[U-Boot] [PATCH v4 1/7] ppc/p4080: Add p4080 platform immap definitions
The p4080 SoC has a significant amount of commonality with the 85xx/PQ3 platform. We reuse the 85xx immap and just add new definitions for local access and global utils. The global utils is now broken into global utils, clocking and run control/power management.
The offsets from CCSR for a number of blocks have also changed. We introduce the CONFIG_FSL_CORENET define to distinquish the PQ3 style of platform from the new p4080 platform. We don't use QoirQ as there are products (like p2020) that are PQ3 based platforms but have the QoirQ name.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/asm-ppc/fsl_lbc.h | 4 + include/asm-ppc/immap_85xx.h | 287 +++++++++++++++++++++++++++++++++++++++--- 2 files changed, 271 insertions(+), 20 deletions(-)
diff --git a/include/asm-ppc/fsl_lbc.h b/include/asm-ppc/fsl_lbc.h index 08d31e1..5723de6 100644 --- a/include/asm-ppc/fsl_lbc.h +++ b/include/asm-ppc/fsl_lbc.h @@ -317,6 +317,10 @@ #define LCRR_CLKDIV_2 0x00000002 #define LCRR_CLKDIV_4 0x00000004 #define LCRR_CLKDIV_8 0x00000008 +#elif defined(CONFIG_FSL_CORENET) +#define LCRR_CLKDIV_8 0x00000002 +#define LCRR_CLKDIV_16 0x00000004 +#define LCRR_CLKDIV_32 0x00000008 #else #define LCRR_CLKDIV_4 0x00000002 #define LCRR_CLKDIV_8 0x00000004 diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index e7d412d..3e6ed85 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -16,6 +16,29 @@ #include <asm/fsl_i2c.h> #include <asm/fsl_lbc.h>
+typedef struct ccsr_local { + u32 ccsrbarh; /* 0x0 - Control Configuration Status Registers Base Address Register High */ + u32 ccsrbarl; /* 0x4 - Control Configuration Status Registers Base Address Register Low */ + u32 ccsrar; /* 0x8 - Configuration, Control, and Status Attribute Register */ +#define CCSRAR_C 0x80000000 /* Commit */ + u8 res1[4]; + u32 altcbarh; /* 0x10 - Alternate Configuration Base Address Register High */ + u32 altcbarl; /* 0x14 - Alternate Configuration Base Address Register Low */ + u32 altcar; /* 0x18 - Alternate Configuration Attribute Register */ + u8 res2[4]; + u32 bstrh; /* 0x20 - Boot space translation register high */ + u32 bstrl; /* 0x24 - Boot space translation register Low */ + u32 bstrar; /* 0x28 - Boot space translation attributes register */ + u8 res3[0xbd4]; + struct { + u32 lawbarh; /* 0xc00 + n * 0x10 - LAW0 base address register high */ + u32 lawbarl; /* 0xc04 + n * 0x10 - LAW0 base address register low */ + u32 lawar; /* 0xc08 + n * 0x10 - LAW0 attributes register */ + u8 res4[4]; + } law[32]; + u8 res35[0x204]; +} ccsr_local_t; + /* * Local-Access Registers and ECM Registers(0x0000-0x2000) */ @@ -165,7 +188,21 @@ typedef struct ccsr_ddr { uint debug_2; uint debug_3; uint debug_4; - char res12[240]; + uint debug_5; + uint debug_6; + uint debug_7; + uint debug_8; + uint debug_9; + uint debug_10; + uint debug_11; + uint debug_12; + uint debug_13; /* +0xF30 */ + uint debug_14; + uint debug_15; + uint debug_16; + uint debug_17; + uint debug_18; /* +0xF44 */ + char res12[184]; } ccsr_ddr_t;
/* @@ -1531,6 +1568,193 @@ typedef struct par_io { /* * Global Utilities Register Block(0xe_0000-0xf_ffff) */ +#ifdef CONFIG_FSL_CORENET +typedef struct ccsr_gur { + u32 porsr1; /* 0xe0000 - POR status register */ + u8 res1[28]; /* 0xe0004 - 0xe001c Reserved: PORSRn */ + u32 gpporcr1; /* 0xe0020 - General-purpose POR configuration register */ + u8 res2[12]; + u32 gpiocr; /* 0xe0030 - GPIO control register */ + u8 res3[12]; + u32 gpoutdr; /* 0xe0040 - General-purpose output data register */ + u8 res4[12]; + u32 gpindr; /* 0xe0050 - General-purpose input data register */ + u8 res5[12]; + u32 pmuxcr; /* 0xe0060 - Alternate function signal multiplex control */ + u8 res6[12]; + u32 devdisr; /* 0xe0070 - Device disable control */ +#define FSL_CORENET_DEVDISR_PCIE1 0x80000000 +#define FSL_CORENET_DEVDISR_PCIE2 0x40000000 +#define FSL_CORENET_DEVDISR_PCIE3 0x20000000 +#define FSL_CORENET_DEVDISR_RMU 0x08000000 +#define FSL_CORENET_DEVDISR_SRIO1 0x04000000 +#define FSL_CORENET_DEVDISR_SRIO2 0x02000000 +#define FSL_CORENET_DEVDISR_DMA1 0x00400000 +#define FSL_CORENET_DEVDISR_DMA2 0x00200000 +#define FSL_CORENET_DEVDISR_DDR1 0x00100000 +#define FSL_CORENET_DEVDISR_DDR2 0x00080000 +#define FSL_CORENET_DEVDISR_DBG 0x00010000 +#define FSL_CORENET_DEVDISR_NAL 0x00008000 +#define FSL_CORENET_DEVDISR_ELBC 0x00001000 +#define FSL_CORENET_DEVDISR_USB1 0x00000800 +#define FSL_CORENET_DEVDISR_USB2 0x00000400 +#define FSL_CORENET_DEVDISR_ESDHC 0x00000100 +#define FSL_CORENET_DEVDISR_GPIO 0x00000080 +#define FSL_CORENET_DEVDISR_ESPI 0x00000040 +#define FSL_CORENET_DEVDISR_I2C1 0x00000020 +#define FSL_CORENET_DEVDISR_I2C2 0x00000010 +#define FSL_CORENET_DEVDISR_DUART1 0x00000002 +#define FSL_CORENET_DEVDISR_DUART2 0x00000001 + u8 res7[12]; + u32 powmgtcsr; /* 0xe0080 - Power management status and control register */ + u8 res8[12]; + u32 coredisru; /* 0xe0090 - uppper portion for support of 64 cores */ + u32 coredisrl; /* 0xe0094 - lower portion for support of 64 cores */ + u8 res9[8]; + u32 pvr; /* 0xe00a0 - Processor version register */ + u32 svr; /* 0xe00a4 - System version register */ + u8 res10[8]; + u32 rstcr; /* 0xe00b0 - Reset control register */ + u32 rstrqpblsr; /* 0xe00b4 - Reset request preboot loader status register */ + u8 res11[8]; + u32 rstrqmr1; /* 0xe00c0 - Reset request mask register */ + u8 res12[4]; /* Reserved: RSTRQMR2 */ + u32 rstrqsr1; /* 0xe00c8 - Reset request status register */ + u8 res13[4]; /* Reserved: RSTRQSR2 */ + u8 res14[4]; /* Reserved: RSTRQWDTMRU */ + u32 rstrqwdtmrl; /* 0xe00d4 - Reset request WDT mask register */ + u8 res15[4]; /* Reserved: RSTRQWDTSRU */ + u32 rstrqwdtsrl; /* 0xe00dc - Reset request WDT status register */ + u8 res16[4]; /* Reserved: BRRU max total of 2 for up to 64 cores */ + u32 brrl; /* 0xe00e4 Boot release register */ + u8 res17[24]; + u32 rcwsr[16]; /* 0xe0100 - 0xe013c: Reset control word status register */ +#define FSL_CORENET_RCWSR4_SRDS_PRTCL 0xfc000000 +#define FSL_CORENET_RCWSR5_DDR_SYNC 0x00008000 +#define FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT 15 +#define FSL_CORENET_RCWSR7_MCK_TO_PLAT_RAT 0x00400000 +#define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 +#define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 + u8 res18[192]; /* Reserved: RCWSRn (max total of 64)*/ + u32 scratchrw[4]; /* 0xe0200 - 0xe020c: Scratch Read/Write register */ + u8 res19[240]; /* Reserved: SCRATCHRWn (max total of 64)*/ + u32 scratchw1r[4]; /* 0xe0300 - 0xe030c: Scratch Read register (Write once) */ + u8 res20[240]; /* Reserved: SCRATCHW1Rn (max total of 64)*/ + u32 scrtsr[8]; /* 0xe0400 - 0xe041c: Core reset status register */ + u8 res21[224]; /* Reserved: CRSTSRn (max total of 64 for up to 64 cores)*/ + u32 pex1liodnr; /* 0xe0500 PCI Express 1 Logical I/O Device Number register*/ + u32 pex2liodnr; /* 0xe0504 PCI Express 2 Logical I/O Device Number register*/ + u32 pex3liodnr; /* 0xe0508 PCI Express 3 Logical I/O Device Number register*/ + u32 pex4liodnr; /* 0xe050c PCI Express 4 Logical I/O Device Number register*/ + u32 rio1liodnr; /* 0xe0510 RIO 1 Logical I/O Device Number register*/ + u32 rio2liodnr; /* 0xe0514 RIO 2 Logical I/O Device Number register*/ + u32 rio3liodnr; /* 0xe0518 RIO 3 Logical I/O Device Number register*/ + u32 rio4liodnr; /* 0xe051c RIO 4 Logical I/O Device Number register*/ + u32 usb1liodnr; /* 0xe0520 USB 1 Logical I/O Device Number register*/ + u32 usb2liodnr; /* 0xe0524 USB 2 Logical I/O Device Number register*/ + u32 usb3liodnr; /* 0xe0528 USB 3 Logical I/O Device Number register*/ + u32 usb4liodnr; /* 0xe052c USB 4 Logical I/O Device Number register*/ + u32 sdmmc1liodnr; /* 0xe0530 SD/MMC 1 Logical I/O Device Number register*/ + u32 sdmmc2liodnr; /* 0xe0534 SD/MMC 2 Logical I/O Device Number register*/ + u32 sdmmc3liodnr; /* 0xe0538 SD/MMC 3 Logical I/O Device Number register*/ + u32 sdmmc4liodnr; /* 0xe053c SD/MMC 4 Logical I/O Device Number register*/ + u32 rmuliodnr; /* 0xe0540 RIO Message Unit Logical I/O Device Number register*/ + u32 rduliodnr; /* 0xe0544 RIO Doorbell Unit Logical I/O Device Number register*/ + u32 rpwuliodnr; /* 0xe0548 RIO Port Write Unit Logical I/O Device Number register*/ + u8 res22[52]; /* Reserved: for future LIODN register expansion */ + u32 dma1liodnr; /* 0xe0580 DMA 1 Logical I/O Device Number register*/ + u32 dma2liodnr; /* 0xe0584 DMA 2 Logical I/O Device Number register*/ + u32 dma3liodnr; /* 0xe0588 DMA 3 Logical I/O Device Number register*/ + u32 dma4liodnr; /* 0xe058c DMA 4 Logical I/O Device Number register*/ + u8 res23[48]; /* Reserved: for future LIODN register expansion */ + u8 res24[64]; /* Reserved */ + u32 pblsr; /* 0xe0600 Preboot loader status register*/ + u32 pamubypenr; /* 0xe0604 PAMU bypass enable register*/ + u32 dmacr1; /* 0xe0608 DMA control register*/ + u8 res25[4]; /* Reserved: DMACR2 (max total of 2)*/ + u32 gensr1; /* 0xe0610 General status register*/ + u8 res26[12]; /* Reserved: GENSRn (max total of 4)*/ + u32 gencr1; /* 0xe0620 General control register*/ + u8 res27[12]; /* Reserved: GENCRn (max total of 4)*/ + u8 res28[4]; /* Reserved: CGENSRU (upper portion for support of 64 cores) */ + u32 cgensrl; /* 0xe0634 Core general status register*/ + u8 res29[8]; /* Reserved */ + u8 res30[4]; /* Reserved: CGENCRU (upper portion for support of 64 cores) */ + u32 cgencrl; /* 0xe0634 Core general control register*/ + u8 res31[184]; /* Reserved 0xe0648 - 0xe06fc */ + u32 sriopstecr; /* 0xe0700 SRIO prescaler timer enable control register*/ + u8 res32[2300]; /* Reserved 0xe0704 - 0xe0ffc */ +} ccsr_gur_t; + +typedef struct ccsr_clk { + u32 clkc0csr; /* 0xe1000 - Core 0 Clock control/status register */ + u8 res1[0x1c]; + u32 clkc1csr; /* 0xe1020 - Core 1 Clock control/status register */ + u8 res2[0x1c]; + u32 clkc2csr; /* 0xe1040 - Core 2 Clock control/status register */ + u8 res3[0x1c]; + u32 clkc3csr; /* 0xe1060 - Core 3 Clock control/status register */ + u8 res4[0x1c]; + u32 clkc4csr; /* 0xe1080 - Core 4 Clock control/status register */ + u8 res5[0x1c]; + u32 clkc5csr; /* 0xe10a0 - Core 5 Clock control/status register */ + u8 res6[0x1c]; + u32 clkc6csr; /* 0xe10c0 - Core 6 Clock control/status register */ + u8 res7[0x1c]; + u32 clkc7csr; /* 0xe10e0 - Core 7 Clock control/status register */ + u8 res8[0x71c]; + u32 pllc1gsr; /* 0xe1800 - Cluster PLL 1 General Status Register */ + u8 res10[0x1c]; + u32 pllc2gsr; /* 0xe1820 - Cluster PLL 2 General Status Register */ + u8 res11[0x1c]; + u32 pllc3gsr; /* 0xe1840 - Cluster PLL 3 General Status Register */ + u8 res12[0x1c]; + u32 pllc4gsr; /* 0xe1860 - Cluster PLL 4 General Status Register */ + u8 res13[0x39c]; + u32 pllpgsr; /* 