x) (((x) & 0x7)) +#define RBE (1 << 3) +#define RBEA(x) (((x) & 0x7) << 4) +#define RL(x) (((x) & 0x3) << 8) +#define PAT(x) (((x) & 0x7) << 12) +#define APR (1 << 15) + +/* + * WEIM CSnWCR1 + */ +#define WCSN(x) (((x) & 0x7)) +#define WCSA(x) (((x) & 0x7) << 3) +#define WEN(x) (((x) & 0x7) << 6) +#define WEA(x) (((x) & 0x7) << 9) +#define WBEN(x) (((x) & 0x7) << 12) +#define WBEA(x) (((x) & 0x7) << 15) +#define WADVN(x) (((x) & 0x7) << 18) +#define WADVA(x) (((x) & 0x7) << 21) +#define WWSC(x) (((x) & 0x3f) << 24) +#define WBED1 (1 << 30) +#define WAL (1 << 31) + +/* + * WEIM CSnWCR2 + */ +#define WBED 1 + +/* + * WEIM WCR + */ +#define BCM 1 +#define GBCD(x) (((x) & 0x3) << 1) +#define INTEN (1 << 4) +#define INTPOL (1 << 5) +#define WDOG_EN (1 << 8) +#define WDOG_LIMIT(x) (((x) & 0x3) << 9) + +/* * Number of GPIO pins per port */ #define GPIO_NUM_PIN 32 @@ -231,12 +317,45 @@ struct clkctl {
/* WEIM registers */ struct weim { - u32 csgcr1; - u32 csgcr2; - u32 csrcr1; - u32 csrcr2; - u32 cswcr1; - u32 cswcr2; + u32 cs0gcr1; + u32 cs0gcr2; + u32 cs0rcr1; + u32 cs0rcr2; + u32 cs0wcr1; + u32 cs0wcr2; + u32 cs1gcr1; + u32 cs1gcr2; + u32 cs1rcr1; + u32 cs1rcr2; + u32 cs1wcr1; + u32 cs1wcr2; + u32 cs2gcr1; + u32 cs2gcr2; + u32 cs2rcr1; + u32 cs2rcr2; + u32 cs2wcr1; + u32 cs2wcr2; + u32 cs3gcr1; + u32 cs3gcr2; + u32 cs3rcr1; + u32 cs3rcr2; + u32 cs3wcr1; + u32 cs3wcr2; + u32 cs4gcr1; + u32 cs4gcr2; + u32 cs4rcr1; + u32 cs4rcr2; + u32 cs4wcr1; + u32 cs4wcr2; + u32 cs5gcr1; + u32 cs5gcr2; + u32 cs5rcr1; + u32 cs5rcr2; + u32 cs5wcr1; + u32 cs5wcr2; + u32 wcr; + u32 wiar; + u32 ear; };
/* GPIO Registers */
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: - No changes Changes since v4: - No changes Changes since v3: - No changes Changes since v2: - Distinguish iomuxc struct between MX51 and MX53
arch/arm/include/asm/arch-mx5/imx-regs.h | 23 +++++++++++++++++++++++ 1 files changed, 23 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index b65b11f..3c61c7f 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -358,6 +358,29 @@ struct weim { u32 ear; };
+#if defined(CONFIG_MX51) +struct iomuxc { + u32 gpr0; + u32 gpr1; + u32 omux0; + u32 omux1; + u32 omux2; + u32 omux3; + u32 omux4; +}; +#elif defined(CONFIG_MX53) +struct iomuxc { + u32 gpr0; + u32 gpr1; + u32 gpr2; + u32 omux0; + u32 omux1; + u32 omux2; + u32 omux3; + u32 omux4; +}; +#endif + /* GPIO Registers */ struct gpio_regs { u32 gpio_dr;
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v5: - Use iomuxc as the base struct for IOMUXC_BASE_ADDR Changes since v4: - No changes Changes since v3: - Print the chip size in the case of error
arch/arm/cpu/armv7/mx5/soc.c | 30 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx5/imx-regs.h | 5 ++++ arch/arm/include/asm/arch-mx5/sys_proto.h | 2 +- 3 files changed, 36 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 40b8b56..e599df8 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -163,6 +163,36 @@ int cpu_mmc_init(bd_t *bis) #endif }
+void set_chipselect_size(int const cs_size) +{ + unsigned int reg; + struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + reg = readl(&iomuxc_regs->gpr1); + + switch (cs_size) { + case CS0_128: + reg &= ~0x7; /* CS0=128MB, CS1=0, CS2=0, CS3=0 */ + reg |= 0x5; + break; + case CS0_64M_CS1_64M: + reg &= ~0x3F; /* CS0=64MB, CS1=64MB, CS2=0, CS3=0 */ + reg |= 0x1B; + break; + case CS0_64M_CS1_32M_CS2_32M: + reg &= ~0x1FF; /* CS0=64MB, CS1=32MB, CS2=32MB, CS3=0 */ + reg |= 0x4B; + break; + case CS0_32M_CS1_32M_CS2_32M_CS3_32M: + reg &= ~0xFFF; /* CS0=32MB, CS1=32MB, CS2=32MB, CS3=32MB */ + reg |= 0x249; + break; + default: + printf("Unknown chip select size: %d\n", cs_size); + break; + } + + writel(reg, &iomuxc_regs->gpr1); +}
void reset_cpu(ulong addr) { diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 9d2046a..5163614 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -214,6 +214,11 @@ #define WDOG_EN(x) ((x) << 8) #define WDOG_LIMIT(x) (((x) & 0x3) << 9)
+#define CS0_128 0 +#define CS0_64M_CS1_64M 1 +#define CS0_64M_CS1_32M_CS2_32M 2 +#define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3 + /* * Number of GPIO pins per port */ diff --git a/arch/arm/include/asm/arch-mx5/sys_proto.h b/arch/arm/include/asm/arch-mx5/sys_proto.h index f687503..ce63675 100644 --- a/arch/arm/include/asm/arch-mx5/sys_proto.h +++ b/arch/arm/include/asm/arch-mx5/sys_proto.h @@ -27,5 +27,5 @@ u32 get_cpu_rev(void); #define is_soc_rev(rev) ((get_cpu_rev() & 0xFF) - rev) void sdelay(unsigned long); - +void set_chipselect_size(int const); #endif
