[U-Boot] mpc85xx: inhibit bman portals by default
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is needed for deepsleep.
Signed-off-by: Jeffrey Ladouceur Jeffrey.Ladouceur@freescale.com --- Depends on at minimum: Developed during T102X testing. http://patchwork.ozlabs.org/patch/403533 http://patchwork.ozlabs.org/patch/403539/
arch/powerpc/cpu/mpc85xx/portals.c | 41 +++++++++++++++++++++++++++++++++++ include/configs/B4860QDS.h | 8 +++++++ include/configs/P1023RDB.h | 8 +++++++ include/configs/P1023RDS.h | 8 +++++++ include/configs/P2041RDB.h | 8 +++++++ include/configs/T102xQDS.h | 8 +++++++ include/configs/T102xRDB.h | 8 +++++++ include/configs/T1040QDS.h | 8 +++++++ include/configs/T104xRDB.h | 8 +++++++ include/configs/T208xQDS.h | 8 +++++++ include/configs/T208xRDB.h | 8 +++++++ include/configs/T4240EMU.h | 8 +++++++ include/configs/T4240QDS.h | 8 +++++++ include/configs/T4240RDB.h | 8 +++++++ include/configs/corenet_ds.h | 8 +++++++ include/configs/km/kmp204x-common.h | 8 +++++++ 16 files changed, 161 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index 98815f8..4c2ee98 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -14,6 +14,44 @@ #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h>
+#define MAX_PORTALS (CONFIG_SYS_BMAN_CINH_SIZE / CONFIG_SYS_BMAN_SP_CINH_SIZE) +void inhibit_bman_portals(void) +{ + void __iomem *addr = (void *)CONFIG_SYS_BMAN_CINH_BASE + + CONFIG_SYS_BMAN_SWP_ISDR_REG; + uint32_t val; + int portal_count = 0; + + /* Dynamically determine number of portals */ + do { + val = in_be32(addr); + if (val) { + printf("ERROR: should be zero at 0x%p\n", addr); + goto done; + } + out_be32(addr, -1); + val = in_be32(addr); + if (!val) { + /* end of portals */ + if (!portal_count) + printf("ERROR: No portals\n"); + goto done; + } + portal_count++; + addr += CONFIG_SYS_BMAN_SP_CINH_SIZE; + if (portal_count >= MAX_PORTALS) + goto done; + } while (1); + +done: + +#ifdef DEBUG + printf("BMan portal counted %u, defined is %u\n", + portal_count, CONFIG_SYS_BMAN_NUM_PORTALS); +#endif + return; +} + void setup_portals(void) { ccsr_qman_t *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR; @@ -38,6 +76,9 @@ void setup_portals(void) out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); #endif out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); + + /* Change default state of BMan ISDR portals to all 1s */ + inhibit_bman_portals(); }
/* Update portal containter to match LAW setup of portal in phy map */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 2fbb2c7..3f074ea 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -641,6 +641,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index ba3da06..107db72 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -347,6 +347,14 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08
/* For FM */ #define CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index ac75b9c..5d124d4 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -447,6 +447,14 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08
/* For FM */ #define CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 16f7525..a54a917 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -488,6 +488,14 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 66a7031..ed70cd2 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -728,6 +728,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index e575784..2703cbf 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -686,6 +686,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index f2a75ae..8687694 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -599,6 +599,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 1f5d39e..af8524e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -604,6 +604,14 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 25 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index f05933f..b97c895 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -634,6 +634,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 6dbc178..2eb5c1b 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -567,6 +567,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 18 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h index 53c69b0..4df8f10 100644 --- a/include/configs/T4240EMU.h +++ b/include/configs/T4240EMU.h @@ -85,6 +85,14 @@ #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index a770dd0..a343220 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -417,6 +417,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 22ddf45..a6c104f 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -576,6 +576,14 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 12b3296..e6e94e4 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -494,6 +494,14 @@ #define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE #endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index efd9635..1803d90 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -336,6 +336,14 @@ int get_scl(void); #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull #define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_BMAN_SP_CENA_SIZE 0x4000 +#define CONFIG_SYS_BMAN_SP_CINH_SIZE 0x1000 +#define CONFIG_SYS_BMAN_CENA_BASE CONFIG_SYS_BMAN_MEM_BASE +#define CONFIG_SYS_BMAN_CENA_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_CINH_BASE (CONFIG_SYS_BMAN_MEM_BASE + \ + CONFIG_SYS_BMAN_CENA_SIZE) +#define CONFIG_SYS_BMAN_CINH_SIZE (CONFIG_SYS_BMAN_MEM_SIZE >> 1) +#define CONFIG_SYS_BMAN_SWP_ISDR_REG 0xE08 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 #define CONFIG_SYS_QMAN_MEM_PHYS 0xff4200000ull
Jeffrey Ladouceur
