[PATCH] button: qcom-pmic: add software debounce
This helps with reliability on some platforms. We should probably also configure the hardware debounce timer eventually.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/button/button-qcom-pmic.c | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/drivers/button/button-qcom-pmic.c b/drivers/button/button-qcom-pmic.c index ad7fed3ddaaa..f9f0948ae095 100644 --- a/drivers/button/button-qcom-pmic.c +++ b/drivers/button/button-qcom-pmic.c @@ -14,8 +14,9 @@ #include <log.h> #include <power/pmic.h> #include <spmi/spmi.h> #include <linux/bitops.h> +#include <time.h>
#define REG_TYPE 0x4 #define REG_SUBTYPE 0x5
@@ -30,8 +31,9 @@ struct qcom_pmic_btn_priv { u32 base; u32 status_bit; int code; struct udevice *pmic; + ulong last_release_time; };
#define PON_INT_RT_STS 0x10 #define PON_KPDPWR_N_SET 0 @@ -41,15 +43,23 @@ struct qcom_pmic_btn_priv {
static enum button_state_t qcom_pwrkey_get_state(struct udevice *dev) { struct qcom_pmic_btn_priv *priv = dev_get_priv(dev); + bool pressed; + int reg;
- int reg = pmic_reg_read(priv->pmic, priv->base + PON_INT_RT_STS); + if (get_timer_us(0) - priv->last_release_time < 25000) + return BUTTON_OFF;
+ reg = pmic_reg_read(priv->pmic, priv->base + PON_INT_RT_STS); if (reg < 0) return 0;
- return (reg & BIT(priv->status_bit)) != 0; + pressed = !!(reg & BIT(priv->status_bit)); + if (!pressed) + priv->last_release_time = get_timer_us(0); + + return pressed; }
static int qcom_pwrkey_get_code(struct udevice *dev) {
Applied, thanks!
[1/1] button: qcom-pmic: add software debounce https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/commit/709ecea5...
Caleb Connolly
