[U-Boot] [PATCH] lib/libfdt/: General aesthetic/style fixes.
A number of style fixes across the files in this directory, including:
* Correct invalid kernel-doc content. * Tidy up massive comment in fdt_region.c. * Use correct spelling of "U-Boot". * Replace tests of "! <var>" with "!<var>". * Replace "libfdt_env.h" with <libfdt_env.h>.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
since i was already digging through this code, it seemed worth doing one big tidy-up ... compile-tested for sandbox.
diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 934d614..8b86c15 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -5,5 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_sw.o fdt_wip.o \ - fdt_empty_tree.o fdt_addresses.o fdt_region.o +obj-y += \ + fdt.o \ + fdt_ro.o \ + fdt_rw.o \ + fdt_strerror.o \ + fdt_sw.o \ + fdt_wip.o \ + fdt_empty_tree.o \ + fdt_addresses.o \ + fdt_region.o diff --git a/lib/libfdt/README b/lib/libfdt/README index e059876..db40ab2 100644 --- a/lib/libfdt/README +++ b/lib/libfdt/README @@ -1,5 +1,5 @@ The libfdt functionality was written by David Gibson. The original -source came from the git repository: +source came from the Git repository:
URL: git://ozlabs.org/home/dgibson/git/libfdt.git
@@ -11,13 +11,15 @@ commit 857f54e79f74429af20c2b5ecc00ee98af6a3b8b tree 2f648f0f88225a51ded452968d28b4402df8ade0 parent 07a12a08005f3b5cd9337900a6551e450c07b515
-To adapt for u-boot usage, only the applicable files were copied and -imported into the u-boot git repository. +To adapt for U-Boot usage, only the applicable files were copied and +imported into the U-Boot Git repository. + Omitted: -* GPL - u-boot comes with a copy of the GPL license -* test subdirectory - not directly useful for u-boot
-After importing, other customizations were performed. See the git log -for details. + * GPL - U-Boot comes with a copy of the GPL license + * test subdirectory - not directly useful for U-Boot + +After importing, other customizations were performed. See the +"git log" for details.
Jerry Van Baren diff --git a/lib/libfdt/fdt.c b/lib/libfdt/fdt.c index e146aba..96017a1 100644 --- a/lib/libfdt/fdt.c +++ b/lib/libfdt/fdt.c @@ -3,7 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> diff --git a/lib/libfdt/fdt_addresses.c b/lib/libfdt/fdt_addresses.c index 76054d9..b6bc66e 100644 --- a/lib/libfdt/fdt_addresses.c +++ b/lib/libfdt/fdt_addresses.c @@ -3,7 +3,7 @@ * Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> diff --git a/lib/libfdt/fdt_empty_tree.c b/lib/libfdt/fdt_empty_tree.c index 34f1c84..6fde1eb 100644 --- a/lib/libfdt/fdt_empty_tree.c +++ b/lib/libfdt/fdt_empty_tree.c @@ -3,8 +3,7 @@ * Copyright (C) 2012 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" - +#include <libfdt_env.h> #include <fdt.h> #include <libfdt.h>
diff --git a/lib/libfdt/fdt_region.c b/lib/libfdt/fdt_region.c index 747d8bb..d2ce4c1 100644 --- a/lib/libfdt/fdt_region.c +++ b/lib/libfdt/fdt_region.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */
#ifndef USE_HOSTCC #include <fdt.h> @@ -18,14 +18,13 @@
/** * fdt_add_region() - Add a new region to our list + * @info: State information + * @offset: Start offset of region + * @size: Size of region * * The region is added if there is space, but in any case we increment the * count. If permitted, and the new region overlaps the last one, we merge * them. - * - * @info: State information - * @offset: Start offset of region - * @size: Size of region */ static int fdt_add_region(struct fdt_region_state *info, int offset, int size) { @@ -119,6 +118,8 @@ int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count,
/** * fdt_include_supernodes() - Include supernodes required by this node + * @info: State information + * @depth: Current stack depth * * When we decided to include a node or property which is not at the top * level, this function forces the inclusion of higher level nodes. For @@ -131,9 +132,6 @@ int fdt_add_alias_regions(const void *fdt, struct fdt_region *region, int count, * * If we decide to include testing then we need the root node to have a valid * tree. This function adds those regions. - * - * @info: State information - * @depth: Current stack depth */ static int fdt_include_supernodes(struct fdt_region_state *info, int depth) { @@ -203,72 +201,78 @@ int fdt_first_region(const void *fdt, path, path_len, flags, info); }
-/* - * Theory of operation +/*********************************************************************** + * + * Theory of operation + * + * Note: in this description 'included' means that a node (or other part + * of the tree) should be included in the region list, i.e. it will have + * a region which covers its part of the tree. + * + * This function maintains some state from the last time it is called. + * It checks the next part of the tree that it is supposed to look at + * (p.nextoffset) to see if that should be included or not. When it + * finds something to include, it sets info->start to its offset. This + * marks the start of the region we want to include. + * + * Once info->start is set to the start (i.e. not -1), we continue + * scanning until we find something that we don't want included. This + * will be the end of a