[U-Boot-Users] [PATCH] NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt smcnutt@psyent.com.
Signed-off-by: Scott Wood scottwood@freescale.com --- cpu/arm926ejs/davinci/nand.c | 10 +++- drivers/mtd/nand/nand_base.c | 103 +++++++++++++++++++++++------------ drivers/mtd/nand/nand_bbt.c | 4 +- drivers/mtd/onenand/onenand_base.c | 95 +++++++++++++++++---------------- drivers/mtd/onenand/onenand_bbt.c | 6 +- include/linux/mtd/mtd.h | 4 +- 6 files changed, 132 insertions(+), 90 deletions(-)
diff --git a/cpu/arm926ejs/davinci/nand.c b/cpu/arm926ejs/davinci/nand.c index ffc770f..36468e6 100644 --- a/cpu/arm926ejs/davinci/nand.c +++ b/cpu/arm926ejs/davinci/nand.c @@ -240,7 +240,8 @@ static int nand_davinci_compare_ecc(u_int8_t *ecc_nand, u_int8_t *ecc_calc, u_in return 0; case 1: /* Uncorrectable error */ - DEBUG (MTD_DEBUG_LEVEL0, "ECC UNCORRECTED_ERROR 1\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "ECC UNCORRECTED_ERROR 1\n"); return(-1); case 12: /* Correctable error */ @@ -256,7 +257,9 @@ static int nand_davinci_compare_ecc(u_int8_t *ecc_nand, u_int8_t *ecc_calc, u_in
find_bit = (ecc_bit[5] << 2) + (ecc_bit[3] << 1) + ecc_bit[1];
- DEBUG (MTD_DEBUG_LEVEL0, "Correcting single bit ECC error at offset: %d, bit: %d\n", find_byte, find_bit); + MTDDEBUG (MTD_DEBUG_LEVEL0, "Correcting single bit ECC " + "error at offset: %d, bit: %d\n", + find_byte, find_bit);
page_data[find_byte] ^= (1 << find_bit);
@@ -266,7 +269,8 @@ static int nand_davinci_compare_ecc(u_int8_t *ecc_nand, u_int8_t *ecc_calc, u_in if (ecc_calc[0] == 0 && ecc_calc[1] == 0 && ecc_calc[2] == 0) return(0); } - DEBUG (MTD_DEBUG_LEVEL0, "UNCORRECTED_ERROR default\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "UNCORRECTED_ERROR default\n"); return(-1); } } diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 740d3fc..6416d15 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -962,7 +962,9 @@ static int nand_write_page (struct mtd_info *mtd, struct nand_chip *this, int pa status = this->waitfunc (mtd, this, FL_WRITING); /* See if device thinks it succeeded */ if (status & 0x01) { - DEBUG (MTD_DEBUG_LEVEL0, "%s: " "Failed write, page 0x%08x, ", __FUNCTION__, page); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "%s: Failed write, page 0x%08x, ", + __FUNCTION__, page); return -EIO; } } else { @@ -1010,7 +1012,9 @@ static int nand_verify_pages (struct mtd_info *mtd, struct nand_chip *this, int for (j = 0; j < eccsteps; j++) { /* Loop through and verify the data */ if (this->verify_buf(mtd, &this->data_poi[datidx], mtd->eccsize)) { - DEBUG (MTD_DEBUG_LEVEL0, "%s: " "Failed write verify, page 0x%08x ", __FUNCTION__, page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "%s: " + "Failed write verify, page 0x%08x ", + __FUNCTION__, page); goto out; } datidx += mtd->eccsize; @@ -1018,7 +1022,9 @@ static int nand_verify_pages (struct mtd_info *mtd, struct nand_chip *this, int if (!hweccbytes) continue; if (this->verify_buf(mtd, &this->oob_buf[oobofs], hweccbytes)) { - DEBUG (MTD_DEBUG_LEVEL0, "%s: " "Failed write verify, page 0x%08x ", __FUNCTION__, page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "%s: " + "Failed write verify, page 0x%08x ", + __FUNCTION__, page); goto out; } oobofs += hweccbytes; @@ -1029,7 +1035,9 @@ static int nand_verify_pages (struct mtd_info *mtd, struct nand_chip *this, int */ if (oobmode) { if (this->verify_buf(mtd, &oob_buf[oobofs], mtd->oobsize - hweccbytes * eccsteps)) { - DEBUG (MTD_DEBUG_LEVEL0, "%s: " "Failed write verify, page 0x%08x ", __FUNCTION__, page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "%s: " + "Failed write verify, page 0x%08x ", + __FUNCTION__, page); goto out; } } else { @@ -1042,9 +1050,11 @@ static int nand_verify_pages (struct mtd_info *mtd, struct nand_chip *this, int for (i = 0; i < ecccnt; i++) { int idx = oobsel->eccpos[i]; if (oobdata[idx] != oob_buf[oobofs + idx] ) { - DEBUG (MTD_DEBUG_LEVEL0, + MTDDEBUG (MTD_DEBUG_LEVEL0, "%s: Failed ECC write " - "verify, page 0x%08x, " "%6i bytes were succesful\n", __FUNCTION__, page, i); + "verify, page 0x%08x, " + "%6i bytes were succesful\n", + __FUNCTION__, page, i); goto out; } } @@ -1131,11 +1141,13 @@ static int nand_read_ecc (struct mtd_info *mtd, loff_t from, size_t len, int oobreadlen;