0xe1c00 - Platform PLL General Status Register */ + u8 res14[0x1c]; + u32 plldgsr; /* 0xe1c20 - DDR PLL General Status Register */ + u8 res15[0x3dc]; +} ccsr_clk_t; + +typedef struct ccsr_rcpm { + u8 res1[4]; /* 0xe2000 - Reserved */ + u32 cdozsrl; /* 0xe2004 - Core Doze Status Register */ + u8 res2[4]; /* 0xe2008 - Reserved */ + u32 cdozcrl; /* 0xe200c - Core Doze Control Register */ + u8 res3[4]; /* 0xe2010 - Reserved */ + u32 cnapsrl; /* 0xe2014 - Core Nap Status Register */ + u8 res4[4]; /* 0xe2018 - Reserved */ + u32 cnapcrl; /* 0xe201c - Core Nap Control Register */ + u8 res5[4]; /* 0xe2020 - Reserved */ + u32 cdozpsrl; /* 0xe2024 - Core Doze Previous Status Register */ + u8 res6[4]; /* 0xe2028 - Reserved */ + u32 cdozpcrl; /* 0xe202c - Core Doze Previous Control Register */ + u8 res7[4]; /* 0xe2030 - Reserved */ + u32 cwaitsrl; /* 0xe2034 - Core Wait Status Register */ + u8 res8[8]; /* Reserved */ + u32 powmgtcsr; /* 0xe2040 - Power Mangement Control & Status Register */ + u8 res9[12]; /* Reserved */ + u32 ippdexpcr0; /* 0xe2050 - IP Powerdown Exception Control Register 0 */ + u8 res10[12]; /* Reserved */ + u8 res11[4]; /* Reserved */ + u32 cpmimrl; /* 0xe2064 - Core Power Management Interrupt Masking Register */ + u8 res12[4]; /* Reserved */ + u32 cpmcimrl; /* 0xe206c - Core Power Management Critical Interrupt Masking Register */ + u8 res13[4]; /* Reserved */ + u32 cpmmcimrl; /* 0xe2074 - Core Power Management Machine Check Interrupt Masking Register */ + u8 res14[4]; /* Reserved */ + u32 cpmnmimrl; /* 0xe207c - Core Power Management NMI Masking Register */ + u8 res15[4]; /* Reserved */ + u32 ctbenrl; /* 0xe2084 - Core Time Base Enable Register */ + u8 res16[4]; /* Reserved */ + u32 ctbclkselrl; /* 0xe208c - Core Time Base Clock Select Register */ + u8 res17[4]; /* Reserved */ + u32 ctbhltcrl; /* 0xe2094 - Core Time Base Halt Control Register */ + u8 res18[0xf68]; +} ccsr_rcpm_t; + +#else typedef struct ccsr_gur { uint porpllsr; /* 0xe0000 - POR PLL ratio status register */ #ifdef CONFIG_MPC8536 @@ -1645,42 +1869,65 @@ typedef struct ccsr_gur { uint tsec34ioovcr; /* 0xe0f2c - eTSEC 3/4 IO override control */ char res15[61648]; /* 0xe0f30 to 0xefffff */ } ccsr_gur_t; +#endif + +#ifdef CONFIG_FSL_CORENET +#define CONFIG_SYS_FSL_CORENET_CCM_OFFSET 0x0000 +#define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x8000 +#define CONFIG_SYS_MPC85xx_DDR2_OFFSET 0x9000 +#define CONFIG_SYS_FSL_CORENET_CLK_OFFSET 0xE1000 +#define CONFIG_SYS_FSL_CORENET_RCPM_OFFSET 0xE2000 +#define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x100000 +#define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x110000 +#define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 +#define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 +#define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 +#define CONFIG_SYS_MPC85xx_QMAN_OFFSET 0x318000 +#define CONFIG_SYS_MPC85xx_BMAN_OFFSET 0x31a000 +#else +#define CONFIG_SYS_MPC85xx_ECM_OFFSET 0x0000 +#define CONFIG_SYS_MPC85xx_DDR_OFFSET 0x2000 +#define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x5000 +#define CONFIG_SYS_MPC85xx_DDR2_OFFSET 0x6000 +#define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x7000 +#define CONFIG_SYS_MPC85xx_PCIX_OFFSET 0x8000 +#define CONFIG_SYS_MPC85xx_PCIX2_OFFSET 0x9000 +#define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0xF000 +#define CONFIG_SYS_MPC85xx_SATA1_OFFSET 0x18000 +#define CONFIG_SYS_MPC85xx_SATA2_OFFSET 0x19000 +#define CONFIG_SYS_MPC85xx_L2_OFFSET 0x20000 +#define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x21000 +#define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x2e000 +#define CONFIG_SYS_MPC85xx_SERDES2_OFFSET 0xE3100 +#define CONFIG_SYS_MPC85xx_SERDES1_OFFSET 0xE3000 +#define CONFIG_SYS_MPC85xx_CPM_OFFSET 0x80000 +#endif + +#define CONFIG_SYS_MPC85xx_PIC_OFFSET 0x40000 +#define CONFIG_SYS_MPC85xx_GUTS_OFFSET 0xE0000
-#define CONFIG_SYS_MPC85xx_GUTS_OFFSET (0xE0000) +#define CONFIG_SYS_MPC85xx_QMAN_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_QMAN_OFFSET) +#define CONFIG_SYS_MPC85xx_BMAN_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_BMAN_OFFSET) #define CONFIG_SYS_MPC85xx_GUTS_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GUTS_OFFSET) -#define CONFIG_SYS_MPC85xx_ECM_OFFSET (0x0000) +#define CONFIG_SYS_FSL_CORENET_CCM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CCM_OFFSET) +#define CONFIG_SYS_FSL_CORENET_CLK_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_CLK_OFFSET) +#define CONFIG_SYS_FSL_CORENET_RCPM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_RCPM_OFFSET) #define CONFIG_SYS_MPC85xx_ECM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ECM_OFFSET) -#define CONFIG_SYS_MPC85xx_DDR_OFFSET (0x2000) #define CONFIG_SYS_MPC85xx_DDR_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR_OFFSET) -#define CONFIG_SYS_MPC85xx_DDR2_OFFSET (0x6000) #define CONFIG_SYS_MPC85xx_DDR2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DDR2_OFFSET) -#define CONFIG_SYS_MPC85xx_LBC_OFFSET (0x5000) #define CONFIG_SYS_MPC85xx_LBC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_LBC_OFFSET) -#define CONFIG_SYS_MPC85xx_ESPI_OFFSET (0x7000) #define CONFIG_SYS_MPC85xx_ESPI_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESPI_OFFSET) -#define CONFIG_SYS_MPC85xx_PCIX_OFFSET (0x8000) #define