[U-Boot] [PATCH v5] clk: at91: Add clock driver
The patch is referred to at91 clock driver of Linux, to make the clock node descriptions in DT aligned with the Linux's.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v5: - Change clk_client.h -> clk.h to adapt to clk API conversion. - Fix missing semicolon and clk->dev in clk-generated.c. - Make clock options selectable via menuconfig.
Changes in v4: - Add Reviewed-by tag. - Add more information in Kconfig help. - Use u32 for num_parents variable, not u8. - Change the check return from clk_get_rate(). - Remove return -ENODEV line, use return ret. - Improve the comments in at91_system_clk_enable().
Changes in v3: - Update based on [PATCH] clk: convert API to match reset/mailbox style (http://patchwork.ozlabs.org/patch/625342/). - Remove [PATCH] clk: clk-uclass: Add post binding for CLK uclass, add bind() method to bind the clk node without compatible. - Add help for Kconfig HAVE_AT91_XX option. - Add ofdata_to_platdata() method for generated clock driver to handle the device tree. - Use setbits_le32() to replace readl()/writel(). - Fixed the return value, -ENODEV->-EINVAL. - Use dev_get_addr_ptr() to replace dev_get_addr(). - Remove check on dev_get_parent() return.
Changes in v2: - Remove the redundant log print.
arch/arm/mach-at91/include/mach/at91_pmc.h | 11 +- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/at91/Kconfig | 43 ++++++++ drivers/clk/at91/Makefile | 11 ++ drivers/clk/at91/clk-generated.c | 162 +++++++++++++++++++++++++++++ drivers/clk/at91/clk-h32mx.c | 56 ++++++++++ drivers/clk/at91/clk-main.c | 55 ++++++++++ drivers/clk/at91/clk-master.c | 33 ++++++ drivers/clk/at91/clk-peripheral.c | 60 +++++++++++ drivers/clk/at91/clk-plla.c | 55 ++++++++++ drivers/clk/at91/clk-slow.c | 37 +++++++ drivers/clk/at91/clk-system.c | 76 ++++++++++++++ drivers/clk/at91/clk-utmi.c | 67 ++++++++++++ drivers/clk/at91/pmc.c | 71 +++++++++++++ drivers/clk/at91/pmc.h | 18 ++++ drivers/clk/at91/sckc.c | 30 ++++++ 17 files changed, 784 insertions(+), 3 deletions(-) create mode 100644 drivers/clk/at91/Kconfig create mode 100644 drivers/clk/at91/Makefile create mode 100644 drivers/clk/at91/clk-generated.c create mode 100644 drivers/clk/at91/clk-h32mx.c create mode 100644 drivers/clk/at91/clk-main.c create mode 100644 drivers/clk/at91/clk-master.c create mode 100644 drivers/clk/at91/clk-peripheral.c create mode 100644 drivers/clk/at91/clk-plla.c create mode 100644 drivers/clk/at91/clk-slow.c create mode 100644 drivers/clk/at91/clk-system.c create mode 100644 drivers/clk/at91/clk-utmi.c create mode 100644 drivers/clk/at91/pmc.c create mode 100644 drivers/clk/at91/pmc.h create mode 100644 drivers/clk/at91/sckc.c
diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index 680ceb0..2875ff2 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -149,6 +149,9 @@ typedef struct at91_pmc {
#define AT91_PMC_PCR_PID_MASK (0x3f) #define AT91_PMC_PCR_GCKCSS (0x7 << 8) +#define AT91_PMC_PCR_GCKCSS_MASK 0x07 +#define AT91_PMC_PCR_GCKCSS_OFFSET 8 +#define AT91_PMC_PCR_GCKCSS_(x) ((x & 0x07) << 8) #define AT91_PMC_PCR_GCKCSS_SLOW_CLK (0x0 << 8) #define AT91_PMC_PCR_GCKCSS_MAIN_CLK (0x1 << 8) #define AT91_PMC_PCR_GCKCSS_PLLA_CLK (0x2 << 8) @@ -158,8 +161,9 @@ typedef struct at91_pmc { #define AT91_PMC_PCR_CMD_WRITE (0x1 << 12) #define AT91_PMC_PCR_DIV (0x3 << 16) #define AT91_PMC_PCR_GCKDIV (0xff << 20) -#define AT91_PMC_PCR_GCKDIV_(x) (((x) & 0xff) << 20) -#define AT91_PMC_PCR_GCKDIV_OFFSET 20 +#define AT91_PMC_PCR_GCKDIV_MASK 0xff +#define AT91_PMC_PCR_GCKDIV_OFFSET 20 +#define AT91_PMC_PCR_GCKDIV_(x) ((x & 0xff) << 20) #define AT91_PMC_PCR_EN (0x1 << 28) #define AT91_PMC_PCR_GCKEN (0x1 << 29)
