[U-Boot] [PATCH v2 0/3] Add Ethernet support for Poplar board
The series adds Ethernet support for Poplar board. It firstly creates a reset driver for HiSilicon platform, then introduces higmacv300 Ethernet driver, and finally enables Ethernet support for Poplar board.
Changes for v2: - Rename driver symbol to HIGMACV300_ETH. - Remove the use of temp variable 'addr' in higmac_recv(). - Simplify the return of function higmac_ofdata_to_platdata() and higmac_probe(). - Combine delaration and initialization for phyintf in function higmac_ofdata_to_platdata(). - Eliminate the MDIO read/write macros. - Use wait_for_bit_le32() for MDIO command completion polling. - Set up RX packet buffers in RX_FQ descriptor at initialization time, so that we do not need to allocate/free packet buffers repeatedly. - Inform GMAC that the RX descriptor is no longer in use in function higmac_free_pkt(). - Define BITS_DESC_ENA instead of using magic number 0xf.
Shawn Guo (3): reset: add reset driver for HiSilicon platform net: add higmacv300 Ethernet driver for HiSilicon platform poplar: enable Ethernet driver support
arch/arm/dts/hi3798cv200-u-boot.dtsi | 6 + configs/poplar_defconfig | 3 + drivers/net/Kconfig | 9 + drivers/net/Makefile | 1 + drivers/net/higmacv300.c | 597 +++++++++++++++++++++++++++ drivers/reset/Kconfig | 6 + drivers/reset/Makefile | 1 + drivers/reset/reset-hisilicon.c | 95 +++++ 8 files changed, 718 insertions(+) create mode 100644 drivers/net/higmacv300.c create mode 100644 drivers/reset/reset-hisilicon.c
It adds a Driver Model compatible reset driver for HiSlicon platform. The driver implements a custom .of_xlate function, and uses .data field as reset register offset and .id field as bit shift.
Signed-off-by: Shawn Guo shawn.guo@linaro.org Reviewed-by: Igor Opaniuk igor.opaniuk@linaro.org --- drivers/reset/Kconfig | 6 +++ drivers/reset/Makefile | 1 + drivers/reset/reset-hisilicon.c | 95 +++++++++++++++++++++++++++++++++ 3 files changed, 102 insertions(+) create mode 100644 drivers/reset/reset-hisilicon.c
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index a81e76769604..6ec6f39c85f0 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -121,4 +121,10 @@ config RESET_SUNXI This enables support for common reset driver for Allwinner SoCs.
+config RESET_HISILICON + bool "Reset controller driver for HiSilicon SoCs" + depends on DM_RESET + help + Support for reset controller on HiSilicon SoCs. + endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 4fad7d412985..7fec75bb4923 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -19,3 +19,4 @@ obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o obj-$(CONFIG_RESET_MEDIATEK) += reset-mediatek.o obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o +obj-$(CONFIG_RESET_HISILICON) += reset-hisilicon.o diff --git a/drivers/reset/reset-hisilicon.c b/drivers/reset/reset-hisilicon.c new file mode 100644 index 000000000000..3a06110f76f3 --- /dev/null +++ b/drivers/reset/reset-hisilicon.c @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019, Linaro Limited + */ + +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <reset-uclass.h> + +struct hisi_reset_priv { + void __iomem *base; +}; + +static int hisi_reset_deassert(struct reset_ctl *rst) +{ + struct hisi_reset_priv *priv = dev_get_priv(rst->dev); + u32 val; + + val = readl(priv->base + rst->data); + val &= ~BIT(rst->id); + writel(val, priv->base + rst->data); + + return 0; +} + +static int hisi_reset_assert(struct reset_ctl *rst) +{ + struct hisi_reset_priv *priv = dev_get_priv(rst->dev); + u32 val; + + val = readl(priv->base + rst->data); + val |= BIT(rst->id); + writel(val, priv->base + rst->data); + + return 0; +} + +static int hisi_reset_free(struct reset_ctl *rst) +{ + return 0; +} + +static int hisi_reset_request(struct reset_ctl *rst) +{ + return 0; +} + +static int hisi_reset_of_xlate(struct reset_ctl *rst, + struct ofnode_phandle_args *args) +{ + if (args->args_count != 2) { + debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + /* We use .data field as register offset and .id field as bit shift. */ + rst->data = args->args[0]; + rst->id = args->args[1]; + + return 0; +} + +static const struct reset_ops hisi_reset_reset_ops = { + .of_xlate = hisi_reset_of_xlate, + .request = hisi_reset_request, + .free = hisi_reset_free, + .rst_assert = hisi_reset_assert, + .rst_deassert = hisi_reset_deassert, +}; + +static const struct udevice_id hisi_reset_ids[] = { + { .compatible = "hisilicon,hi3798cv200-crg" }, + { } +}; + +static int hisi_reset_probe(struct udevice *dev) +{ + struct hisi_reset_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr(dev); + if (!priv->base) + return -ENOMEM; + + return 0; +} + +U_BOOT_DRIVER(hisi_reset) = { + .name = "hisilicon_reset", + .id = UCLASS_RESET, + .of_match = hisi_reset_ids, + .ops = &hisi_reset_reset_ops, + .probe = hisi_reset_probe, + .priv_auto_alloc_size = sizeof(struct hisi_reset_priv), +};
It adds the driver for HIGMACV300 Ethernet controller found on HiSilicon SoCs like Hi3798CV200. It's based on a downstream U-Boot driver, but quite a lot of code gets rewritten and cleaned up to adopt driver model and PHY API.
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- drivers/net/Kconfig | 9 + drivers/net/Makefile | 1 + drivers/net/higmacv300.c | 597 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 607 insertions(+) create mode 100644 drivers/net/higmacv300.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6a570285aac5..ad1e50c0e8ca 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -525,4 +525,13 @@ config MEDIATEK_ETH This Driver support MediaTek Ethernet GMAC Say Y to enable support for the MediaTek Ethernet GMAC.
+config HIGMACV300_ETH + bool "HiSilicon Gigabit Ethernet Controller" + depends on DM_ETH + select DM_RESET + select PHYLIB + help + This driver supports HIGMACV300 Ethernet controller found on + HiSilicon SoCs. + endif # NETDEVICES diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 51be72b0aa86..8d02a378964b 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -76,3 +76,4 @@ obj-$(CONFIG_SNI_AVE) += sni_ave.o obj-y += ti/ obj-$(CONFIG_MEDIATEK_ETH) += mtk_eth.o obj-y += mscc_eswitch/ +obj-$(CONFIG_HIGMACV300_ETH) += higmacv300.o diff --git a/drivers/net/higmacv300.c b/drivers/net/higmacv300.c new file mode 100644 index 000000000000..549c26b19b99 --- /dev/null +++ b/drivers/net/higmacv300.c @@ -0,0 +1,597 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019, Linaro Limited + */ + +#include <asm/io.h> +#include <common.h> +#include <console.h> +#include <linux/bug.