[PATCH 00/28] moveconfig: Drop old code and tidy up
This tool is designed to move CONFIG options to Kconfig. Since this task is complete, some of its functionality is no-longer needed.
This series drops the old code and tidies up some pylint errors.
It also improves the output by only displaying failures and providing a summary at the end.
Finally, the tool is given a new name.
Future work may provide a way to integrate the search functionality with buildman, to permit building boards with a a particular combination of CONFIG options.
Simon Glass (28): moveconfig: Drop -C option moveconfig: Drop -H option moveconfig: Avoid deprecation warning for setDaemon moveconfig: Correct ordering of asteval import moveconfig: Drop unused cleanup options moveconfig: Drop CONFIG-moving code moveconfig: Drop check_defconfig() and update_dotconfig() moveconfig: Drop suspicious boards moveconfig: Correct some regular-expression strings moveconfig: Correct parameter-type warnings moveconfig: Use f strings where possible moveconfig: Correct unused variables moveconfig: Correct non-snake variables names moveconfig: Correct use of members not declared in __init__() moveconfig: Correct list-comprehension warnings moveconfig: Use an encoding with open() moveconfig: Fix misc pylint warnings moveconfig: Only show output when there is a reason moveconfig: Reduce the amount of output moveconfig: Avoid showing progress at the end moveconfig: Use u_boot_pylib for terminal colour moveconfig: Show failures in progress moveconfig: Show a summary at the end moveconfig: Drop the initial output moveconfig: Move summaries to the end moveconfig: Rename the tool to qconfig qconfig: Rename the database file qconfig: Update the documentation
.gitignore | 4 +- doc/develop/index.rst | 2 +- doc/develop/{moveconfig.rst => qconfig.rst} | 148 +--- tools/{moveconfig.py => qconfig.py} | 910 +++++--------------- 4 files changed, 264 insertions(+), 800 deletions(-) rename doc/develop/{moveconfig.rst => qconfig.rst} (60%) rename tools/{moveconfig.py => qconfig.py} (64%)
Drop this option, which is no longer needed now that we have converted all CONFIG options to Kconfig.
tools/moveconfig.py | 14 -------------- 1 file changed, 14 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 6cbecc3d5c8..83c53911284 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1940,8 +1940,6 @@ doc/develop/moveconfig.rst for documentation.''' help='build a CONFIG database') parser.add_argument('-c', '--color', action='store_true', default=False, help='display the log in color') - parser.add_argument('-C', '--commit', action='store_true', default=False, - help='Create a git commit for the operation') parser.add_argument('-d', '--defconfigs', type=str, help='a file containing a list of defconfigs to move, ' "one per line (for example 'snow_defconfig') " @@ -2048,18 +2046,6 @@ doc/develop/moveconfig.rst for documentation.''' cleanup_headers(configs, args) cleanup_readme(configs, args)
- if args.commit: - subprocess.call(['git', 'add', '-u']) - if configs: - msg = 'Convert %s %sto Kconfig' % (configs[0], - 'et al ' if len(configs) > 1 else '') - msg += ('\n\nThis converts the following to Kconfig:\n %s\n' % - '\n '.join(configs)) - else: - msg = 'configs: Resync with savedefconfig' - msg += '\n\nRsync all defconfig files using moveconfig.py' - subprocess.call(['git', 'commit', '-s', '-m', msg]) - if args.build_db: with open(CONFIG_DATABASE, 'w', encoding='utf-8') as fd: for defconfig, configs in config_db.items():
NAK, I use this every -rc release as the configs do change around as part of resyncing them, and in turn as options change places slightly and/or dependencies get fixed.
tools/moveconfig.py | 18 +++++++----------- 1 file changed, 7 insertions(+), 11 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 83c53911284..7b7426726bd 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1949,9 +1949,6 @@ doc/develop/moveconfig.rst for documentation.''' help='exit immediately on any error') parser.add_argument('-f', '--find', action='store_true', default=False, help='Find boards with a given config combination') - parser.add_argument('-H', '--headers-only', dest='cleanup_headers_only', - action='store_true', default=False, - help='only cleanup the headers') parser.add_argument('-i', '--imply', action='store_true', default=False, help='find options which imply others') parser.add_argument('-I', '--imply-flags', type=str, default='', @@ -2033,14 +2030,13 @@ doc/develop/moveconfig.rst for documentation.''' t.setDaemon(True) t.start()
- if not args.cleanup_headers_only: - check_clean_directory() - bsettings.setup('') - toolchains = toolchain.Toolchains() - toolchains.GetSettings() - toolchains.Scan(verbose=False) - move_config(toolchains, configs, args, db_queue) - db_queue.join() + check_clean_directory() + bsettings.setup('') + toolchains = toolchain.Toolchains() + toolchains.GetSettings() + toolchains.Scan(verbose=False) + move_config(toolchains, configs, args, db_queue) + db_queue.join()
if configs: cleanup_headers(configs, args)
Use the recommended new way of setting a thread to be a daemon.
This avoids a warning:
DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
tools/moveconfig.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 7b7426726bd..446b68bcd10 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -2027,7 +2027,7 @@ doc/develop/moveconfig.rst for documentation.''' config_db = {} db_queue = queue.Queue() t = DatabaseThread(config_db, db_queue) - t.setDaemon(True) + t.daemon = True t.start()
This should be after the standard imports. Move it to avoid a lot of pylint warnings.
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 446b68bcd10..70dc6a4d144 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -11,7 +11,6 @@ See doc/develop/moveconfig.rst for documentation. """
from argparse import ArgumentParser -import asteval import collections from contextlib import ExitStack import copy @@ -32,6 +31,7 @@ import threading import time import unittest
+import asteval from buildman import bsettings from buildman import kconfiglib from buildman import toolchain
Cleaning up the README and config.h files are not needed now, since we don't have any CONFIG options to convert. Drop this code.
tools/moveconfig.py | 254 +------------------------------------------- 1 file changed, 2 insertions(+), 252 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 70dc6a4d144..767aee39a79 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -13,8 +13,6 @@ See doc/develop/moveconfig.rst for documentation. from argparse import ArgumentParser import collections from contextlib import ExitStack -import copy -import difflib import doctest import filecmp import fnmatch @@ -205,102 +203,6 @@ def color_text(color_enabled, color, string): for s in string.split('\n') ]) return string
-def show_diff(alines, blines, file_path, color_enabled): - """Show unidified diff. - - Args: - alines (list of str): A list of lines (before) - blines (list of str): A list of lines (after) - file_path (str): Path to the file - color_enabled (bool): Display the diff in color - """ - diff = difflib.unified_diff(alines, blines, - fromfile=os.path.join('a', file_path), - tofile=os.path.join('b', file_path)) - - for line in diff: - if line.startswith('-') and not line.startswith('--'): - print(color_text(color_enabled, COLOR_RED, line)) - elif line.startswith('+') and not line.startswith('++'): - print(color_text(color_enabled, COLOR_GREEN, line)) - else: - print(line) - -def extend_matched_lines(lines, matched, pre_patterns, post_patterns, - extend_pre, extend_post): - """Extend matched lines if desired patterns are found before/after already - matched lines. - - Args: - lines (list of str): list of lines handled. - matched (list of int): list of line numbers that have been already - matched (will be updated by this function) - pre_patterns (list of re.Pattern): list of regular expression that should - be matched as preamble - post_patterns (list of re.Pattern): list of regular expression that should - be matched as postamble - extend_pre (bool): Add the line number of matched preamble to the matched - list - extend_post (bool): Add the line number of matched postamble to the - matched list - """ - extended_matched = [] - - j = matched[0] - - for i in matched: - if i == 0 or i < j: - continue - j = i - while j in matched: - j += 1 - if j >= len(lines): - break - - for pat in pre_patterns: - if pat.search(lines[i - 1]): - break - else: - # not matched - continue - - for pat in post_patterns: - if pat.search(lines[j]): - break - else: - # not matched - continue - - if extend_pre: - extended_matched.append(i - 1) - if extend_post: - extended_matched.append(j) - - matched += extended_matched - matched.sort() - -def confirm(args, prompt): - """Ask the user to confirm something - - Args: - args (Namespace ): program arguments - - Returns: - bool: True to confirm, False to cancel/stop - """ - if not args.yes: - while True: - choice = input(f'{prompt} [y/n]: ') - choice = choice.lower() - print(choice) - if choice in ('y', 'n'): - break - - if choice == 'n': - return False - - return True - def write_file(fname, data): """Write data to a file
@@ -344,155 +246,6 @@ def read_file(fname, as_lines=True, skip_unicode=False): print("Failed on file %s': %s" % (fname, e)) return None
-def cleanup_empty_blocks(header_path, args): - """Clean up empty conditional blocks - - Args: - header_path (str): path to the cleaned file. - args (Namespace): program arguments - """ - pattern = re.compile(r'^\s*#\s*if.*$\n^\s*#\s*endif.*$\n*', flags=re.M) - data = read_file(header_path, as_lines=False, skip_unicode=True) - if data is None: - return - - new_data = pattern.sub('\n', data) - - show_diff(data.splitlines(True), new_data.splitlines(True), header_path, - args.color) - - if args.dry_run: - return - - if new_data != data: - write_file(header_path, new_data) - -def cleanup_one_header(header_path, patterns, args): - """Clean regex-matched lines away from a file. - - Args: - header_path: path to the cleaned file. - patterns: list of regex patterns. Any lines matching to these - patterns are deleted. - args (Namespace): program arguments - """ - lines = read_file(header_path, skip_unicode=True) - if lines is None: - return - - matched = [] - for i, line in enumerate(lines): - if i - 1 in matched and lines[i - 1].endswith('\'): - matched.append(i) - continue - for pattern in patterns: - if pattern.search(line): - matched.append(i) - break - - if not matched: - return - - # remove empty #ifdef ... #endif, successive blank lines - pattern_if = re.compile(r'#\s*if(def|ndef)?\b') # #if, #ifdef, #ifndef - pattern_elif = re.compile(r'#\s*el(if|se)\b') # #elif, #else - pattern_endif = re.compile(r'#\s*endif\b') # #endif - pattern_blank = re.compile(r'^\s*$') # empty line - - while True: - old_matched = copy.copy(matched) - extend_matched_lines(lines, matched, [pattern_if], - [pattern_endif], True, True) - extend_matched_lines(lines, matched, [pattern_elif], - [pattern_elif, pattern_endif], True, False) - extend_matched_lines(lines, matched, [pattern_if, pattern_elif], - [pattern_blank], False, True) - extend_matched_lines(lines, matched, [pattern_blank], - [pattern_elif, pattern_endif], True, False) - extend_matched_lines(lines, matched, [pattern_blank], - [pattern_blank], True, False) - if matched == old_matched: - break - - tolines = copy.copy(lines) - - for i in reversed(matched): - tolines.pop(i) - - show_diff(lines, tolines, header_path, args.color) - - if args.dry_run: - return - - write_file(header_path, tolines) - -def cleanup_headers(configs, args): - """Delete config defines from board headers. - - Args: - configs: A list of CONFIGs to remove. - args (Namespace): program arguments - """ - if not confirm(args, 'Clean up headers?'): - return - - patterns = [] - for config in configs: - patterns.append(re.compile(r'#\s*define\s+%s\b' % config)) - patterns.append(re.compile(r'#\s*undef\s+%s\b' % config)) - - for dir in 'include', 'arch', 'board': - for (dirpath, dirnames, filenames) in os.walk(dir): - if dirpath == os.path.join('include', 'generated'): - continue - for filename in filenames: - if not filename.endswith(('~', '.dts', '.dtsi', '.bin', - '.elf','.aml','.dat')): - header_path = os.path.join(dirpath, filename) - # This file contains UTF-16 data and no CONFIG symbols - if header_path == 'include/video_font_data.h': - continue - cleanup_one_header(header_path, patterns, args) - cleanup_empty_blocks(header_path, args) - -def find_matching(patterns, line): - for pat in patterns: - if pat.search(line): - return True - return False - -def cleanup_readme(configs, args): - """Delete config description in README - - Args: - configs: A list of CONFIGs to remove. - args (Namespace): program arguments - """ - if not confirm(args, 'Clean up README?'): - return - - patterns = [] - for config in configs: - patterns.append(re.compile(r'^\s+%s' % config)) - - lines = read_file('README') - - found = False - newlines = [] - for line in lines: - if not found: - found = find_matching(patterns, line) - if found: - continue - - if found and re.search(r'^\s+CONFIG', line): - found = False - - if not found: - newlines.append(line) - - write_file('README', newlines) - def try_expand(line): """If value looks like an expression, try expanding it Otherwise just return the existing value @@ -2024,6 +1777,7 @@ doc/develop/moveconfig.rst for documentation.''' do_find_config(configs) return
+ # We are either building the database or forcing a sync of defconfigs config_db = {} db_queue = queue.Queue() t = DatabaseThread(config_db, db_queue) @@ -2035,13 +1789,9 @@ doc/develop/moveconfig.rst for documentation.''' toolchains = toolchain.Toolchains() toolchains.GetSettings() toolchains.Scan(verbose=False) - move_config(toolchains, configs, args, db_queue) + move_config(toolchains, [], args, db_queue) db_queue.join()
- if configs: - cleanup_headers(configs, args) - cleanup_readme(configs, args) - if args.build_db: with open(CONFIG_DATABASE, 'w', encoding='utf-8') as fd: for defconfig, configs in config_db.items():
As a step towards cleaning out old code, drop most of the code that moves CONFIG options to Kconfig. This includes parse_one_config().
