[PATCH 1/1] board: sifive: unmatched: enlarge CONFIG_SYS_SPL_MALLOC_SIZE
Avoid an error like
Could not get FIT buffer of 1725952 bytes check CONFIG_SYS_SPL_MALLOC_SIZE No device tree specified in SPL image ### ERROR ### Please RESET the board ###
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/configs/sifive-unmatched.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/sifive-unmatched.h b/include/configs/sifive-unmatched.h index f8ad2cce1f..8d3deabdd3 100644 --- a/include/configs/sifive-unmatched.h +++ b/include/configs/sifive-unmatched.h @@ -18,7 +18,7 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00200000
#define CONFIG_SPL_STACK (0x08000000 + 0x001D0000 - \ GENERATED_GBL_DATA_SIZE)
Hi Heinrich,
On Fri, Oct 1, 2021 at 7:37 PM Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Avoid an error like
What caused this?
Last time this was seen on Ax25-AE350, CONFIG_SPL_SYS_MALLOC_F_LEN was increased, instead of CONFIG_SYS_SPL_MALLOC_SIZE which the error messages point to
https://lists.denx.de/pipermail/u-boot/2021-May/449447.html
Regards, Bin
On Fri, Oct 1, 2021 at 5:35 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Heinrich,
Avoid an error like
What caused this?
I fell into the same issue this morning and increasing CONFIG_SYS_SPL_MALLOC_SIZE fixed it, though I had to increase it even more than Heinrich.
Alex
Regards, Bin
On Tue, Oct 19, 2021 at 4:32 PM Alexandre Ghiti alexandre.ghiti@canonical.com wrote:
Hi Heinrich,
Avoid an error like
What caused this?
Is this default build that caused Unmatched boot failure?
@Rick Chen can you comment on why CONFIG_SPL_SYS_MALLOC_F_LEN was needed on AE350?
Regards, Bin
Hi Heinrich,
Avoid an error like
What caused this?
Yes but I made a mistake as I used openSBI fw_payload.bin instead of fw_dymanic.bin and the fw_payload.bin is ~2MB against 74K for the fw_dynamic.bin.
Sorry about that!
Alex
Regards, Bin
Alexandre Ghiti
Bin Meng