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <net.h> +#include <reset.h> +#include <wait_bit.h> + +#define STATION_ADDR_LOW 0x0000 +#define STATION_ADDR_HIGH 0x0004 +#define MAC_DUPLEX_HALF_CTRL 0x0008 +#define PORT_MODE 0x0040 +#define PORT_EN 0x0044 +#define BIT_TX_EN BIT(2) +#define BIT_RX_EN BIT(1) +#define MODE_CHANGE_EN 0x01b4 +#define BIT_MODE_CHANGE_EN BIT(0) +#define MDIO_SINGLE_CMD 0x03c0 +#define BIT_MDIO_BUSY BIT(20) +#define MDIO_READ (BIT(17) | BIT_MDIO_BUSY) +#define MDIO_WRITE (BIT(16) | BIT_MDIO_BUSY) +#define MDIO_SINGLE_DATA 0x03c4 +#define MDIO_RDATA_STATUS 0x03d0 +#define BIT_MDIO_RDATA_INVALID BIT(0) +#define RX_FQ_START_ADDR 0x0500 +#define RX_FQ_DEPTH 0x0504 +#define RX_FQ_WR_ADDR 0x0508 +#define RX_FQ_RD_ADDR 0x050c +#define RX_FQ_REG_EN 0x0518 +#define RX_BQ_START_ADDR 0x0520 +#define RX_BQ_DEPTH 0x0524 +#define RX_BQ_WR_ADDR 0x0528 +#define RX_BQ_RD_ADDR 0x052c +#define RX_BQ_REG_EN 0x0538 +#define TX_BQ_START_ADDR 0x0580 +#define TX_BQ_DEPTH 0x0584 +#define TX_BQ_WR_ADDR 0x0588 +#define TX_BQ_RD_ADDR 0x058c +#define TX_BQ_REG_EN 0x0598 +#define TX_RQ_START_ADDR 0x05a0 +#define TX_RQ_DEPTH 0x05a4 +#define TX_RQ_WR_ADDR 0x05a8 +#define TX_RQ_RD_ADDR 0x05ac +#define TX_RQ_REG_EN 0x05b8 +#define BIT_START_ADDR_EN BIT(2) +#define BIT_DEPTH_EN BIT(1) +#define DESC_WR_RD_ENA 0x05cc +#define BIT_RX_OUTCFF_WR BIT(3) +#define BIT_RX_CFF_RD BIT(2) +#define BIT_TX_OUTCFF_WR BIT(1) +#define BIT_TX_CFF_RD BIT(0) +#define BITS_DESC_ENA (BIT_RX_OUTCFF_WR | BIT_RX_CFF_RD | \ + BIT_TX_OUTCFF_WR | BIT_TX_CFF_RD) + +/* MACIF_CTRL */ +#define RGMII_SPEED_1000 0x2c +#define RGMII_SPEED_100 0x2f +#define RGMII_SPEED_10 0x2d +#define MII_SPEED_100 0x0f +#define MII_SPEED_10 0x0d +#define GMAC_SPEED_1000 0x05 +#define GMAC_SPEED_100 0x01 +#define GMAC_SPEED_10 0x00 +#define GMAC_FULL_DUPLEX BIT(4) + +#define RX_DESC_NUM 64 +#define TX_DESC_NUM 2 +#define DESC_SIZE 32 +#define DESC_WORD_SHIFT 3 +#define DESC_BYTE_SHIFT 5 +#define DESC_CNT(n) ((n) >> DESC_BYTE_SHIFT) +#define DESC_BYTE(n) ((n) << DESC_BYTE_SHIFT) +#define DESC_VLD_FREE 0 +#define DESC_VLD_BUSY 1 + +#define MAC_MAX_FRAME_SIZE 1600 + +enum higmac_queue { + RX_FQ, + RX_BQ, + TX_BQ, + TX_RQ, +}; + +struct higmac_desc { + unsigned int buf_addr; + unsigned int buf_len:11; + unsigned int reserve0:5; + unsigned int data_len:11; + unsigned int reserve1:2; + unsigned int fl:2; + unsigned int descvid:1; + unsigned int reserve2[6]; +}; + +struct higmac_priv { + void __iomem *base; + void __iomem *macif_ctrl; + struct reset_ctl rst_phy; + struct higmac_desc *rxfq; + struct higmac_desc *rxbq; + struct higmac_desc *txbq; + struct higmac_desc *txrq; + int rxdesc_in_use; + struct mii_dev *bus; + struct phy_device *phydev; + int phyintf; + int phyaddr; +}; + +#define flush_desc(d) flush_cache((unsigned long)(d), sizeof(*(d))) +#define invalidate_desc(d) \ + invalidate_dcache_range((unsigned long)(d), \ + (unsigned long)(d) + sizeof(*(d))) + +static int higmac_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct higmac_priv *priv = dev_get_priv(dev); + unsigned char *mac = pdata->enetaddr; + u32 val; + + val = mac[1] | (mac[0] << 8); + writel(val, priv->base + STATION_ADDR_HIGH); + + val = mac[5] | (mac[4] << 8) | (mac[3] << 16) | (mac[2] << 24); + writel(val, priv->base + STATION_ADDR_LOW); + + return 0; +} + +static int higmac_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct higmac_priv *priv = dev_get_priv(dev); + + /* Inform GMAC that the RX descriptor is no longer in use */ + writel(DESC_BYTE(priv->rxdesc_in_use), priv->base + RX_BQ_RD_ADDR); + + return 0; +} + +static int higmac_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct higmac_priv *priv = dev_get_priv(dev); + struct higmac_desc *fqd = priv->rxfq; + struct higmac_desc *bqd = priv->rxbq; + int fqw_pos, fqr_pos, bqw_pos, bqr_pos; + int timeout = 100000; + int len = 0; + int space; + int i; + + fqw_pos = DESC_CNT(readl(priv->base + RX_FQ_WR_ADDR)); + fqr_pos = DESC_CNT(readl(priv->base + RX_FQ_RD_ADDR)); + + if (fqw_pos >= fqr_pos) + space = RX_DESC_NUM - (fqw_pos - fqr_pos); + else + space = fqr_pos - fqw_pos; + + /* Leave one free to distinguish full filled from empty buffer */ + for (i = 0; i < space - 1; i++) { + fqd = priv->rxfq + fqw_pos; + invalidate_dcache_range(fqd->buf_addr, + fqd->buf_addr + MAC_MAX_FRAME_SIZE); + + if (++fqw_pos >= RX_DESC_NUM) + fqw_pos = 0; + + writel(DESC_BYTE(fqw_pos), priv->base + RX_FQ_WR_ADDR); + } + + bqr_pos = DESC_CNT(readl(priv->base + RX_BQ_RD_ADDR)); + bqd += bqr_pos; + /* BQ is only ever written by GMAC */ + invalidate_desc(bqd); + + do { + bqw_pos = DESC_CNT(readl(priv->base + RX_BQ_WR_ADDR)); + udelay(1); + } while (--timeout && bqw_pos == bqr_pos); + + if (!timeout) + return -ETIMEDOUT; + + if (++bqr_pos >= RX_DESC_NUM) + bqr_pos = 0; + + len = bqd->data_len; + + /* CPU should not have touched this buffer since we added it to FQ */ + invalidate_dcache_range(bqd->buf_addr, bqd->buf_addr + len); + *packetp = (void *)(unsigned long)bqd->buf_addr; + + /* Record the RX_BQ descriptor that is holding RX data */ + priv->rxdesc_in_use = bqr_pos; + + return len; +} + +static int higmac_send(struct udevice *dev, void *packet, int length) +{ + struct higmac_priv *priv = dev_get_priv(dev); + struct higmac_desc *bqd = priv->txbq; + int bqw_pos, rqw_pos, rqr_pos; + int timeout = 1000; + + flush_cache((unsigned long)packet, length); + + bqw_pos = DESC_CNT(readl(priv->base + TX_BQ_WR_ADDR)); + bqd += bqw_pos; + bqd->buf_addr = (unsigned long)packet; + bqd->descvid = DESC_VLD_BUSY; + bqd->data_len = length; + flush_desc(bqd); + + if (++bqw_pos >= TX_DESC_NUM) + bqw_pos = 0; + + writel(DESC_BYTE(bqw_pos), priv->base + TX_BQ_WR_ADDR); + + rqr_pos = DESC_CNT(readl(priv->base + TX_RQ_RD_ADDR)); + if (++rqr_pos >= TX_DESC_NUM) + rqr_pos = 0; + + do { + rqw_pos = DESC_CNT(readl(priv->base + TX_RQ_WR_ADDR)); + udelay(1); + } while (--timeout && rqr_pos != rqw_pos); + + if (!timeout) + return -ETIMEDOUT; + + writel(DESC_BYTE(rqr_pos), priv->base + TX_RQ_RD_ADDR); + + return 0; +} + +static int higmac_adjust_link(struct higmac_priv *priv) +{ + struct phy_device *phydev = priv->phydev; + int interface = priv->phyintf; + u32 val; + + switch (interface) { + case PHY_INTERFACE_MODE_RGMII: + if (phydev->speed == SPEED_1000) + val = RGMII_SPEED_1000; + else if (phydev->speed == SPEED_100) + val = RGMII_SPEED_100; + else + val = RGMII_SPEED_10; + break; + case PHY_INTERFACE_MODE_MII: + if (phydev->speed == SPEED_100) + val = MII_SPEED_100; + else + val = MII_SPEED_10; + break; + default: + debug("unsupported mode: %d\n", interface); + return -EINVAL; + } + + if (phydev->duplex) + val |= GMAC_FULL_DUPLEX; + + writel(val, priv->macif_ctrl); + + if (phydev->speed == SPEED_1000) + val = GMAC_SPEED_1000; + else if (phydev->speed == SPEED_100) + val = GMAC_SPEED_100; + else + val = GMAC_SPEED_10; + + writel(BIT_MODE_CHANGE_EN, priv->base + MODE_CHANGE_EN); + writel(val, priv->base + PORT_MODE); + writel(0, priv->base + MODE_CHANGE_EN); + writel(phydev->duplex, priv->base + MAC_DUPLEX_HALF_CTRL); + + return 0; +} + +static int higmac_start(struct udevice *dev) +{ + struct higmac_priv *priv = dev_get_priv(dev); + struct phy_device *phydev = priv->phydev; + int ret; + + ret = phy_startup(phydev); + if (ret) + return ret; + + if (!phydev->link) { + debug("%s: link down\n", phydev->dev->name); + return -ENODEV; + } + + ret = higmac_adjust_link(priv); + if (ret) + return ret; + + /* Enable port */ + writel(BITS_DESC_ENA, priv->base + DESC_WR_RD_ENA); + writel(BIT_TX_EN | BIT_RX_EN, priv->base + PORT_EN); + + return 0; +} + +static void higmac_stop(struct udevice *dev) +{ + struct higmac_priv *priv = dev_get_priv(dev); + + /* Disable port */ + writel(0, priv->base + PORT_EN); + writel(0, priv->base + DESC_WR_RD_ENA); +} + +static const struct eth_ops higmac_ops = { + .start = higmac_start, + .send = higmac_send, + .recv = higmac_recv, + .free_pkt = higmac_free_pkt, + .stop = higmac_stop, + .write_hwaddr = higmac_write_hwaddr, +}; + +static int higmac_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct higmac_priv *priv = bus->priv; + int ret; + + ret = wait_for_bit_le32(priv->base + MDIO_SINGLE_CMD, BIT_MDIO_BUSY, + false, 1000, false); + if (ret) + return ret; + + writel(MDIO_READ | addr << 8 | reg, priv->base + MDIO_SINGLE_CMD); + + ret = wait_for_bit_le32(priv->base + MDIO_SINGLE_CMD, BIT_MDIO_BUSY, + false, 1000, false); + if (ret) + return ret; + + if (readl(priv->base + MDIO_RDATA_STATUS) & BIT_MDIO_RDATA_INVALID) + return -EINVAL; + + return readl(priv->base + MDIO_SINGLE_DATA) >> 16; +} + +static int higmac_mdio_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 value) +{ + struct higmac_priv *priv = bus->priv; + int ret; + + ret = wait_for_bit_le32(priv->base + MDIO_SINGLE_CMD, BIT_MDIO_BUSY, + false, 1000, false); + if (ret) + return ret; + + writel(value, priv->base + MDIO_SINGLE_DATA); + writel(MDIO_WRITE | addr << 8 | reg, priv->base + MDIO_SINGLE_CMD); + + return 0; +} + +static int higmac_init_rx_descs(struct higmac_desc *descs, int num) +{ + int i; + + for (i = 0; i < num; i++) { + struct higmac_desc *desc = &descs[i]; + + desc->buf_addr = (unsigned long)memalign(ARCH_DMA_MINALIGN, + MAC_MAX_FRAME_SIZE); + if (!desc->buf_addr) + goto free_bufs; + + desc->descvid = DESC_VLD_FREE; + desc->buf_len = MAC_MAX_FRAME_SIZE - 1; + flush_desc(desc); + } + + return 0; + +free_bufs: + while (--i > 0) + free((void *)(unsigned long)descs[i].buf_addr); + return -ENOMEM; +} + +static int higmac_init_hw_queue(struct higmac_priv *priv, + enum higmac_queue queue) +{ + struct higmac_desc *desc, **pdesc; + u32 regaddr, regen, regdep; + int depth; + int len; + + switch (queue) { + case RX_FQ: + regaddr = RX_FQ_START_ADDR; + regen = RX_FQ_REG_EN; + regdep = RX_FQ_DEPTH; + depth = RX_DESC_NUM; + pdesc = &priv->rxfq; + break; + case RX_BQ: + regaddr = RX_BQ_START_ADDR; + regen = RX_BQ_REG_EN; + regdep = RX_BQ_DEPTH; + depth = RX_DESC_NUM; + pdesc = &priv->rxbq; + break; + case TX_BQ: + regaddr = TX_BQ_START_ADDR; + regen = TX_BQ_REG_EN; + regdep = TX_BQ_DEPTH; + depth = TX_DESC_NUM; + pdesc = &priv->txbq; + break; + case TX_RQ: + regaddr = TX_RQ_START_ADDR; + regen = TX_RQ_REG_EN; + regdep = TX_RQ_DEPTH; + depth = TX_DESC_NUM; + pdesc = &priv->txrq; + break; + } + + /* Enable depth */ + writel(BIT_DEPTH_EN, priv->base + regen); + writel(depth << DESC_WORD_SHIFT, priv->base + regdep); + writel(0, priv->base + regen); + + len = depth * sizeof(*desc); + desc = memalign(ARCH_DMA_MINALIGN, len); + if (!desc) + return -ENOMEM; + memset(desc, 0, len); + flush_cache((unsigned long)desc, len); + *pdesc = desc; + + /* Set up RX_FQ descriptors */ + if (queue == RX_FQ) + higmac_init_rx_descs(desc, depth); + + /* Enable start address */ + writel(BIT_START_ADDR_EN, priv->base + regen); + writel((unsigned long)desc, priv->base + regaddr); + writel(0, priv->base + regen); + + return 0; +} + +static int higmac_hw_init(struct higmac_priv *priv) +{ + int ret; + + /* Initialize hardware queues */ + ret = higmac_init_hw_queue(priv, RX_FQ); + if (ret) + return ret; + + ret = higmac_init_hw_queue(priv, RX_BQ); + if (ret) + goto free_rx_fq; + + ret = higmac_init_hw_queue(priv, TX_BQ); + if (ret) + goto free_rx_bq; + + ret = higmac_init_hw_queue(priv, TX_RQ); + if (ret) + goto free_tx_bq; + + /* Reset phy */ + reset_assert(&priv->rst_phy); + mdelay(10); + reset_deassert(&priv->rst_phy); + mdelay(30); + reset_assert(&priv->rst_phy); + mdelay(30); + + return 0; + +free_tx_bq: + free(priv->txbq); +free_rx_bq: + free(priv->rxbq); +free_rx_fq: + free(priv->rxfq); + return ret; +} + +static int higmac_probe(struct udevice *dev) +{ + struct higmac_priv *priv = dev_get_priv(dev); + struct phy_device *phydev; + struct mii_dev *bus; + int ret; + + ret = higmac_hw_init(priv); + if (ret) + return ret; + + bus = mdio_alloc(); + if (!bus) + return -ENOMEM; + + bus->read = higmac_mdio_read; + bus->write = higmac_mdio_write; + bus->priv = priv; + priv->bus = bus; + + ret = mdio_register_seq(bus, dev->seq); + if (ret) + return ret; + + phydev = phy_connect(bus, priv->phyaddr, dev, priv->phyintf); + if (!phydev) + return -ENODEV; + + phydev->supported &= PHY_GBIT_FEATURES; + phydev->advertising = phydev->supported; + priv->phydev = phydev; + + return phy_config(phydev); +} + +static int higmac_remove(struct udevice *dev) +{ + struct higmac_priv *priv = dev_get_priv(dev); + int i; + + mdio_unregister(priv->bus); + mdio_free(priv->bus); + + /* Free RX packet buffers */ + for (i = 0; i < RX_DESC_NUM; i++) + free((void *)(unsigned long)priv->rxfq[i].buf_addr); + + return 0; +} + +static int higmac_ofdata_to_platdata(struct udevice *dev) +{ + struct higmac_priv *priv = dev_get_priv(dev); + int phyintf = PHY_INTERFACE_MODE_NONE; + const char *phy_mode; + ofnode phy_node; + + priv->base = dev_remap_addr_index(dev, 0); + priv->macif_ctrl = dev_remap_addr_index(dev, 1); + + phy_mode = dev_read_string(dev, "phy-mode"); + if (phy_mode) + phyintf = phy_get_interface_by_name(phy_mode); + if (phyintf == PHY_INTERFACE_MODE_NONE) + return -ENODEV; + priv->phyintf = phyintf; + + phy_node = dev_read_subnode(dev, "phy"); + if (!ofnode_valid(phy_node)) { + debug("failed to find phy node\n"); + return -ENODEV; + } + priv->phyaddr = ofnode_read_u32_default(phy_node, "reg", 0); + + return reset_get_by_name(dev, "phy", &priv->rst_phy); +} + +static const struct udevice_id higmac_ids[] = { + { .compatible = "hisilicon,hi3798cv200-gmac" }, + { } +}; + +U_BOOT_DRIVER(eth_higmac) = { + .name = "eth_higmac", + .id = UCLASS_ETH, + .of_match = higmac_ids, + .ofdata_to_platdata = higmac_ofdata_to_platdata, + .probe = higmac_probe, + .remove = higmac_remove, + .ops = &higmac_ops, + .priv_auto_alloc_size = sizeof(struct higmac_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +};
Looks pretty good. I have a few questions / comments below.