CONFIG_SYS_MPC85xx_PCIX_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX_OFFSET) -#define CONFIG_SYS_MPC85xx_PCIX2_OFFSET (0x9000) #define CONFIG_SYS_MPC85xx_PCIX2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PCIX2_OFFSET) -#define CONFIG_SYS_MPC85xx_GPIO_OFFSET (0xF000) -#define CONFIG_SYS_MPC85xx_GPIO_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GPIO_OFFSET) -#define CONFIG_SYS_MPC85xx_SATA1_OFFSET (0x18000) +#define CONFIG_SYS_MPC85xx_GPIO_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_GPIO_OFFSET) #define CONFIG_SYS_MPC85xx_SATA1_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA1_OFFSET) -#define CONFIG_SYS_MPC85xx_SATA2_OFFSET (0x19000) #define CONFIG_SYS_MPC85xx_SATA2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SATA2_OFFSET) -#define CONFIG_SYS_MPC85xx_L2_OFFSET (0x20000) #define CONFIG_SYS_MPC85xx_L2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_L2_OFFSET) -#define CONFIG_SYS_MPC85xx_DMA_OFFSET (0x21000) #define CONFIG_SYS_MPC85xx_DMA_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_DMA_OFFSET) -#define CONFIG_SYS_MPC85xx_ESDHC_OFFSET (0x2e000) #define CONFIG_SYS_MPC85xx_ESDHC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESDHC_OFFSET) -#define CONFIG_SYS_MPC85xx_PIC_OFFSET (0x40000) #define CONFIG_SYS_MPC85xx_PIC_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PIC_OFFSET) -#define CONFIG_SYS_MPC85xx_CPM_OFFSET (0x80000) #define CONFIG_SYS_MPC85xx_CPM_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_CPM_OFFSET) -#define CONFIG_SYS_MPC85xx_SERDES1_OFFSET (0xE3000) #define CONFIG_SYS_MPC85xx_SERDES1_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) -#define CONFIG_SYS_MPC85xx_SERDES2_OFFSET (0xE3100) #define CONFIG_SYS_MPC85xx_SERDES2_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES2_OFFSET) #define CONFIG_SYS_MPC85xx_USB_OFFSET 0x22000 #define CONFIG_SYS_MPC85xx_USB_ADDR \
On CoreNet based platforms the LAW address is split between an high & low register and we no longer shift the address. Also, the target IDs on CoreNet platforms have been completely re-assigned.
Additionally, added a new find_law() API to which LAW an address hits in. This is need for the CoreNet style boot release code since it will need to determine what the target ID should be set to for boot window translation.
Finally, enamed LAWAR_EN to LAW_EN and moved to header so we can use it elsewhere.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Added rename of LAWAR_EN -> LAW_EN
drivers/misc/fsl_law.c | 96 +++++++++++++++++++++++++++++++++++++++++++- include/asm-ppc/fsl_law.h | 31 ++++++++++++++ 2 files changed, 124 insertions(+), 3 deletions(-)
diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index aa877c6..10cfbf8 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008-2009 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -29,7 +29,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define LAWAR_EN 0x80000000 /* number of LAWs in the hw implementation */ #if defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ defined(CONFIG_MPC8560) || defined(CONFIG_MPC8555) @@ -48,6 +47,20 @@ DECLARE_GLOBAL_DATA_PTR;
void set_law(u8 idx, phys_addr_t addr, enum law_size sz, enum law_trgt_if id) { +#ifdef CONFIG_FSL_CORENET + volatile ccsr_local_t *ccm = + (void *)(CONFIG_SYS_FSL_CORENET_CCM_ADDR); + + gd->used_laws |= (1 << idx); + + out_be32(&ccm->law[idx].lawar, 0); + out_be32(&ccm->law[idx].lawbarh, ((u64)addr >> 32)); + out_be32(&ccm->law[idx].lawbarl, addr & 0xffffffff); + out_be32(&ccm->law[idx].lawar, LAW_EN | ((u32)id << 20) | (u32)sz); + + /* Read back so that we sync the writes */ + in_be32(&ccm->law[idx].lawar); +#else volatile u32 *base = (volatile u32 *)(CONFIG_SYS_IMMR + 0xc08); volatile u32 *lawbar = base + 8 * idx; volatile u32 *lawar = base + 8 * idx + 2; @@ -56,10 +69,11 @@ void set_law(u8 idx, phys_addr_t addr, enum law_size sz, enum law_trgt_if id)
out_be32(lawar, 0); out_be32(lawbar, addr >> 12); - out_be32(lawar, LAWAR_EN | ((u32)id << 20) | (u32)sz); + out_be32(lawar, LAW_EN | ((u32)id << 20) | (u32)sz);
/* Read back so that we sync the writes */ in_be32(lawar); +#endif }
int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) @@ -96,6 +110,19 @@ int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id)
void disable_law(u8 idx) { +#ifdef CONFIG_FSL_CORENET + volatile ccsr_local_t *ccm = + (void *)(CONFIG_SYS_FSL_CORENET_CCM_ADDR); + + gd->used_laws &= ~(1 << idx); + + out_be32(&ccm->law[idx].lawar, 0); + out_be32(&ccm->law[idx].lawbarh, 0); + out_be32(&ccm->law[idx].lawbarl, 0); + + /* Read back so that we sync the writes */ + in_be32(&ccm->law[idx].lawar); +#else volatile u32 *base = (volatile u32 *)(CONFIG_SYS_IMMR + 0xc08); volatile u32 *lawbar = base + 8 * idx; volatile u32 *lawar = base + 8 * idx + 2; @@ -105,9 +132,66 @@ void disable_law(u8 idx) out_be32(lawar, 0); out_be32(lawbar, 0);
+ /* Read back so that we sync the writes */ + in_be32(lawar); +#endif + return; }
