RE: [U-Boot-Users] No more omap1510inn/omap1610inn Maintainer?
George-
Mostly I was interested in seeing if he would be interested in submitting a patch to the omap1510inn board to use the driver/cfi_flash.c driver. I tested that configuration in developing my recent patch for the file, and found it worked quite well. I certainly can't complain about writing to flash about 10x as fast as before.
If Kshitij is no longer around, and others are interested in trying it out, I can make a patch for the modifications I made to that board configuration. I don't see a reason to stick with the non-central, slow flash writing code for omap1510inn if a better option is available.
-Michael Bendzick
-----Original Message----- From: George G. Davis [mailto:gdavis@mvista.com] Sent: Friday, July 16, 2004 4:43 PM To: Michael Bendzick Cc: 'wd@denx.de'; U-Boot-Users (E-mail) Subject: Re: [U-Boot-Users] No more omap1510inn/omap1610inn Maintainer?
On Thu, Jul 15, 2004 at 02:44:35PM -0500, Michael Bendzick wrote:
Wolfgang-
It appears that Kshitij Gupta, the maintainer for the omap1510inn & omap1610inn, is no longer reachable at his email address listed in the MAINTAINERS file. Is there anyone else that has been closely associated with this board,
I'm casually aquainted with the OMAP1610 H2 and Innovator/OMAP1510.
What's the problem?
or does anyone know of a new way to contact Kshitij?
Perhaps you can ask questions about those boards here and he or someone else may answer eventually? I'm sure he is just as busy as the rest us are.
-- Regards, George
-Michael Bendzick Systems and Software Engineering Logic Product Development michael.b@logicpd.com 612-436-5122 www.logicpd.com
This SF.Net email is sponsored by BEA Weblogic Workshop FREE Java Enterprise J2EE developer tools! Get your free copy of BEA WebLogic Workshop 8.1 today. http://ads.osdn.com/?ad_id=4721&alloc_id=10040&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On Fri, Jul 16, 2004 at 05:11:20PM -0500, Michael Bendzick wrote:
George-
Sounds agreeable. Just submit it and we can all give it a try. : )
I'm sure he's probably still around but probably quite busy.
I'll give it a try.
Please do send a patch.
Agreed, it sounds good to me to use the common flash driver when/where possible.
FWIW, the OMAP1610 H2 uses Intel L18 flash parts. I'm not sure if the common cfi_flash.c driver supports this part yet.
-- Regards, George
-Michael Bendzick
Wolfgang-
What's the problem?
-- Regards, George
'George G. Davis'
Michael Bendzick