- DEBUG (MTD_DEBUG_LEVEL3, "nand_read_ecc: from = 0x%08x, len = %i\n", (unsigned int) from, (int) len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_read_ecc: from = 0x%08x, len = %i\n", + (unsigned int) from, (int) len);
/* Do not allow reads past end of device */ if ((from + len) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_read_ecc: Attempt read beyond end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_read_ecc: Attempt read beyond end of device\n"); *retlen = 0; return -EINVAL; } @@ -1252,7 +1264,7 @@ static int nand_read_ecc (struct mtd_info *mtd, loff_t from, size_t len, * generator for an error, reads back the syndrome and * does the error correction on the fly */ if (this->correct_data(mtd, &data_poi[datidx], &oob_data[i], &ecc_code[i]) == -1) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_read_ecc: " + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_read_ecc: " "Failed ECC read, page 0x%08x on chip %d\n", page, chipnr); ecc_failed++; } @@ -1291,7 +1303,9 @@ static int nand_read_ecc (struct mtd_info *mtd, loff_t from, size_t len, }
if (ecc_status == -1) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_read_ecc: " "Failed ECC read, page 0x%08x\n", page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_read_ecc: " + "Failed ECC read, page 0x%08x\n", + page); ecc_failed++; } } @@ -1388,7 +1402,8 @@ static int nand_read_oob (struct mtd_info *mtd, loff_t from, size_t len, size_t struct nand_chip *this = mtd->priv; int blockcheck = (1 << (this->phys_erase_shift - this->page_shift)) - 1;
- DEBUG (MTD_DEBUG_LEVEL3, "nand_read_oob: from = 0x%08x, len = %i\n", (unsigned int) from, (int) len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_read_oob: from = 0x%08x, len = %i\n", + (unsigned int) from, (int) len);
/* Shift to get page */ page = (int)(from >> this->page_shift); @@ -1402,7 +1417,8 @@ static int nand_read_oob (struct mtd_info *mtd, loff_t from, size_t len, size_t
/* Do not allow reads past end of device */ if ((from + len) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_read_oob: Attempt read beyond end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_read_oob: Attempt read beyond end of device\n"); *retlen = 0; return -EINVAL; } @@ -1488,7 +1504,8 @@ int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_t len,
/* Do not allow reads past end of device */ if ((from + len) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_read_raw: Attempt read beyond end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_read_raw: Attempt read beyond end of device\n"); return -EINVAL; }
@@ -1626,14 +1643,16 @@ static int nand_write_ecc (struct mtd_info *mtd, loff_t to, size_t len, u_char *oobbuf, *bufstart; int ppblock = (1 << (this->phys_erase_shift - this->page_shift));
- DEBUG (MTD_DEBUG_LEVEL3, "nand_write_ecc: to = 0x%08x, len = %i\n", (unsigned int) to, (int) len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_write_ecc: to = 0x%08x, len = %i\n", + (unsigned int) to, (int) len);
/* Initialize retlen, in case of early exit */ *retlen = 0;
/* Do not allow write past end of device */ if ((to + len) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_ecc: Attempt to write past end of page\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_write_ecc: Attempt to write past end of page\n"); return -EINVAL; }