+#ifdef CONFIG_FSL_CORENET +#define GET_LAW_ADDR ((u64)in_be32(lawbarh) << 32) | in_be32(lawbarl) +#else +#define GET_LAW_ADDR ((u64)in_be32(lawbar) << 12) +#endif + +struct law_entry find_law(phys_addr_t addr) +{ + struct law_entry entry; + int i; + + entry.index = -1; + entry.addr = 0; + entry.size = 0; + entry.trgt_id = 0; + + for(i = 0; i < FSL_HW_NUM_LAWS; i++) { + + u64 upper; + u32 temp; +#ifdef CONFIG_FSL_CORENET + volatile ccsr_local_t *ccm; + volatile u32 *lawbarh, *lawbarl, *lawar; + + ccm = (void *)(CONFIG_SYS_FSL_CORENET_CCM_ADDR); + + lawbarh = &ccm->law[i].lawbarh; + lawbarl = &ccm->law[i].lawbarl; + lawar = &ccm->law[i].lawar; +#else + volatile u32 *base = (volatile u32 *)(CONFIG_SYS_IMMR + 0xc08); + volatile u32 *lawbar = base + 8 * i; + volatile u32 *lawar = base + 8 * i + 2; +#endif + temp = in_be32(lawar); + + if (!(temp & LAW_EN)) + continue; + + entry.addr = GET_LAW_ADDR; + entry.size = temp & 0x3f; + entry.trgt_id = (temp >> 20) & 0xff; + + upper = entry.addr + (2ull << entry.size); + if ((addr >= entry.addr) && (addr < upper)) { + entry.index = i; + break; + } + } + + return entry; +} + void print_laws(void) { volatile u32 *base = (volatile u32 *)(CONFIG_SYS_IMMR + 0xc08); @@ -173,7 +257,13 @@ void init_laws(void) { int i;
+#if FSL_HW_NUM_LAWS < 32 gd->used_laws = ~((1 << FSL_HW_NUM_LAWS) - 1); +#elif FSL_HW_NUM_LAWS == 32 + gd->used_laws = 0; +#else +#error FSL_HW_NUM_LAWS can not be greater than 32 w/o code changes +#endif
for (i = 0; i < num_law_entries; i++) { if (law_table[i].index == -1) diff --git a/include/asm-ppc/fsl_law.h b/include/asm-ppc/fsl_law.h index e06a1a6..31bb754 100644 --- a/include/asm-ppc/fsl_law.h +++ b/include/asm-ppc/fsl_law.h @@ -1,8 +1,18 @@ +/* + * Copyright 2008-2009 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + #ifndef _FSL_LAW_H_ #define _FSL_LAW_H_
#include <asm/io.h>
+#define LAW_EN 0x80000000 + #define SET_LAW_ENTRY(idx, a, sz, trgt) \ { .index = idx, .addr = a, .size = sz, .trgt_id = trgt }
@@ -36,6 +46,25 @@ enum law_size { LAW_SIZE_32G, };
+#ifdef CONFIG_FSL_CORENET +enum law_trgt_if { + LAW_TRGT_IF_PCIE_1 = 0x00, + LAW_TRGT_IF_PCIE_2 = 0x01, + LAW_TRGT_IF_PCIE_3 = 0x02, + LAW_TRGT_IF_RIO_1 = 0x08, + LAW_TRGT_IF_RIO_2 = 0x09, + + LAW_TRGT_IF_DDR_1 = 0x10, + LAW_TRGT_IF_DDR_2 = 0x11, /* 2nd controller */ + LAW_TRGT_IF_DDR_INTRLV = 0x14, + + LAW_TRGT_IF_BMAN = 0x18, + LAW_TRGT_IF_DCSR = 0x1d, + LAW_TRGT_IF_LBC = 0x1f, + LAW_TRGT_IF_QMAN = 0x3c, +}; +#define LAW_TRGT_IF_DDR LAW_TRGT_IF_DDR_1 +#else enum law_trgt_if { LAW_TRGT_IF_PCI = 0x00, LAW_TRGT_IF_PCI_2 = 0x01, @@ -64,6 +93,7 @@ enum law_trgt_if { #if defined(CONFIG_MPC8572) || defined(CONFIG_P2020) #define LAW_TRGT_IF_PCIE_3 LAW_TRGT_IF_PCI #endif +#endif /* CONFIG_FSL_CORENET */
struct law_entry { int index; @@ -76,6 +106,7 @@ extern void set_law(u8 idx, phys_addr_t addr, enum law_size sz, enum law_trgt_if extern int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id); extern int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id); extern int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id); +extern struct law_entry find_law(phys_addr_t addr); extern void disable_law(u8 idx); extern void init_laws(void); extern void print_laws(void);
On CoreNet based platforms the CCSRBAR address is split between an high & low register and we no longer shift the address.
Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: Scott Wood scottwood@freescale.com --- * Fixup for LAW_EN
cpu/mpc85xx/cpu_init_early.c | 29 +++++++++++++++++++++++++++++ 1 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/cpu_init_early.c b/cpu/mpc85xx/cpu_init_early.c index 7886f86..a12847d 100644 --- a/cpu/mpc85xx/cpu_init_early.c +++ b/cpu/mpc85xx/cpu_init_early.c @@ -54,6 +54,9 @@ void cpu_init_early_f(void) u32 temp; volatile u32 *ccsr_virt = (volatile u32 *)(CONFIG_SYS_CCSRBAR + 0x1000); +#ifdef CONFIG_FSL_CORENET + volatile ccsr_local_t *ccm; +#endif
mas0 = MAS0_TLBSEL(0) | MAS0_ESEL(1); /* mas1 is the same as above */ @@ -64,9 +67,35 @@ void cpu_init_early_f(void)
write_tlb(mas0, mas1, mas2, mas3, mas7);
+#ifdef CONFIG_FSL_CORENET + /* + * We can't call set_law() because we haven't moved + * CCSR yet. + */ + ccm = (void *)ccsr_virt; + + out_be32(&ccm->law[0].lawbarh, + (u64)CONFIG_SYS_CCSRBAR_PHYS >> 32); + out_be32(&ccm->law[0].lawbarl, (u32)CONFIG_SYS_CCSRBAR_PHYS); + out_be32(&ccm->law[0].lawar, + LAW_EN | (0x1e << 20) | LAW_SIZE_4K); + + in_be32((u32 *)(ccsr_virt + 0)); + in_be32((u32 *)(ccsr_virt + 1)); + isync(); + + ccm = (void *)CONFIG_SYS_CCSRBAR; + /* Now use the temporary LAW to move CCSR */ + out_be32(&ccm->ccsrbarh, (u64)CONFIG_SYS_CCSRBAR_PHYS >> 32); + out_be32(&ccm->ccsrbarl, (u32)CONFIG_SYS_CCSRBAR_PHYS); + out_be32(&ccm->ccsrar, CCSRAR_C); + temp = in_be32(&ccm->ccsrar); + disable_law(0); +#else temp = in_be32(ccsr_virt); out_be32(ccsr_virt, CONFIG_SYS_CCSRBAR_PHYS >> 12); temp = in_be32((volatile u32 *)CONFIG_SYS_CCSRBAR); +#endif } #endif
The CoreNet platform style of bringing secondary cores out of reset is a bit different that the PQ3 style. Mostly the registers that we use to setup boot translation, enable time bases, and boot release the cores have moved around.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Fix up for LAW_EN, and use LAW_SIZE_4K instead of LAWAR_SIZE_4K
cpu/mpc85xx/mp.c | 68 +++++++++++++++++++++++++++++++++++++++++++++++++++++- 1 files changed, 67 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc85xx/mp.c b/cpu/mpc85xx/mp.c index fa65bed..59c4fb6 100644 --- a/cpu/mpc85xx/mp.c +++ b/cpu/mpc85xx/mp.c @@ -26,6 +26,7 @@ #include <lmb.h> #include <asm/io.h> #include <asm/mmu.h> +#include <asm/fsl_law.h> #include "mp.h"
DECLARE_GLOBAL_DATA_PTR; @@ -135,6 +136,66 @@ ulong get_spin_addr(void) return addr; }