- Use void in the declaration of: void weim_smc911x_iomux and weim_cs1_settings Changes since v4: - Changed the weim cs1 settings for the single-bit fields - Removed unused 'reg' variable inside weim_smc911x_iomux() - Made void weim_cs1_settings() and weim_smc911x_iomux() static Changes since v3: - No changes Changes since v2: - Use macros for setting up weim register - Use set_chipselect_size function - Rename the file to imximage_dd3.cfg to make explicit the DDR type. MAINTAINERS | 1 + board/freescale/mx53ard/Makefile | 48 +++++ board/freescale/mx53ard/imximage_dd3.cfg | 96 ++++++++++ board/freescale/mx53ard/mx53ard.c | 306 ++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/mx53ard.h | 198 +++++++++++++++++++ 6 files changed, 650 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx53ard/Makefile create mode 100644 board/freescale/mx53ard/imximage_dd3.cfg create mode 100644 board/freescale/mx53ard/mx53ard.c create mode 100644 include/configs/mx53ard.h
diff --git a/MAINTAINERS b/MAINTAINERS index 07237e3..b63f53f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -639,6 +639,7 @@ Kristoffer Ericson kristoffer.ericson@gmail.com Fabio Estevam fabio.estevam@freescale.com
mx31pdk i.MX31 + mx53ard i.MX53 mx53smd i.MX53
Peter Figuli peposh@etc.sk diff --git a/board/freescale/mx53ard/Makefile b/board/freescale/mx53ard/Makefile new file mode 100644 index 0000000..c48ece8 --- /dev/null +++ b/board/freescale/mx53ard/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := mx53ard.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx53ard/imximage_dd3.cfg b/board/freescale/mx53ard/imximage_dd3.cfg new file mode 100644 index 0000000..0f298ab --- /dev/null +++ b/board/freescale/mx53ard/imximage_dd3.cfg @@ -0,0 +1,96 @@ +# +# (C) Copyright 2009 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# image version + +IMAGE_VERSION 2 + +# Boot Device : one of +# spi, sd (the board has no nand neither onenand) + +BOOT_FROM sd + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register +DATA 4 0x53fa8554 0x00300000 +DATA 4 0x53fa8558 0x00300040 +DATA 4 0x53fa8560 0x00300000 +DATA 4 0x53fa8564 0x00300040 +DATA 4 0x53fa8568 0x00300040 +DATA 4 0x53fa8570 0x00300000 +DATA 4 0x53fa8574 0x00300000 +DATA 4 0x53fa8578 0x00300000 +DATA 4 0x53fa857c 0x00300040 +DATA 4 0x53fa8580 0x00300040 +DATA 4 0x53fa8584 0x00300000 +DATA 4 0x53fa8588 0x00300000 +DATA 4 0x53fa8590 0x00300040 +DATA 4 0x53fa8594 0x00300000 +DATA 4 0x53fa86f0 0x00300000 +DATA 4 0x53fa86f4 0x00000000 +DATA 4 0x53fa86fc 0x00000000 +DATA 4 0x53fa8714 0x00000000 +DATA 4 0x53fa8718 0x00300000 +DATA 4 0x53fa871c 0x00300000 +DATA 4 0x53fa8720 0x00300000 +DATA 4 0x53fa8724 0x04000000 +DATA 4 0x53fa8728 0x00300000 +DATA 4 0x53fa872c 0x00300000 +DATA 4 0x63fd9088 0x35343535 +DATA 4 0x63fd9090 0x4d444c44 +DATA 4 0x63fd907c 0x01370138 +DATA 4 0x63fd9080 0x013b013c +DATA 4 0x63fd9018 0x00011740 +DATA 4 0x63fd9000 0xc3190000 +DATA 4 0x63fd900c 0x9f5152e3 +DATA 4 0x63fd9010 0xb68e8a63 +DATA 4 0x63fd9014 0x01ff00db +DATA 4 0x63fd902c 0x000026d2 +DATA 4 0x63fd9030 0x009f0e21 +DATA 4 0x63fd9008 0x12273030 +DATA 4 0x63fd9004 0x0002002d +DATA 4 0x63fd901c 0x00008032 +DATA 4 0x63fd901c 0x00008033 +DATA 4 0x63fd901c 0x00028031 +DATA 4 0x63fd901c 0x092080b0 +DATA 4 0x63fd901c 0x04008040 +DATA 4 0x63fd901c 0x0000803a +DATA 4 0x63fd901c 0x0000803b +DATA 4 0x63fd901c 0x00028039 +DATA 4 0x63fd901c 0x09208138 +DATA 4 0x63fd901c 0x04008048 +DATA 4 0x63fd9020 0x00001800 +DATA 4 0x63fd9040 0x04b80003 +DATA 4 0x63fd9058 0x00022227 +DATA 4 0x63fd901C 0x00000000 diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c new file mode 100644 index 0000000..7bc9c2e --- /dev/null +++ b/board/freescale/mx53ard/mx53ard.c @@ -0,0 +1,306 @@ +/* + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx5x_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/errno.h> +#include <netdev.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <mxc_gpio.h> + +#define ETHERNET_INT (1 * 32 + 31) /* GPIO2_31 */ + +DECLARE_GLOBAL_DATA_PTR; + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int dram_init(void) +{ + u32 size1, size2; + + size1 = get_ram_size((volatile void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); + size2 = get_ram_size((volatile void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); + + gd->ram_size = size1 + size2; + + return 0; +} +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +} + +static void setup_iomux_uart(void) +{ + /* UART1 RXD */ + mxc_request_iomux(MX53_PIN_ATA_DMACK, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX53_PIN_ATA_DMACK, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_UART1_IPP_UART_RXD_MUX_SELECT_INPUT, 