@@ -1695,7 +1714,8 @@ static int nand_write_ecc (struct mtd_info *mtd, loff_t to, size_t len, */ ret = nand_write_page (mtd, this, page, &oobbuf[oob], oobsel, (--numpages > 0)); if (ret) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_ecc: write_page failed %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_write_ecc: write_page failed %d\n", ret); goto out; } /* Next oob page */ @@ -1719,7 +1739,8 @@ static int nand_write_ecc (struct mtd_info *mtd, loff_t to, size_t len, page - startpage, oobbuf, oobsel, chipnr, (eccbuf != NULL)); if (ret) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_ecc: verify_pages failed %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_write_ecc: " + "verify_pages failed %d\n", ret); goto out; } *retlen = written; @@ -1752,7 +1773,8 @@ cmp: if (!ret) *retlen = written; else - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_ecc: verify_pages failed %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_write_ecc: verify_pages failed %d\n", ret);
out: /* Deselect and wake up anyone waiting on the device */ @@ -1777,7 +1799,8 @@ static int nand_write_oob (struct mtd_info *mtd, loff_t to, size_t len, size_t * int column, page, status, ret = -EIO, chipnr; struct nand_chip *this = mtd->priv;
- DEBUG (MTD_DEBUG_LEVEL3, "nand_write_oob: to = 0x%08x, len = %i\n", (unsigned int) to, (int) len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_write_oob: to = 0x%08x, len = %i\n", + (unsigned int) to, (int) len);
/* Shift to get page */ page = (int) (to >> this->page_shift); @@ -1791,7 +1814,8 @@ static int nand_write_oob (struct mtd_info *mtd, loff_t to, size_t len, size_t *
/* Do not allow write past end of page */ if ((column + len) > mtd->oobsize) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: Attempt to write past end of page\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " + "Attempt to write past end of page\n"); return -EINVAL; }
@@ -1821,8 +1845,9 @@ static int nand_write_oob (struct mtd_info *mtd, loff_t to, size_t len, size_t * this->cmdfunc (mtd, NAND_CMD_SEQIN, mtd->oobblock, page & this->pagemask); if (!ffchars) { if (!(ffchars = kmalloc (mtd->oobsize, GFP_KERNEL))) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " - "No memory for padding array, need %d bytes", mtd->oobsize); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " + "No memory for padding array, " + "need %d bytes", mtd->oobsize); ret = -ENOMEM; goto out; } @@ -1847,7 +1872,8 @@ static int nand_write_oob (struct mtd_info *mtd, loff_t to, size_t len, size_t *
/* See if device thinks it succeeded */ if (status & 0x01) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " "Failed write, page 0x%08x\n", page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " + "Failed write, page 0x%08x\n", page); ret = -EIO; goto out; } @@ -1859,7 +1885,8 @@ static int nand_write_oob (struct mtd_info *mtd, loff_t to, size_t len, size_t * this->cmdfunc (mtd, NAND_CMD_READOOB, column, page & this->pagemask);
if (this->verify_buf(mtd, buf, len)) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " "Failed write verify, page 0x%08x\n", page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_write_oob: " + "Failed write verify, page 0x%08x\n", page); ret = -EIO; goto out; } @@ -1919,12 +1946,14 @@ static int nand_writev_ecc (struct mtd_info *mtd, const struct kvec *vecs, unsig for (i = 0; i < count; i++) total_len += (int) vecs[i].iov_len;
- DEBUG (MTD_DEBUG_LEVEL3, - "nand_writev: to = 0x%08x, len = %i, count = %ld\n", (unsigned int) to, (unsigned int) total_len, count); + MTDDEBUG (MTD_DEBUG_LEVEL3, + "nand_writev: to = 0x%08x, len = %i, count = %ld\n", + (unsigned int) to, (unsigned int) total_len, count);
/* Do not allow write past end of page */ if ((to + total_len) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_writev: Attempted write past end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_writev: Attempted write past end of device\n"); return -EINVAL; }
