[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 645b271a6039e79b368f027a5624dc0820441733:
patman: Add Series-process-log tag to sort/uniq change logs (2013-04-08 15:21:22 -0700)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to dda48e8efff878e51e986befd9c6c3780b4757a7:
powerpc/usb: Fix usb device-tree fix-up (2013-04-10 15:22:25 +0200)
---------------------------------------------------------------- Pantelis Antoniou (4): dfu: Support larger than memory transfers. dfu: NAND specific routines for DFU operation am335x_evm: Define CONFIG_SYS_CACHELINE_SIZE am335x_evm: Enable DFU for NAND and MMC, provide example alt_infos
Tom Rini (5): README: Document current DFU CONFIG options dfu: Change indentation of defines in <dfu.h> nand: Extend nand_(read|write)_skip_bad with *actual and limit parameters cmd_nand.c: Fix CONFIG_CMD_NAND_YAFFS am335x_evm: Add CONFIG_CMD_MTDPARTS and relevant defaults
ramneek mehresh (1): powerpc/usb: Fix usb device-tree fix-up
README | 23 +++++++++ arch/powerpc/cpu/mpc8xxx/fdt.c | 5 ++ board/cm_t35/cm_t35.c | 2 + common/cmd_nand.c | 55 +++++++++++--------- common/env_nand.c | 3 +- drivers/dfu/Makefile | 1 + drivers/dfu/dfu.c | 249 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------- drivers/dfu/dfu_mmc.c | 108 ++++++++++++++++++++++++++------------- drivers/dfu/dfu_nand.c | 187 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/nand_util.c | 68 ++++++++++++++++++++++--- include/configs/am335x_evm.h | 52 ++++++++++++++++++- include/dfu.h | 53 +++++++++++++++++-- include/nand.h | 4 +- 13 files changed, 681 insertions(+), 129 deletions(-) create mode 100644 drivers/dfu/dfu_nand.c
For the record, applied to u-boot/master, thanks!
