The following changes since commit 6015f8f1b6fc30de7b4839bd691058583ec7f521:
doc: document the fdtdir PXE command (2015-09-03 16:59:07 -0400)
git://git.denx.de/u-boot-usb.git
for you to fetch changes up to 49b4c5c700077e387fef61a7225f92d190ee0c45:
usb: ehci: remember init mode (2015-09-07 13:41:05 +0200)
---------------------------------------------------------------- Jiandong Zheng (1): implement Fastboot via USB OTG on bcm28155_ap boards
Kishon Vijay Abraham I (1): h2200: Fix build error
Lukasz Majewski (11): dfu:tests: Modify dfu_gadget_test.sh to accept USB device vendor:product ID dfu: Delete superfluous initialization of the dfu_buf_size static variable doc: dfu: tftp: README entry for TFTP extension of DFU net: tftp: Move tftp.h file from ./net to ./include/net tftp: update: Allow some parts of the code to be reused when CONFIG_SYS_NO_FLASH is set dfu: tftp: update: Provide tftp support for the DFU subsystem dfu: tftp: update: Add dfu_write_from_mem_addr() function update: tftp: dfu: Extend update_tftp() function to support DFU dfu: command: Extend "dfu" command to handle receiving data via TFTP dfu: tftp: Kconfig: Add Kconfig entry for dfu tftp feature dfu: tftp: Kconfig: Enable DFU_TFTP support on the am335x_boneblack_defconfig
Siva Durga Prasad Paladugu (2): f_thor: Dont perform reset at the end of thor usb: gadget: f_thor: Allocate request up to THOR_PACKET_SIZE
Stephen Warren (1): usb: ehci: remember init mode
board/h2200/h2200.c | 12 +++++++++++ common/Makefile | 1 + common/cmd_dfu.c | 20 ++++++++++++++++++ common/cmd_fitupd.c | 2 +- common/main.c | 2 +- common/update.c | 58 +++++++++++++++++++++++++++++++++++++--------------- configs/am335x_boneblack_defconfig | 1 + doc/README.dfutftp | 114 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ doc/README.update | 7 +++++++ drivers/dfu/Kconfig | 10 +++++++++ drivers/dfu/Makefile | 1 + drivers/dfu/dfu.c | 39 ++++++++++++++++++++++++++++++++++- drivers/dfu/dfu_tftp.c | 65 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/f_thor.c | 9 ++++++++- drivers/usb/gadget/f_thor.h | 3 +++ drivers/usb/host/ehci-hcd.c | 7 ++++++- drivers/usb/host/ehci.h | 1 + include/configs/bcm28155_ap.h | 19 ++++++++++++++++++ include/dfu.h | 41 +++++++++++++++++++++++++++++++++++++ include/net.h | 14 +++++++++++-- {net => include/net}/tftp.h | 0 net/bootp.c | 2 +- net/net.c | 2 +- net/rarp.c | 2 +- net/tftp.c | 2 +- test/dfu/README | 9 ++++++++- test/dfu/dfu_gadget_test.sh | 18 ++++++++++------- 27 files changed, 426 insertions(+), 35 deletions(-) create mode 100644 doc/README.dfutftp create mode 100644 drivers/dfu/dfu_tftp.c rename {net => include/net}/tftp.h (100%)