@@ -2117,24 +2146,26 @@ int nand_erase_nand (struct mtd_info *mtd, struct erase_info *instr, int allowbb int page, len, status, pages_per_block, ret, chipnr; struct nand_chip *this = mtd->priv;
- DEBUG (MTD_DEBUG_LEVEL3, - "nand_erase: start = 0x%08x, len = %i\n", (unsigned int) instr->addr, (unsigned int) instr->len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_erase: start = 0x%08x, len = %i\n", + (unsigned int) instr->addr, (unsigned int) instr->len);
/* Start address must align on block boundary */ if (instr->addr & ((1 << this->phys_erase_shift) - 1)) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_erase: Unaligned address\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_erase: Unaligned address\n"); return -EINVAL; }
/* Length must align on block boundary */ if (instr->len & ((1 << this->phys_erase_shift) - 1)) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_erase: Length not block aligned\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_erase: Length not block aligned\n"); return -EINVAL; }
/* Do not allow erase past end of device */ if ((instr->len + instr->addr) > mtd->size) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_erase: Erase past end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_erase: Erase past end of device\n"); return -EINVAL; }
@@ -2156,7 +2187,8 @@ int nand_erase_nand (struct mtd_info *mtd, struct erase_info *instr, int allowbb /* Check the WP bit */ /* Check, if it is write protected */ if (nand_check_wp(mtd)) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_erase: Device is write protected!!!\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "nand_erase: Device is write protected!!!\n"); instr->state = MTD_ERASE_FAILED; goto erase_exit; } @@ -2186,7 +2218,8 @@ int nand_erase_nand (struct mtd_info *mtd, struct erase_info *instr, int allowbb
/* See if block erase succeeded */ if (status & 0x01) { - DEBUG (MTD_DEBUG_LEVEL0, "nand_erase: " "Failed erase, page 0x%08x\n", page); + MTDDEBUG (MTD_DEBUG_LEVEL0, "nand_erase: " + "Failed erase, page 0x%08x\n", page); instr->state = MTD_ERASE_FAILED; instr->fail_addr = (page << this->page_shift); goto erase_exit; @@ -2229,7 +2262,7 @@ static void nand_sync (struct mtd_info *mtd) { struct nand_chip *this = mtd->priv;
- DEBUG (MTD_DEBUG_LEVEL3, "nand_sync: called\n"); + MTDDEBUG (MTD_DEBUG_LEVEL3, "nand_sync: called\n");
/* Grab the lock and see if the device is available */ nand_get_device (this, mtd, FL_SYNCING); diff --git a/drivers/mtd/nand/nand_bbt.c b/drivers/mtd/nand/nand_bbt.c index eff76d7..a97743b 100644 --- a/drivers/mtd/nand/nand_bbt.c +++ b/drivers/mtd/nand/nand_bbt.c @@ -1038,8 +1038,8 @@ int nand_isbad_bbt (struct mtd_info *mtd, loff_t offs, int allowbbt) block = (int) (offs >> (this->bbt_erase_shift - 1)); res = (this->bbt[block >> 3] >> (block & 0x06)) & 0x03;
- DEBUG (MTD_DEBUG_LEVEL2, "nand_isbad_bbt(): bbt info for offs 0x%08x: (block %d) 0x%02x\n", - (unsigned int)offs, res, block >> 1); + MTDDEBUG (MTD_DEBUG_LEVEL2, "nand_isbad_bbt(): bbt info for offs 0x%08x: " + "(block %d) 0x%02x\n", (unsigned int)offs, res, block >> 1);
switch ((int)res) { case 0x00: return 0; diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index d1b9f8f..d32e382 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -293,22 +293,22 @@ static int onenand_wait(struct mtd_info *mtd, int state) ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
if (ctrl & ONENAND_CTRL_ERROR) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_wait: controller error = 0x%04x\n", ctrl); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_wait: controller error = 0x%04x\n", ctrl); return -EAGAIN; }
if (ctrl & ONENAND_CTRL_LOCK) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_wait: it's locked error = 0x%04x\n", ctrl); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_wait: it's locked error = 0x%04x\n", ctrl); return -EIO; }