depends on DM_ETH
select DM_RESET
select PHYLIB
help
HiSilicon SoCs.
- Copyright (c) 2019, Linaro Limited
RX_FQ,
RX_BQ,
TX_BQ,
TX_RQ,
unsigned int fl:2;
void __iomem *base;
int rxdesc_in_use;
int phyintf;
int phyaddr;
u32 val;
int len = 0;
int space;
int i;
else
fqw_pos = 0;
bqd += bqr_pos;
do {
udelay(1);
Did you look into using wait bit macros?
if (!timeout)
return -ETIMEDOUT;
bqr_pos = 0;
return len;
int timeout = 1000;
bqd += bqw_pos;
flush_desc(bqd);
bqw_pos = 0;
rqr_pos = 0;
do {
udelay(1);
Same here on wait bit.
if (!timeout)
return -ETIMEDOUT;
u32 val;
else
break;
else
val = MII_SPEED_10;
break;
default:
return -EINVAL;
if (phydev->duplex)
else
int ret;
if (ret)
return ret;
return -ENODEV;
if (ret)
return ret;
/* Enable port */
/* Disable port */
int ret;
if (ret)
return ret;
if (ret)
return ret;
return -EINVAL;
int reg, u16 value)
int ret;
if (ret)
return ret;
int i;
goto free_bufs;
flush_desc(desc);
+free_bufs:
while (--i > 0)
return -ENOMEM;
int depth;
int len;
switch (queue) {
case RX_FQ:
break;
case RX_BQ:
break;
case TX_BQ:
break;
case TX_RQ:
break;
/* Enable depth */
if (!desc)
return -ENOMEM;
*pdesc = desc;
if (queue == RX_FQ)
int ret;
if (ret)
return ret;
if (ret)
goto free_rx_fq;
if (ret)
goto free_rx_bq;
if (ret)
goto free_tx_bq;
/* Reset phy */
mdelay(10);
I'm surprised the delay here is not a DT parameter.
mdelay(30);
mdelay(30);
Why is this reasserted?
+free_tx_bq:
free(priv->txbq);
+free_rx_bq:
free(priv->rxbq);
+free_rx_fq:
free(priv->rxfq);
return ret;
int ret;
if (ret)
return ret;
bus = mdio_alloc();
if (!bus)
return -ENOMEM;
bus->priv = priv;
priv->bus = bus;
if (ret)
return ret;
if (!phydev)
return -ENODEV;
int i;
ofnode phy_node;
Should there not be a default? Is it supposed to be required to be specified in the DT?
if (phy_mode)
return -ENODEV;
return -ENODEV;
.id = UCLASS_ETH,
.ops = &higmac_ops,
2.18.0
int len = 0;
int space;
int i;
else
fqw_pos = 0;
bqd += bqr_pos;
do {
udelay(1);
I may miss your point, but this is not a loop waiting for some bits set or clear. It's waiting for a given number.
if (!timeout)
return -ETIMEDOUT;
bqr_pos = 0;
return len;
<snip>
int ret;
if (ret)
return ret;
if (ret)
goto free_rx_fq;
if (ret)
goto free_rx_bq;
if (ret)
goto free_tx_bq;
/* Reset phy */
mdelay(10);
We do not see the necessity for now. We can make it a DT parameter when we see the real need in the future.
mdelay(30);
mdelay(30);
I have to admit this is a bit hackish. Ideally, the reset sequence should be: deassert -> assert -> deassert. But this reset signal gets an opposite polarity than others that reset driver handles. I can add a comment to explain it if you can tolerate this little hack, or I will add polarity support to reset driver to handle this phy reset quirk. Please let me know your preference.
