[U-Boot] [PATCH 1/2] usb: Use get_unaligned() in usb_endpoint_maxp() for wMaxPacketSize
Use unaligned access to fetch wMaxPacketSize in usb_endpoint_maxp() api. In its absence we see following data abort message: ============================================================== data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<bf794e24>] lr : [<bf794e1c>] sp : bf37c7b0 ip : 0000002f fp : 00000000 r10: 00000000 r9 : 00000002 r8 : bf37fecc r7 : 00000001 r6 : bf7d8931 r5 : bf7d891c r4 : bf7d8800 r3 : bf7d65b0 r2 : 00000002 r1 : bf7d65b4 r0 : 00000027 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
resetting ... ==============================================================
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Cc: Ilya Yanok ilya.yanok@cogentembedded.com Cc: Marek Vasut marex@denx.de ---
Based on u-boot-usb/next. Tested with 'u-boot-usb/master' branch.
include/linux/usb/ch9.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h index d1d732c..bd48704 100644 --- a/include/linux/usb/ch9.h +++ b/include/linux/usb/ch9.h @@ -35,6 +35,7 @@
#include <linux/types.h> /* __u8 etc */ #include <asm/byteorder.h> /* le16_to_cpu */ +#include <asm/unaligned.h> /* get_unaligned() */
@@ -596,7 +597,7 @@ static inline int usb_endpoint_is_isoc_out( */ static inline int usb_endpoint_maxp(const struct usb_endpoint_descriptor *epd) { - return __le16_to_cpu(epd->wMaxPacketSize); + return __le16_to_cpu(get_unaligned(&epd->wMaxPacketSize)); }
static inline int usb_endpoint_interrupt_type(
Use get_unaligned() while fetching wMaxPacketSize to avoid voilating any alignment rules.
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com Cc: Lukasz Dalek luk0104@gmail.com Cc: Marek Vasut marex@denx.de ---
Just did a build test on u-boot-usb/master branch. Need to be tested further.
drivers/usb/gadget/f_mass_storage.c | 3 ++- drivers/usb/gadget/pxa25x_udc.c | 13 +++++++------ 2 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index c28866f..45bc132 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -2261,7 +2261,8 @@ reset: if (rc) goto reset; fsg->bulk_out_enabled = 1; - common->bulk_out_maxpacket = le16_to_cpu(d->wMaxPacketSize); + common->bulk_out_maxpacket = + le16_to_cpu(get_unaligned(&d->wMaxPacketSize)); clear_bit(IGNORE_BULK_OUT, &fsg->atomic_bitflags);
/* Allocate the requests */ diff --git a/drivers/usb/gadget/pxa25x_udc.c b/drivers/usb/gadget/pxa25x_udc.c index 9ce98f0..085503d 100644 --- a/drivers/usb/gadget/pxa25x_udc.c +++ b/drivers/usb/gadget/pxa25x_udc.c @@ -314,7 +314,8 @@ static int pxa25x_ep_enable(struct usb_ep *_ep, if (!_ep || !desc || ep->desc || _ep->name == ep0name || desc->bDescriptorType != USB_DT_ENDPOINT || ep->bEndpointAddress != desc->bEndpointAddress - || ep->fifo_size < le16_to_cpu(desc->wMaxPacketSize)) { + || ep->fifo_size < + le16_to_cpu(get_unaligned(&desc->wMaxPacketSize))) { printf("%s, bad ep or descriptor\n", __func__); return -EINVAL; } @@ -329,9 +330,9 @@ static int pxa25x_ep_enable(struct usb_ep *_ep,
