[U-Boot] [PATCH 1/2] smbios: add parsing API
Add an very simple API to be able to access SMBIOS strings like vendor, model and bios version.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- include/smbios.h | 37 ++++++++++ lib/Kconfig | 6 ++ lib/Makefile | 1 + lib/smbios-parser.c | 162 ++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 206 insertions(+) create mode 100644 lib/smbios-parser.c
diff --git a/include/smbios.h b/include/smbios.h index 97b9ddce23..ad44e54245 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -237,4 +237,41 @@ typedef int (*smbios_write_type)(ulong *addr, int handle); */ ulong write_smbios_table(ulong addr);
+ +struct smbios_parser; + +/** + * smbios_parser_create() - Create smbios parser + * + * @addr: start address to search for SMBIOS structure + * @len: size of search area + * @return: NULL or valid pointer to a struct smbios_parser + */ +struct smbios_parser *smbios_parser_create(unsigned int addr, unsigned int len); + +/** + * smbios_parser_destroy() - Destroy smbios parser + * + * @p: pointer to a struct smbios_parser + */ +void smbios_parser_destroy(struct smbios_parser *p); + +/** + * smbios_header() - Search for SMBIOS header type + * + * @p: pointer to a struct smbios_parser + * @type: SMBIOS type + * @return: NULL or a valid pointer to a struct smbios_header + */ +struct smbios_header *smbios_header(const struct smbios_parser *p, int type); + +/** + * smbios_string() - Return string from SMBIOS + * + * @header: pointer to struct smbios_header + * @index: string index + * @return: NULL or a valid const char pointer + */ +const char *smbios_string(const struct smbios_header *header, int index); + #endif /* _SMBIOS_H_ */ diff --git a/lib/Kconfig b/lib/Kconfig index 2120216593..59aafc63a7 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -432,6 +432,12 @@ config SMBIOS_PRODUCT_NAME
endmenu
+config SMBIOS_PARSER + bool "SMBIOS parser" + default n + help + A simple parser for SMBIOS data. + source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig diff --git a/lib/Makefile b/lib/Makefile index 47829bfed5..f095bd420a 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_FIT) += fdtdec_common.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += smbios.o +obj-$(CONFIG_SMBIOS_PARSER) += smbios-parser.o obj-$(CONFIG_IMAGE_SPARSE) += image-sparse.o obj-y += ldiv.o obj-$(CONFIG_MD5) += md5.o diff --git a/lib/smbios-parser.c b/lib/smbios-parser.c new file mode 100644 index 0000000000..b24fd7210c --- /dev/null +++ b/lib/smbios-parser.c @@ -0,0 +1,162 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Bachmann electronic GmbH + */ + +#include <common.h> +#include <malloc.h> +#include <mapmem.h> +#include <smbios.h> + +struct smbios_parser { + void *search_area; + unsigned int search_area_len; + struct smbios_entry *entry; + void *data; +}; + +static inline int verify_checksum(const struct smbios_entry *e) +{ + /* + * Checksums for SMBIOS tables are calculated to have a value, so that + * the sum over all bytes yields zero (using unsigned 8 bit arithmetic). + */ + u8 *byte = (u8 *)e; + u8 sum = 0; + + for (int i = 0; i < e->length; i++) + sum += byte[i]; + + return sum; +} + +static struct smbios_entry *find_smbios_entry(const struct smbios_parser *p) +{ + static const char sm_sig[] = "_SM_"; + u8 *buf = (u8 *)p->search_area; + const u8 *end = (u8 *)p->search_area + p->search_area_len; + struct smbios_entry *entry = NULL; + + /* look for smbios entry */ + while (buf < end) { + if (memcmp(sm_sig, buf, 4) == 0) { + entry = (struct smbios_entry *)buf; + + if (verify_checksum(entry)) { + entry = NULL; + buf++; + continue; + } + + break; + } + + buf++; + } + + return entry; +} + +void smbios_parser_destroy(struct smbios_parser *p) +{ + if (!p) + return; + + unmap_sysmem(p->data); + unmap_sysmem(p->search_area); + + free(p); +} + +struct smbios_parser *smbios_parser_create(unsigned int addr, unsigned int len) +{ + struct smbios_parser *p = malloc(sizeof(struct smbios_parser)); + + if (!p) + return NULL; + + p->search_area_len = len; + p->search_area = map_sysmem(addr, len); + + if (!p->search_area) + goto fail; + + /* find main entry smbios table */ + p->entry = find_smbios_entry(p); + + if (!p->entry) + goto fail; + + /* map smbios data area */ + p->data = map_sysmem(p->entry->struct_table_address, + p->entry->struct_table_length); + + if (!p->data) + goto fail; + + return p; + +fail: + smbios_parser_destroy(p); + + return NULL; +} + +static struct smbios_header *next_header(const struct smbios_header *curr) +{ + u8 *pos = ((u8 *)curr) + curr->length; + + /* search for _double_ NULL bytes */ + while (!((*pos == 0) && (*(pos + 1) == 0))) + pos++; + + /* step behind the double NULL bytes */ + pos += 2; + + return (struct smbios_header *)pos; +} + +struct smbios_header *smbios_header(const struct smbios_parser *p, int type) +{ + const struct smbios_entry *entry = p->entry; + const unsigned int num_header = entry->struct_count; + struct smbios_header *header = (struct smbios_header *)p->data; + + for (unsigned int i = 0; i < num_header; i++) { + if (header->type == type) + return header; + + header = next_header(header); + } + + return NULL; +} + +static const char *string_from_smbios_table(const struct smbios_header *header, + int idx) +{ + unsigned int i = 1; + u8 *pos; + + if (!header) + return NULL; + + pos = ((u8 *)header) + header->length; + + while (i < idx) { + if (*pos == 0x0) + i++; + + pos++; + } + + return (const char *)pos; +} + +const char *smbios_string(const struct smbios_header *header, int index) +{ + if (!header) + return NULL; + + return string_from_smbios_table(header, index); +}
If u-boot gets used as coreboot payload it might be nice to get vendor, model and bios version from smbios. I am not sure about the output of all the read information.
With qemu target for coreboot this could look this:
CBFS: 'Master Header Locator' located CBFS at [7a0200:800000) CBFS: Locating 'fallback/payload' CBFS: Found @ offset 13000 size 36ae4 Checking segment from ROM address 0xfffb3238 Checking segment from ROM address 0xfffb3254 Loading segment from ROM address 0xfffb3238 code (compression=1) New segment dstaddr 0x01110000 memsize 0x7c7bb srcaddr 0xfffb3270 filesize 0x36aac Loading Segment: addr: 0x01110000 memsz: 0x000000000007c7bb filesz: 0x0000000000036aac using LZMA Loading segment from ROM address 0xfffb3254 Entry Point 0x01110015 Jumping to boot code at 01110015(07fa8000)
U-Boot 2019.04-00337-ga602a0489f-dirty (Apr 16 2019 - 13:30:50 +0200)
CPU: x86, vendor Intel, device 663h DRAM: 127.4 MiB MMC: Video: No video mode configured in coreboot! Video: No video mode configured in coreboot! Vendor: QEMU Model: Standard PC (i440FX + PIIX, 1996) Bios Version: 4.9-1324-ge2f0a5f76c-dirty Net: e1000: 52:54:00:12:34:56
Warning: e1000#0 using MAC address from ROM eth0: e1000#0 No working controllers found Finalizing coreboot Hit any key to stop autoboot: 0
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/coreboot/coreboot/coreboot.c | 47 ++++++++++++++++++++++++++++++ configs/coreboot_defconfig | 1 + 2 files changed, 48 insertions(+)
