[U-Boot] [PATCH] serial: bcm283x_mu: Detect disabled serial device
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times.
However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today.
This patch adds detection logic for that case and disables the mini uart if it sends a zero byte during probe. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not.
Signed-off-by: Alexander Graf agraf@suse.de --- drivers/serial/serial_bcm283x_mu.c | 48 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/serial/serial_bcm283x_mu.c b/drivers/serial/serial_bcm283x_mu.c index 7357bbf..ff077ec 100644 --- a/drivers/serial/serial_bcm283x_mu.c +++ b/drivers/serial/serial_bcm283x_mu.c @@ -48,8 +48,14 @@ struct bcm283x_mu_regs {
struct bcm283x_mu_priv { struct bcm283x_mu_regs *regs; + bool beyond_first_byte; + bool within_first_byte; + uint8_t first_byte; + bool broken; };
+static int bcm283x_mu_serial_getc(struct udevice *dev); + static int bcm283x_mu_serial_setbrg(struct udevice *dev, int baudrate) { struct bcm283x_mu_serial_platdata *plat = dev_get_platdata(dev); @@ -75,6 +81,13 @@ static int bcm283x_mu_serial_probe(struct udevice *dev)
priv->regs = (struct bcm283x_mu_regs *)plat->base;
+ /* + * We get greeted by a zero byte? That means the serial console really + * is disabled and we better ignore it. + */ + if (!bcm283x_mu_serial_getc(dev)) + priv->broken = true; + return 0; }
@@ -84,6 +97,16 @@ static int bcm283x_mu_serial_getc(struct udevice *dev) struct bcm283x_mu_regs *regs = priv->regs; u32 data;
+ if (priv->broken) + return -EAGAIN; + + if (priv->within_first_byte) { + priv->within_first_byte = false; + priv->beyond_first_byte = true; + + return (int)priv->first_byte; + } + /* Wait until there is data in the FIFO */ if (!(readl(®s->lsr) & BCM283X_MU_LSR_RX_READY)) return -EAGAIN; @@ -98,6 +121,9 @@ static int bcm283x_mu_serial_putc(struct udevice *dev, const char data) struct bcm283x_mu_priv *priv = dev_get_priv(dev); struct bcm283x_mu_regs *regs = priv->regs;
+ if (priv->broken) + return 0; + /* Wait until there is space in the FIFO */ if (!(readl(®s->lsr) & BCM283X_MU_LSR_TX_EMPTY)) return -EAGAIN; @@ -116,8 +142,30 @@ static int bcm283x_mu_serial_pending(struct udevice *dev, bool input)
if (input) { WATCHDOG_RESET(); + + if (priv->broken) + return 0; + + if (priv->within_first_byte) + return 1; + + if (!priv->beyond_first_byte && + (lsr & BCM283X_MU_LSR_RX_READY)) { + priv->first_byte = bcm283x_mu_serial_getc(dev); + priv->within_first_byte = true; + + if (!priv->first_byte) { + /* First byte was zero, serial is broken */ + priv->broken = true; + return 0; + } + } + return (lsr & BCM283X_MU_LSR_RX_READY) ? 1 : 0; } else { + if (priv->broken) + return 0; + return (lsr & BCM283X_MU_LSR_TX_IDLE) ? 0 : 1; } }
I don't think this is the correct approach; it is quite possible and legal to receive a NULL character (which with this HW IIRC can also be triggered by a break condition on the line) even when the UART is fully operational. This could lead to false detection, and end up disabling the UART when it should not.
Rather, I would suggest detecting this condition based on some register content. The most direct might be to check the pinmux for the UART's RX pin, or perhaps whether the UART itself has been initialized.
Right, that’s why I tried to be very careful about the detection and only have it triggered when the very first byte ever received is a null byte. Any bytes after that don’t affect it.
Hmm. I can try and dig through the documentation again to see whether there is a way.
Alex
Alexander Graf
Stephen Warren