@@ -243,8 +247,9 @@ typedef struct at91_pmc { #define AT91_PMC_PCK1RDY (1 << 9) /* Programmable Clock 1 */ #define AT91_PMC_PCK2RDY (1 << 10) /* Programmable Clock 2 */ #define AT91_PMC_PCK3RDY (1 << 11) /* Programmable Clock 3 */ +#define AT91_PMC_MOSCSELS BIT(16) /* Main Oscillator Selection Status */ +#define AT91_PMC_MOSCRCS BIT(17) /* 12 MHz RC Oscillator Status */ #define AT91_PMC_GCKRDY (1 << 24) - #define AT91_PMC_PROTKEY 0x504d4301 /* Activation Code */
/* PLL Charge Pump Current Register (PMC_PLLICPR) */ diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 6eee8eb..3da63c0 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -22,5 +22,6 @@ config SPL_CLK
source "drivers/clk/uniphier/Kconfig" source "drivers/clk/exynos/Kconfig" +source "drivers/clk/at91/Kconfig"
endmenu diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index f7a8891..863a8d7 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_SANDBOX) += clk_sandbox_test.o obj-$(CONFIG_MACH_PIC32) += clk_pic32.o obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ obj-$(CONFIG_CLK_EXYNOS) += exynos/ +obj-$(CONFIG_CLK_AT91) += at91/ diff --git a/drivers/clk/at91/Kconfig b/drivers/clk/at91/Kconfig new file mode 100644 index 0000000..10050d8 --- /dev/null +++ b/drivers/clk/at91/Kconfig @@ -0,0 +1,43 @@ +config CLK_AT91 + bool "AT91 clock drivers" + depends on CLK + help + This option is used to enable the AT91 clock driver. + The driver supports the AT91 clock generator, including + the oscillators and PLLs, such as main clock, slow clock, + PLLA, UTMI PLL. Clocks can also be a source clock of other + clocks a tree structure, such as master clock, usb device + clock, matrix clock and generic clock. + Devices can use a common clock API to request a particular + clock, enable it and get its rate. + +config AT91_UTMI + bool "Support UTMI PLL Clock" + depends on CLK_AT91 + help + This option is used to enable the AT91 UTMI PLL clock + driver. It is the clock provider of USB, and UPLLCK is the + output of 480 MHz UTMI PLL, The souce clock of the UTMI + PLL is the main clock, so the main clock must select the + fast crystal oscillator to meet the frequency accuracy + required by USB. + +config AT91_H32MX + bool "Support H32MX 32-bit Matrix Clock" + depends on CLK_AT91 + help + This option is used to enable the AT91 H32MX matrixes + clock driver. There are H64MX and H32MX matrixes clocks, + H64MX 64-bit matrix clocks are MCK. The H32MX 32-bit + matrix clock is to be configured as MCK if MCK does not + exceed 83 MHz, else it is to be configured as MCK/2. + +config AT91_GENERIC_CLK + bool "Support Generic Clock" + depends on CLK_AT91 + help + This option is used to enable the AT91 generic clock + driver. Some peripherals may need a second clock source + that may be different from the system clock. This second + clock is the generic clock (GCLK) and is managed by + the PMC via PMC_PCR register. diff --git a/drivers/clk/at91/Makefile b/drivers/clk/at91/Makefile new file mode 100644 index 0000000..fbe3cb6 --- /dev/null +++ b/drivers/clk/at91/Makefile @@ -0,0 +1,11 @@ +# +# Makefile for at91 specific clk +# + +obj-y += pmc.o sckc.o +obj-y += clk-slow.o clk-main.o clk-plla.o clk-master.o +obj-y += clk-system.o clk-peripheral.o + +obj-$(CONFIG_AT91_UTMI) += clk-utmi.o +obj-$(CONFIG_AT91_H32MX) += clk-h32mx.o +obj-$(CONFIG_AT91_GENERIC_CLK) += clk-generated.o diff --git a/drivers/clk/at91/clk-generated.c b/drivers/clk/at91/clk-generated.c new file mode 100644 index 0000000..f6164cc --- /dev/null +++ b/drivers/clk/at91/clk-generated.c @@ -0,0 +1,162 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define GENERATED_SOURCE_MAX 6 +#define GENERATED_MAX_DIV 255 + +struct generated_clk_priv { + u32 num_parents; +}; + +static ulong generated_clk_get_rate(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct clk parent; + u32 tmp, gckdiv; + u8 parent_id; + int