Re: [U-Boot] [PATCH 2/2] zynq: nand: Enable Nand flash controller driver a zynq board
Please ignore this series. I will resend the patch.
Regards, Siva
-----Original Message----- From: root [mailto:root@xhdsivadur40] Sent: Friday, September 23, 2016 6:00 PM To: u-boot@lists.denx.de Cc: oss@buserror.net; Michal Simek michals@xilinx.com; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: [PATCH 2/2] zynq: nand: Enable Nand flash controller driver a zynq board
Enable zynq Nand flash controller driver for a zynq ZC770 XM011(dc2) board.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com
configs/zynq_zc770_xm011_defconfig | 2 ++ include/configs/zynq-common.h | 7 +++++++ 2 files changed, 9 insertions(+)
diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index b841fdc..3ce7114 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm011" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_NAND_ZYNQ=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011" CONFIG_SYS_NO_FLASH=y CONFIG_SPL=y @@ -18,6 +19,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_CMD_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_GEM=y diff --git a/include/configs/zynq-common.h b/include/configs/zynq- common.h index 260df2f..27c02e5 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -76,6 +76,13 @@ # define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #endif
+#ifdef CONFIG_NAND_ZYNQ +#define CONFIG_CMD_NAND_LOCK_UNLOCK +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_MTD_DEVICE +#endif
/* MMC */ #if defined(CONFIG_ZYNQ_SDHCI)
# define CONFIG_MMC
2.7.4
