[U-Boot] Pull request: u-boot-ti
Hello,
The following changes since commit 304db0b38cfb04cfdb05a740d5ef27da06ea98ea:
arm: Remove IXP425 boards pdnb3 and scpu (2013-10-17 09:28:08 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to f6723794fd8f3362c4f3b5d0f36607a6a6f107b2:
TI:omap5: Add rdaddr, use consistent loadaddr values (2013-11-01 15:56:00 -0400)
---------------------------------------------------------------- Andreas Bießmann (10): tricorder: update flash partitioning tricorder: use generic provided loadaddr tricorder: add configuration for a flashcard u-boot tricorder: add cmdline history tricorder: add mtdparts to environment tricorder: add tricordereeprom command tricorder: panic() on unknown board tricorder: add led support tricorder: read kernel directly from NAND tricorder: support 256MiB SDRAM on revision > D
Heiko Schocher (2): nand, davinci: add special UBL ecc position arm, da85x: update for the ipam390 board
Igor Grinberg (2): cm-t35: move the eeprom code to common place cm-t35: move the display code to common place
Javier Martinez Canillas (2): ARM: IGEP0033: rename config file to am335x_igep0033.h OMAP3: igep00x0: rename config file to omap3_igep00x0.h
Lokesh Vutla (1): ARM: OMAP4: Convert to ti_armv7_common.h
Minal Shah (1): dra7xx_evm: Enabled UART-boot mode and add dra7xx_evm_uart3 build
Nikita Kiryanov (3): cm_t35: reduce default bootdelay to 3 seconds cm_t35: turn on GPIO commands cm_t35: update lcd predefines
SRICHARAN R (1): ARM: OMAP5: DDR3: Change io settings
Thomas Weber (3): tricorder: remove lcdmode from bootargs tricorder: Make u-boot faster tricorder: switch to alternative memtest
Tom Rini (7): drivers/rtc/davinci.c: Reference DAVINCI_RTC_BASE more directly am33xx, davinci: Create and use <asm/davinci_rtc.h> bootcount_davinci: Switch to scratch register #2 TI:am33xx: Add bootcount support to ti_am335x_common.h am335x: Enable CONFIG_OMAP_WATCHDOG support TI:armv7: Change CONFIG_SYS_SPL_ARGS_ADDR to a higher address TI:omap5: Add rdaddr, use consistent loadaddr values
arch/arm/cpu/armv7/am33xx/board.c | 7 +- arch/arm/cpu/armv7/omap-common/boot-common.c | 4 + arch/arm/include/asm/arch-am33xx/cpu.h | 9 - arch/arm/include/asm/arch-davinci/hardware.h | 38 --- arch/arm/include/asm/arch-omap5/omap.h | 4 +- arch/arm/include/asm/arch-omap5/spl.h | 1 + arch/arm/include/asm/davinci_rtc.h | 52 ++++ board/Barix/ipam390/ipam390-ais-uart.cfg | 2 +- board/Barix/ipam390/ipam390.c | 29 +-- board/compulab/cm_t35/Makefile | 3 - board/compulab/cm_t35/cm_t35.c | 7 +- board/compulab/common/Makefile | 36 +++ board/compulab/{cm_t35 => common}/eeprom.c | 51 ++-- board/compulab/{cm_t35 => common}/eeprom.h | 8 +- .../{cm_t35/display.c => common/omap3_display.c} | 8 +- board/corscience/tricorder/Makefile | 2 +- board/corscience/tricorder/led.c | 80 +++++++ board/corscience/tricorder/tricorder-eeprom.c | 251 ++++++++++++++++++++ board/corscience/tricorder/tricorder-eeprom.h | 41 ++++ board/corscience/tricorder/tricorder.c | 126 +++++++++- board/corscience/tricorder/tricorder.h | 4 +- board/enbw/enbw_cmc/enbw_cmc.c | 1 + board/ti/am335x/board.c | 6 + boards.cfg | 16 +- drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount_davinci.c | 13 +- drivers/mtd/nand/davinci_nand.c | 12 + drivers/rtc/davinci.c | 8 +- include/configs/{igep0033.h => am335x_igep0033.h} | 0 include/configs/cm_t35.h | 3 +- include/configs/dra7xx_evm.h | 9 +- include/configs/ipam390.h | 35 ++- include/configs/{igep00x0.h => omap3_igep00x0.h} | 0 include/configs/omap4_common.h | 188 +++------------ include/configs/omap4_panda.h | 2 - include/configs/omap4_sdp4430.h | 2 - include/configs/omap5_common.h | 7 +- include/configs/ti_am335x_common.h | 14 ++ include/configs/ti_armv7_common.h | 2 +- include/configs/tricorder.h | 155 +++++++++--- 40 files changed, 876 insertions(+), 361 deletions(-) create mode 100644 arch/arm/include/asm/davinci_rtc.h create mode 100644 board/compulab/common/Makefile rename board/compulab/{cm_t35 => common}/eeprom.c (60%) rename board/compulab/{cm_t35 => common}/eeprom.h (62%) rename board/compulab/{cm_t35/display.c => common/omap3_display.c} (97%) create mode 100644 board/corscience/tricorder/led.c create mode 100644 board/corscience/tricorder/tricorder-eeprom.c create mode 100644 board/corscience/tricorder/tricorder-eeprom.h rename include/configs/{igep0033.h => am335x_igep0033.h} (100%) rename include/configs/{igep00x0.h => omap3_igep00x0.h} (100%)
Thanks!
Hi Tom,
On Mon, 4 Nov 2013 09:22:54 -0500, Tom Rini trini@ti.com wrote:
Hello,
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