if (interrupt & ONENAND_INT_READ) { ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); if (ecc & ONENAND_ECC_2BIT_ALL) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_wait: ECC error = 0x%04x\n", ecc); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_wait: ECC error = 0x%04x\n", ecc); return -EBADMSG; } } @@ -524,13 +524,14 @@ static int onenand_read_ecc(struct mtd_info *mtd, loff_t from, size_t len, int thislen; int ret = 0;
- DEBUG(MTD_DEBUG_LEVEL3, "onenand_read_ecc: from = 0x%08x, len = %i\n", - (unsigned int)from, (int)len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_read_ecc: " + "from = 0x%08x, len = %i\n", + (unsigned int)from, (int)len);
/* Do not allow reads past end of device */ if ((from + len) > mtd->size) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_read_ecc: Attempt read beyond end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_read_ecc: " + "Attempt read beyond end of device\n"); *retlen = 0; return -EINVAL; } @@ -561,8 +562,8 @@ static int onenand_read_ecc(struct mtd_info *mtd, loff_t from, size_t len, break;
if (ret) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_read_ecc: read failed = %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_read_ecc: read failed = %d\n", ret); break; }
@@ -615,16 +616,17 @@ int onenand_read_oob(struct mtd_info *mtd, loff_t from, size_t len, int read = 0, thislen, column; int ret = 0;
- DEBUG(MTD_DEBUG_LEVEL3, "onenand_read_oob: from = 0x%08x, len = %i\n", - (unsigned int)from, (int)len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_read_oob: " + "from = 0x%08x, len = %i\n", + (unsigned int)from, (int)len);
/* Initialize return length value */ *retlen = 0;
/* Do not allow reads past end of device */ if (unlikely((from + len) > mtd->size)) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_read_oob: Attempt read beyond end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_read_oob: " + "Attempt read beyond end of device\n"); return -EINVAL; }
@@ -652,8 +654,8 @@ int onenand_read_oob(struct mtd_info *mtd, loff_t from, size_t len, break;
if (ret) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_read_oob: read failed = %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_read_oob: read failed = %d\n", ret); break; }
@@ -733,23 +735,24 @@ static int onenand_write_ecc(struct mtd_info *mtd, loff_t to, size_t len, int written = 0; int ret = 0;
- DEBUG(MTD_DEBUG_LEVEL3, "onenand_write_ecc: to = 0x%08x, len = %i\n", - (unsigned int)to, (int)len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_write_ecc: " + "to = 0x%08x, len = %i\n", + (unsigned int)to, (int)len);
/* Do not allow writes past end of device */ if (unlikely((to + len) > mtd->size)) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_write_ecc: Attempt write to past end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_write_ecc: " + "Attempt write to past end of device\n"); return -EINVAL; }
/* Reject writes, which are not page aligned */ if (unlikely(NOTALIGNED(to)) || unlikely(NOTALIGNED(len))) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_write_ecc: Attempt to write not page aligned data\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_write_ecc: " + "Attempt to write not page aligned data\n"); return -EINVAL; }
@@ -772,8 +775,8 @@ static int onenand_write_ecc(struct mtd_info *mtd, loff_t to, size_t len,
ret = this->wait(mtd, FL_WRITING); if (ret) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_write_ecc: write filaed %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_write_ecc: write filaed %d\n", ret); break; }
@@ -782,8 +785,8 @@ static int onenand_write_ecc(struct mtd_info *mtd, loff_t to, size_t len, /* Only check verify write turn on */ ret = onenand_verify_page(mtd, (u_char *) buf, to, block, page); if (ret) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_write_ecc: verify failed %d\n", ret); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_write_ecc: verify failed %d\n", ret); break; }