Drop the ACTION_... values as well, since they are no-longer used.
tools/moveconfig.py | 163 ++++++-------------------------------------- 1 file changed, 19 insertions(+), 144 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 767aee39a79..b32a9002b18 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -42,11 +42,6 @@ STATE_DEFCONFIG = 1 STATE_AUTOCONF = 2 STATE_SAVEDEFCONFIG = 3
-ACTION_MOVE = 0 -ACTION_NO_ENTRY = 1 -ACTION_NO_ENTRY_WARN = 2 -ACTION_NO_CHANGE = 3 - COLOR_BLACK = '0;30' COLOR_RED = '0;31' COLOR_GREEN = '0;32' @@ -312,15 +307,13 @@ class KconfigParser: re_arch = re.compile(r'CONFIG_SYS_ARCH="(.*)"') re_cpu = re.compile(r'CONFIG_SYS_CPU="(.*)"')
- def __init__(self, configs, args, build_dir): + def __init__(self, args, build_dir): """Create a new parser.
Args: - configs: A list of CONFIGs to move. args (Namespace): program arguments build_dir: Build directory. """ - self.configs = configs self.args = args self.dotconfig = os.path.join(build_dir, '.config') self.autoconf = os.path.join(build_dir, 'include', 'autoconf.mk') @@ -355,56 +348,6 @@ class KconfigParser:
return arch
- def parse_one_config(self, config, dotconfig_lines, autoconf_lines): - """Parse .config, defconfig, include/autoconf.mk for one config. - - This function looks for the config options in the lines from - defconfig, .config, and include/autoconf.mk in order to decide - which action should be taken for this defconfig. - - Args: - config: CONFIG name to parse. - dotconfig_lines: lines from the .config file. - autoconf_lines: lines from the include/autoconf.mk file. - - Returns: - A tupple of the action for this defconfig and the line - matched for the config. - """ - not_set = '# %s is not set' % config - - for line in autoconf_lines: - line = line.rstrip() - if line.startswith(config + '='): - new_val = line - break - else: - new_val = not_set - - new_val = try_expand(new_val) - - for line in dotconfig_lines: - line = line.rstrip() - if line.startswith(config + '=') or line == not_set: - old_val = line - break - else: - if new_val == not_set: - return (ACTION_NO_ENTRY, config) - else: - return (ACTION_NO_ENTRY_WARN, config) - - # If this CONFIG is neither bool nor trisate - if old_val[-2:] != '=y' and old_val[-2:] != '=m' and old_val != not_set: - # tools/scripts/define2mk.sed changes '1' to 'y'. - # This is a problem if the CONFIG is int type. - # Check the type in Kconfig and handle it correctly. - if new_val[-2:] == '=y': - new_val = new_val[:-1] + '1' - - return (ACTION_NO_CHANGE if old_val == new_val else ACTION_MOVE, - new_val) - def update_dotconfig(self): """Parse files for the config options and update the .config.
@@ -420,66 +363,17 @@ class KconfigParser: The "updated flag" is True if the .config was updated, False otherwise. The "log string" shows what happend to the .config. """ - - results = [] updated = False suspicious = False - rm_files = [self.config_autoconf, self.autoconf]
- if self.args.spl: - if os.path.exists(self.spl_autoconf): - autoconf_path = self.spl_autoconf - rm_files.append(self.spl_autoconf) - else: - for f in rm_files: - os.remove(f) - return (updated, suspicious, - color_text(self.args.color, COLOR_BROWN, - "SPL is not enabled. Skipped.") + '\n') - else: - autoconf_path = self.autoconf + autoconf_path = self.autoconf
dotconfig_lines = read_file(self.dotconfig)
autoconf_lines = read_file(autoconf_path)
- for config in self.configs: - result = self.parse_one_config(config, dotconfig_lines, - autoconf_lines) - results.append(result) - log = ''
- for (action, value) in results: - if action == ACTION_MOVE: - actlog = "Move '%s'" % value - log_color = COLOR_LIGHT_GREEN - elif action == ACTION_NO_ENTRY: - actlog = '%s is not defined in Kconfig. Do nothing.' % value - log_color = COLOR_LIGHT_BLUE - elif action == ACTION_NO_ENTRY_WARN: - actlog = '%s is not defined in Kconfig (suspicious). Do nothing.' % value - log_color = COLOR_YELLOW - suspicious = True - elif action == ACTION_NO_CHANGE: - actlog = "'%s' is the same as the define in Kconfig. Do nothing." \ - % value - log_color = COLOR_LIGHT_PURPLE - else: - sys.exit('Internal Error. This should not happen.') - - log += color_text(self.args.color, log_color, actlog) + '\n' - - with open(self.dotconfig, 'a', encoding='utf-8') as out: - for (action, value) in results: - if action == ACTION_MOVE: - out.write(value + '\n') - updated = True - - self.results = results - for f in rm_files: - os.remove(f) - return (updated, suspicious, log)
def check_defconfig(self): @@ -494,14 +388,6 @@ class KconfigParser:
defconfig_lines = read_file(self.defconfig)
- for (action, value) in self.results: - if action != ACTION_MOVE: - continue - if not value in defconfig_lines: - log += color_text(self.args.color, COLOR_YELLOW, - "'%s' was removed by savedefconfig.\n" % - value) - return log
@@ -541,13 +427,12 @@ class Slot: for faster processing. """
- def __init__(self, toolchains, configs, args, progress, devnull, + def __init__(self, toolchains, args, progress, devnull, make_cmd, reference_src_dir, db_queue): """Create a new process slot.
Args: toolchains: Toolchains object containing toolchains. - configs: A list of CONFIGs to move. args: Program arguments progress: A progress indicator. devnull: A file object of '/dev/null'. @@ -564,7 +449,7 @@ class Slot: self.make_cmd = (make_cmd, 'O=' + self.build_dir) self.reference_src_dir = reference_src_dir self.db_queue = db_queue - self.parser = KconfigParser(configs, args, self.build_dir) + self.parser = KconfigParser(args, self.build_dir) self.state = STATE_IDLE self.failed_boards = set() self.suspicious_boards = set() @@ -783,13 +668,11 @@ class Slots:
"""Controller of the array of subprocess slots."""
- def __init__(self, toolchains, configs, args, progress, - reference_src_dir, db_queue): + def __init__(self, toolchains, args, progress, reference_src_dir, db_queue): """Create a new slots controller.
Args: toolchains: Toolchains object containing toolchains. - configs: A list of CONFIGs to move. args: Program arguments progress: A progress indicator. reference_src_dir: Determine the true starting config state from this @@ -801,9 +684,8 @@ class Slots: devnull = subprocess.DEVNULL make_cmd = get_make_cmd() for i in range(args.jobs): - self.slots.append(Slot(toolchains, configs, args, progress, - devnull, make_cmd, reference_src_dir, - db_queue)) + self.slots.append(Slot(toolchains, args, progress, devnull, + make_cmd, reference_src_dir, db_queue))
def add(self, defconfig): """Add a new subprocess if a vacant slot is found. @@ -913,22 +795,18 @@ class ReferenceSource:
return self.src_dir
-def move_config(toolchains, configs, args, db_queue): - """Move config options to defconfig files. +def move_config(toolchains, args, db_queue): + """Build database or sync config options to defconfig files.