ret; + + writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr); + tmp = readl(&pmc->pcr); + parent_id = (tmp >> AT91_PMC_PCR_GCKCSS_OFFSET) & + AT91_PMC_PCR_GCKCSS_MASK; + gckdiv = (tmp >> AT91_PMC_PCR_GCKDIV_OFFSET) & AT91_PMC_PCR_GCKDIV_MASK; + + ret = clk_get_by_index(clk->dev, parent_id, &parent); + if (ret) + return 0; + + return clk_get_rate(&parent) / (gckdiv + 1); +} + +static ulong generated_clk_set_rate(struct clk *clk, ulong rate) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + struct generated_clk_priv *priv = dev_get_priv(clk->dev); + struct clk parent, best_parent; + ulong tmp_rate, best_rate = rate, parent_rate; + int tmp_diff, best_diff = -1; + u32 div, best_div = 0; + u8 best_parent_id = 0; + u8 i; + u32 tmp; + int ret; + + for (i = 0; i < priv->num_parents; i++) { + ret = clk_get_by_index(clk->dev, i, &parent); + if (ret) + return ret; + + parent_rate = clk_get_rate(&parent); + if (IS_ERR_VALUE(parent_rate)) + return parent_rate; + + for (div = 1; div < GENERATED_MAX_DIV + 2; div++) { + tmp_rate = DIV_ROUND_CLOSEST(parent_rate, div); + if (rate < tmp_rate) + continue; + tmp_diff = rate - tmp_rate; + + if (best_diff < 0 || best_diff > tmp_diff) { + best_rate = tmp_rate; + best_diff = tmp_diff; + + best_div = div - 1; + best_parent = parent; + best_parent_id = i; + } + + if (!best_diff || tmp_rate < rate) + break; + } + + if (!best_diff) + break; + } + + debug("GCK: best parent: %s, best_rate = %ld, best_div = %d\n", + best_parent.dev->name, best_rate, best_div); + + ret = clk_enable(&best_parent); + if (ret) + return ret; + + writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr); + tmp = readl(&pmc->pcr); + tmp &= ~(AT91_PMC_PCR_GCKDIV | AT91_PMC_PCR_GCKCSS); + tmp |= AT91_PMC_PCR_GCKCSS_(best_parent_id) | + AT91_PMC_PCR_CMD_WRITE | + AT91_PMC_PCR_GCKDIV_(best_div) | + AT91_PMC_PCR_GCKEN; + writel(tmp, &pmc->pcr); + + while (!(readl(&pmc->sr) & AT91_PMC_GCKRDY)) + ; + + return 0; +} + +static struct clk_ops generated_clk_ops = { + .get_rate = generated_clk_get_rate, + .set_rate = generated_clk_set_rate, +}; + +static int generated_clk_ofdata_to_platdata(struct udevice *dev) +{ + struct generated_clk_priv *priv = dev_get_priv(dev); + u32 cells[GENERATED_SOURCE_MAX]; + u32 num_parents; + + num_parents = fdtdec_get_int_array_count(gd->fdt_blob, dev->of_offset, + "clocks", cells, + GENERATED_SOURCE_MAX); + + if (!num_parents) + return -1; + + priv->num_parents = num_parents; + + return 0; +} + +static int generated_clk_bind(struct udevice *dev) +{ + return at91_pmc_clk_node_bind(dev); +} + +static int generated_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id generated_clk_match[] = { + { .compatible = "atmel,sama5d2-clk-generated" }, + {} +}; + +U_BOOT_DRIVER(generated_clk) = { + .name = "generated-clk", + .id = UCLASS_CLK, + .of_match = generated_clk_match, + .bind = generated_clk_bind, + .probe = generated_clk_probe, + .ofdata_to_platdata = generated_clk_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct generated_clk_priv), + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &generated_clk_ops, +}; diff --git a/drivers/clk/at91/clk-h32mx.c b/drivers/clk/at91/clk-h32mx.c new file mode 100644 index 0000000..1a304ba --- /dev/null +++ b/drivers/clk/at91/clk-h32mx.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/util.