+#ifdef CONFIG_FSL_CORENET +static void corenet_mp_up(unsigned long bootpg) +{ + u32 up, cpu_up_mask, whoami; + u32 *table = (u32 *)get_spin_addr(); + volatile ccsr_gur_t *gur; + volatile ccsr_local_t *ccm; + volatile ccsr_rcpm_t *rcpm; + volatile ccsr_pic_t *pic; + int timeout = 10; + u32 nr_cpus; + struct law_entry e; + + gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccm = (void *)(CONFIG_SYS_FSL_CORENET_CCM_ADDR); + rcpm = (void *)(CONFIG_SYS_FSL_CORENET_RCPM_ADDR); + pic = (void *)(CONFIG_SYS_MPC85xx_PIC_ADDR); + + nr_cpus = ((in_be32(&pic->frr) >> 8) & 0xff) + 1; + + whoami = in_be32(&pic->whoami); + cpu_up_mask = 1 << whoami; + out_be32(&ccm->bstrl, bootpg); + + e = find_law(bootpg); + out_be32(&ccm->bstrar, LAW_EN | e.trgt_id << 20 | LAW_SIZE_4K); + + /* disable time base at the platform */ + out_be32(&rcpm->ctbenrl, cpu_up_mask); + + /* release the hounds */ + up = ((1 << nr_cpus) - 1); + out_be32(&gur->brrl, up); + + /* wait for everyone */ + while (timeout) { + int i; + for (i = 0; i < nr_cpus; i++) { + if (table[i * NUM_BOOT_ENTRY + BOOT_ENTRY_ADDR_LOWER]) + cpu_up_mask |= (1 << i); + }; + + if ((cpu_up_mask & up) == up) + break; + + udelay(100); + timeout--; + } + + if (timeout == 0) + printf("CPU up timeout. CPU up mask is %x should be %x\n", + cpu_up_mask, up); + + /* enable time base at the platform */ + out_be32(&rcpm->ctbenrl, 0); + mtspr(SPRN_TBWU, 0); + mtspr(SPRN_TBWL, 0); + out_be32(&rcpm->ctbenrl, (1 << nr_cpus) - 1); +} +#else static void pq3_mp_up(unsigned long bootpg) { u32 up, cpu_up_mask, whoami; @@ -196,6 +257,7 @@ static void pq3_mp_up(unsigned long bootpg) devdisr &= ~(MPC85xx_DEVDISR_TB0 | MPC85xx_DEVDISR_TB1); out_be32(&gur->devdisr, devdisr); } +#endif
void cpu_mp_lmb_reserve(struct lmb *lmb) { @@ -217,7 +279,7 @@ void setup_mp(void) if (i != -1) { /* map reset page to bootpg so we can copy code there */ disable_tlb(i); - + set_tlb(1, 0xfffff000, bootpg, /* tlb, epn, rpn */ MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, /* perms, wimge */ 0, i, BOOKE_PAGESZ_4K, 1); /* ts, esel, tsize, iprot */ @@ -234,7 +296,11 @@ void setup_mp(void) MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I, /* perms, wimge */ 0, i, BOOKE_PAGESZ_4K, 1); /* ts, esel, tsize, iprot */
+#ifdef CONFIG_FSL_CORENET + corenet_mp_up(bootpg); +#else pq3_mp_up(bootpg); +#endif } else { puts("WARNING: No reset page TLB. " "Skipping secondary core setup\n");
There are various locations that we have chip specific info:
* Makefile for which ddr code to build * Added p4080 & p4040 to cpu_type_list and SVR list * Added number of LAWs for p4080 * Set CONFIG_MAX_CPUS to 8 for p4080
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/Makefile | 1 + cpu/mpc8xxx/cpu.c | 4 ++++ drivers/misc/fsl_law.c | 2 ++ include/asm-ppc/config.h | 6 ++++-- include/asm-ppc/processor.h | 4 ++++ 5 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc85xx/Makefile b/cpu/mpc85xx/Makefile index 3ef00e8..56de7eb 100644 --- a/cpu/mpc85xx/Makefile +++ b/cpu/mpc85xx/Makefile @@ -53,6 +53,7 @@ COBJS-$(CONFIG_P1011) += ddr-gen3.o COBJS-$(CONFIG_P1020) += ddr-gen3.o COBJS-$(CONFIG_P2010) += ddr-gen3.o COBJS-$(CONFIG_P2020) += ddr-gen3.o +COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o
COBJS-$(CONFIG_CPM2) += ether_fcc.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/cpu/mpc8xxx/cpu.c b/cpu/mpc8xxx/cpu.c index 00791e1..d191263 100644 --- a/cpu/mpc8xxx/cpu.c +++ b/cpu/mpc8xxx/cpu.c @@ -72,6 +72,10 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P2010, P2010_E, 1), CPU_TYPE_ENTRY(P2020, P2020, 2), CPU_TYPE_ENTRY(P2020, P2020_E, 2), + CPU_TYPE_ENTRY(P4040, P4040, 4), + CPU_TYPE_ENTRY(P4040, P4040_E, 4), + CPU_TYPE_ENTRY(P4080, P4080, 8), + CPU_TYPE_ENTRY(P4080, P4080_E, 8), #elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2), diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index c61e1f5..1d16fd1 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -41,6 +41,8 @@ DECLARE_GLOBAL_DATA_PTR; defined(CONFIG_P1011) || defined(CONFIG_P1020) || \ defined(CONFIG_P2010) || defined(CONFIG_P2020) #define FSL_HW_NUM_LAWS 12 +#elif defined(CONFIG_PPC_P4080) +#define FSL_HW_NUM_LAWS 32 #else #error FSL_HW_NUM_LAWS not defined for this platform #endif diff --git a/include/asm-ppc/config.h b/include/asm-ppc/config.h index 5670d06..e35b0b7 100644 --- a/include/asm-ppc/config.h +++ b/include/asm-ppc/config.h @@ -40,9 +40,11 @@
#if defined(CONFIG_MPC8572) || defined(CONFIG_P1020) || \ defined(CONFIG_P2020) || defined(CONFIG_MPC8641) -#define CONFIG_MAX_CPUS 2 +#define CONFIG_MAX_CPUS 2 +#elif defined(CONFIG_PPC_P4080) +#define CONFIG_MAX_CPUS 8 #else -#define CONFIG_MAX_CPUS 1 +#define CONFIG_MAX_CPUS 1 #endif
#endif /* _ASM_CONFIG_H_ */ diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 3764a5a..d009957 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -1031,6 +1031,10 @@ #define SVR_P2010_E 0x80EB00 #define SVR_P2020 0x80E200 #define SVR_P2020_E 0x80EA00 +#define SVR_P4040 0x820100 +#define SVR_P4040_E 0x820900 +#define SVR_P4080 0x820000 +#define SVR_P4080_E 0x820800
#define SVR_8610 0x80A000 #define SVR_8641 0x809000