/* hardware _could_ do smaller, but driver doesn't */ if ((desc->bmAttributes == USB_ENDPOINT_XFER_BULK - && le16_to_cpu(desc->wMaxPacketSize) + && le16_to_cpu(get_unaligned(&desc->wMaxPacketSize)) != BULK_FIFO_SIZE) - || !desc->wMaxPacketSize) { + || !get_unaligned(&desc->wMaxPacketSize)) { printf("%s, bad %s maxpacket\n", __func__, _ep->name); return -ERANGE; } @@ -345,7 +346,7 @@ static int pxa25x_ep_enable(struct usb_ep *_ep, ep->desc = desc; ep->stopped = 0; ep->pio_irqs = 0; - ep->ep.maxpacket = le16_to_cpu(desc->wMaxPacketSize); + ep->ep.maxpacket = le16_to_cpu(get_unaligned(&desc->wMaxPacketSize));
/* flush fifo (mostly for OUT buffers) */ pxa25x_ep_fifo_flush(_ep); @@ -485,7 +486,7 @@ write_fifo(struct pxa25x_ep *ep, struct pxa25x_request *req) { unsigned max;
- max = le16_to_cpu(ep->desc->wMaxPacketSize); + max = le16_to_cpu(get_unaligned(&ep->desc->wMaxPacketSize)); do { unsigned count; int is_last, is_short; @@ -766,7 +767,7 @@ pxa25x_ep_queue(struct usb_ep *_ep, struct usb_request *_req, gfp_t gfp_flags) */ if (unlikely(ep->bmAttributes == USB_ENDPOINT_XFER_ISOC && req->req.length > - le16_to_cpu(ep->desc->wMaxPacketSize))) + le16_to_cpu(get_unaligned(&ep->desc->wMaxPacketSize)))) return -EMSGSIZE;
debug_cond(NOISY, "%s queue req %p, len %d buf %p\n",
It's another story, can we get performance gain with unaligned access feature? In case of kernel, we got some gains.
Anyway, good job!
Acked-by: Kyungmin Park kyungmin.park@samsung.com
|| ep->fifo_size <
|| ep->fifo_size <
ep->ep.maxpacket =
-- 1.7.6.5
typo here s/voilating/violating
This change was necessary since we get data abort if we try to fetch wMaxPacketSize which violates the natural alignment rules being a member of "struct usb_endpoint_descriptor".
I am not sure of the performance gains with this. However, if you can guide me how to measure that, we can get the numbers if any.
Anyway, good job!
Thanks !
|| ep->fifo_size <
|| ep->fifo_size <
ep->ep.maxpacket =
-- 1.7.6.5
Hi Kyungmin,
On Mon, 13 May 2013 19:50:28 +0900, Kyungmin Park kmpark@infradead.org wrote:
Please do not forget that U-Boot does not run on ARMv7+ only; it runs on many ARM generations and on many non-ARM architectures too. Some of these targets have a severe penalty on unaligned access; some cannot even perform unaligned accesses.
File drivers/usb/gadget/f_mass_storage.c is generic and must build and run for such targets too.
The best approach is to properly align fields wherever possible, and when not possible, to use unaligned access macros (and if posisble detect unaligned accesses at runtime).
Amicalement,
Tested pxa25x_udc.c on u-boot/master on h2200 (PXA255) and works fine.
Yours sincerely, Lukasz Dalek
-----Original Message----- From: Vivek Gautam [mailto:gautam.vivek@samsung.com] Sent: Monday, May 13, 2013 12:24 PM To: u-boot@lists.denx.de Cc: gautam.vivek@samsung.com; Lukasz Majewski; Piotr Wilczek; Kyungmin Park; Lukasz Dalek; Marek Vasut Subject: [PATCH 2/2] usb: gadget: Use unaligned access for wMaxPacketSize
Tested 'f_mass_storage.c' on u-boot/samsung. It works fine with or without this patch on Trats2.
Best regards, Piotr Wilczek
Dear Vivek Gautam,
I'll pick both, thanks.
Best regards, Marek Vasut
participants (7)
Albert ARIBAUD
Kyungmin Park
Piotr Wilczek
Vivek Gautam
Vivek Gautam
Łukasz Dałek