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define H32MX_MAX_FREQ 90000000 + +static ulong sama5d4_h32mx_clk_get_rate(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + ulong rate = gd->arch.mck_rate_hz; + + if (readl(&pmc->mckr) & AT91_PMC_MCKR_H32MXDIV) + rate /= 2; + + if (rate > H32MX_MAX_FREQ) + dm_warn("H32MX clock is too fast\n"); + + return rate; +} + +static struct clk_ops sama5d4_h32mx_clk_ops = { + .get_rate = sama5d4_h32mx_clk_get_rate, +}; + +static int sama5d4_h32mx_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id sama5d4_h32mx_clk_match[] = { + { .compatible = "atmel,sama5d4-clk-h32mx" }, + {} +}; + +U_BOOT_DRIVER(sama5d4_h32mx_clk) = { + .name = "sama5d4-h32mx-clk", + .id = UCLASS_CLK, + .of_match = sama5d4_h32mx_clk_match, + .probe = sama5d4_h32mx_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &sama5d4_h32mx_clk_ops, +}; diff --git a/drivers/clk/at91/clk-main.c b/drivers/clk/at91/clk-main.c new file mode 100644 index 0000000..252d076 --- /dev/null +++ b/drivers/clk/at91/clk-main.c @@ -0,0 +1,55 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int main_osc_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + + if (readl(&pmc->sr) & AT91_PMC_MOSCSELS) + return 0; + + return -EINVAL; +} + +static ulong main_osc_clk_get_rate(struct clk *clk) +{ + return gd->arch.main_clk_rate_hz; +} + +static struct clk_ops main_osc_clk_ops = { + .enable = main_osc_clk_enable, + .get_rate = main_osc_clk_get_rate, +}; + +static int main_osc_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id main_osc_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-main" }, + {} +}; + +U_BOOT_DRIVER(at91sam9x5_main_osc_clk) = { + .name = "at91sam9x5-main-osc-clk", + .id = UCLASS_CLK, + .of_match = main_osc_clk_match, + .probe = main_osc_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &main_osc_clk_ops, +}; diff --git a/drivers/clk/at91/clk-master.c b/drivers/clk/at91/clk-master.c new file mode 100644 index 0000000..284b248 --- /dev/null +++ b/drivers/clk/at91/clk-master.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> + +DECLARE_GLOBAL_DATA_PTR; + +static ulong at91_master_clk_get_rate(struct clk *clk) +{ + return gd->arch.mck_rate_hz; +} + +static struct clk_ops at91_master_clk_ops = { + .get_rate = at91_master_clk_get_rate, +}; + +static const struct udevice_id at91_master_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-master" }, + {} +}; + +U_BOOT_DRIVER(at91_master_clk) = { + .name = "at91-master-clk", + .id = UCLASS_CLK, + .of_match = at91_master_clk_match, + .ops = &at91_master_clk_ops, +}; diff --git a/drivers/clk/at91/clk-peripheral.c b/drivers/clk/at91/clk-peripheral.c new file mode 100644 index 0000000..16688e9 --- /dev/null +++ b/drivers/clk/at91/clk-peripheral.c @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +#define PERIPHERAL_ID_MIN 2 +#define PERIPHERAL_ID_MAX 31 +#define PERIPHERAL_MASK(id) (1 << ((id) & PERIPHERAL_ID_MAX)) + +static int sam9x5_periph_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + + if (clk->id < PERIPHERAL_ID_MIN) + return -1; + + writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr); + setbits_le32(&pmc->pcr, AT91_PMC_PCR_CMD_WRITE | AT91_PMC_PCR_EN); + + return 0; +} + +static struct clk_ops sam9x5_periph_clk_ops = { + .enable = sam9x5_periph_clk_enable, +}; + +static int sam9x5_periph_clk_bind(struct udevice *dev) +{ + return at91_pmc_clk_node_bind(dev); +} + +static int sam9x5_periph_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id sam9x5_periph_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-peripheral" }, + {} +}; + +U_BOOT_DRIVER(sam9x5_periph_clk) = { + .name = "sam9x5-periph-clk", + .id = UCLASS_CLK, + .of_match = sam9x5_periph_clk_match, + .bind = sam9x5_periph_clk_bind, + .probe = sam9x5_periph_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &sam9x5_periph_clk_ops, +}; diff --git a/drivers/clk/at91/clk-plla.c b/drivers/clk/at91/clk-plla.c new file mode 100644 index 0000000..2a71399 --- /dev/null +++ b/drivers/clk/at91/clk-plla.c @@ -0,0 +1,55 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int plla_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + + if (readl(&pmc->sr) & AT91_PMC_LOCKA) + return 0; + + return -EINVAL; +} + +static ulong plla_clk_get_rate(struct clk *clk) +{ + return gd->arch.plla_rate_hz; +} + +static