[U-Boot] [PATCH] microblaze: Use standard functions for memory decoding
The standard function is less error prone than custom one.
.../xilinx/microblaze-generic/microblaze-generic.c | 27 +++------------------- 1 file changed, 3 insertions(+), 24 deletions(-)
diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index 44fb48b347a5..c946ec320855 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -32,34 +32,13 @@ ulong ram_base;
int dram_init_banksize(void) { - gd->bd->bi_dram[0].start = ram_base; - gd->bd->bi_dram[0].size = get_effective_memsize(); - - return 0; + return fdtdec_setup_memory_banksize(); }
int dram_init(void) { - int node; - fdt_addr_t addr; - fdt_size_t size; - const void *blob = gd->fdt_blob; - - node = fdt_node_offset_by_prop_value(blob, -1, "device_type", - "memory", 7); - if (node == -FDT_ERR_NOTFOUND) { - debug("DRAM: Can't get memory node\n"); - return 1; - } - addr = fdtdec_get_addr_size(blob, node, "reg", &size); - if (addr == FDT_ADDR_T_NONE || size == 0) { - debug("DRAM: Can't get base address or size\n"); - return 1; - } - ram_base = addr; - - gd->ram_top = addr; /* In setup_dest_addr() is done +ram_size */ - gd->ram_size = size; + if (fdtdec_setup_mem_size_base() != 0) + return -EINVAL;
return 0; };
Michal Simek