0x3); + + /* UART1 TXD */ + mxc_request_iomux(MX53_PIN_ATA_DIOW, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX53_PIN_ATA_DIOW, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg[2] = { + {MMC_SDHC1_BASE_ADDR, 1 }, + {MMC_SDHC2_BASE_ADDR, 1 }, +}; + +int board_mmc_getcd(u8 *cd, struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) + *cd = mxc_gpio_get(1); /*GPIO1_1*/ + else + *cd = mxc_gpio_get(4); /*GPIO1_4*/ + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + u32 index; + s32 status = 0; + + for (index = 0; index < CONFIG_SYS_FSL_ESDHC_NUM; index++) { + switch (index) { + case 0: + mxc_request_iomux(MX53_PIN_SD1_CMD, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_CLK, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA0, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA1, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA2, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA3, + IOMUX_CONFIG_ALT0); + + mxc_iomux_set_pad(MX53_PIN_SD1_CMD, 0x1E4); + mxc_iomux_set_pad(MX53_PIN_SD1_CLK, 0xD4); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA0, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA1, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA2, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA3, 0x1D4); + break; + case 1: + mxc_request_iomux(MX53_PIN_SD2_CMD, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX53_PIN_SD2_CLK, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX53_PIN_SD2_DATA0, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD2_DATA1, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD2_DATA2, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD2_DATA3, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_ATA_DATA12, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_DATA13, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_DATA14, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_DATA15, + IOMUX_CONFIG_ALT2); + + mxc_iomux_set_pad(MX53_PIN_SD2_CMD, 0x1E4); + mxc_iomux_set_pad(MX53_PIN_SD2_CLK, 0xD4); + mxc_iomux_set_pad(MX53_PIN_SD2_DATA0, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD2_DATA1, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD2_DATA2, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_SD2_DATA3, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA12, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA13, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA14, 0x1D4); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA15, 0x1D4); + break; + default: + printf("Warning: you configured more ESDHC controller" + "(%d) as supported by the board(2)\n", + CONFIG_SYS_FSL_ESDHC_NUM); + return status; + } + status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); + } + + return status; +} +#endif + +static void weim_smc911x_iomux(void) +{ + /* ETHERNET_INT as GPIO2_31 */ + mxc_request_iomux(MX53_PIN_EIM_EB3, IOMUX_CONFIG_ALT1); + mxc_gpio_direction(ETHERNET_INT, MXC_GPIO_DIRECTION_IN); + + /* Data bus */ + mxc_request_iomux(MX53_PIN_EIM_D16, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D16, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D17, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D17, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D18, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D18, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D19, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D19, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D20, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D20, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D21, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D21, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D22, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D22, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D23, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D23, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D24, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D24, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D25, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D25, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D26, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D26, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D27, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D27, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D28, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D28, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D29, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D29, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D30, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D30, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_D31, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_D31, 