[PATCH v4 0/3] cmd/mtd: add missed featuries
Some nand flashes (like spi-nand one) are registered with mtd subsystem only, thus nand command can't be used to work with such flashes. As result some functionality is missing.
This patch series implements following subcommands: * markbad -- mark block as bad (clone of 'nand markbad') * nand_write_test -- destructive test of flash blocks (clone of 'nand torture') * nand_read_test -- non-destructive test of nand flashes
Changes v2: * add cover letter
Changes v3: * rename 'mtd torture' to 'mtd nand_write_test' * rename 'mtd nandread' to 'mtd nand_read_test' * improve features description * code fixes suggested by Heinrich Schuchardt
Changes v4: * fix missed renaming * replace '#ifdef CONFIG_CMD_MTD_*' with '#if CONFIG_IS_ENABLED(CMD_MTD_*)' * improve nand_read_test output * use do_div() properly
Mikhail Kshevetskiy (3): cmd: mtd: add markbad command support cmd: mtd: add nand_write_test command support cmd: mtd: add nand_read_test command support
cmd/Kconfig | 38 +++++ cmd/mtd.c | 452 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 490 insertions(+)
This patch implements 'nand markbad' functionality for mtd command.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- cmd/Kconfig | 8 ++++++++ cmd/mtd.c | 58 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d50f6396fc7..29d1929ff94 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1449,6 +1449,14 @@ config CMD_MTD_OTP help MTD commands for OTP access.
+config CMD_MTD_MARKBAD + bool "mtd markbad" + depends on CMD_MTD + help + MTD markbad command support. + + This is a clone of "nand markbad" command, but for 'mtd' subsystem. + config CMD_MUX bool "mux" depends on MULTIPLEXER diff --git a/cmd/mtd.c b/cmd/mtd.c index 795aaa2b37d..ac78df75267 100644 --- a/cmd/mtd.c +++ b/cmd/mtd.c @@ -691,6 +691,57 @@ out_put_mtd: return ret; }
+#ifdef CONFIG_CMD_MTD_MARKBAD +static int do_mtd_markbad(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct mtd_info *mtd; + loff_t off; + int ret = 0; + + if (argc < 3) + return CMD_RET_USAGE; + + mtd = get_mtd_by_name(argv[1]); + if (IS_ERR_OR_NULL(mtd)) + return CMD_RET_FAILURE; + + if (!mtd_can_have_bb(mtd)) { + printf("Only NAND-based devices can have bad blocks\n"); + goto out_put_mtd; + } + + argc -= 2; + argv += 2; + while (argc > 0) { + off = hextoul(argv[0], NULL); + if (!mtd_is_aligned_with_block_size(mtd, off)) { + printf("Offset not aligned with a block (0x%x)\n", + mtd->erasesize); + ret = CMD_RET_FAILURE; + goto out_put_mtd; + } + + ret = mtd_block_markbad(mtd, off); + if (ret) { + printf("block 0x%08llx NOT marked as bad! ERROR %d\n", + off, ret); + ret = CMD_RET_FAILURE; + } else { + printf("block 0x%08llx successfully marked as bad\n", + off); + } + --argc; + ++argv; + } + +out_put_mtd: + put_mtd_device(mtd); + + return ret; +} +#endif + static int do_mtd_bad(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -773,6 +824,9 @@ U_BOOT_LONGHELP(mtd, "mtd otpwrite <name> <off> <hex string>\n" "mtd otplock <name> <off> <size>\n" "mtd otpinfo <name> [u|f]\n" +#endif +#if CONFIG_IS_ENABLED(CMD_MTD_MARKBAD) + "mtd markbad <name> <off> [<off> ...]\n" #endif "\n" "With:\n" @@ -807,5 +861,9 @@ U_BOOT_CMD_WITH_SUBCMDS(mtd, "MTD utils", mtd_help_text, mtd_name_complete), U_BOOT_SUBCMD_MKENT_COMPLETE(erase, 4, 0, do_mtd_erase, mtd_name_complete), +#if CONFIG_IS_ENABLED(CMD_MTD_MARKBAD) + U_BOOT_SUBCMD_MKENT_COMPLETE(markbad, 20, 0, do_mtd_markbad, + mtd_name_complete), +#endif U_BOOT_SUBCMD_MKENT_COMPLETE(bad, 2, 1, do_mtd_bad, mtd_name_complete));