On CoreNet style platforms the timebase frequency is the bus frequency defined by 16 (on PQ3 it is divide by 8). Also on the CoreNet platforms the core not longer controls the enabling of the timebase. We now need to enable the boot core's timebase via CCSR register writes.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/cpu.c | 4 ++++ cpu/mpc85xx/cpu_init.c | 12 ++++++++++++ cpu/mpc85xx/fdt.c | 4 ++-- 3 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index bdd9ee4..25c0416 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -184,7 +184,11 @@ int do_reset (cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char *argv[]) */ unsigned long get_tbclk (void) { +#ifdef CONFIG_FSL_CORENET + return (gd->bus_clk + 8) / 16; +#else return (gd->bus_clk + 4UL)/8UL; +#endif }
diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index a6d1e99..428b461 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -229,6 +229,18 @@ void cpu_init_f (void) #if defined(CONFIG_FSL_DMA) dma_init(); #endif +#ifdef CONFIG_FSL_CORENET + { + volatile ccsr_rcpm_t *rcpm = + (void *)(CONFIG_SYS_FSL_CORENET_RCPM_ADDR); + volatile ccsr_pic_t *pic = + (void *)(CONFIG_SYS_MPC85xx_PIC_ADDR); + u32 whoami = in_be32(&pic->whoami); + + /* Enable the timebase register for this core */ + out_be32(&rcpm->ctbenrl, (1 << whoami)); + } +#endif }
diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index 723f473..64a1710 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -1,5 +1,5 @@ /* - * Copyright 2007 Freescale Semiconductor, Inc. + * Copyright 2007-2009 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -287,7 +287,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) fdt_add_enet_stashing(blob);
do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, - "timebase-frequency", bd->bi_busfreq / 8, 1); + "timebase-frequency", get_tbclk(), 1); do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, "bus-frequency", bd->bi_busfreq, 1); get_sys_info(&sysinfo);
The means to determine the core, bus, and DDR frequencies are completely new on CoreNet style platforms. Additionally on p4080 we can have different frequencies for FMAN and PME IP blocks. We need to keep track of the FMAN & PME frequencies since they are used for time stamping capabilities inside each block.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/cpu.c | 29 +++++++++++++++++ cpu/mpc85xx/speed.c | 85 +++++++++++++++++++++++++++++++++++++++++++++++++++ include/e500.h | 6 +++ 3 files changed, 120 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 25c0416..1c0f2b2 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -46,11 +46,20 @@ int checkcpu (void) char buf1[32], buf2[32]; #ifdef CONFIG_DDR_CLK_FREQ volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#ifdef CONFIG_FSL_CORENET + u32 ddr_sync = ((gur->rcwsr[5]) & FSL_CORENET_RCWSR5_DDR_SYNC) + >> FSL_CORENET_RCWSR5_DDR_SYNC_SHIFT; +#else u32 ddr_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_DDR_RATIO) >> MPC85xx_PORPLLSR_DDR_RATIO_SHIFT; +#endif +#else +#ifdef CONFIG_FSL_CORENET + u32 ddr_sync = 0; #else u32 ddr_ratio = 0; #endif +#endif int i;
svr = get_svr(); @@ -111,6 +120,16 @@ int checkcpu (void) } printf("\n CCB:%-4s MHz,\n", strmhz(buf1, sysinfo.freqSystemBus));
+#ifdef CONFIG_FSL_CORENET + if (ddr_sync == 1) + printf(" DDR:%-4s MHz (%s MT/s data rate) (Synchronous), ", + strmhz(buf1, sysinfo.freqDDRBus/2), + strmhz(buf2, sysinfo.freqDDRBus)); + else + printf(" DDR:%-4s MHz (%s MT/s data rate) (Asynchronous), ", + strmhz(buf1, sysinfo.freqDDRBus/2), + strmhz(buf2, sysinfo.freqDDRBus)); +#else switch (ddr_ratio) { case 0x0: printf(" DDR:%-4s MHz (%s MT/s data rate), ", @@ -128,6 +147,7 @@ int checkcpu (void) strmhz(buf2, sysinfo.freqDDRBus)); break; } +#endif
if (sysinfo.freqLocalBus > LCRR_CLKDIV) printf("LBC:%-4s MHz\n", strmhz(buf1, sysinfo.freqLocalBus)); @@ -143,6 +163,15 @@ int checkcpu (void) printf(" QE:%-4s MHz\n", strmhz(buf1, sysinfo.freqQE)); #endif
+#ifdef CONFIG_SYS_DPAA_FMAN + for (i = 0; i < CONFIG_SYS_NUM_FMAN; i++) + printf(" FMAN%d: %s MHz\n", i, strmhz(buf1, sysinfo.freqFMan[i])); +#endif + +#ifdef CONFIG_SYS_DPAA_PME + printf(" PME: %s MHz\n", strmhz(buf1, sysinfo.freqPME)); +#endif + puts("L1: D-cache 32 kB enabled\n I-cache 32 kB enabled\n");
return 0; diff --git a/cpu/mpc85xx/speed.c b/cpu/mpc85xx/speed.c index 2fdcefb..dc18798 100644 --- a/cpu/mpc85xx/speed.c +++ b/cpu/mpc85xx/speed.c @@ -1,5 +1,6 @@ /* * Copyright 2004, 2007-2009 Freescale Semiconductor, Inc. + * * (C) Copyright 2003 Motorola Inc. * Xianghua Xiao, (X.Xiao@motorola.com) * @@ -37,6 +38,89 @@ DECLARE_GLOBAL_DATA_PTR; void get_sys_info (sys_info_t * sysInfo) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#ifdef CONFIG_FSL_CORENET + volatile ccsr_clk_t *clk = (void *)(CONFIG_SYS_FSL_CORENET_CLK_ADDR); + + const u8 core_cplx_PLL[16] = { + [ 0] = 0, /* CC1 PPL / 1 */ + [ 1] = 0, /* CC1 PPL / 2 */ + [ 2] = 0, /* CC1 PPL / 4 */ + [ 4] = 1, /* CC2 PPL / 1 */ + [ 5] = 1, /* CC2 PPL / 2 */ + [ 6] = 1, /* CC2 PPL / 4 */ + [ 8] = 2, /* CC3 PPL / 1 */ + [ 9] = 2, /* CC3 PPL / 2 */ + [10] = 2, /* CC3 PPL / 4 */ + [12] = 3, /* CC4 PPL / 1 */ + [13] = 3, /* CC4 PPL / 2 */ + [14] = 3, /* CC4 PPL / 4 */ + }; + + const u8 core_cplx_PLL_div[16] = { + [ 0] = 1, /* CC1 PPL / 1 */ + [ 1] = 2, /* CC1 PPL / 2 */ + [ 2] = 4, /* CC1 PPL / 4 */ + [ 4] = 1, /* CC2 PPL / 1 */ + [ 5] = 2, /* CC2 PPL / 2 */ + [ 6] = 4, /* CC2 PPL / 4 */ + [ 8] = 1, /* CC3 PPL / 1 */ + [ 9] = 2, /* CC3 PPL / 2 */ + [10] = 4, /* CC3 PPL / 4 */ + [12] = 1, /* CC4 PPL / 1 */ + [13] = 2, /* CC4 PPL / 2 */ + [14] = 4, /* CC4 PPL / 4 */ + }; + uint