Args: - configs: A list of CONFIGs to move. + toolchains: Toolchains to use args: Program arguments + db_queue: Queue for database updates """ - if len(configs) == 0: - if args.force_sync: - print('No CONFIG is specified. You are probably syncing defconfigs.', end=' ') - elif args.build_db: - print('Building %s database' % CONFIG_DATABASE) - else: - print('Neither CONFIG nor --force-sync is specified. Nothing will happen.', end=' ') - else: - print('Move ' + ', '.join(configs), end=' ') + if args.force_sync: + print('Syncing defconfigs', end=' ') + elif args.build_db: + print('Building %s database' % CONFIG_DATABASE) print('(jobs: %d)\n' % args.jobs)
if args.git_ref: @@ -943,8 +821,7 @@ def move_config(toolchains, configs, args, db_queue): defconfigs = get_all_defconfigs()
progress = Progress(len(defconfigs)) - slots = Slots(toolchains, configs, args, progress, reference_src_dir, - db_queue) + slots = Slots(toolchains, args, progress, reference_src_dir, db_queue)
# Main loop to process defconfig files: # Add a new subprocess into a vacant slot. @@ -1729,7 +1606,6 @@ doc/develop/moveconfig.rst for documentation.''' parser.add_argument('configs', nargs='*')
args = parser.parse_args() - configs = args.configs
if args.test: sys.argv = [sys.argv[0]] @@ -1742,13 +1618,12 @@ doc/develop/moveconfig.rst for documentation.''' do_scan_source(os.getcwd(), args.update) return
- if not any((len(configs), args.force_sync, args.build_db, args.imply, - args.find)): + if not any((args.force_sync, args.build_db, args.imply, args.find)): parser.print_usage() sys.exit(1)
# prefix the option name with CONFIG_ if missing - configs = [prefix_config(cfg) for cfg in configs] + configs = [prefix_config(cfg) for cfg in args.configs]
check_top_directory()
@@ -1789,7 +1664,7 @@ doc/develop/moveconfig.rst for documentation.''' toolchains = toolchain.Toolchains() toolchains.GetSettings() toolchains.Scan(verbose=False) - move_config(toolchains, [], args, db_queue) + move_config(toolchains, args, db_queue) db_queue.join()
if args.build_db:
These functions are not needed anymore. Drop them.
tools/moveconfig.py | 62 ++------------------------------------------- 1 file changed, 2 insertions(+), 60 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index b32a9002b18..4f9bea0827f 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -348,48 +348,6 @@ class KconfigParser:
return arch
- def update_dotconfig(self): - """Parse files for the config options and update the .config. - - This function parses the generated .config and include/autoconf.mk - searching the target options. - Move the config option(s) to the .config as needed. - - Args: - defconfig: defconfig name. - - Returns: - Return a tuple of (updated flag, log string). - The "updated flag" is True if the .config was updated, False - otherwise. The "log string" shows what happend to the .config. - """ - updated = False - suspicious = False - - autoconf_path = self.autoconf - - dotconfig_lines = read_file(self.dotconfig) - - autoconf_lines = read_file(autoconf_path) - - log = '' - - return (updated, suspicious, log) - - def check_defconfig(self): - """Check the defconfig after savedefconfig - - Returns: - Return additional log if moved CONFIGs were removed again by - 'make savedefconfig'. - """ - - log = '' - - defconfig_lines = read_file(self.defconfig) - - return log -
class DatabaseThread(threading.Thread): """This thread processes results from Slot threads. @@ -452,7 +410,6 @@ class Slot: self.parser = KconfigParser(args, self.build_dir) self.state = STATE_IDLE self.failed_boards = set() - self.suspicious_boards = set()
def __del__(self): """Delete the working directory @@ -588,20 +545,10 @@ class Slot:
def do_savedefconfig(self): """Update the .config and run 'make savedefconfig'.""" - - (updated, suspicious, log) = self.parser.update_dotconfig() - if suspicious: - self.suspicious_boards.add(self.defconfig) - self.log += log - - if not self.args.force_sync and not updated: + if not self.args.force_sync: self.finish(True) return - if updated: - self.log += color_text(self.args.color, COLOR_LIGHT_GREEN, - 'Syncing by savedefconfig...\n') - else: - self.log += 'Syncing by savedefconfig (forced by option)...\n' + self.log += 'Syncing by savedefconfig (forced by option)...\n'
cmd = list(self.make_cmd) cmd.append('savedefconfig') @@ -611,11 +558,6 @@ class Slot:
def update_defconfig(self): """Update the input defconfig and go back to the idle state.""" - - log = self.parser.check_defconfig() - if log: - self.suspicious_boards.add(self.defconfig) - self.log += log orig_defconfig = os.path.join('configs', self.defconfig) new_defconfig = os.path.join(self.build_dir, 'defconfig') updated = not filecmp.cmp(orig_defconfig, new_defconfig)
This code isn't needed anymore. Drop it.
tools/moveconfig.py | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 4f9bea0827f..45b86cb1db5 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -601,11 +601,6 @@ class Slot: """ return self.failed_boards
- def get_suspicious_boards(self): - """Returns a set of boards (defconfigs) with possible misconversion. - """ - return self.suspicious_boards - self.failed_boards - class Slots:
"""Controller of the array of subprocess slots.""" @@ -684,25 +679,6 @@ class Slots:
write_file(output_file, boards)
- def show_suspicious_boards(self): - """Display all boards (defconfigs) with possible misconversion.""" - boards = set() - output_file = 'moveconfig.suspicious' - - for slot in self.slots: - boards |= slot.get_suspicious_boards() - - if boards: - boards = '\n'.join(boards) + '\n' - msg = 'The following boards might have been converted incorrectly.\n' - msg += 'It is highly recommended to check them manually:\n' - msg += boards - msg += '(the list has been saved in %s)\n' % output_file - print(color_text(self.args.color, COLOR_YELLOW, - msg), file=sys.stderr) - - write_file(output_file, boards) - class ReferenceSource:
"""Reference source against which original configs should be parsed.""" @@ -780,7 +756,6 @@ def move_config(toolchains, args, db_queue):
print('') slots.show_failed_boards() - slots.show_suspicious_boards()
def find_kconfig_rules(kconf, config, imply_config): """Check whether a config has a 'select' or 'imply' keyword
Use the 'r' prefix for these strings to avoid pylint warnings.
tools/moveconfig.py | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 45b86cb1db5..a282ae90d05 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1153,10 +1153,10 @@ def prefix_config(cfg): return op + cfg
-RE_MK_CONFIGS = re.compile('CONFIG_($(SPL_(?:TPL_)?))?([A-Za-z0-9_]*)') -RE_IFDEF = re.compile('(ifdef|ifndef)') -RE_C_CONFIGS = re.compile('CONFIG_([A-Za-z0-9_]*)') -RE_CONFIG_IS = re.compile('CONFIG_IS_ENABLED(([A-Za-z0-9_]*))') +RE_MK_CONFIGS = re.compile(r'CONFIG_($(SPL_(?:TPL_)?))?([A-Za-z0-9_]*)') +RE_IFDEF = re.compile(r'(ifdef|ifndef)') +RE_C_CONFIGS = re.compile(r'CONFIG_([A-Za-z0-9_]*)') +RE_CONFIG_IS = re.compile(r'CONFIG_IS_ENABLED(([A-Za-z0-9_]*))')
class ConfigUse: def __init__(self, cfg, is_spl, fname, rest):
Fix pylint warnings related to parameter types.
tools/moveconfig.py | 43 ++++++++++++++++++++++--------------------- 1 file changed, 22 insertions(+), 21 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index a282ae90d05..54ce8ef7d51 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -218,7 +218,7 @@ def read_file(fname, as_lines=True, skip_unicode=False):
Args: fname (str): Filename to read from - as_lines: Return file contents as a list of lines + as_lines (bool): Return file contents as a list of lines skip_unicode (bool): True to report unicode errors and continue
Returns: @@ -434,7 +434,7 @@ class Slot: the slot is occupied (i.e. the current subprocess is still running).
Args: - defconfig: defconfig name. + defconfig (str): defconfig name.
Returns: Return True on success or False on failure @@ -574,7 +574,7 @@ class Slot: """Display log along with progress and go to the idle state.
Args: - success: Should be True when the defconfig was processed + success (bool): Should be True when the defconfig was processed successfully, or False when it fails. """ # output at least 30 characters to hide the "* defconfigs out of *". @@ -628,7 +628,7 @@ class Slots: """Add a new subprocess if a vacant slot is found.
Args: - defconfig: defconfig name to be put into. + defconfig (str): defconfig name to be put into.
Returns: Return True on success or False on failure @@ -717,9 +717,9 @@ def move_config(toolchains, args, db_queue): """Build database or sync config options to defconfig files.
Args: - toolchains: Toolchains to use - args: Program arguments - db_queue: Queue for database updates + toolchains (Toolchains): Toolchains to use + args (Namespace): Program arguments + db_queue (Queue): Queue for database updates """ if args.force_sync: print('Syncing defconfigs', end=' ') @@ -761,10 +761,10 @@ def find_kconfig_rules(kconf, config, imply_config): """Check whether a config has a 'select' or 'imply' keyword
Args: - kconf: Kconfiglib.Kconfig object - config: Name of config to check (without CONFIG_ prefix) - imply_config: Implying config (without CONFIG_ prefix) which may or - may not have an 'imply' for 'config') + kconf (Kconfiglib.Kconfig): Kconfig object + config (str): Name of config to check (without CONFIG_ prefix) + imply_config (str): Implying config (without CONFIG_ prefix) which may + or may not have an 'imply' for 'config')
Returns: Symbol object for 'config' if found, else None @@ -783,16 +783,17 @@ def check_imply_rule(kconf, config, imply_config): to add an 'imply' for 'config' to that part of the Kconfig.
Returns: tuple: - filename of Kconfig file containing imply_config, or None if none - line number within the Kconfig file, or 0 if none - message indicating the result + str: filename of Kconfig file containing imply_config, or None if + none + int: line number within the Kconfig file, or 0 if none + str: message indicating the result """ sym = kconf.syms.get(imply_config) if not sym: @@ -815,9 +816,9 @@ def add_imply_rule(config, fname, linenum): """Add a new 'imply' option to a Kconfig
Args: - config: config option to add an imply for (without CONFIG_ prefix) - fname: Kconfig filename to update - linenum: Line number to place the 'imply' before + config (str): config option to add an imply for (without CONFIG_ prefix) + fname (str): Kconfig filename to update + linenum (int): Line number to place the 'imply' before
Returns: Message indicating the result
Avoid pylint warnings by using 'f' strings where possible.