+free_tx_bq:
free(priv->txbq);
+free_rx_bq:
free(priv->rxbq);
+free_rx_fq:
free(priv->rxfq);
return ret;
int ret;
if (ret)
return ret;
bus = mdio_alloc();
if (!bus)
return -ENOMEM;
bus->priv = priv;
priv->bus = bus;
if (ret)
return ret;
if (!phydev)
return -ENODEV;
int i;
ofnode phy_node;
Yes, we choose to implement it as a required property. If the property is missing, the device probe would fail.
Shawn
if (phy_mode)
return -ENODEV;
return -ENODEV;
.id = UCLASS_ETH,
.ops = &higmac_ops,
2.18.0
int len = 0;
int space;
int i;
else
fqw_pos = 0;
bqd += bqr_pos;
do {
udelay(1);
OK, I see that, thanks. Should you make these "breakable" in the same way that wait_for_bit_* does? The timeout seems quite long.
if (!timeout)
return -ETIMEDOUT;
bqr_pos = 0;
return len;
<snip>
int ret;
if (ret)
return ret;
if (ret)
goto free_rx_fq;
if (ret)
goto free_rx_bq;
if (ret)
goto free_tx_bq;
/* Reset phy */
mdelay(10);
OK
mdelay(30);
mdelay(30);
I would prefer a polarity to be defined in the DT for this reset.
+free_tx_bq:
free(priv->txbq);
+free_rx_bq:
free(priv->rxbq);
+free_rx_fq:
free(priv->rxfq);
return ret;
int ret;
if (ret)
return ret;
bus = mdio_alloc();
if (!bus)
return -ENOMEM;
bus->priv = priv;
priv->bus = bus;
if (ret)
return ret;
if (!phydev)
return -ENODEV;
int i;
ofnode phy_node;
OK.
Thanks, -Joe
Shawn
if (phy_mode)
return -ENODEV;
return -ENODEV;
.id = UCLASS_ETH,
.ops = &higmac_ops,
2.18.0
int len = 0;
int space;
int i;
else
fqw_pos = 0;
bqd += bqr_pos;
do {
udelay(1);
I assume that you mean the "breakable" as user interaction (CTRL-C)? I'm not sure 100000 us (0.1 s) is so long for user to break.
<snip>
mdelay(30);
OK, I will implement it in v3. Thanks for the comment.
Shawn
The 'phy' reset of gmac device in kernel device tree is not generic enough for u-boot to use, so we need to overwrite the 'resets' property as needed. With this device tree fixup and poplar_defconfig changes, Ethernet starts working on Poplar board.
Signed-off-by: Shawn Guo shawn.guo@linaro.org Reviewed-by: Igor Opaniuk igor.opaniuk@linaro.org --- arch/arm/dts/hi3798cv200-u-boot.dtsi | 6 ++++++ configs/poplar_defconfig | 3 +++ 2 files changed, 9 insertions(+)
diff --git a/arch/arm/dts/hi3798cv200-u-boot.dtsi b/arch/arm/dts/hi3798cv200-u-boot.dtsi index 7844c5208c5d..972ea67de3b1 100644 --- a/arch/arm/dts/hi3798cv200-u-boot.dtsi +++ b/arch/arm/dts/hi3798cv200-u-boot.dtsi @@ -16,6 +16,12 @@ }; };
+&gmac1 { + resets = <&crg 0xcc 9>, + <&crg 0xcc 11>, + <&crg 0xcc 13>; +}; + &uart0 { clock = <75000000>; status = "okay"; diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 81bd3702e42a..76ab5eb70e7e 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -19,6 +19,9 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_K3=y +CONFIG_DM_ETH=y +CONFIG_HIGMACV300_ETH=y +CONFIG_RESET_HISILICON=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y
Changes for v2:
Hi Joe,
Does this version look good to you?
Shawn
Joe Hershberger
Shawn Guo