@@ -836,16 +839,17 @@ int onenand_write_oob(struct mtd_info *mtd, loff_t to, size_t len, int column, status; int written = 0;
- DEBUG(MTD_DEBUG_LEVEL3, "onenand_write_oob: to = 0x%08x, len = %i\n", - (unsigned int)to, (int)len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_write_oob: " + "to = 0x%08x, len = %i\n", + (unsigned int)to, (int)len);
/* Do not allow writes past end of device */ if (unlikely((to + len) > mtd->size)) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_write_oob: Attempt write to past end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_write_oob: " + "Attempt write to past end of device\n"); return -EINVAL; }
@@ -904,28 +908,29 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) int len; int ret = 0;
- DEBUG(MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int)instr->addr, (unsigned int)instr->len);
block_size = (1 << this->erase_shift);
/* Start address must align on block boundary */ if (unlikely(instr->addr & (block_size - 1))) { - DEBUG(MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_erase: Unaligned address\n"); return -EINVAL; }
/* Length must align on block boundary */ if (unlikely(instr->len & (block_size - 1))) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_erase: Length not block aligned\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_erase: Length not block aligned\n"); return -EINVAL; }
/* Do not allow erase past end of device */ if (unlikely((instr->len + instr->addr) > mtd->size)) { - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_erase: Erase past end of device\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, + "onenand_erase: Erase past end of device\n"); return -EINVAL; }
@@ -950,12 +955,12 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) /* Check, if it is write protected */ if (ret) { if (ret == -EPERM) - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_erase: Device is write protected!!!\n"); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " + "Device is write protected!!!\n"); else - DEBUG(MTD_DEBUG_LEVEL0, - "onenand_erase: Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); + MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " + "Failed erase, block %d\n", + (unsigned)(addr >> this->erase_shift)); instr->state = MTD_ERASE_FAILED; instr->fail_addr = addr; goto erase_exit; @@ -988,7 +993,7 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) */ void onenand_sync(struct mtd_info *mtd) { - DEBUG(MTD_DEBUG_LEVEL3, "onenand_sync: called\n"); + MTDDEBUG (MTD_DEBUG_LEVEL3, "onenand_sync: called\n");
/* Grab the lock and see if the device is available */ onenand_get_device(mtd, FL_SYNCING); diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index 5a610ee..87344ab 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -156,9 +156,9 @@ static int onenand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) block = (int)(offs >> (bbm->bbt_erase_shift - 1)); res = (bbm->bbt[block >> 3] >> (block & 0x06)) & 0x03;
- DEBUG(MTD_DEBUG_LEVEL2, - "onenand_isbad_bbt: bbt info for offs 0x%08x: (block %d) 0x%02x\n", - (unsigned int)offs, block >> 1, res); + MTDDEBUG (MTD_DEBUG_LEVEL2, + "onenand_isbad_bbt: bbt info for offs 0x%08x: (block %d) 0x%02x\n", + (unsigned int)offs, block >> 1, res);
switch ((int)res) { case 0x00: diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 71cb2d5..05ba375 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -201,13 +201,13 @@ static inline void mtd_erase_callback(struct erase_info *instr) #define MTD_DEBUG_LEVEL3 (3) /* Noisy */
#ifdef CONFIG_MTD_DEBUG -#define DEBUG(n, args...) \ +#define MTDDEBUG(n, args...) \ do { \ if (n <= CONFIG_MTD_DEBUG_VERBOSE) \ printk(KERN_INFO args); \ } while(0) #else /* CONFIG_MTD_DEBUG */ -#define DEBUG(n, args...) do { } while(0) +#define MTDDEBUG(n, args...) do { } while(0)
#endif /* CONFIG_MTD_DEBUG */
Scott Wood