tools/moveconfig.py | 56 ++++++++++++++++++++++----------------------- 1 file changed, 28 insertions(+), 28 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 54ce8ef7d51..cc35c4bce9d 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -238,7 +238,7 @@ def read_file(fname, as_lines=True, skip_unicode=False): except UnicodeDecodeError as e: if not skip_unicode: raise - print("Failed on file %s': %s" % (fname, e)) + print(f"Failed on file '{fname}: {e}") return None
def try_expand(line): @@ -254,10 +254,10 @@ def try_expand(line): val= val.strip('"') if re.search(r'[*+-/]|<<|SZ_+|(([^)]+))', val): newval = hex(aeval(val)) - print('\tExpanded expression %s to %s' % (val, newval)) + print(f'\tExpanded expression {val} to {newval}') return cfg+'='+newval except: - print('\tFailed to expand expression in %s' % line) + print(f'\tFailed to expand expression in {line}')
return line
@@ -283,7 +283,7 @@ class Progress:
def show(self): """Display the progress.""" - print(' %d defconfigs out of %d\r' % (self.current, self.total), end=' ') + print(f' {self.current} defconfigs out of {self.total}\r', end=' ') sys.stdout.flush()
@@ -520,7 +520,7 @@ class Slot: toolchain = self.toolchains.Select(arch) except ValueError: self.log += color_text(self.args.color, COLOR_YELLOW, - "Tool chain for '%s' is missing. Do nothing.\n" % arch) + f"Tool chain for '{arch}' is missing. Do nothing.\n") self.finish(False) return env = toolchain.MakeEnvironment(False) @@ -673,7 +673,7 @@ class Slots: boards = '\n'.join(boards) + '\n' msg = 'The following boards were not processed due to error:\n' msg += boards - msg += '(the list has been saved in %s)\n' % output_file + msg += f'(the list has been saved in {output_file})\n' print(color_text(self.args.color, COLOR_LIGHT_RED, msg), file=sys.stderr)
@@ -693,8 +693,9 @@ class ReferenceSource: print('Cloning git repo to a separate work directory...') subprocess.check_output(['git', 'clone', os.getcwd(), '.'], cwd=self.src_dir) - print("Checkout '%s' to build the original autoconf.mk." % \ - subprocess.check_output(['git', 'rev-parse', '--short', commit]).strip()) + rev = subprocess.check_output(['git', 'rev-parse', '--short', + commit]).strip() + print(f"Checkout '{rev}' to build the original autoconf.mk.") subprocess.check_output(['git', 'checkout', commit], stderr=subprocess.STDOUT, cwd=self.src_dir)
@@ -724,8 +725,8 @@ def move_config(toolchains, args, db_queue): if args.force_sync: print('Syncing defconfigs', end=' ') elif args.build_db: - print('Building %s database' % CONFIG_DATABASE) - print('(jobs: %d)\n' % args.jobs) + print(f'Building {CONFIG_DATABASE} database') + print(f'(jobs: {args.jobs})\n')
if args.git_ref: reference_src = ReferenceSource(args.git_ref) @@ -800,17 +801,17 @@ def check_imply_rule(kconf, config, imply_config): return 'cannot find sym' nodes = sym.nodes if len(nodes) != 1: - return '%d locations' % len(nodes) + return f'{len(nodes)} locations' node = nodes[0] fname, linenum = node.filename, node.linenr cwd = os.getcwd() if cwd and fname.startswith(cwd): fname = fname[len(cwd) + 1:] - file_line = ' at %s:%d' % (fname, linenum) + file_line = f' at {fname}:{linenum}' data = read_file(fname) - if data[linenum - 1] != 'config %s' % imply_config: - return None, 0, 'bad sym format %s%s' % (data[linenum], file_line) - return fname, linenum, 'adding%s' % file_line + if data[linenum - 1] != f'config {imply_config}': + return None, 0, f'bad sym format {data[linenum]}{file_line})' + return fname, linenum, f'adding{file_line}'
def add_imply_rule(config, fname, linenum): """Add a new 'imply' option to a Kconfig @@ -823,15 +824,15 @@ def add_imply_rule(config, fname, linenum): Returns: Message indicating the result """ - file_line = ' at %s:%d' % (fname, linenum) + file_line = f' at {fname}:{linenum}' data = read_file(fname) linenum -= 1
for offset, line in enumerate(data[linenum:]): if line.strip().startswith('help') or not line: - data.insert(linenum + offset, '\timply %s' % config) + data.insert(linenum + offset, f'\timply {config}') write_file(fname, data) - return 'added%s' % file_line + return f'added{file_line}'
return 'could not insert%s'
@@ -946,15 +947,14 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, for config in config_list: defconfigs = defconfig_db.get(config) if not defconfigs: - print('%s not found in any defconfig' % config) + print(f'{config} not found in any defconfig') continue
# Get the set of defconfigs without this one (since a config cannot # imply itself) non_defconfigs = all_defconfigs - defconfigs num_defconfigs = len(defconfigs) - print('%s found in %d/%d defconfigs' % (config, num_defconfigs, - len(all_configs))) + print(f'{config} found in {num_defconfigs}/{len(all_configs)} defconfigs')
# This will hold the results: key=config, value=defconfigs containing it imply_configs = {} @@ -1035,7 +1035,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, fname, linenum = nodes[0].filename, nodes[0].linenr if cwd and fname.startswith(cwd): fname = fname[len(cwd) + 1:] - kconfig_info = '%s:%d' % (fname, linenum) + kconfig_info = f'{fname}:{linenum}' if skip_added: show = False else: @@ -1061,8 +1061,8 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, add_list[fname].append(linenum)
if show and kconfig_info != 'skip': - print('%5d : %-30s%-25s %s' % (num_common, iconfig.ljust(30), - kconfig_info, missing_str)) + print(f'{num_common:5d} : ' + f'{iconfig.ljust(30):-30s}{kconfig_info:-25s} {missing_str}')
# Having collected a list of things to add, now we add them. We process # each file from the largest line number to the smallest so that @@ -1554,11 +1554,11 @@ doc/develop/moveconfig.rst for documentation.''' for flag in args.imply_flags.split(','): bad = flag not in IMPLY_FLAGS if bad: - print("Invalid flag '%s'" % flag) + print(f"Invalid flag '{flag}'") if flag == 'help' or bad: print("Imply flags: (separate with ',')") for name, info in IMPLY_FLAGS.items(): - print(' %-15s: %s' % (name, info[1])) + print(f' {name:-15s}: {info[1]}') parser.print_usage() sys.exit(1) imply_flags |= IMPLY_FLAGS[flag][0] @@ -1588,9 +1588,9 @@ doc/develop/moveconfig.rst for documentation.''' if args.build_db: with open(CONFIG_DATABASE, 'w', encoding='utf-8') as fd: for defconfig, configs in config_db.items(): - fd.write('%s\n' % defconfig) + fd.write(f'{defconfig}\n') for config in sorted(configs.keys()): - fd.write(' %s=%s\n' % (config, configs[config])) + fd.write(f' {config}={configs[config]}\n') fd.write('\n')
if __name__ == '__main__':
Fix pylint warnings about unused variables.
tools/moveconfig.py | 26 ++++++++++++-------------- 1 file changed, 12 insertions(+), 14 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index cc35c4bce9d..02c1d13f865 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -620,7 +620,7 @@ class Slots: self.slots = [] devnull = subprocess.DEVNULL make_cmd = get_make_cmd() - for i in range(args.jobs): + for _ in range(args.jobs): self.slots.append(Slot(toolchains, args, progress, devnull, make_cmd, reference_src_dir, db_queue))
@@ -772,7 +772,7 @@ def find_kconfig_rules(kconf, config, imply_config): """ sym = kconf.syms.get(imply_config) if sym: - for sel, cond in (sym.selects + sym.implies): + for sel, _ in (sym.selects + sym.implies): if sel.name == config: return sym return None @@ -941,7 +941,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, if add_imply and add_imply != 'all': add_imply = add_imply.split(',')
- all_configs, all_defconfigs, config_db, defconfig_db = read_database() + all_configs, all_defconfigs, _, defconfig_db = read_database()
# Work through each target config option in turn, independently for config in config_list: @@ -1101,7 +1101,7 @@ def do_find_config(config_list): is preceded by a tilde (~) then it must be false, otherwise it must be true) """ - all_configs, all_defconfigs, config_db, defconfig_db = read_database() + _, all_defconfigs, config_db, _ = read_database()
# Start with all defconfigs out = all_defconfigs @@ -1199,9 +1199,7 @@ def scan_makefiles(fnames): fname_uses = {} for fname, rest in fnames: m_iter = RE_MK_CONFIGS.finditer(rest) - found = False for m in m_iter: - found = True real_opt = m.group(2) if real_opt == '': continue @@ -1242,9 +1240,11 @@ def scan_src_files(fnames): >>> RE_CONFIG_IS.search('#if CONFIG_IS_ENABLED(OF_PLATDATA)').groups() ('OF_PLATDATA',) """ + fname = None + rest = None + def add_uses(m_iter, is_spl): for m in m_iter: - found = True real_opt = m.group(1) if real_opt == '': continue @@ -1302,7 +1302,7 @@ def do_scan_source(path, do_update): """ # Make sure we know about all the options not_found = collections.defaultdict(list) - for use, rest in all_uses.items(): + for use, _ in all_uses.items(): name = use.cfg if name in IGNORE_SYMS: continue @@ -1314,7 +1314,6 @@ def do_scan_source(path, do_update): # If it is an SPL symbol, try prepending all SPL_ prefixes to # find at least one SPL symbol if use.is_spl: - add_to_dict = False for prefix in SPL_PREFIXES: try_name = prefix + name sym = kconf.syms.get(try_name) @@ -1332,7 +1331,6 @@ def do_scan_source(path, do_update): elif not use.is_spl: check = False else: # MODE_NORMAL - debug = False sym = kconf.syms.get(name) if not sym: proper_name = is_not_proper(name) @@ -1373,7 +1371,7 @@ def do_scan_source(path, do_update): print(f'Scanning source in {path}') args = ['git', 'grep', '-E', r'IS_ENABLED|\bCONFIG'] with subprocess.Popen(args, stdout=subprocess.PIPE) as proc: - out, err = proc.communicate() + out, _ = proc.communicate() lines = out.splitlines() re_fname = re.compile('^([^:]*):(.*)') src_list = [] @@ -1407,7 +1405,7 @@ def do_scan_source(path, do_update): print(f'Not sure how to handle file {fname}')
# Scan the Makefiles - all_uses, fname_uses = scan_makefiles(mk_list) + all_uses, _ = scan_makefiles(mk_list)
spl_not_found = set() proper_not_found = set() @@ -1428,7 +1426,7 @@ def do_scan_source(path, do_update): proper_not_found |= set([key for key in not_found.keys()])
# Scan the source code - all_uses, fname_uses = scan_src_files(src_list) + all_uses, _ = scan_src_files(src_list)
# Make sure we know about all the options print('\nCONFIG options present in source but not Kconfig:') @@ -1527,7 +1525,7 @@ doc/develop/moveconfig.rst for documentation.'''
if args.test: sys.argv = [sys.argv[0]] - fail, count = doctest.testmod() + fail, _ = doctest.testmod() if fail: return 1 unittest.main()
Correct some variable names that do not conform to snake case, with the three-character minimum.
