[U-Boot-Users] [PATCH] Handle Asynchronous DDR clock on 85xx
The MPC8572 introduces the concept of an asynchronous DDR clock with regards to the platform clock.
Introduce get_ddr_freq() to report the DDR freq regardless of sync/async mode.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
in my git tree.
cpu/mpc85xx/cpu.c | 16 +++++++++++++++- cpu/mpc85xx/spd_sdram.c | 6 +++--- cpu/mpc85xx/speed.c | 25 +++++++++++++++++++++++++ include/common.h | 1 + include/e500.h | 1 + 5 files changed, 45 insertions(+), 4 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index e55d337..ac8b018 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -39,6 +39,8 @@ int checkcpu (void) uint fam; uint ver; uint major, minor; + u32 ddr_ratio; + volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR);
svr = get_svr(); ver = SVR_VER(svr); @@ -102,7 +104,19 @@ int checkcpu (void) puts("Clock Configuration:\n"); printf(" CPU:%4lu MHz, ", sysinfo.freqProcessor / 1000000); printf("CCB:%4lu MHz,\n", sysinfo.freqSystemBus / 1000000); - printf(" DDR:%4lu MHz, ", sysinfo.freqSystemBus / 2000000); + + ddr_ratio = ((gur->porpllsr) & 0x00003e00) >> 9; + switch (ddr_ratio) { + case 0x0: + printf(" DDR:%4lu MHz, ", sysinfo.freqDDRBus / 2000000); + break; + case 0x7: + printf(" DDR:%4lu MHz (Synchronous), ", sysinfo.freqDDRBus / 2000000); + break; + default: + printf(" DDR:%4lu MHz (Asynchronous), ", sysinfo.freqDDRBus / 2000000); + break; + }
#if defined(CFG_LBC_LCRR) lcrr = CFG_LBC_LCRR; diff --git a/cpu/mpc85xx/spd_sdram.c b/cpu/mpc85xx/spd_sdram.c index 2a4cd57..553f736 100644 --- a/cpu/mpc85xx/spd_sdram.c +++ b/cpu/mpc85xx/spd_sdram.c @@ -53,8 +53,8 @@ picos_to_clk(int picos) { int clks;
- clks = picos / (2000000000 / (get_bus_freq(0) / 1000)); - if (picos % (2000000000 / (get_bus_freq(0) / 1000)) != 0) { + clks = picos / (2000000000 / (get_ddr_freq(0) / 1000)); + if (picos % (2000000000 / (get_ddr_freq(0) / 1000)) != 0) { clks++; }
@@ -421,7 +421,7 @@ spd_sdram(void) * Adjust the CAS Latency to allow for bus speeds that * are slower than the DDR module. */ - busfreq = get_bus_freq(0) / 1000000; /* MHz */ + busfreq = get_ddr_freq(0) / 1000000; /* MHz */
effective_data_rate = max_data_rate; if (busfreq < 90) { diff --git a/cpu/mpc85xx/speed.c b/cpu/mpc85xx/speed.c index 293269c..27de37a 100644 --- a/cpu/mpc85xx/speed.c +++ b/cpu/mpc85xx/speed.c @@ -48,6 +48,15 @@ void get_sys_info (sys_info_t * sysInfo) * overflow for processor speeds above 2GHz */ half_freqSystemBus = sysInfo->freqSystemBus/2; sysInfo->freqProcessor = e500_ratio*half_freqSystemBus; + sysInfo->freqDDRBus = sysInfo->freqSystemBus; + +#ifdef CONFIG_DDR_CLK_FREQ + { + u32 ddr_ratio = ((gur->porpllsr) & 0x00003e00) >> 9; + if (ddr_ratio != 0x7) + sysInfo->freqDDRBus = ddr_ratio * CONFIG_DDR_CLK_FREQ; + } +#endif }
@@ -93,3 +102,19 @@ ulong get_bus_freq (ulong dummy)
return val; } + +/******************************************** + * get_ddr_freq + * return ddr bus freq in Hz + *********************************************/ +ulong get_ddr_freq (ulong dummy) +{ + ulong val; + + sys_info_t sys_info; + + get_sys_info (&sys_info); + val = sys_info.freqDDRBus; + + return val; +} diff --git a/include/common.h b/include/common.h index 63ac8b0..01957e3 100644 --- a/include/common.h +++ b/include/common.h @@ -497,6 +497,7 @@ ulong get_bus_freq (ulong); #if defined(CONFIG_MPC85xx) typedef MPC85xx_SYS_INFO sys_info_t; void get_sys_info ( sys_info_t * ); +ulong get_ddr_freq (ulong); #endif #if defined(CONFIG_MPC86xx) typedef MPC86xx_SYS_INFO sys_info_t; diff --git a/include/e500.h b/include/e500.h index 8e3bf8c..0d73260 100644 --- a/include/e500.h +++ b/include/e500.h @@ -12,6 +12,7 @@ typedef struct { unsigned long freqProcessor; unsigned long freqSystemBus; + unsigned long freqDDRBus; } MPC85xx_SYS_INFO;
#endif /* _ASMLANGUAGE */
Kumar Gala