diff --git a/board/coreboot/coreboot/coreboot.c b/board/coreboot/coreboot/coreboot.c index ed5606d4a4..12b3eef52f 100644 --- a/board/coreboot/coreboot/coreboot.c +++ b/board/coreboot/coreboot/coreboot.c @@ -4,6 +4,53 @@ */
#include <common.h> +#include <smbios.h> + +int show_board_info(void) +{ + struct smbios_parser *p = smbios_parser_create(0xF0000, 0x10000); + + if (!p) + goto fallback; + + const struct smbios_header *bios = smbios_header(p, SMBIOS_BIOS_INFORMATION); + const struct smbios_header *system = smbios_header(p, SMBIOS_SYSTEM_INFORMATION); + const struct smbios_type0 *t0 = (struct smbios_type0 *)bios; + const struct smbios_type1 *t1 = (struct smbios_type1 *)system; + + if (!t0 || !t1) + goto fallback; + + const char *bios_ver = smbios_string(bios, t0->bios_ver); + const char *model = smbios_string(system, t1->product_name); + const char *manufacturer = smbios_string(system, t1->manufacturer); + + if (!model || !manufacturer || !bios_ver) + goto fallback; + + printf("Vendor: %s\n", manufacturer); + printf("Model: %s\n", model); + printf("Bios Version: %s\n", bios_ver); + + smbios_parser_destroy(p); + + return 0; + +fallback: + + smbios_parser_destroy(p); + +#ifdef CONFIG_OF_CONTROL + DECLARE_GLOBAL_DATA_PTR; + + model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + + if (model) + printf("Model: %s\n", model); +#endif + + return checkboard(); +}
int board_early_init_r(void) { diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 2795fe97ca..9f4a1473fa 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -39,3 +39,4 @@ CONFIG_SYSCON=y CONFIG_SOUND=y CONFIG_SOUND_I8254=y CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_SMBIOS_PARSER=y
Am Di., 16. Apr. 2019 um 13:38 Uhr schrieb Christian Gmeiner christian.gmeiner@gmail.com:
ping
- smbios_parser_create() - Create smbios parser
- @addr: start address to search for SMBIOS structure
- @len: size of search area
- @return: NULL or valid pointer to a struct smbios_parser
- smbios_parser_destroy() - Destroy smbios parser
- @p: pointer to a struct smbios_parser
- smbios_header() - Search for SMBIOS header type
- @type: SMBIOS type
- @return: NULL or a valid pointer to a struct smbios_header
- smbios_string() - Return string from SMBIOS
- @header: pointer to struct smbios_header
- @index: string index
- @return: NULL or a valid const char pointer
endmenu
default n
help
- Copyright (C) 2019, Bachmann electronic GmbH
void *search_area;
void *data;
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
while (buf < end) {
entry = NULL;
buf++;
continue;
break;
buf++;
return entry;
if (!p)
return;
free(p);
if (!p)
return NULL;
goto fail;
if (!p->entry)
goto fail;
if (!p->data)
goto fail;
return p;
+fail:
return NULL;
pos++;
pos += 2;
return header;
return NULL;
int idx)
unsigned int i = 1;
u8 *pos;
if (!header)
return NULL;
while (i < idx) {
if (*pos == 0x0)
i++;
pos++;
if (!header)
return NULL;
2.20.1
endmenu
- bool "SMBIOS parser"
- default n
- help
- void *search_area;
- unsigned int search_area_len;
- struct smbios_entry *entry;
- void *data;
- u8 *byte = (u8 *)e;
- u8 sum = 0;
- for (int i = 0; i < e->length; i++)
sum += byte[i];
- return sum;
- static const char sm_sig[] = "_SM_";
- u8 *buf = (u8 *)p->search_area;
- const u8 *end = (u8 *)p->search_area + p->search_area_len;
- struct smbios_entry *entry = NULL;
- /* look for smbios entry */
- while (buf < end) {
Don't you have a way to pass the DMI pointer directly, maybe using cbfs? Searching through the SMBIOS search area is so 1990s (and pretty much only works on x86).