tools/moveconfig.py | 70 ++++++++++++++++++++++----------------------- 1 file changed, 35 insertions(+), 35 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 02c1d13f865..4a47d1578eb 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -235,10 +235,10 @@ def read_file(fname, as_lines=True, skip_unicode=False): return [line.rstrip('\n') for line in inf.readlines()] else: return inf.read() - except UnicodeDecodeError as e: + except UnicodeDecodeError as exc: if not skip_unicode: raise - print(f"Failed on file '{fname}: {e}") + print(f"Failed on file '{fname}: {exc}") return None
def try_expand(line): @@ -331,13 +331,13 @@ class KconfigParser: arch = '' cpu = '' for line in read_file(self.dotconfig): - m = self.re_arch.match(line) - if m: - arch = m.group(1) + m_arch = self.re_arch.match(line) + if m_arch: + arch = m_arch.group(1) continue - m = self.re_cpu.match(line) - if m: - cpu = m.group(1) + m_cpu = self.re_cpu.match(line) + if m_cpu: + cpu = m_cpu.group(1)
if not arch: return None @@ -422,7 +422,7 @@ class Slot: If the subprocess is still running, wait until it finishes. """ if self.state != STATE_IDLE: - while self.ps.poll() == None: + while self.proc.poll() == None: pass shutil.rmtree(self.build_dir)
@@ -467,10 +467,10 @@ class Slot: if self.state == STATE_IDLE: return True
- if self.ps.poll() == None: + if self.proc.poll() == None: return False
- if self.ps.poll() != 0: + if self.proc.poll() != 0: self.handle_error() elif self.state == STATE_DEFCONFIG: if self.reference_src_dir and not self.current_src_dir: @@ -499,7 +499,7 @@ class Slot: 'Failed to process.\n') if self.args.verbose: self.log += color_text(self.args.color, COLOR_LIGHT_CYAN, - self.ps.stderr.read().decode()) + self.proc.stderr.read().decode()) self.finish(False)
def do_defconfig(self): @@ -507,9 +507,9 @@ class Slot:
cmd = list(self.make_cmd) cmd.append(self.defconfig) - self.ps = subprocess.Popen(cmd, stdout=self.devnull, - stderr=subprocess.PIPE, - cwd=self.current_src_dir) + self.proc = subprocess.Popen(cmd, stdout=self.devnull, + stderr=subprocess.PIPE, + cwd=self.current_src_dir) self.state = STATE_DEFCONFIG
def do_autoconf(self): @@ -528,9 +528,9 @@ class Slot: cmd = list(self.make_cmd) cmd.append('KCONFIG_IGNORE_DUPLICATES=1') cmd.append(AUTO_CONF_PATH) - self.ps = subprocess.Popen(cmd, stdout=self.devnull, env=env, - stderr=subprocess.PIPE, - cwd=self.current_src_dir) + self.proc = subprocess.Popen(cmd, stdout=self.devnull, env=env, + stderr=subprocess.PIPE, + cwd=self.current_src_dir) self.state = STATE_AUTOCONF
def do_build_db(self): @@ -552,8 +552,8 @@ class Slot:
cmd = list(self.make_cmd) cmd.append('savedefconfig') - self.ps = subprocess.Popen(cmd, stdout=self.devnull, - stderr=subprocess.PIPE) + self.proc = subprocess.Popen(cmd, stdout=self.devnull, + stderr=subprocess.PIPE) self.state = STATE_SAVEDEFCONFIG
def update_defconfig(self): @@ -1145,13 +1145,13 @@ def prefix_config(cfg): >>> prefix_config('A123') 'CONFIG_A123' """ - op = '' + oper = '' if cfg[0] == '~': - op = cfg[0] + oper = cfg[0] cfg = cfg[1:] if not cfg.startswith('CONFIG_'): cfg = 'CONFIG_' + cfg - return op + cfg + return oper + cfg
RE_MK_CONFIGS = re.compile(r'CONFIG_($(SPL_(?:TPL_)?))?([A-Za-z0-9_]*)') @@ -1199,12 +1199,12 @@ def scan_makefiles(fnames): fname_uses = {} for fname, rest in fnames: m_iter = RE_MK_CONFIGS.finditer(rest) - for m in m_iter: - real_opt = m.group(2) + for mat in m_iter: + real_opt = mat.group(2) if real_opt == '': continue is_spl = False - if m.group(1): + if mat.group(1): is_spl = True use = ConfigUse(real_opt, is_spl, fname, rest) if fname not in fname_uses: @@ -1244,8 +1244,8 @@ def scan_src_files(fnames): rest = None
def add_uses(m_iter, is_spl): - for m in m_iter: - real_opt = m.group(1) + for mat in m_iter: + real_opt = mat.group(1) if real_opt == '': continue use = ConfigUse(real_opt, is_spl, fname, rest) @@ -1571,9 +1571,9 @@ doc/develop/moveconfig.rst for documentation.''' # We are either building the database or forcing a sync of defconfigs config_db = {} db_queue = queue.Queue() - t = DatabaseThread(config_db, db_queue) - t.daemon = True - t.start() + dbt = DatabaseThread(config_db, db_queue) + dbt.daemon = True + dbt.start()
check_clean_directory() bsettings.setup('') @@ -1584,12 +1584,12 @@ doc/develop/moveconfig.rst for documentation.''' db_queue.join()
if args.build_db: - with open(CONFIG_DATABASE, 'w', encoding='utf-8') as fd: + with open(CONFIG_DATABASE, 'w', encoding='utf-8') as outf: for defconfig, configs in config_db.items(): - fd.write(f'{defconfig}\n') + outf.write(f'{defconfig}\n') for config in sorted(configs.keys()): - fd.write(f' {config}={configs[config]}\n') - fd.write('\n') + outf.write(f' {config}={configs[config]}\n') + outf.write('\n')
if __name__ == '__main__': sys.exit(main())
Fix these pylint warnings.
tools/moveconfig.py | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 4a47d1578eb..fbfa71b186a 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -410,6 +410,10 @@ class Slot: self.parser = KconfigParser(args, self.build_dir) self.state = STATE_IDLE self.failed_boards = set() + self.defconfig = None + self.log = '' + self.current_src_dir = None + self.proc = None
Correct some pylint warnings about needing to use list comprehension.
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index fbfa71b186a..309ff89f7af 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1422,12 +1422,12 @@ def do_scan_source(path, do_update): print('\nCONFIG options present in Makefiles but not Kconfig (SPL):') not_found = check_not_found(all_uses, MODE_SPL) show_uses(not_found) - spl_not_found |= set([is_not_proper(key) or key for key in not_found.keys()]) + spl_not_found |= {is_not_proper(key) or key for key in not_found.keys()}
print('\nCONFIG options used as Proper in Makefiles but without a non-SPL_ variant:') not_found = check_not_found(all_uses, MODE_PROPER) show_uses(not_found) - proper_not_found |= set([key for key in not_found.keys()]) + proper_not_found |= {not_found.keys()}
# Scan the source code all_uses, _ = scan_src_files(src_list) @@ -1440,12 +1440,12 @@ def do_scan_source(path, do_update): print('\nCONFIG options present in source but not Kconfig (SPL):') not_found = check_not_found(all_uses, MODE_SPL) show_uses(not_found) - spl_not_found |= set([is_not_proper(key) or key for key in not_found.keys()]) + spl_not_found |= {is_not_proper(key) or key for key in not_found.keys()}
print('\nCONFIG options used as Proper in source but without a non-SPL_ variant:') not_found = check_not_found(all_uses, MODE_PROPER) show_uses(not_found) - proper_not_found |= set([key for key in not_found.keys()]) + proper_not_found |= {not_found.keys()}
print('\nCONFIG options used as SPL but without an SPL_ variant:') for item in sorted(spl_not_found):
Fix pylint warnings about needing an explicit character encoding.
tools/moveconfig.py | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 309ff89f7af..5896deb8c71 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1457,12 +1457,14 @@ def do_scan_source(path, do_update):
# Write out the updated information if do_update: - with open(os.path.join(path, 'scripts', 'conf_nospl'), 'w') as out: + with open(os.path.join(path, 'scripts', 'conf_nospl'), 'w', + encoding='utf-8') as out: print('# These options should not be enabled in SPL builds\n', file=out) for item in sorted(spl_not_found): print(item, file=out) - with open(os.path.join(path, 'scripts', 'conf_noproper'), 'w') as out: + with open(os.path.join(path, 'scripts', 'conf_noproper'), 'w', + encoding='utf-8') as out: print('# These options should not be enabled in Proper builds\n', file=out) for item in sorted(proper_not_found):
Fix various remaining pylint warnings.
tools/moveconfig.py | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 5896deb8c71..816eb151bdf 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -233,8 +233,7 @@ def read_file(fname, as_lines=True, skip_unicode=False): try: if as_lines: return [line.rstrip('\n') for line in inf.readlines()] - else: - return inf.read() + return inf.read() except UnicodeDecodeError as exc: if not skip_unicode: raise @@ -426,7 +425,7 @@ class Slot: If the subprocess is still running, wait until it finishes. """ if self.state != STATE_IDLE: - while self.proc.poll() == None: + while self.proc.poll() is None: pass shutil.rmtree(self.build_dir)
@@ -471,7 +470,7 @@ class Slot: if self.state == STATE_IDLE: return True
- if self.proc.poll() == None: + if self.proc.poll() is None: return False
if self.proc.poll() != 0: @@ -494,7 +493,7 @@ class Slot: else: sys.exit('Internal Error. This should not happen.')
- return True if self.state == STATE_IDLE else False + return self.state == STATE_IDLE
def handle_error(self): """Handle error cases.""" @@ -521,13 +520,13 @@ class Slot:
arch = self.parser.get_arch() try: - toolchain = self.toolchains.Select(arch) + tchain = self.toolchains.Select(arch) except ValueError: self.log += color_text(self.args.color, COLOR_YELLOW, f"Tool chain for '{arch}' is missing. Do nothing.\n") self.finish(False) return - env = toolchain.MakeEnvironment(False) + env = tchain.MakeEnvironment(False)
cmd = list(self.make_cmd) cmd.append('KCONFIG_IGNORE_DUPLICATES=1') @@ -1004,7 +1003,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, # skip imply_config because prev is a superset skip = True break - elif count > prev_count: + if count > prev_count: # delete prev because imply_config is a superset del imply_configs[prev] if not skip: @@ -1538,7 +1537,7 @@ doc/develop/moveconfig.rst for documentation.'''
if args.scan_source: do_scan_source(os.getcwd(), args.update) - return + return 0
if not any((args.force_sync, args.build_db, args.imply, args.find)): parser.print_usage() @@ -1568,11 +1567,11 @@ doc/develop/moveconfig.rst for documentation.''' imply_flags |= IMPLY_FLAGS[flag][0]
do_imply_config(configs, args.add_imply, imply_flags, args.skip_added) - return + return 0
if args.find: do_find_config(configs) - return + return 0
# We are either building the database or forcing a sync of defconfigs config_db = {} @@ -1596,6 +1595,8 @@ doc/develop/moveconfig.rst for documentation.''' for config in sorted(configs.keys()): outf.write(f' {config}={configs[config]}\n') outf.write('\n') + return 0 +
There is no point in listing a board if everything went well. It makes it harder to see the failures, particularly on a fast machine.