struct clk_ops plla_clk_ops = { + .enable = plla_clk_enable, + .get_rate = plla_clk_get_rate, +}; + +static int plla_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id plla_clk_match[] = { + { .compatible = "atmel,sama5d3-clk-pll" }, + {} +}; + +U_BOOT_DRIVER(at91_plla_clk) = { + .name = "at91-plla-clk", + .id = UCLASS_CLK, + .of_match = plla_clk_match, + .probe = plla_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &plla_clk_ops, +}; diff --git a/drivers/clk/at91/clk-slow.c b/drivers/clk/at91/clk-slow.c new file mode 100644 index 0000000..f7666b4 --- /dev/null +++ b/drivers/clk/at91/clk-slow.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> + +static int at91_slow_clk_enable(struct clk *clk) +{ + return 0; +} + +static ulong at91_slow_clk_get_rate(struct clk *clk) +{ + return CONFIG_SYS_AT91_SLOW_CLOCK; +} + +static struct clk_ops at91_slow_clk_ops = { + .enable = at91_slow_clk_enable, + .get_rate = at91_slow_clk_get_rate, +}; + +static const struct udevice_id at91_slow_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-slow" }, + {} +}; + +U_BOOT_DRIVER(at91_slow_clk) = { + .name = "at91-slow-clk", + .id = UCLASS_CLK, + .of_match = at91_slow_clk_match, + .ops = &at91_slow_clk_ops, +}; diff --git a/drivers/clk/at91/clk-system.c b/drivers/clk/at91/clk-system.c new file mode 100644 index 0000000..fa80bad --- /dev/null +++ b/drivers/clk/at91/clk-system.c @@ -0,0 +1,76 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +#define SYSTEM_MAX_ID 31 + +static inline int is_pck(int id) +{ + return (id >= 8) && (id <= 15); +} + +static int at91_system_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + u32 mask; + + if (clk->id > SYSTEM_MAX_ID) + return -EINVAL; + + mask = BIT(clk->id); + + writel(mask, &pmc->scer); + + /** + * For the programmable clocks the Ready status in the PMC + * status register should be checked after enabling. + * For other clocks this is unnecessary. + */ + if (!is_pck(clk->id)) + return 0; + + while (!(readl(&pmc->sr) & mask)) + ; + + return 0; +} + +static struct clk_ops at91_system_clk_ops = { + .enable = at91_system_clk_enable, +}; + +static int at91_system_clk_bind(struct udevice *dev) +{ + return at91_pmc_clk_node_bind(dev); +} + +static int at91_system_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id at91_system_clk_match[] = { + { .compatible = "atmel,at91rm9200-clk-system" }, + {} +}; + +U_BOOT_DRIVER(at91_system_clk) = { + .name = "at91-system-clk", + .id = UCLASS_CLK, + .of_match = at91_system_clk_match, + .bind = at91_system_clk_bind, + .probe = at91_system_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &at91_system_clk_ops, +}; diff --git a/drivers/clk/at91/clk-utmi.c b/drivers/clk/at91/clk-utmi.c new file mode 100644 index 0000000..369a687 --- /dev/null +++ b/drivers/clk/at91/clk-utmi.c @@ -0,0 +1,67 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <linux/io.h> +#include <mach/at91_pmc.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define UTMI_FIXED_MUL 40 + +static int utmi_clk_enable(struct clk *clk) +{ + struct pmc_platdata *plat = dev_get_platdata(clk->dev); + struct at91_pmc *pmc = plat->reg_base; + u32 tmp; + + if (readl(&pmc->sr) & AT91_PMC_LOCKU) + return 0; + + tmp = readl(&pmc->uckr); + tmp |= AT91_PMC_UPLLEN | + AT91_PMC_UPLLCOUNT | + AT91_PMC_BIASEN; + writel(tmp, &pmc->uckr); + + while (!