This patch implements 'nand torture' functionality for mtd command.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- cmd/Kconfig | 14 ++++ cmd/mtd.c | 197 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 211 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 29d1929ff94..9a5ba5ccb4e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1457,6 +1457,20 @@ config CMD_MTD_MARKBAD
+config CMD_MTD_NAND_WRITE_TEST + bool "mtd nand_write_test (destructive)" + depends on CMD_MTD + help + MTD nand_write_test command support. + + Writes blocks of NAND flash with different patterns. + This is useful to determine if a block that caused a write error + is still good or should be marked as bad. + + This is a clone of "nand torture" command, but for 'mtd' subsystem. + + WARNING: This test will destroy any data on blocks being tested. + config CMD_MUX bool "mux" depends on MULTIPLEXER diff --git a/cmd/mtd.c b/cmd/mtd.c index ac78df75267..1c819b35e9d 100644 --- a/cmd/mtd.c +++ b/cmd/mtd.c @@ -18,6 +18,7 @@ #include <mtd.h> #include <dm/devres.h> #include <linux/err.h> +#include <memalign.h>
#include <linux/ctype.h>
@@ -742,6 +743,194 @@ out_put_mtd: } #endif
+#ifdef CONFIG_CMD_MTD_NAND_WRITE_TEST +/** + * nand_check_pattern: + * + * Check if buffer contains only a certain byte pattern. + * + * @param buf buffer to check + * @param patt the pattern to check + * @param size buffer size in bytes + * Return: 1 if there are only patt bytes in buf + * 0 if something else was found + */ +static int nand_check_pattern(const u_char *buf, u_char patt, int size) +{ + int i; + + for (i = 0; i < size; i++) + if (buf[i] != patt) + return 0; + return 1; +} + +/** + * nand_write_test: + * + * Writes a block of NAND flash with different patterns. + * This is useful to determine if a block that caused a write error is still + * good or should be marked as bad. + * + * @param mtd nand mtd instance + * @param offset offset in flash + * Return: 0 if the block is still good + */ +static int nand_write_test(struct mtd_info *mtd, loff_t offset) +{ + u_char patterns[] = {0xa5, 0x5a, 0x00}; + struct erase_info instr = { + .mtd = mtd, + .addr = offset, + .len = mtd->erasesize, + }; + size_t retlen; + int err, ret = -1, i, patt_count; + u_char *buf; + + if ((offset & (mtd->erasesize - 1)) != 0) { + puts("Attempt to torture a block at a non block-aligned offset\n"); + return -EINVAL; + } + + if (offset + mtd->erasesize > mtd->size) { + puts("Attempt to torture a block outside the flash area\n"); + return -EINVAL; + } + + patt_count = ARRAY_SIZE(patterns); + + buf = malloc_cache_aligned(mtd->erasesize); + if (buf == NULL) { + puts("Out of memory for erase block buffer\n"); + return -ENOMEM; + } + + for (i = 0; i < patt_count; i++) { + err = mtd_erase(mtd, &instr); + if (err) { + printf("%s: erase() failed for block at 0x%llx: %d\n", + mtd->name, instr.addr, err); + goto out; + } + + /* Make sure the block contains only 0xff bytes */ + err = mtd_read(mtd, offset, mtd->erasesize, &retlen, buf); + if ((err && err != -EUCLEAN) || retlen != mtd->erasesize) { + printf("%s: read() failed for block at 0x%llx: %d\n", + mtd->name, instr.addr, err); + goto out; + } + + err = nand_check_pattern(buf, 0xff, mtd->erasesize); + if (!err) { + printf("Erased block at 0x%llx, but a non-0xff byte was found\n", + offset); + ret = -EIO; + goto out; + } + + /* Write a pattern and check it */ + memset(buf, patterns[i], mtd->erasesize); + err = mtd_write(mtd, offset, mtd->erasesize, &retlen, buf); + if (err || retlen != mtd->erasesize) { + printf("%s: write() failed for block at 0x%llx: %d\n", + mtd->name, instr.addr, err); + goto out; + } + + err = mtd_read(mtd, offset, mtd->erasesize, &retlen, buf); + if ((err && err != -EUCLEAN) || retlen != mtd->erasesize) { + printf("%s: read() failed for block at 0x%llx: %d\n", + mtd->name, instr.addr, err); + goto out; + } + + err = nand_check_pattern(buf, patterns[i], mtd->erasesize); + if (!err) { + printf("Pattern 0x%.2x checking failed for block at " + "0x%llx\n", patterns[i], offset); + ret = -EIO; + goto out; + } + } + + ret = 0; + +out: + free(buf); + return ret; +} + +static int do_nand_write_test(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct mtd_info *mtd; + loff_t off, len; + int ret = 0; + unsigned int failed = 0, passed = 0; + + if (argc < 2) + return CMD_RET_USAGE; + + mtd = get_mtd_by_name(argv[1]); + if (IS_ERR_OR_NULL(mtd)) + return CMD_RET_FAILURE; + + if (!mtd_can_have_bb(mtd)) { + printf("Only NAND-based devices can be tortured\n"); + goto out_put_mtd; + } + + argc -= 2; + argv += 2; + + off = argc > 0 ? hextoul(argv[0], NULL) : 0; + len = argc > 1 ? hextoul(argv[1], NULL) : mtd->size; + + if (!mtd_is_aligned_with_block_size(mtd, off)) { + printf("Offset not aligned with a block (0x%x)\n", + mtd->erasesize); + ret = CMD_RET_FAILURE; + goto out_put_mtd; + } + + if (!mtd_is_aligned_with_block_size(mtd, len)) { + printf("Size not a multiple of a block (0x%x)\n", + mtd->erasesize); + ret = CMD_RET_FAILURE; + goto out_put_mtd; + } + + printf("\nNAND write test: device '%s' offset 0x%llx size 0x%llx (block size 0x%x)\n", + mtd->name, off, len, mtd->erasesize); + while (len > 0) { + printf("\r block at %llx ", off); + if (mtd_block_isbad(mtd, off)) { + printf("marked bad, skipping\n"); + } else { + ret = nand_write_test(mtd, off); + if (ret) { + failed++; + printf("failed\n"); + } else { + passed++; + } + } + off += mtd->erasesize; + len -= mtd->erasesize; + } + printf("\n Passed: %u, failed: %u\n", passed, failed); + if (failed != 0) + ret = CMD_RET_FAILURE; + +out_put_mtd: + put_mtd_device(mtd); + + return ret; +} +#endif + static int do_mtd_bad(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -827,6 +1016,9 @@ U_BOOT_LONGHELP(mtd, #endif #if CONFIG_IS_ENABLED(CMD_MTD_MARKBAD) "mtd markbad <name> <off> [<off> ...]\n" +#endif +#if CONFIG_IS_ENABLED(CMD_MTD_NAND_WRITE_TEST) + "mtd nand_write_test <name> [<off> [<size>]]\n" #endif "\n" "With:\n" @@ -864,6 +1056,11 @@ U_BOOT_CMD_WITH_SUBCMDS(mtd, "MTD utils", mtd_help_text, #if CONFIG_IS_ENABLED(CMD_MTD_MARKBAD) U_BOOT_SUBCMD_MKENT_COMPLETE(markbad, 20, 0, do_mtd_markbad, mtd_name_complete), +#endif +#if CONFIG_IS_ENABLED(CMD_MTD_NAND_WRITE_TEST) + U_BOOT_SUBCMD_MKENT_COMPLETE(nand_write_test, 4, 0, + do_nand_write_test, + mtd_name_complete), #endif U_BOOT_SUBCMD_MKENT_COMPLETE(bad, 2, 1, do_mtd_bad, mtd_name_complete));
This patch implements read-only test of nand flash devices.