I also don't think we really need all the smbios_parser logic. No need to create special pseudo objects. IMHO you should either create an actual UCLASS for SMBIOS with genuine callbacks and expose the table as DM object or just make all search functions in this patch stateless. I'd opt for the latter - it's how the SMBIOS creation works too.
Alex
entry = NULL;
buf++;
continue;
break;
buf++;
- return entry;
- if (!p)
return;
- unmap_sysmem(p->data);
- unmap_sysmem(p->search_area);
- free(p);
- struct smbios_parser *p = malloc(sizeof(struct smbios_parser));
- if (!p)
return NULL;
- p->search_area_len = len;
- p->search_area = map_sysmem(addr, len);
- if (!p->search_area)
goto fail;
- /* find main entry smbios table */
- p->entry = find_smbios_entry(p);
- if (!p->entry)
goto fail;
- /* map smbios data area */
- p->data = map_sysmem(p->entry->struct_table_address,
- if (!p->data)
goto fail;
- return p;
+fail:
- smbios_parser_destroy(p);
- return NULL;
- u8 *pos = ((u8 *)curr) + curr->length;
- /* search for _double_ NULL bytes */
- while (!((*pos == 0) && (*(pos + 1) == 0)))
pos++;
- /* step behind the double NULL bytes */
- pos += 2;
- return (struct smbios_header *)pos;
- const struct smbios_entry *entry = p->entry;
- const unsigned int num_header = entry->struct_count;
- struct smbios_header *header = (struct smbios_header *)p->data;
- for (unsigned int i = 0; i < num_header; i++) {
return header;
- return NULL;
int idx)
- unsigned int i = 1;
- u8 *pos;
- if (!header)
return NULL;
- pos = ((u8 *)header) + header->length;
- while (i < idx) {
if (*pos == 0x0)
i++;
pos++;
- return (const char *)pos;
- if (!header)
return NULL;
- return string_from_smbios_table(header, index);
Hi
Am Do., 25. Apr. 2019 um 12:09 Uhr schrieb Alexander Graf agraf@csgraf.de:
endmenu
default n
help
void *search_area;
void *data;
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
while (buf < end) {
Coreboot adds a smbios cbmem entry which can be used to get the base address. Will make use of that mechanism in the next version of the patch set.
I am not sure what you mean with 'special pseudo objects' - struct smbios_parser?
On 29.04.19 16:29, Christian Gmeiner wrote:
Hi
endmenu
default n
help
void *search_area;
void *data;
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
while (buf < end) {
Thanks, that will make this code a lot more robust :).
Yes. The parser is stateful. I would ideally like it best if it wasn't :).
Alex
Am Mo., 29. Apr. 2019 um 17:35 Uhr schrieb Alexander Graf agraf@csgraf.de:
Hi
endmenu
default n
help
void *search_area;
void *data;
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
while (buf < end) {
One of the reasons I need the smbios_parser is the map_sysmem(..) thing. Maybe I do not need it at all - that would make the whole thing much simpler.
Am 29.04.2019 um 17:52 schrieb Christian Gmeiner christian.gmeiner@gmail.com:
On 29.04.19 16:29, Christian Gmeiner wrote: Hi
On 16.04.19 13:38, Christian Gmeiner wrote: Add an very simple API to be able to access SMBIOS strings like vendor, model and bios version.
endmenu
default n
help
void *search_area;
void *data;
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
while (buf < end) {
I think you need it for sandbox, so it's good to have around. But I don't understand why map_sysmem() brings any statefulness requirements?
Alex
Can you please also add a test for each of these functions, with sample data.
BTW here is some code to write fake tables in case it helps:
https://chromium-review.googlesource.com/c/chromiumos/platform2/+/1062212/6/...
Am Mo., 29. Apr. 2019 um 17:41 Uhr schrieb Simon Glass sjg@chromium.org:
Will try my best :)
Alexander Graf
Christian Gmeiner