Suppress output unless something actually happened.
Drop the 'Syncing by savedefconfig' since this is selected by the -s and is the same for all boards in this mode.
tools/moveconfig.py | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 816eb151bdf..08ff82a4c02 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -551,7 +551,6 @@ class Slot: if not self.args.force_sync: self.finish(True) return - self.log += 'Syncing by savedefconfig (forced by option)...\n'
cmd = list(self.make_cmd) cmd.append('savedefconfig') @@ -581,12 +580,13 @@ class Slot: successfully, or False when it fails. """ # output at least 30 characters to hide the "* defconfigs out of *". - log = self.defconfig.ljust(30) + '\n' + if self.log: + log = self.defconfig.ljust(30) + '\n'
- log += '\n'.join([ ' ' + s for s in self.log.split('\n') ]) - # Some threads are running in parallel. - # Print log atomically to not mix up logs from different threads. - print(log, file=(sys.stdout if success else sys.stderr)) + log += '\n'.join([ ' ' + s for s in self.log.split('\n') ]) + # Some threads are running in parallel. + # Print log atomically to not mix up logs from different threads. + print(log, file=(sys.stdout if success else sys.stderr))
if not success: if self.args.exit_on_error:
Output a single line in the case where the defconfig only has one line of output. Show the name without the _defconfig suffix, since that is the same for all boards.
Use a list for the log so it is easier to process at the end.
tools/moveconfig.py | 29 +++++++++++++++++------------ 1 file changed, 17 insertions(+), 12 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 08ff82a4c02..b97f82cd689 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -410,7 +410,7 @@ class Slot: self.state = STATE_IDLE self.failed_boards = set() self.defconfig = None - self.log = '' + self.log = [] self.current_src_dir = None self.proc = None
@@ -446,7 +446,7 @@ class Slot: return False
self.defconfig = defconfig - self.log = '' + self.log = [] self.current_src_dir = self.reference_src_dir self.do_defconfig() return True @@ -498,11 +498,12 @@ class Slot: def handle_error(self): """Handle error cases."""
- self.log += color_text(self.args.color, COLOR_LIGHT_RED, - 'Failed to process.\n') + self.log.append(color_text(self.args.color, COLOR_LIGHT_RED, + 'Failed to process')) if self.args.verbose: - self.log += color_text(self.args.color, COLOR_LIGHT_CYAN, - self.proc.stderr.read().decode()) + for line in self.proc.stderr.read().decode().splitlines(): + self.log.append(color_text(self.args.color, COLOR_LIGHT_CYAN, + line)) self.finish(False)
def do_defconfig(self): @@ -522,8 +523,8 @@ class Slot: try: tchain = self.toolchains.Select(arch) except ValueError: - self.log += color_text(self.args.color, COLOR_YELLOW, - f"Tool chain for '{arch}' is missing. Do nothing.\n") + self.log.append(color_text(self.args.color, COLOR_YELLOW, + f"Tool chain for '{arch}' is missing: do nothing")) self.finish(False) return env = tchain.MakeEnvironment(False) @@ -565,8 +566,8 @@ class Slot: updated = not filecmp.cmp(orig_defconfig, new_defconfig)
if updated: - self.log += color_text(self.args.color, COLOR_LIGHT_BLUE, - 'defconfig was updated.\n') + self.log.append(color_text(self.args.color, COLOR_LIGHT_BLUE, + 'defconfig updated'))
if not self.args.dry_run and updated: shutil.move(new_defconfig, orig_defconfig) @@ -581,9 +582,13 @@ class Slot: """ # output at least 30 characters to hide the "* defconfigs out of *". if self.log: - log = self.defconfig.ljust(30) + '\n' + name = self.defconfig[:-len('_defconfig')]
- log += '\n'.join([ ' ' + s for s in self.log.split('\n') ]) + # Put the first log line on the first line + log = name.ljust(20) + ' ' + self.log[0] + + if len(self.log) > 1: + log += '\n' + '\n'.join([' ' + s for s in self.log[1:]]) # Some threads are running in parallel. # Print log atomically to not mix up logs from different threads. print(log, file=(sys.stdout if success else sys.stderr))
When the process is finished, moveconfig leaves a line saying that all boards were processed (for better or worse). Drop this, since it is unncessary.
Future work will provide a summary at the end instead.
tools/moveconfig.py | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index b97f82cd689..f4fb3f46b81 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -282,7 +282,8 @@ class Progress:
def show(self): """Display the progress.""" - print(f' {self.current} defconfigs out of {self.total}\r', end=' ') + if self.current != self.total: + print(f' {self.current} defconfigs out of {self.total}\r', end=' ') sys.stdout.flush()
Use the existing terminal code to handle ANSI colours. Enable colour by default if the output is going to a terminal.
tools/moveconfig.py | 92 +++++++++++++++++++-------------------------- 1 file changed, 38 insertions(+), 54 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index f4fb3f46b81..30d8489f7e3 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -33,6 +33,7 @@ import asteval from buildman import bsettings from buildman import kconfiglib from buildman import toolchain +from u_boot_pylib import terminal
SHOW_GNU_MAKE = 'scripts/show-gnu-make' SLEEP_TIME=0.03 @@ -42,23 +43,6 @@ STATE_DEFCONFIG = 1 STATE_AUTOCONF = 2 STATE_SAVEDEFCONFIG = 3
-COLOR_BLACK = '0;30' -COLOR_RED = '0;31' -COLOR_GREEN = '0;32' -COLOR_BROWN = '0;33' -COLOR_BLUE = '0;34' -COLOR_PURPLE = '0;35' -COLOR_CYAN = '0;36' -COLOR_LIGHT_GRAY = '0;37' -COLOR_DARK_GRAY = '1;30' -COLOR_LIGHT_RED = '1;31' -COLOR_LIGHT_GREEN = '1;32' -COLOR_YELLOW = '1;33' -COLOR_LIGHT_BLUE = '1;34' -COLOR_LIGHT_PURPLE = '1;35' -COLOR_LIGHT_CYAN = '1;36' -COLOR_WHITE = '1;37' - AUTO_CONF_PATH = 'include/config/auto.conf' CONFIG_DATABASE = 'moveconfig.db'
@@ -189,15 +173,6 @@ def get_all_defconfigs():
return defconfigs
-def color_text(color_enabled, color, string): - """Return colored string.""" - if color_enabled: - # LF should not be surrounded by the escape sequence. - # Otherwise, additional whitespace or line-feed might be printed. - return '\n'.join([ '\033[' + color + 'm' + s + '\033[0m' if s else '' - for s in string.split('\n') ]) - return string - def write_file(fname, data): """Write data to a file
@@ -385,8 +360,8 @@ class Slot: for faster processing. """
- def __init__(self, toolchains, args, progress, devnull, - make_cmd, reference_src_dir, db_queue): + def __init__(self, toolchains, args, progress, devnull, make_cmd, + reference_src_dir, db_queue, col): """Create a new process slot.
Args: @@ -398,6 +373,7 @@ class Slot: reference_src_dir: Determine the true starting config state from this source tree. db_queue: output queue to write config info for the database + col (terminal.Color): Colour object """ self.toolchains = toolchains self.args = args @@ -407,6 +383,7 @@ class Slot: self.make_cmd = (make_cmd, 'O=' + self.build_dir) self.reference_src_dir = reference_src_dir self.db_queue = db_queue + self.col = col self.parser = KconfigParser(args, self.build_dir) self.state = STATE_IDLE self.failed_boards = set() @@ -499,12 +476,11 @@ class Slot: def handle_error(self): """Handle error cases."""
- self.log.append(color_text(self.args.color, COLOR_LIGHT_RED, - 'Failed to process')) + self.log.append(self.col.build(self.col.RED, 'Failed to process', + bright=True)) if self.args.verbose: for line in self.proc.stderr.read().decode().splitlines(): - self.log.append(color_text(self.args.color, COLOR_LIGHT_CYAN, - line)) + self.log.append(self.col.build(self.col.CYAN, line, True)) self.finish(False)
def do_defconfig(self): @@ -524,8 +500,9 @@ class Slot: try: tchain = self.toolchains.Select(arch) except ValueError: - self.log.append(color_text(self.args.color, COLOR_YELLOW, - f"Tool chain for '{arch}' is missing: do nothing")) + self.log.append(self.col.build( + self.col.YELLOW, + f"Tool chain for '{arch}' is missing: do nothing")) self.finish(False) return env = tchain.MakeEnvironment(False) @@ -567,8 +544,8 @@ class Slot: updated = not filecmp.cmp(orig_defconfig, new_defconfig)
if updated: - self.log.append(color_text(self.args.color, COLOR_LIGHT_BLUE, - 'defconfig updated')) + self.log.append( + self.col.build(self.col.BLUE, 'defconfig updated', bright=True))
if not self.args.dry_run and updated: shutil.move(new_defconfig, orig_defconfig) @@ -614,24 +591,27 @@ class Slots:
- def __init__(self, toolchains, args, progress, reference_src_dir, db_queue): + def __init__(self, toolchains, args, progress, reference_src_dir, db_queue, + col): """Create a new slots controller.
Args: - toolchains: Toolchains object containing toolchains. - args: Program arguments - progress: A progress indicator. - reference_src_dir: Determine the true starting config state from this - source tree. - db_queue: output queue to write config info for the database + toolchains (Toolchains): Toolchains object containing toolchains + args (Namespace): Program arguments + progress (Progress): A progress indicator. + reference_src_dir (str): Determine the true starting config state + from this source tree (None for none) + db_queue (Queue): output queue to write config info for the database + col (terminal.Color): Colour object """ self.args = args self.slots = [] + self.col = col devnull = subprocess.DEVNULL make_cmd = get_make_cmd() for _ in range(args.jobs): self.slots.append(Slot(toolchains, args, progress, devnull, - make_cmd, reference_src_dir, db_queue)) + make_cmd, reference_src_dir, db_queue, col))
def add(self, defconfig): """Add a new subprocess if a vacant slot is found. @@ -683,8 +663,8 @@ class Slots: msg = 'The following boards were not processed due to error:\n' msg += boards msg += f'(the list has been saved in {output_file})\n' - print(color_text(self.args.color, COLOR_LIGHT_RED, - msg), file=sys.stderr) + print(self.col.build(self.col.RED, msg, bright=True), + file=sys.stderr)
@@ -723,13 +703,14 @@ class ReferenceSource:
return self.src_dir
-def move_config(toolchains, args, db_queue): +def move_config(toolchains, args, db_queue, col): """Build database or sync config options to defconfig files.