region. At this point we can close off the + * region and add it to the list. So we do so, and reset info->start + * to -1. + * + * One complication here is that we want to merge regions. So when we + * come to add another region later, we may in fact merge it with the + * previous one if one ends where the other starts. + * + * The function fdt_add_region() will return -1 if it fails to add the + * region, because we already have a region ready to be returned, and + * the new one cannot be merged in with it. In this case, we must return + * the region we found, and wait for another call to this function. + * When it comes, we will repeat the processing of the tag and again + * try to add a region. This time it will succeed. + * + * The current state of the pointers (stack, offset, etc.) is maintained + * in a ptrs member. At the start of every loop iteration we make a copy + * of it. The copy is then updated as the tag is processed. Only if we + * get to the end of the loop iteration (and successfully call + * fdt_add_region() if we need to) can we commit the changes we have + * made to these pointers. For example, if we see an FDT_END_NODE tag, + * we will decrement the depth value. But if we need to add a region + * for this tag (let's say because the previous tag is included and this + * FDT_END_NODE tag is not included) then we will only commit the result + * if we were able to add the region. That allows us to retry again next + * time. + * + * We keep track of a variable called 'want' which tells us what we want + * to include when there is no specific information provided by the + * h_include function for a particular property. This basically handles + * the inclusion of properties which are pulled in by virtue of the node + * they are in. So if you include a node, its properties are also + * included. In this case 'want' will be WANT_NODES_AND_PROPS. The + * FDT_REG_DIRECT_SUBNODES feature also makes use of 'want'. While we + * are inside the subnode, 'want' will be set to WANT_NODES_ONLY, so + * that only the subnode's FDT_BEGIN_NODE and FDT_END_NODE tags will be + * included, and properties will be skipped. If WANT_NOTHING is + * selected, then we will just rely on what the h_include() function + * tells us. * + * Using 'want' we work out 'include', which tells us whether this + * current tag should be included or not. As you can imagine, if the + * value of 'include' changes, that means we are on a boundary between + * nodes to include and nodes to exclude. At this point we either close + * off a previous region and add it to the list, or mark the start of a + * new region. * + * Apart from the nodes, we have mem_rsvmap, the FDT_END tag and the + * string list. Each of these dealt with as a whole (i.e. we create a + * region for each if it is to be included). For mem_rsvmap we don't + * allow it to merge with the first struct region. For the stringlist, + * we don't allow it to merge with the last struct region (which + * contains at minimum the FDT_END tag). * + *********************************************************************/
-Note: in this description 'included' means that a node (or other part of -the tree) should be included in the region list, i.e. it will have a region -which covers its part of the tree. - -This function maintains some state from the last time it is called. It -checks the next part of the tree that it is supposed to look at -(p.nextoffset) to see if that should be included or not. When it finds -something to include, it sets info->start to its offset. This marks the -start of the region we want to include. - -Once info->start is set to the start (i.e. not -1), we continue scanning -until we find something that we don't want included. This will be the end -of a region. At this point we can close off the region and add it to the -list. So we do so, and reset info->start to -1. - -One complication here is that we want to merge regions. So when we come to -add another region later, we may in fact merge it with the previous one if -one ends where the other starts. - -The function fdt_add_region() will return -1 if it fails to add the region, -because we already have a region ready to be returned, and the new one -cannot be merged in with it. In this case, we must return the region we -found, and wait for another call to this function. When it comes, we will -repeat the processing of the tag and again try to add a region. This time it -will succeed. - -The current state of the pointers (stack, offset, etc.) is maintained in -a ptrs member. At the start of every loop iteration we make a copy of it. -The copy is then updated as the tag is processed. Only if we get to the end -of the loop iteration (and successfully call fdt_add_region() if we need -to) can we commit the changes we have made to these pointers. For example, -if we see an FDT_END_NODE tag we will decrement the depth value. But if we -need to add a region for this tag (let's say because the previous tag is -included and this FDT_END_NODE tag is not included) then we will only commit -the result if we were able to add the region. That allows us to retry again -next time. - -We keep track of a variable called 'want' which