lcrr_div, i, freqCC_PLL[4], rcw_tmp; + unsigned long sysclk = CONFIG_SYS_CLK_FREQ; + + sysInfo->freqSystemBus = sysclk; + sysInfo->freqDDRBus = sysclk; + freqCC_PLL[0] = sysclk; + freqCC_PLL[1] = sysclk; + freqCC_PLL[2] = sysclk; + freqCC_PLL[3] = sysclk; + + sysInfo->freqSystemBus *= (in_be32(&gur->rcwsr[0]) >> 25) & 0xf; + sysInfo->freqDDRBus *= ((in_be32(&gur->rcwsr[0]) >> 17) & 0xf); + freqCC_PLL[0] *= (in_be32(&clk->pllc1gsr) >> 1) & 0x3f; + freqCC_PLL[1] *= (in_be32(&clk->pllc2gsr) >> 1) & 0x3f; + freqCC_PLL[2] *= (in_be32(&clk->pllc3gsr) >> 1) & 0x3f; + freqCC_PLL[3] *= (in_be32(&clk->pllc4gsr) >> 1) & 0x3f; + + rcw_tmp = in_be32(&gur->rcwsr[3]); + for (i = 0; i < cpu_numcores(); i++) { + u32 c_pll_sel = (in_be32(&clk->clkc0csr + i*8) >> 27) & 0xf; + u32 cplx_pll = core_cplx_PLL[c_pll_sel]; + + sysInfo->freqProcessor[i] = freqCC_PLL[cplx_pll] / core_cplx_PLL_div[c_pll_sel]; + } + +#define PME_CLK_SEL 0x80000000 +#define FM1_CLK_SEL 0x40000000 +#define FM2_CLK_SEL 0x20000000 + rcw_tmp = in_be32(&gur->rcwsr[7]); + +#ifdef CONFIG_SYS_DPAA_PME + if (rcw_tmp & PME_CLK_SEL) + sysInfo->freqPME = freqCC_PLL[2] / 2; + else + sysInfo->freqPME = sysInfo->freqSystemBus / 2; +#endif + +#ifdef CONFIG_SYS_DPAA_FMAN + if (rcw_tmp & FM1_CLK_SEL) + sysInfo->freqFMan[0] = freqCC_PLL[2] / 2; + else + sysInfo->freqFMan[0] = sysInfo->freqSystemBus / 2; +#if (CONFIG_SYS_NUM_FMAN) == 2 + if (rcw_tmp & FM2_CLK_SEL) + sysInfo->freqFMan[1] = freqCC_PLL[2] / 2; + else + sysInfo->freqFMan[1] = sysInfo->freqSystemBus / 2; +#endif +#endif + +#else uint plat_ratio,e500_ratio,half_freqSystemBus; uint lcrr_div; int i; @@ -67,6 +151,7 @@ void get_sys_info (sys_info_t * sysInfo) sysInfo->freqDDRBus = ddr_ratio * CONFIG_DDR_CLK_FREQ; } #endif +#endif
#ifdef CONFIG_QE qe_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_QE_RATIO) diff --git a/include/e500.h b/include/e500.h index f8c8266..e1708b9 100644 --- a/include/e500.h +++ b/include/e500.h @@ -15,6 +15,12 @@ typedef struct unsigned long freqDDRBus; unsigned long freqLocalBus; unsigned long freqQE; +#ifdef CONFIG_SYS_DPAA_FMAN + unsigned long freqFMan[CONFIG_SYS_NUM_FMAN]; +#endif +#ifdef CONFIG_SYS_DPAA_PME + unsigned long freqPME; +#endif } MPC85xx_SYS_INFO;
#endif /* _ASMLANGUAGE */
Dear Kumar Gala,
In message 1253380099-27864-7-git-send-email-galak@kernel.crashing.org you wrote:
- u32 ddr_sync = ((gur->rcwsr[5]) & FSL_CORENET_RCWSR5_DDR_SYNC)
- u32 ddr_sync = 0;
Please make this
#endif /* CONFIG_DDR_CLK_FREQ */
so we can see more easily what ends wher ein this #ifdef hell.
- if (ddr_sync == 1)
- else
Please use braces around multi-line statements.
- rcw_tmp = in_be32(&gur->rcwsr[3]);
- for (i = 0; i < cpu_numcores(); i++) {
Line too long, please check globally.
Dear Kumar Gala,
In message 1253380099-27864-6-git-send-email-galak@kernel.crashing.org you wrote:
Please do not add variable declarations right in the middle of a function.
Dear Kumar Gala,
In message 1253380099-27864-1-git-send-email-galak@kernel.crashing.org you wrote:
Why are you reposting? What was changed compared to v3?
- u32 ccsrbarh; /* 0x0 - Control Configuration Status Registers Base Address Register High */
- u32 ccsrbarl; /* 0x4 - Control Configuration Status Registers Base Address Register Low */
- u32 ccsrar; /* 0x8 - Configuration, Control, and Status Attribute Register */
Seems my previous comments still apply - lines are wayyyyy to long.
On Sep 23, 2009, at 1:37 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
In message <1253380099-27864-1-git-send-email-galak@kernel.crashing.org
you wrote: The p4080 SoC has a significant amount of commonality with the 85xx/ PQ3 platform. We reuse the 85xx immap and just add new definitions for local access and global utils. The global utils is now broken into global utils, clocking and run control/power management.
include/asm-ppc/fsl_lbc.h | 4 + include/asm-ppc/immap_85xx.h | 287 ++++++++++++++++++++++++++++++++ +++++++--- 2 files changed, 271 insertions(+), 20 deletions(-)
diff --git a/include/asm-ppc/fsl_lbc.h b/include/asm-ppc/fsl_lbc.h index 08d31e1..5723de6 100644 --- a/include/asm-ppc/fsl_lbc.h +++ b/include/asm-ppc/fsl_lbc.h @@ -317,6 +317,10 @@ #define LCRR_CLKDIV_2 0x00000002 #define LCRR_CLKDIV_4 0x00000004 #define LCRR_CLKDIV_8 0x00000008 +#elif defined(CONFIG_FSL_CORENET) +#define LCRR_CLKDIV_8 0x00000002 +#define LCRR_CLKDIV_16 0x00000004 +#define LCRR_CLKDIV_32 0x00000008 #else #define LCRR_CLKDIV_4 0x00000002 #define LCRR_CLKDIV_8 0x00000004 diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/ immap_85xx.h index e7d412d..3e6ed85 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -16,6 +16,29 @@ #include <asm/fsl_i2c.h> #include <asm/fsl_lbc.h>
Dope, posted the wrong version. I agree w/the long lines, not sure what to do about it. Move to something like:
typedef struct ccsr_local { /* 0x0 - Control Configuration Status Registers Base Address Register High */ u32 ccsrbarh; /* 0x4 - Control Configuration Status Registers Base Address Register Low */ u32 ccsrbarl;
even this exceeds the 80 column limit.
- k
Dear Kumar Gala,
In message 19E9B551-F442-4BA2-98A3-C941620E4E64@kernel.crashing.org you wrote:
Why do you need to carry the offset in the comment?
What about:
Control Config Status Regs Base Addr Reg ?
or
BAR = Base Address Register (once initially)
Control Config Status Regs BAR ?
Kumar Gala