Args: - toolchains (Toolchains): Toolchains to use - args (Namespace): Program arguments - db_queue (Queue): Queue for database updates + toolchains (Toolchains): Toolchains to use + args (Namespace): Program arguments + db_queue (Queue): Queue for database updates + col (terminal.Color): Colour object """ if args.force_sync: print('Syncing defconfigs', end=' ') @@ -749,7 +730,7 @@ def move_config(toolchains, args, db_queue): defconfigs = get_all_defconfigs()
progress = Progress(len(defconfigs)) - slots = Slots(toolchains, args, progress, reference_src_dir, db_queue) + slots = Slots(toolchains, args, progress, reference_src_dir, db_queue, col)
# Main loop to process defconfig files: # Add a new subprocess into a vacant slot. @@ -1495,8 +1476,8 @@ doc/develop/moveconfig.rst for documentation.''' 'implying others') parser.add_argument('-b', '--build-db', action='store_true', default=False, help='build a CONFIG database') - parser.add_argument('-c', '--color', action='store_true', default=False, - help='display the log in color') + parser.add_argument('-C', '--nocolour', action='store_true', default=False, + help="don't display the log in colour") parser.add_argument('-d', '--defconfigs', type=str, help='a file containing a list of defconfigs to move, ' "one per line (for example 'snow_defconfig') " @@ -1541,6 +1522,9 @@ doc/develop/moveconfig.rst for documentation.''' return 1 unittest.main()
+ col = terminal.Color(terminal.COLOR_NEVER if args.nocolour + else terminal.COLOR_IF_TERMINAL) + if args.scan_source: do_scan_source(os.getcwd(), args.update) return 0 @@ -1591,7 +1575,7 @@ doc/develop/moveconfig.rst for documentation.''' toolchains = toolchain.Toolchains() toolchains.GetSettings() toolchains.Scan(verbose=False) - move_config(toolchains, args, db_queue) + move_config(toolchains, args, db_queue, col) db_queue.join()
if args.build_db:
Show the number of accumulated failures when processing. Use a shorter format with colour.
An unwanted space appears before the defconfig name on every item except the last. Fix that while we are here.
tools/moveconfig.py | 26 +++++++++++++++++++------- 1 file changed, 19 insertions(+), 7 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 30d8489f7e3..f28863ae4fb 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -241,24 +241,36 @@ class Progress:
"""Progress Indicator"""
- def __init__(self, total): + def __init__(self, col, total): """Create a new progress indicator.
Args: - total: A number of defconfig files to process. + color_enabled (bool): True for colour output + total (int): A number of defconfig files to process. """ + self.col = col self.current = 0 + self.good = 0 self.total = total
- def inc(self): - """Increment the number of processed defconfig files.""" + def inc(self, success): + """Increment the number of processed defconfig files.
+ Args: + success (bool): True if processing succeeded + """ + self.good += success self.current += 1
def show(self): """Display the progress.""" if self.current != self.total: - print(f' {self.current} defconfigs out of {self.total}\r', end=' ') + line = self.col.build(self.col.GREEN, f'{self.good:5d}') + line += self.col.build(self.col.RED, + f'{self.current - self.good:5d}') + line += self.col.build(self.col.MAGENTA, + f'/{self.total - self.current}') + print(f'{line} \r', end='') sys.stdout.flush()
@@ -578,7 +590,7 @@ class Slot: # Record the failed board. self.failed_boards.add(self.defconfig)
- self.progress.inc() + self.progress.inc(success) self.progress.show() self.state = STATE_IDLE
@@ -729,7 +741,7 @@ def move_config(toolchains, args, db_queue, col): else: defconfigs = get_all_defconfigs()
- progress = Progress(len(defconfigs)) + progress = Progress(col, len(defconfigs)) slots = Slots(toolchains, args, progress, reference_src_dir, db_queue, col)
Rather than printing all the failed boards, which are now easily visible on the terminal, just show a summary. Sort it by defconfig and drop the '_defconfig' suffix.
tools/moveconfig.py | 28 +++++++++++++++------------- 1 file changed, 15 insertions(+), 13 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index f28863ae4fb..0cdf902d14e 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -571,8 +571,8 @@ class Slot: successfully, or False when it fails. """ # output at least 30 characters to hide the "* defconfigs out of *". + name = self.defconfig[:-len('_defconfig')] if self.log: - name = self.defconfig[:-len('_defconfig')]
# Put the first log line on the first line log = name.ljust(20) + ' ' + self.log[0] @@ -588,7 +588,7 @@ class Slot: sys.exit('Exit on error.') # If --exit-on-error flag is not set, skip this board and continue. # Record the failed board. - self.failed_boards.add(self.defconfig) + self.failed_boards.add(name)
self.progress.inc(success) self.progress.show() @@ -618,6 +618,7 @@ class Slots: """ self.args = args self.slots = [] + self.progress = progress self.col = col devnull = subprocess.DEVNULL make_cmd = get_make_cmd() @@ -662,8 +663,8 @@ class Slots: ret = False return ret
- def show_failed_boards(self): - """Display all of the failed boards (defconfigs).""" + def show_result(self): + """Show the results of processing""" boards = set() output_file = 'moveconfig.failed'
@@ -671,14 +672,16 @@ class Slots: boards |= slot.get_failed_boards()
if boards: - boards = '\n'.join(boards) + '\n' - msg = 'The following boards were not processed due to error:\n' - msg += boards - msg += f'(the list has been saved in {output_file})\n' - print(self.col.build(self.col.RED, msg, bright=True), - file=sys.stderr) - + print(self.col.build( + self.col.RED, + f'{len(boards)} failed (see {output_file})', True)) + boards = '\n'.join(sorted(boards)) + '\n' write_file(output_file, boards) + else: + # Add enough spaces to overwrite the progress indicator + print(self.col.build( + self.col.GREEN, + f'{self.progress.total} processed ', bright=True))
@@ -757,8 +760,7 @@ def move_config(toolchains, args, db_queue, col): while not slots.empty(): time.sleep(SLEEP_TIME)
- print('') - slots.show_failed_boards() + slots.show_result()
Since moveconfig now just does what it is told (build database or sync defconfigs) we don't need to print what it is doing. Drop this info, which is of very little use.
tools/moveconfig.py | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 0cdf902d14e..4ff5cf9d5b7 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -727,12 +727,6 @@ def move_config(toolchains, args, db_queue, col): db_queue (Queue): Queue for database updates col (terminal.Color): Colour object """ - if args.force_sync: - print('Syncing defconfigs', end=' ') - elif args.build_db: - print(f'Building {CONFIG_DATABASE} database') - print(f'(jobs: {args.jobs})\n') - if args.git_ref: reference_src = ReferenceSource(args.git_ref) reference_src_dir = reference_src.get_dir()
Write the summary for -s and -b at the end, using a unified format.
tools/moveconfig.py | 36 +++++++++++++++++++++++------------- 1 file changed, 23 insertions(+), 13 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 4ff5cf9d5b7..c86f65a7c83 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -45,6 +45,7 @@ STATE_SAVEDEFCONFIG = 3
AUTO_CONF_PATH = 'include/config/auto.conf' CONFIG_DATABASE = 'moveconfig.db' +FAILED_LIST = 'moveconfig.failed'
CONFIG_LEN = len('CONFIG_')
@@ -663,25 +664,17 @@ class Slots: ret = False return ret
- def show_result(self): + def write_failed_boards(self): """Show the results of processing""" boards = set() - output_file = 'moveconfig.failed'
for slot in self.slots: boards |= slot.get_failed_boards()
if boards: - print(self.col.build( - self.col.RED, - f'{len(boards)} failed (see {output_file})', True)) boards = '\n'.join(sorted(boards)) + '\n' - write_file(output_file, boards) - else: - # Add enough spaces to overwrite the progress indicator - print(self.col.build( - self.col.GREEN, - f'{self.progress.total} processed ', bright=True)) + write_file(FAILED_LIST, boards) +
@@ -726,6 +719,9 @@ def move_config(toolchains, args, db_queue, col): args (Namespace): Program arguments db_queue (Queue): Queue for database updates col (terminal.Color): Colour object + + Returns: + Progress: Progress indicator """ if args.git_ref: reference_src = ReferenceSource(args.git_ref) @@ -754,7 +750,8 @@ def move_config(toolchains, args, db_queue, col): while not slots.empty(): time.sleep(SLEEP_TIME)
- slots.show_result() + slots.write_failed_boards() + return progress
def find_kconfig_rules(kconf, config, imply_config): """Check whether a config has a 'select' or 'imply' keyword @@ -1583,9 +1580,11 @@ doc/develop/moveconfig.rst for documentation.''' toolchains = toolchain.Toolchains() toolchains.GetSettings() toolchains.Scan(verbose=False) - move_config(toolchains, args, db_queue, col) + progress = move_config(toolchains, args, db_queue, col) db_queue.join()
+ failed = progress.total - progress.good + failure = f'{failed} failed, ' if failed else '' if args.build_db: with open(CONFIG_DATABASE, 'w', encoding='utf-8') as outf: for defconfig, configs in config_db.items(): @@ -1593,6 +1592,17 @@ doc/develop/moveconfig.rst for documentation.''' for config in sorted(configs.keys()): outf.write(f' {config}={configs[config]}\n') outf.write('\n') + print(col.build( + col.RED if failed else col.GREEN, + f'{failure}{len(config_db)} boards written to {CONFIG_DATABASE}')) + else: + if failed: + print(col.build(col.RED, f'{failure}see {FAILED_LIST}', True)) + else: + # Add enough spaces to overwrite the progress indicator + print(col.build( + col.GREEN, f'{progress.total} processed ', bright=True)) + return 0
This does not move configs anymore, but queries them, based on a database it can build. Rename the tool to better reflect its purpose.
tools/{moveconfig.py => qconfig.py} | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-) rename tools/{moveconfig.py => qconfig.py} (99%)
diff --git a/tools/moveconfig.py b/tools/qconfig.py similarity index 99% rename from tools/moveconfig.py rename to tools/qconfig.py index c86f65a7c83..875e467c274 100755 --- a/tools/moveconfig.py +++ b/tools/qconfig.py @@ -5,7 +5,7 @@ #
""" -Move config options from headers to defconfig files. +Build and query a Kconfig database for boards.
See doc/develop/moveconfig.rst for documentation. """ @@ -900,7 +900,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, all x86 boards will have that option, avoiding adding CONFIG_CMD_IRQ to each of the x86 defconfig files.
- This function uses the moveconfig database to find such options. It + This function uses the qconfig database to find such options. It displays a list of things that could possibly imply those in the list. The algorithm ignores any that start with CONFIG_TARGET since these typically refer to only a few defconfigs (often one). It also does not
Use qconfig.db as the new name, to reflect the tool's purpose.