tells us what we want to -include when there is no specific information provided by the h_include -function for a particular property. This basically handles the inclusion of -properties which are pulled in by virtue of the node they are in. So if you -include a node, its properties are also included. In this case 'want' will -be WANT_NODES_AND_PROPS. The FDT_REG_DIRECT_SUBNODES feature also makes use -of 'want'. While we are inside the subnode, 'want' will be set to -WANT_NODES_ONLY, so that only the subnode's FDT_BEGIN_NODE and FDT_END_NODE -tags will be included, and properties will be skipped. If WANT_NOTHING is -selected, then we will just rely on what the h_include() function tells us. - -Using 'want' we work out 'include', which tells us whether this current tag -should be included or not. As you can imagine, if the value of 'include' -changes, that means we are on a boundary between nodes to include and nodes -to exclude. At this point we either close off a previous region and add it -to the list, or mark the start of a new region. - -Apart from the nodes, we have mem_rsvmap, the FDT_END tag and the string -list. Each of these dealt with as a whole (i.e. we create a region for each -if it is to be included). For mem_rsvmap we don't allow it to merge with -the first struct region. For the stringlist we don't allow it to merge with -the last struct region (which contains at minimum the FDT_END tag). -*/ int fdt_next_region(const void *fdt, int (*h_include)(void *priv, const void *fdt, int offset, int type, const char *data, int size), diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 7b0777b..12214c2 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -3,7 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> @@ -19,7 +19,7 @@ static int _fdt_nodename_eq(const void *fdt, int offset, { const char *p = fdt_offset_ptr(fdt, offset + FDT_TAGSIZE, len+1);
- if (! p) + if (!p) /* short match */ return 0;
@@ -115,7 +115,7 @@ int fdt_subnode_offset(const void *fdt, int parentoffset,
/* * Find the next of path seperator, note we need to search for both '/' and ':' - * and then take the first one so that we do the rigth thing for e.g. + * and then take the first one so that we do the right thing for e.g. * "foo/bar:option" and "bar:option/otheroption", both of which happen, so * first searching for either ':' or '/' does not work. */ @@ -163,7 +163,7 @@ int fdt_path_offset(const void *fdt, const char *path) if (*p == '\0' || *p == ':') return offset; q = fdt_path_next_seperator(p); - if (! q) + if (!q) q = end;
offset = fdt_subnode_offset_namelen(fdt, offset, p, q-p); @@ -273,7 +273,7 @@ const void *fdt_getprop_namelen(const void *fdt, int nodeoffset, const struct fdt_property *prop;
prop = fdt_get_property_namelen(fdt, nodeoffset, name, namelen, lenp); - if (! prop) + if (!prop) return NULL;
return prop->data; diff --git a/lib/libfdt/fdt_rw.c b/lib/libfdt/fdt_rw.c index 1a358a8..e7321cc 100644 --- a/lib/libfdt/fdt_rw.c +++ b/lib/libfdt/fdt_rw.c @@ -3,7 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> @@ -168,7 +168,7 @@ static int _fdt_resize_property(void *fdt, int nodeoffset, const char *name, int err;
*prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); - if (! (*prop)) + if (!(*prop)) return oldlen;
if ((err = _fdt_splice_struct(fdt, (*prop)->data, FDT_TAGALIGN(oldlen), @@ -283,7 +283,7 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name) FDT_RW_CHECK_HEADER(fdt);
prop = fdt_get_property_w(fdt, nodeoffset, name, &len); - if (! prop) + if (!prop) return len;
proplen = sizeof(*prop) + FDT_TAGALIGN(len); diff --git a/lib/libfdt/fdt_strerror.c b/lib/libfdt/fdt_strerror.c index 2f3cc24..3b7e168 100644 --- a/lib/libfdt/fdt_strerror.c +++ b/lib/libfdt/fdt_strerror.c @@ -3,7 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> diff --git a/lib/libfdt/fdt_sw.c b/lib/libfdt/fdt_sw.c index 345a3ac..70fd026 100644 --- a/lib/libfdt/fdt_sw.c +++ b/lib/libfdt/fdt_sw.c @@ -3,8 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" - +#include <libfdt_env.h> #include <fdt.h> #include <libfdt.h>
diff --git a/lib/libfdt/fdt_wip.c b/lib/libfdt/fdt_wip.c index 3f2dfa5..9fe9886 100644 --- a/lib/libfdt/fdt_wip.c +++ b/lib/libfdt/fdt_wip.c @@ -3,7 +3,7 @@ * Copyright (C) 2006 David Gibson, IBM Corporation. * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause */ -#include "libfdt_env.h" +#include <libfdt_env.h>
#ifndef USE_HOSTCC #include <fdt.h> @@ -21,7 +21,7 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, int proplen;
propval = fdt_getprop_w(fdt, nodeoffset, name, &proplen); - if (! propval) + if (!propval) return proplen;
if (proplen != len) @@ -45,7 +45,7 @@ int fdt_nop_property(void *fdt, int nodeoffset, const char *name) int len;
_fdt_nop_region(prop, len + sizeof(*prop));
Hi Robert,
- Correct invalid kernel-doc content.
- Tidy up massive comment in fdt_region.c.
- Use correct spelling of "U-Boot".
- Replace tests of "! <var>" with "!<var>".
- Replace "libfdt_env.h" with <libfdt_env.h>.
Did you create this patch with patman? It seems to be missing the diffstat.
Regards, SImon
On 7 June 2016 at 20:43, Simon Glass sjg@chromium.org wrote:
Hi Robert,
Applied to u-boot-dm, thanks!
Robert P. J. Day