(readl(&pmc->sr) & AT91_PMC_LOCKU)) + ; + + return 0; +} + +static ulong utmi_clk_get_rate(struct clk *clk) +{ + return gd->arch.main_clk_rate_hz * UTMI_FIXED_MUL; +} + +static struct clk_ops utmi_clk_ops = { + .enable = utmi_clk_enable, + .get_rate = utmi_clk_get_rate, +}; + +static int utmi_clk_probe(struct udevice *dev) +{ + return at91_pmc_core_probe(dev); +} + +static const struct udevice_id utmi_clk_match[] = { + { .compatible = "atmel,at91sam9x5-clk-utmi" }, + {} +}; + +U_BOOT_DRIVER(at91sam9x5_utmi_clk) = { + .name = "at91sam9x5-utmi-clk", + .id = UCLASS_CLK, + .of_match = utmi_clk_match, + .probe = utmi_clk_probe, + .platdata_auto_alloc_size = sizeof(struct pmc_platdata), + .ops = &utmi_clk_ops, +}; diff --git a/drivers/clk/at91/pmc.c b/drivers/clk/at91/pmc.c new file mode 100644 index 0000000..a08d7e8 --- /dev/null +++ b/drivers/clk/at91/pmc.c @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/lists.h> +#include <dm/root.h> +#include "pmc.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int at91_pmc_bind(struct udevice *dev) +{ + return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); +} + +static const struct udevice_id at91_pmc_match[] = { + { .compatible = "atmel,sama5d2-pmc" }, + {} +}; + +U_BOOT_DRIVER(at91_pmc) = { + .name = "at91-pmc-core", + .id = UCLASS_CLK, + .of_match = at91_pmc_match, + .bind = at91_pmc_bind, +}; + +int at91_pmc_core_probe(struct udevice *dev) +{ + struct pmc_platdata *plat = dev_get_platdata(dev); + + dev = dev_get_parent(dev); + + plat->reg_base = (struct at91_pmc *)dev_get_addr_ptr(dev); + + return 0; +} + +int at91_pmc_clk_node_bind(struct udevice *dev) +{ + const void *fdt = gd->fdt_blob; + int offset = dev->of_offset; + const char *name; + int ret; + + for (offset = fdt_first_subnode(fdt, offset); + offset > 0; + offset = fdt_next_subnode(fdt, offset)) { + name = fdt_get_name(fdt, offset, NULL); + if (!name) + return -EINVAL; + + ret = device_bind_driver_to_node(dev, "clk", name, + offset, NULL); + if (ret) + return ret; + } + + return 0; +} + +U_BOOT_DRIVER(clk_generic) = { + .id = UCLASS_CLK, + .name = "clk", +}; diff --git a/drivers/clk/at91/pmc.h b/drivers/clk/at91/pmc.h new file mode 100644 index 0000000..5444c84 --- /dev/null +++ b/drivers/clk/at91/pmc.h @@ -0,0 +1,18 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __AT91_PMC_H__ +#define __AT91_PMC_H__ + +struct pmc_platdata { + struct at91_pmc *reg_base; +}; + +int at91_pmc_core_probe(struct udevice *dev); +int at91_pmc_clk_node_bind(struct udevice *dev); + +#endif diff --git a/drivers/clk/at91/sckc.c b/drivers/clk/at91/sckc.c new file mode 100644 index 0000000..b207611 --- /dev/null +++ b/drivers/clk/at91/sckc.c @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/root.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int at91_sckc_clk_bind(struct udevice *dev) +{ + return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); +} + +static const struct udevice_id at91_sckc_clk_match[] = { + { .compatible = "atmel,at91sam9x5-sckc" }, + {} +}; + +U_BOOT_DRIVER(at91_sckc_clk) = { + .name = "at91_sckc_clk", + .id = UCLASS_CLK, + .of_match = at91_sckc_clk_match, + .bind = at91_sckc_clk_bind, +};
Hi Andreas,
Do you have some comments?
Best Regards, Wenyou Yang
-----Original Message----- From: Wenyou Yang [mailto:wenyou.yang@atmel.com] Sent: 2016年7月20日 17:55 To: U-Boot Mailing List u-boot@lists.denx.de Cc: Stephen Warren swarren@nvidia.com; Andreas Bießmann andreas@biessmann.org; Simon Glass sjg@chromium.org; Wenyou Yang wenyou.yang@atmel.com Subject: [PATCH v5] clk: at91: Add clock driver
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach- at91/include/mach/at91_pmc.h index 680ceb0..2875ff2 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -149,6 +149,9 @@ typedef struct at91_pmc {
- bool "AT91 clock drivers"
- depends on CLK
- help
+config AT91_UTMI
- bool "Support UTMI PLL Clock"
- depends on CLK_AT91
- help
required by USB.
+config AT91_H32MX
- bool "Support H32MX 32-bit Matrix Clock"
- help
- bool "Support Generic Clock"
- help
+obj-y += pmc.o sckc.o +obj-y += clk-slow.o clk-main.o clk-plla.o clk-master.o obj-y += +clk-system.o clk-peripheral.o
- Copyright (C) 2016 Atmel Corporation
Wenyou.Yang <wenyou.yang@atmel.com>
- u32 num_parents;