0xA4); + + /* Address lines */ + mxc_request_iomux(MX53_PIN_EIM_DA0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA0, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA1, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA2, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA2, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA3, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA3, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA4, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA4, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA5, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA5, 0xA4); + + mxc_request_iomux(MX53_PIN_EIM_DA6, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA6, 0xA4); + + /* other EIM signals for ethernet */ + mxc_request_iomux(MX53_PIN_EIM_OE, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_EIM_RW, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_EIM_CS1, IOMUX_CONFIG_ALT0); +} + +static void weim_cs1_settings(void) +{ + struct weim *weim_regs = (struct weim *)WEIM_BASE_ADDR; + + writel(MX53ARD_CS1GCR1, &weim_regs->cs1gcr1); + writel(0x0, &weim_regs->cs1gcr2); + writel(MX53ARD_CS1RCR1, &weim_regs->cs1rcr1); + writel(MX53ARD_CS1RCR2, &weim_regs->cs1rcr2); + writel(MX53ARD_CS1WCR1, &weim_regs->cs1wcr1); + writel(0x0, &weim_regs->cs1wcr2); + writel(0x0, &weim_regs->wcr); + + set_chipselect_size(CS0_64M_CS1_64M); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_MX53_ARD; + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; + + weim_smc911x_iomux(); + weim_cs1_settings(); + +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + +int checkboard(void) +{ + puts("Board: MX53ARD\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 9339981..a616f29 100644 --- a/boards.cfg +++ b/boards.cfg @@ -124,6 +124,7 @@ dkb arm arm926ejs - Marvell pantheon ca9x4_ct_vxp arm armv7 vexpress armltd efikamx arm armv7 efikamx - mx5 mx51evk arm armv7 mx51evk freescale mx5 mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg +mx53ard arm armv7 mx53ard freescale mx5 mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg mx53loco arm armv7 mx53loco freescale mx5 mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg mx53smd arm armv7 mx53smd freescale mx5 mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h new file mode 100644 index 0000000..c872510 --- /dev/null +++ b/include/configs/mx53ard.h @@ -0,0 +1,198 @@ +/* + * Copyright (C) 2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the MX53ARD Freescale board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX53 + +#define CONFIG_SYS_MX5_HCLK 24000000 +#define CONFIG_SYS_MX5_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_L2_OFF + +#include <asm/arch/imx-regs.h> + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_REVISION_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX53_UART1 + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_HARD_I2C +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_MX53_PORT2 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0xfe + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* Eth Configs */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_MII_GASKET +#define CONFIG_DISCOVER_PHY + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_PRIME "smc911x" + +/*Support LAN9217*/ +#define CONFIG_SMC911X +#define CONFIG_SMC911X_16_BIT +#define CONFIG_SMC911X_BASE CS1_BASE_ADDR + +#define CONFIG_LOADADDR 0x70800000 /* loadaddr env var */ +#define CONFIG_SYS_TEXT_BASE 0x77800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "mmcargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm\0" \ + "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan ${mmcdev}; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "MX53ARD U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x70000000 +#define CONFIG_SYS_MEMTEST_END 0x70010000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/* Stack sizes */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024) +#define PHYS_SDRAM_2 CSD1_BASE_ADDR +#define PHYS_SDRAM_2_SIZE (512 * 1024 * 1024) +#define PHYS_SDRAM_SIZE (PHYS_SDRAM_1_SIZE + PHYS_SDRAM_2_SIZE) + +#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT + +#define MX53ARD_CS1GCR1 (CSEN | DSZ(2)) +#define MX53ARD_CS1RCR1 (RCSN(2) | OEN (1) | RWSC(22)) +#define MX53ARD_CS1RCR2 RBEN(2) +#define MX53ARD_CS1WCR1 (WCSN(2) | WEN(2) | WBEN(2) | WWSC(22)) + +#endif /* __CONFIG_H */
Fabio Estevam
