[U-Boot] [PATCH] common: tsi148 - fix gcc 4.6 compiler warning
Configuring for vme8349 board... cmd_tsi148.c: In function 'tsi148_init': cmd_tsi148.c:56:17: warning: variable 'lastError' set but not used [-Wunused-but-set-variable]
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- common/cmd_tsi148.c | 7 ++----- 1 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/common/cmd_tsi148.c b/common/cmd_tsi148.c index 6dc9dab..7f48ea2 100644 --- a/common/cmd_tsi148.c +++ b/common/cmd_tsi148.c @@ -53,7 +53,7 @@ static TSI148_DEV *dev;
int tsi148_init(void) { - int j, result, lastError = 0; + int j, result; pci_dev_t busdevfn; unsigned int val;
@@ -69,8 +69,7 @@ int tsi148_init(void) dev = malloc(sizeof(*dev)); if (NULL == dev) { puts("Tsi148: No memory!\n"); - result = -1; - goto break_20; + return -1; }
memset(dev, 0, sizeof(*dev)); @@ -139,8 +138,6 @@ int tsi148_init(void) break_30: free(dev); dev = NULL; - break_20: - lastError = result;
return result; }
Dear Kim Phillips,
In message 1321434143-3410-1-git-send-email-kim.phillips@freescale.com you wrote:
Applied, thanks.
Kim Phillips
