Bcc: Subject: Re: [PATCH 2/3] mksunxi_fit_atf.sh: Update FIT component descriptions Reply-To: In-Reply-To: 20200507232035.31892-2-samuel@sholland.org
now this really confuses me.
commit 0db0ba6141f402b1d496ef53d9fa69978f75ec61 has explicitly made u-boot the firmware and moved atf into the loadables on NXP i.MX. Here you do the complete opposite for sunxi.
Can people please make up their minds how it is *supposed* to work?
Oh, and your previous diff about the "minimal os parsing", I need that too for my use-case, so I like that one!
Patrick
On Thu, May 07, 2020 at 06:20:34PM -0500, Samuel Holland wrote:
Since commit d879616e9e64 ("spl: fit: simplify logic for FDT loading for non-OS boots"), the SPL looks at the "os" properties of FIT images to determine where to append the FDT.
The "os" property of the "firmware" image also determines how to execute the next stage of the boot process, as in 1d3790905d9c ("spl: atf: introduce spl_invoke_atf and make bl31_entry private").
To support this additional functionality, and to properly model the boot process, where ATF runs before U-Boot, add the "os" properties and swap the firmware/loadable images in the FIT image.
Signed-off-by: Samuel Holland samuel@sholland.org
board/sunxi/mksunxi_fit_atf.sh | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/mksunxi_fit_atf.sh b/board/sunxi/mksunxi_fit_atf.sh index 88ad719747..4dfd22db78 100755 --- a/board/sunxi/mksunxi_fit_atf.sh +++ b/board/sunxi/mksunxi_fit_atf.sh @@ -31,6 +31,7 @@ cat << __HEADER_EOF description = "U-Boot (64-bit)"; data = /incbin/("u-boot-nodtb.bin"); type = "standalone";
os = "u-boot"; arch = "arm64"; compression = "none"; load = <0x4a000000>;
@@ -39,6 +40,7 @@ cat << __HEADER_EOF description = "ARM Trusted Firmware"; data = /incbin/("$BL31"); type = "firmware";
os = "arm-trusted-firmware"; arch = "arm64"; compression = "none"; load = <$BL31_ADDR>;
@@ -73,8 +75,8 @@ do cat << __CONF_SECTION_EOF config_$cnt { description = "$(basename $dtname .dtb)";
firmware = "uboot";
loadables = "atf";
firmware = "atf";
};loadables = "uboot"; fdt = "fdt_$cnt";
__CONF_SECTION_EOF
2.24.1
Patrick Wildt
