Re: [U-Boot-Users] Re: Problem building U-Boot for ARM target
Peter Pearse ha scritto:
No question is stupid - just giving you the info.
I mean, it is quite obvious that it works by you (... and probably by a lot of other people to)
Depends how much time you have available to sort the bug.... Sometimes it's worth it in the long run.
Definitely! but I'm far to be a "guru" in the make stuff.
I tried the macro cc-option "by hand" (so without $CFLAGS) in a bash
shell and I got the same results as above, i.e. the check > for option -mapcs-32 fails but the compiler support it and indeed the compilation works fine! May be a bug?
Sorry forget about this I was making a mistake :-(
The script suggested by Catalin works perfectly either in a bash or a sh shell. On the other hand, the U-Boot build process fails in both shell.
So I have investigated a little bit the macro cc-option: cc-option = $(shell if $(CC) $(CFLAGS) $(1) -S -o /dev/null -xc /dev/null \ > /dev/null 2>&1; then echo "$(1)"; else echo "$(2)"; fi ;)
I tried to drop the CFLAGS variable from the macro: cc-option = $(shell if $(CC) $(1) -S -o /dev/null -xc /dev/null \ > /dev/null 2>&1; then echo "$(1)"; else echo "$(2)"; fi ;) and the build process worked fine i.e. the check for -mapcs-32 was OK.
Next step, in order to see the content of CFLAGS, I modified the macro as: cc-option = $(shell echo "$(CFLAGS)" > ./flags.txt; if $(CC) $(CFLAGS) $(1) -S -o /dev/null -xc /dev/null \ > /dev/null 2>&1; then echo "$(1)"; else echo "$(2)"; fi ;) and this revealed that among a lot of other otions it contains the failing option -mabi=apcs-gnu !!! But this option is not set by anybody else just by: PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mabi=apcs-gnu) So it is obvious why cc-option returns the wrong option!
Now the questions are: 1) Why the CFLAGS is in the macro since cc-option should check the compiler support for a particular option? Indeed the cc-option contained in config.mk is exactly the same as theone contained in linux kernel 2.6.x makefile.
2) How is it possible that CFLAGS contains the failing option since $(call cc-option,-mapcs-32,-mabi=apcs-gnu) is not yet processed and not set by anybody else?
3) Why if I replace -mapcs-32 with -g everything works fine? I wish I never tried that!!
Please Peter or Catalin since your compiler support both -mapcs-32 and -mabi=apcs-gnu options could you try the following? PLATFORM_CPPFLAGS +=$(call cc-option,-mapcs-32,-mfoo)
Thanks for your patience!
-P.Broggini
Paolo Broggini