Test reads blocks of NAND flash in normal and raw modes and compares results. The following statuses can be returned for a block: * non-ecc reading failed, * ecc reading failed, * block is bad, * bitflips is above maximum, * actual number of biflips above reported one, * bitflips reached it maximum value, * block is ok.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- cmd/Kconfig | 16 +++++ cmd/mtd.c | 197 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 213 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 9a5ba5ccb4e..2546679e7be 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1471,6 +1471,22 @@ config CMD_MTD_NAND_WRITE_TEST
+config CMD_MTD_NAND_READ_TEST + bool "mtd nand_read_test" + depends on CMD_MTD + help + MTD nand_read_test command support. + + Reads blocks of NAND flash in normal and raw modes and compares results. + The following statuses can be returned for a block: + * non-ecc reading failed, + * ecc reading failed, + * block is bad, + * bitflips is above maximum, + * actual number of biflips above reported one, + * bitflips reached it maximum value, + * block is ok. + config CMD_MUX bool "mux" depends on MULTIPLEXER diff --git a/cmd/mtd.c b/cmd/mtd.c index 1c819b35e9d..3cd6403bc13 100644 --- a/cmd/mtd.c +++ b/cmd/mtd.c @@ -931,6 +931,195 @@ out_put_mtd: } #endif
+#ifdef CONFIG_CMD_MTD_NAND_READ_TEST +enum nand_read_status { + NAND_READ_STATUS_UNKNOWN = 0, + NAND_READ_STATUS_NONECC_READ_FAIL, + NAND_READ_STATUS_ECC_READ_FAIL, + NAND_READ_STATUS_BAD_BLOCK, + NAND_READ_STATUS_BITFLIP_ABOVE_MAX, + NAND_READ_STATUS_BITFLIP_MISMATCH, + NAND_READ_STATUS_BITFLIP_MAX, + NAND_READ_STATUS_OK, +}; + +static enum nand_read_status nand_read_block_check(struct mtd_info *mtd, + loff_t off, size_t blocksize) +{ + struct mtd_oob_ops ops = {}; + u_char *buf; + int i, d, ret, len, pos, cnt, max; + + if (blocksize % mtd->writesize != 0) { + printf("\r block at 0x%llx: bad block size\n", off); + return NAND_READ_STATUS_UNKNOWN; + } + + buf = malloc_cache_aligned(2 * blocksize); + if (buf == NULL) { + printf("\r block at 0x%llx: can't allocate memory\n", off); + return NAND_READ_STATUS_UNKNOWN; + } + + ops.mode = MTD_OPS_RAW; + ops.len = blocksize; + ops.datbuf = buf; + ops.ooblen = 0; + ops.oobbuf = NULL; + + if (mtd->_read_oob) + ret = mtd->_read_oob(mtd, off, &ops); + else + ret = mtd->_read(mtd, off, ops.len, &ops.retlen, ops.datbuf); + + if (ret != 0) { + free(buf); + printf("\r block at 0x%llx: non-ecc reading error %d\n", + off, ret); + return NAND_READ_STATUS_NONECC_READ_FAIL; + } + + ops.mode = MTD_OPS_AUTO_OOB; + ops.datbuf = buf + blocksize; + + if (mtd->_read_oob) + ret = mtd->_read_oob(mtd, off, &ops); + else + ret = mtd->_read(mtd, off, ops.len, &ops.retlen, ops.datbuf); + + if (ret == -EBADMSG) { + free(buf); + printf("\r block at 0x%llx: bad block\n", off); + return NAND_READ_STATUS_BAD_BLOCK; + } + + if (ret < 0) { + free(buf); + printf("\r block at 0x%llx: ecc reading error %d\n", off, ret); + return NAND_READ_STATUS_ECC_READ_FAIL; + } + + if (mtd->ecc_strength == 0) { + free(buf); + return NAND_READ_STATUS_OK; + } + + if (ret > mtd->ecc_strength) { + free(buf); + printf("\r block at 0x%llx: returned bit-flips value %d " + "is above maximum value %d\n", + off, ret, mtd->ecc_strength); + return NAND_READ_STATUS_BITFLIP_ABOVE_MAX; + } + + max = 0; + pos = 0; + len = blocksize; + while (len > 0) { + cnt = 0; + for (i = 0; i < mtd->ecc_step_size; i++) { + d = buf[pos + i] ^ buf[blocksize + pos + i]; + if (d == 0) + continue; + + while (d > 0) { + d &= (d - 1); + cnt++; + } + } + if (cnt > max) + max = cnt; + + len -= mtd->ecc_step_size; + pos += mtd->ecc_step_size; + } + + free(buf); + + if (max > ret) { + printf("\r block at 0x%llx: bitflip mismatch, " + "read %d but actual %d\n", off, ret, max); + return NAND_READ_STATUS_BITFLIP_MISMATCH; + } + + if (ret == mtd->ecc_strength) { + printf("\r block at 0x%llx: max bitflip reached, " + "block is unreliable\n", off); + return NAND_READ_STATUS_BITFLIP_MAX; + } + + return NAND_READ_STATUS_OK; +} + +static int do_mtd_nand_read_test(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct mtd_info *mtd; + u64 off, blocks; + int stat[NAND_READ_STATUS_OK + 1]; + enum nand_read_status ret; + + if (argc < 2) + return CMD_RET_USAGE; + + mtd = get_mtd_by_name(argv[1]); + if (IS_ERR_OR_NULL(mtd)) + return CMD_RET_FAILURE; + + if (!mtd_can_have_bb(mtd)) { + printf("Only NAND-based devices can be checked\n"); + goto out_put_mtd; + } + + blocks = mtd->size; + do_div(blocks, mtd->erasesize); + + printf("ECC strength: %d\n", mtd->ecc_strength); + printf("ECC step size: %d\n", mtd->ecc_step_size); + printf("Erase block size: 0x%x\n", mtd->erasesize); + printf("Total blocks: %lld\n", blocks); + + printf("\nworking...\n"); + memset(stat, 0, sizeof(stat)); + for (off = 0; off < mtd->size; off += mtd->erasesize) { + ret = nand_read_block_check(mtd, off, mtd->erasesize); + stat[ret]++; + + switch (ret) { + case NAND_READ_STATUS_BAD_BLOCK: + case NAND_READ_STATUS_BITFLIP_MAX: + if (!mtd_block_isbad(mtd, off)) + printf("\r block at 0x%llx: should be marked " + "as BAD\n", off); + break; + + case NAND_READ_STATUS_OK: + if (mtd_block_isbad(mtd, off)) + printf("\r block at 0x%llx: marked as BAD, but " + "probably is GOOD\n", off); + break; + + default: + break; + } + } + +out_put_mtd: + put_mtd_device(mtd); + printf("\n"); + printf("results:\n"); + printf(" Good blocks: %d\n", stat[NAND_READ_STATUS_OK]); + printf(" Physically bad blocks: %d\n", stat[NAND_READ_STATUS_BAD_BLOCK]); + printf(" Unreliable blocks: %d\n", stat[NAND_READ_STATUS_BITFLIP_MAX]); + printf(" Non checked blocks: %d\n", stat[NAND_READ_STATUS_UNKNOWN]); + printf(" Failed to check blocks: %d\n", stat[NAND_READ_STATUS_NONECC_READ_FAIL] + + stat[NAND_READ_STATUS_ECC_READ_FAIL]); + printf(" Suspictious blocks: %d\n", stat[NAND_READ_STATUS_BITFLIP_ABOVE_MAX] + + stat[NAND_READ_STATUS_BITFLIP_MISMATCH]); + return CMD_RET_SUCCESS; +} +#endif + static int do_mtd_bad(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -1019,6 +1208,9 @@ U_BOOT_LONGHELP(mtd, #endif #if CONFIG_IS_ENABLED(CMD_MTD_NAND_WRITE_TEST) "mtd nand_write_test <name> [<off> [<size>]]\n" +#endif +#if CONFIG_IS_ENABLED(CMD_MTD_NAND_READ_TEST) + "mtd nand_read_test <name>\n" #endif "\n" "With:\n" @@ -1061,6 +1253,11 @@ U_BOOT_CMD_WITH_SUBCMDS(mtd, "MTD utils", mtd_help_text, U_BOOT_SUBCMD_MKENT_COMPLETE(nand_write_test, 4, 0, do_nand_write_test, mtd_name_complete), +#endif +#if CONFIG_IS_ENABLED(CMD_MTD_NAND_READ_TEST) + U_BOOT_SUBCMD_MKENT_COMPLETE(nand_read_test, 2, 0, + do_mtd_nand_read_test, + mtd_name_complete), #endif U_BOOT_SUBCMD_MKENT_COMPLETE(bad, 2, 1, do_mtd_bad, mtd_name_complete));
Mikhail Kshevetskiy