+static ulong generated_clk_get_rate(struct clk *clk) {
- struct pmc_platdata *plat = dev_get_platdata(clk->dev);
- struct at91_pmc *pmc = plat->reg_base;
- struct clk parent;
- u32 tmp, gckdiv;
- u8 parent_id;
- int ret;
- writel(clk->id & AT91_PMC_PCR_PID_MASK, &pmc->pcr);
- tmp = readl(&pmc->pcr);
- parent_id = (tmp >> AT91_PMC_PCR_GCKCSS_OFFSET) &
- gckdiv = (tmp >> AT91_PMC_PCR_GCKDIV_OFFSET) &
+AT91_PMC_PCR_GCKDIV_MASK;
- ret = clk_get_by_index(clk->dev, parent_id, &parent);
- if (ret)
- return clk_get_rate(&parent) / (gckdiv + 1); }
+static ulong generated_clk_set_rate(struct clk *clk, ulong rate) {
- struct generated_clk_priv *priv = dev_get_priv(clk->dev);
- struct clk parent, best_parent;
- ulong tmp_rate, best_rate = rate, parent_rate;
- int tmp_diff, best_diff = -1;
- u32 div, best_div = 0;
- u8 best_parent_id = 0;
- u8 i;
- u32 tmp;
- int ret;
- for (i = 0; i < priv->num_parents; i++) {
if (ret)
return ret;
return parent_rate;
continue;
best_div = div - 1;
best_parent_id = i;
break;
if (!best_diff)
break;
- debug("GCK: best parent: %s, best_rate = %ld, best_div = %d\n",
- ret = clk_enable(&best_parent);
- if (ret)
return ret;
- tmp &= ~(AT91_PMC_PCR_GCKDIV | AT91_PMC_PCR_GCKCSS);
- tmp |= AT91_PMC_PCR_GCKCSS_(best_parent_id) |
AT91_PMC_PCR_GCKEN;
- writel(tmp, &pmc->pcr);
- while (!(readl(&pmc->sr) & AT91_PMC_GCKRDY))
- .get_rate = generated_clk_get_rate,
- .set_rate = generated_clk_set_rate,
+static int generated_clk_ofdata_to_platdata(struct udevice *dev) {
- struct generated_clk_priv *priv = dev_get_priv(dev);
- u32 cells[GENERATED_SOURCE_MAX];
- u32 num_parents;
- num_parents = fdtdec_get_int_array_count(gd->fdt_blob, dev->of_offset,
"clocks", cells,
- if (!num_parents)
return -1;
- priv->num_parents = num_parents;
+static int generated_clk_bind(struct udevice *dev) {
- return at91_pmc_clk_node_bind(dev);
+static int generated_clk_probe(struct udevice *dev) {
- return at91_pmc_core_probe(dev);
- { .compatible = "atmel,sama5d2-clk-generated" },
- .name = "generated-clk",
- .id = UCLASS_CLK,
- .of_match = generated_clk_match,
- .bind = generated_clk_bind,
- .probe = generated_clk_probe,
- .ofdata_to_platdata = generated_clk_ofdata_to_platdata,
- .priv_auto_alloc_size = sizeof(struct generated_clk_priv),
- .platdata_auto_alloc_size = sizeof(struct pmc_platdata),
- .ops = &generated_clk_ops,
+static ulong sama5d4_h32mx_clk_get_rate(struct clk *clk) {
- ulong rate = gd->arch.mck_rate_hz;
- if (readl(&pmc->mckr) & AT91_PMC_MCKR_H32MXDIV)
rate /= 2;
- if (rate > H32MX_MAX_FREQ)
- return rate;
- .get_rate = sama5d4_h32mx_clk_get_rate, };
+static int sama5d4_h32mx_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,sama5d4-clk-h32mx" },
- .name = "sama5d4-h32mx-clk",
- .id = UCLASS_CLK,
- .of_match = sama5d4_h32mx_clk_match,
- .probe = sama5d4_h32mx_clk_probe,
- .ops = &sama5d4_h32mx_clk_ops,
+static int main_osc_clk_enable(struct clk *clk) {
- if (readl(&pmc->sr) & AT91_PMC_MOSCSELS)
- return -EINVAL;
+static ulong main_osc_clk_get_rate(struct clk *clk) {
- return gd->arch.main_clk_rate_hz;
- .enable = main_osc_clk_enable,
- .get_rate = main_osc_clk_get_rate,
+static int main_osc_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,at91sam9x5-clk-main" },
- .name = "at91sam9x5-main-osc-clk",
- .id = UCLASS_CLK,
- .of_match = main_osc_clk_match,
- .probe = main_osc_clk_probe,
- .ops = &main_osc_clk_ops,
+static ulong at91_master_clk_get_rate(struct clk *clk) {
- return gd->arch.mck_rate_hz;
- .get_rate = at91_master_clk_get_rate,
- { .compatible = "atmel,at91sam9x5-clk-master" },
- .name = "at91-master-clk",
- .id = UCLASS_CLK,
- .of_match = at91_master_clk_match,
- .ops = &at91_master_clk_ops,
+static int sam9x5_periph_clk_enable(struct clk *clk) {
- if (clk->id < PERIPHERAL_ID_MIN)
return -1;
- setbits_le32(&pmc->pcr, AT91_PMC_PCR_CMD_WRITE |