.gitignore | 4 ++-- tools/qconfig.py | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/.gitignore b/.gitignore index 002f95de4fe..7f64446db3c 100644 --- a/.gitignore +++ b/.gitignore @@ -107,5 +107,5 @@ __pycache__ /pylint.cur /pylint.out/
-# moveconfig database -/moveconfig.db +# qconfig database +/qconfig.db diff --git a/tools/qconfig.py b/tools/qconfig.py index 875e467c274..8177370587d 100755 --- a/tools/qconfig.py +++ b/tools/qconfig.py @@ -44,8 +44,8 @@ STATE_AUTOCONF = 2 STATE_SAVEDEFCONFIG = 3
AUTO_CONF_PATH = 'include/config/auto.conf' -CONFIG_DATABASE = 'moveconfig.db' -FAILED_LIST = 'moveconfig.failed' +CONFIG_DATABASE = 'qconfig.db' +FAILED_LIST = 'qconfig.failed'
Update qconfig's documentation to better reflect its new purpose in life.
doc/develop/index.rst | 2 +- doc/develop/{moveconfig.rst => qconfig.rst} | 148 +++++--------------- 2 files changed, 38 insertions(+), 112 deletions(-) rename doc/develop/{moveconfig.rst => qconfig.rst} (60%)
diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 5b230d0321f..8bd08fd17f9 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -87,7 +87,7 @@ Refactoring
checkpatch coccinelle - moveconfig + qconfig
Code quality ------------ diff --git a/doc/develop/moveconfig.rst b/doc/develop/qconfig.rst similarity index 60% rename from doc/develop/moveconfig.rst rename to doc/develop/qconfig.rst index ad8596e6c61..22bfe2bd2a7 100644 --- a/doc/develop/moveconfig.rst +++ b/doc/develop/qconfig.rst @@ -1,100 +1,37 @@ .. SPDX-License-Identifier: GPL-2.0+
-moveconfig - Migrating and querying CONFIG options -================================================== +qconfig - Querying CONFIG options +=================================
-Since Kconfig was introduced to U-Boot, we have worked on moving -config options from headers to Kconfig (defconfig). +It is not possible to see all the CONFIG options used by a board without +building its `.config` file. This tool allowing this to be done efficiently for +all boards, or a subset, writing the results to a unified database file.
-This tool intends to help this tremendous work. +This database can be queried, to find boards which used a certain combination +of options, to aid in discovering Kconfig options which imply others. + +The tool also permits syncing of defconfigs, which corrects the ordering and +drops options which are implied by others. + +Finally, it allow scanning the source code to look for inconsistencies in the +use of Kconfig options.
Installing ----------
You may need to install 'python3-asteval' for the 'asteval' module.
-Usage ------ - -First, you must edit the Kconfig to add the menu entries for the configs -you are moving. - -Then run this tool giving CONFIG names you want to move. -For example, if you want to move CONFIG_CMD_USB and CONFIG_TEXT_BASE, -simply type as follows:: - - $ tools/moveconfig.py CONFIG_CMD_USB CONFIG_TEXT_BASE - -The tool walks through all the defconfig files and move the given CONFIGs. - -The log is also displayed on the terminal. - -The log is printed for each defconfig as follows:: - - <defconfig_name> - <action1> - <action2> - <action3> - ... - -`<defconfig_name>` is the name of the defconfig. - -`<action*>` shows what the tool did for that defconfig. -It looks like one of the following: - - - Move 'CONFIG_... ' - This config option was moved to the defconfig - - - CONFIG_... is not defined in Kconfig. Do nothing. - The entry for this CONFIG was not found in Kconfig. The option is not - defined in the config header, either. So, this case can be just skipped. - - - CONFIG_... is not defined in Kconfig (suspicious). Do nothing. - This option is defined in the config header, but its entry was not found - in Kconfig. - There are two common cases: - - - You forgot to create an entry for the CONFIG before running - this tool, or made a typo in a CONFIG passed to this tool. - - The entry was hidden due to unmet 'depends on'. - - The tool does not know if the result is reasonable, so please check it - manually. - - - 'CONFIG_...' is the same as the define in Kconfig. Do nothing. - The define in the config header matched the one in Kconfig. - We do not need to touch it. - - - Compiler is missing. Do nothing. - The compiler specified for this architecture was not found - in your PATH environment. - (If -e option is passed, the tool exits immediately.) - - - Failed to process. - An error occurred during processing this defconfig. Skipped. - (If -e option is passed, the tool exits immediately on error.) - -Finally, you will be asked, Clean up headers? [y/n]: - -If you say 'y' here, the unnecessary config defines are removed -from the config headers (include/configs/*.h). -It just uses the regex method, so you should not rely on it. -Just in case, please do 'git diff' to see what happened. - - How does it work? -----------------
-This tool runs configuration and builds include/autoconf.mk for every -defconfig. The config options defined in Kconfig appear in the .config -file (unless they are hidden because of unmet dependency.) +When building a database (`-b`), this tool runs configuration and builds +include/autoconf.mk for every defconfig. The config options defined in Kconfig +appear in the .config file (unless they are hidden because of unmet dependency.) On the other hand, the config options defined by board headers are seen -in include/autoconf.mk. The tool looks for the specified options in both -of them to decide the appropriate action for the options. If the given -config option is found in the .config, but its value does not match the -one from the board header, the config option in the .config is replaced -with the define in the board header. Then, the .config is synced by -"make savedefconfig" and the defconfig is updated with it. +in include/autoconf.mk. + +When resyncing defconfigs (`-s`) the .config is synced by "make savedefconfig" +and the defconfig is updated with it.
For faster processing, this tool handles multi-threading. It creates separate build directories where the out-of-tree build is run. The @@ -109,7 +46,7 @@ Toolchains Appropriate toolchain are necessary to generate include/autoconf.mk for all the architectures supported by U-Boot. Most of them are available at the kernel.org site, some are not provided by kernel.org. This tool uses -the same tools as buildman, so see that tool for setup (e.g. --fetch-arch). +the same tools as buildman, so see that tool for setup (e.g. `--fetch-arch`).
Tips and trips @@ -117,32 +54,32 @@ Tips and trips
To sync only X86 defconfigs::
- ./tools/moveconfig.py -s -d <(grep -l X86 configs/*) + ./tools/qconfig.py -s -d <(grep -l X86 configs/*)
or::
- grep -l X86 configs/* | ./tools/moveconfig.py -s -d - + grep -l X86 configs/* | ./tools/qconfig.py -s -d -
To process CONFIG_CMD_FPGAD only for a subset of configs based on path match::
ls configs/{hrcon*,iocon*,strider*} | \ - ./tools/moveconfig.py -Cy CONFIG_CMD_FPGAD -d - + ./tools/qconfig.py -Cy CONFIG_CMD_FPGAD -d -
Finding boards with particular CONFIG combinations --------------------------------------------------
-You can use `moveconfig.py` to figure out which boards have a CONFIG enabled, or +You can use `qconfig.py` to figure out which boards have a CONFIG enabled, or which do not. To use it, first build a database::
- ./tools/moveconfig.py -b + ./tools/qconfig.py -b
Then you can run queries using the `-f` flag followed by a list of CONFIG terms. Each term is CONFIG name, with or without a tilde (~) prefix. The tool searches for boards which match the CONFIG name, or do not match if tilde is used. For example, to find boards which enabled CONFIG_SCSI but not CONFIG_BLK::
- tools/moveconfig.py -f SCSI ~BLK + tools/qconfig.py -f SCSI ~BLK 3 matches pg_wcom_seli8_defconfig highbank_defconfig pg_wcom_expu1_defconfig
@@ -158,11 +95,11 @@ each of the x86 defconfig files.
This tool can help find such configs. To use it, first build a database::
Then try to query it::
- ./tools/moveconfig.py -i CONFIG_I8042_KEYB + ./tools/qconfig.py -i CONFIG_I8042_KEYB CONFIG_I8042_KEYB found in 33/5155 defconfigs 28 : CONFIG_X86 28 : CONFIG_SA_PCIEX_LENGTH @@ -193,12 +130,12 @@ indicates that CONFIG_I8042_KEYB is not needed for the remaining 5 boards. Many of the options listed are not suitable as they are not related. E.g. it would be odd for CONFIG_RAMBASE to imply CONFIG_I8042_KEYB.
-Using this search you can reduce the size of moveconfig patches. +Using this search you can reduce the size of qconfig patches.
You can automatically add 'imply' statements in the Kconfig with the -a option::
- ./tools/moveconfig.py -s -i CONFIG_SCSI \ + ./tools/qconfig.py -s -i CONFIG_SCSI \ -a CONFIG_ARCH_LS1021A,CONFIG_ARCH_LS1043A
This will add 'imply SCSI' to the two CONFIG options mentioned, assuming that @@ -220,7 +157,7 @@ the size of their defconfig files.
If you want to add an 'imply' to every imply config in the list, you can use::
- ./tools/moveconfig.py -s -i CONFIG_SCSI -a all + ./tools/qconfig.py -s -i CONFIG_SCSI -a all
To control which ones are displayed, use -I <list> where list is a list of options (use '-I help' to see possible options and their meaning). @@ -230,7 +167,7 @@ To skip showing you options that already have an 'imply' attached, use -A. When you have finished adding 'imply' options you can regenerate the defconfig files for affected boards with something like::
- git show --stat | ./tools/moveconfig.py -s -d - + git show --stat | ./tools/qconfig.py -s -d -
This will regenerate only those defconfigs changed in the current commit. If you start with (say) 100 defconfigs being changed in the commit, and add @@ -241,13 +178,9 @@ number of defconfigs changed in the commit. Available options -----------------
- -c, --color - Surround each portion of the log with escape sequences to display it - in color on the terminal. - - -C, --commit - Create a git commit with the changes when the operation is complete. A - standard commit message is used which may need to be edited. + --nocolour + Disables colouring of output. This is normally used when writing to a + terminal.
-d, --defconfigs Specify a file containing a list of defconfigs to move. The defconfig @@ -275,9 +208,6 @@ Available options because SPL related options (mostly prefixed with CONFIG_SPL_) are sometimes blocked by CONFIG_SPL_BUILD ifdef conditionals.
- -H, --headers-only - Only cleanup the headers; skip the defconfig processing - -j, --jobs Specify the number of threads to run simultaneously. If not specified, the number of threads is the same as the number of CPU cores. @@ -293,10 +223,6 @@ Available options -v, --verbose Show any build errors as boards are built
- -y, --yes - Instead of prompting, automatically go ahead with all operations. This - includes cleaning up headers, the config whitelist and the README. - To see the complete list of supported options, run::
- tools/moveconfig.py -h + tools/qconfig.py -h