AT91_PMC_PCR_EN);
- .enable = sam9x5_periph_clk_enable,
+static int sam9x5_periph_clk_bind(struct udevice *dev) {
+static int sam9x5_periph_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,at91sam9x5-clk-peripheral" },
- .name = "sam9x5-periph-clk",
- .id = UCLASS_CLK,
- .of_match = sam9x5_periph_clk_match,
- .bind = sam9x5_periph_clk_bind,
- .probe = sam9x5_periph_clk_probe,
- .ops = &sam9x5_periph_clk_ops,
+static int plla_clk_enable(struct clk *clk) {
- if (readl(&pmc->sr) & AT91_PMC_LOCKA)
- return -EINVAL;
+static ulong plla_clk_get_rate(struct clk *clk) {
- return gd->arch.plla_rate_hz;
- .enable = plla_clk_enable,
- .get_rate = plla_clk_get_rate,
+static int plla_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,sama5d3-clk-pll" },
- .name = "at91-plla-clk",
- .id = UCLASS_CLK,
- .of_match = plla_clk_match,
- .probe = plla_clk_probe,
- .ops = &plla_clk_ops,
+static int at91_slow_clk_enable(struct clk *clk) {
+static ulong at91_slow_clk_get_rate(struct clk *clk) {
- return CONFIG_SYS_AT91_SLOW_CLOCK;
- .enable = at91_slow_clk_enable,
- .get_rate = at91_slow_clk_get_rate,
- { .compatible = "atmel,at91sam9x5-clk-slow" },
- .name = "at91-slow-clk",
- .id = UCLASS_CLK,
- .of_match = at91_slow_clk_match,
- .ops = &at91_slow_clk_ops,
- return (id >= 8) && (id <= 15);
+static int at91_system_clk_enable(struct clk *clk) {
- u32 mask;
- if (clk->id > SYSTEM_MAX_ID)
return -EINVAL;
- mask = BIT(clk->id);
- writel(mask, &pmc->scer);
- if (!is_pck(clk->id))
- while (!(readl(&pmc->sr) & mask))
- .enable = at91_system_clk_enable,
+static int at91_system_clk_bind(struct udevice *dev) {
+static int at91_system_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,at91rm9200-clk-system" },
- .name = "at91-system-clk",
- .id = UCLASS_CLK,
- .of_match = at91_system_clk_match,
- .bind = at91_system_clk_bind,
- .probe = at91_system_clk_probe,
- .ops = &at91_system_clk_ops,
+static int utmi_clk_enable(struct clk *clk) {
- u32 tmp;
- if (readl(&pmc->sr) & AT91_PMC_LOCKU)
- tmp = readl(&pmc->uckr);
- tmp |= AT91_PMC_UPLLEN |
AT91_PMC_BIASEN;
- writel(tmp, &pmc->uckr);
- while (!(readl(&pmc->sr) & AT91_PMC_LOCKU))
+static ulong utmi_clk_get_rate(struct clk *clk) {
- return gd->arch.main_clk_rate_hz * UTMI_FIXED_MUL; }
- .enable = utmi_clk_enable,
- .get_rate = utmi_clk_get_rate,
+static int utmi_clk_probe(struct udevice *dev) {
- { .compatible = "atmel,at91sam9x5-clk-utmi" },
- .name = "at91sam9x5-utmi-clk",
- .id = UCLASS_CLK,
- .of_match = utmi_clk_match,
- .probe = utmi_clk_probe,
- .ops = &utmi_clk_ops,
+static int at91_pmc_bind(struct udevice *dev) {
- return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); }
- { .compatible = "atmel,sama5d2-pmc" },
- .name = "at91-pmc-core",
- .id = UCLASS_CLK,
- .of_match = at91_pmc_match,
- .bind = at91_pmc_bind,
+int at91_pmc_core_probe(struct udevice *dev) {
- struct pmc_platdata *plat = dev_get_platdata(dev);
- dev = dev_get_parent(dev);
- plat->reg_base = (struct at91_pmc *)dev_get_addr_ptr(dev);
+int at91_pmc_clk_node_bind(struct udevice *dev) {
- const void *fdt = gd->fdt_blob;
- int offset = dev->of_offset;
- const char *name;
- int ret;
- for (offset = fdt_first_subnode(fdt, offset);
offset > 0;
if (!name)
return -EINVAL;
offset, NULL);
if (ret)
return ret;
- .id = UCLASS_CLK,
- .name = "clk",
- struct at91_pmc *reg_base;
+int at91_pmc_core_probe(struct udevice *dev); int +at91_pmc_clk_node_bind(struct udevice *dev);
+static int at91_sckc_clk_bind(struct udevice *dev) {
- { .compatible = "atmel,at91sam9x5-sckc" },
- .name = "at91_sckc_clk",
- .id = UCLASS_CLK,
- .of_match = at91_sckc_clk_match,
- .bind = at91_sckc_clk_bind,
2.7.4
Dear Wenyou Yang,
Wenyou Yang wenyou.yang@atmel.com writes:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Wenyou Yang
Wenyou.Yang@microchip.com
