[U-Boot] [PATCH v6 0/5] Add support for Thumb-1 builds
This series implements essential changes for thumb-1 support and activates thumb-1 build for openrd and tricorder as a proof of concept as well as a fix to bring the image sizes of openrd and tricorder targets back under an acceptable limit.
For other targets, some additional files might need to be forced to ARM building, notably architecture-specific instances of lowlevel_init.S or of cpu.c. This should be handled on a case-by-case basis.
This series has two unfixed checkpatch diagnostics:
warning: arch/arm/mach-kirkwood/Kconfig,7: please write a paragraph that describes the config symbol fully
(no option in this Kconfig has help info)
check: board/Marvell/openrd/openrd.c,42: Avoid CamelCase: <MPP6_SYSRST_OUTn>
(this is actually not an OpenRD problem and will be fixed in another patch)
IMPORTANT NOTE:
The whole set has been build-tested across all ARM targets and no build regression was detected -- actually, the series does fix the x600 board which otherwise fails assembling an mcr instruction.
Patch 1 has been confirmed to be binary-invariant.
Patch 2 has been build- and run-tested on ED Mini V2 (switched temporarily to Thumb build) and confirmed to be binary-invariant for non-thumb target Wireless Space.
Patches 3 through 6 have been build-tested BUT HAVE NOT BEEN RUN-TESTED so far.
I will test on OpenRD (client) before the end of the merge window, but:
********************************************************* Open-RD and Tricorder owners, PLEASE run-test this series and report on the mailing list whether the target works. *********************************************************
Changes in v6: - revive OpenRD targets and assume maintainership - switch OpenRD to generic board and Thumb - fix checkpatch warning and checks
Changes in v5: - switched tricorder[_flash] to Thumb-1 build
Changes in v4: - Made stm32f429-discovery explicitly state that it builds for Thumb
Changes in v3: - added arch/arm/lib/mem{set,cpy}.S to the list of modules which should always be built in ARM state. - Selected HAS_THUMB2 for CPU_V7M. - Fixed invalidate_l2_cache() when building for Thumb-1.
Changes in v2: - fixed a typo in the commit message - added file arch/arm/thumb1/include/asm/proc-armv/system.h, which overrides arch/arm/include/asm/proc-armv/system.h when building for Thumb-1 and provides non-functional but Thumb-compilable IRQ and FIQ related macros and functions.
Albert ARIBAUD (5): stm32f429-discovery: add CONFIG_SYS_THUMB_BUILD arm: support Thumb-1 with CONFIG_SYS_THUMB_BUILD tricorder: switch to CONFIG_SYS_THUMB_BUILD kirkwood: support CONFIG_SYS_THUMB_BUILD Revive OpenRD targets
Makefile | 2 + arch/arm/Kconfig | 5 + arch/arm/cpu/arm926ejs/Makefile | 11 ++ arch/arm/cpu/arm926ejs/cache.c | 5 + arch/arm/include/asm/cache.h | 4 + arch/arm/lib/Makefile | 24 ++++ arch/arm/lib/cache.c | 11 ++ arch/arm/lib/memcpy.S | 4 +- arch/arm/lib/memset.S | 2 +- arch/arm/mach-kirkwood/Kconfig | 4 + arch/arm/mach-kirkwood/Makefile | 6 + arch/arm/mach-orion5x/Makefile | 10 ++ arch/arm/thumb1/include/asm/proc-armv/system.h | 69 +++++++++++ board/Marvell/openrd/Kconfig | 12 ++ board/Marvell/openrd/MAINTAINERS | 12 ++ board/Marvell/openrd/Makefile | 14 +++ board/Marvell/openrd/kwbimage.cfg | 152 +++++++++++++++++++++++ board/Marvell/openrd/openrd.c | 160 +++++++++++++++++++++++++ board/Marvell/openrd/openrd.h | 30 +++++ configs/openrd_base_defconfig | 7 ++ configs/openrd_client_defconfig | 7 ++ configs/openrd_ultimate_defconfig | 7 ++ examples/standalone/Makefile | 10 ++ include/configs/openrd.h | 140 ++++++++++++++++++++++ include/configs/stm32f429-discovery.h | 1 + include/configs/tricorder.h | 1 + 26 files changed, 707 insertions(+), 3 deletions(-) create mode 100644 arch/arm/thumb1/include/asm/proc-armv/system.h create mode 100644 board/Marvell/openrd/Kconfig create mode 100644 board/Marvell/openrd/MAINTAINERS create mode 100644 board/Marvell/openrd/Makefile create mode 100644 board/Marvell/openrd/kwbimage.cfg create mode 100644 board/Marvell/openrd/openrd.c create mode 100644 board/Marvell/openrd/openrd.h create mode 100644 configs/openrd_base_defconfig create mode 100644 configs/openrd_client_defconfig create mode 100644 configs/openrd_ultimate_defconfig create mode 100644 include/configs/openrd.h
This target is ARMv7-M therefore can only build for Thumb, but it did not #define CONFIG_SYS_THUMB_BUILD, so the U-Boot code did not know it had to build for Thumb(2), not ARM.
This patch is binary-invariant: builds of stm32f429-discovery with and without this patch were compared and found to differ only by their U-Boot version strings.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net ---
Changes in v6: None Changes in v5: None Changes in v4: - Made stm32f429-discovery explicitly state that it builds for Thumb
include/configs/stm32f429-discovery.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 19d9cf9..e773de4 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -9,6 +9,7 @@ #define __CONFIG_H
#define CONFIG_STM32F4 +#define CONFIG_SYS_THUMB_BUILD #define CONFIG_STM32F4DISCOVERY #define CONFIG_SYS_GENERIC_BOARD
When building a Thumb-1-only target with CONFIG_SYS_THUMB_BUILD, some files fail to build, most of the time because they include mcr instructions, which only exist for Thumb-2.
This patch introduces a Kconfig option CONFIG_THUMB2 and uses it to select between Thumb-2 and ARM mode for the aforementioned files.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- This patch has been build-tested and run-tested on ED Mini V2, above the "edmini: switch to SPL" patch, and found to reduce U-Boot size by 25% and SPL size by 14%... and to run fine. :)
This patch has also been tested against side effects on the non-Thumb wireless_space target. The binaries produced with and without this patch were found to differ only by their version string.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: - added arch/arm/lib/mem{set,cpy}.S to the list of modules which should always be built in ARM state. - Selected HAS_THUMB2 for CPU_V7M. - Fixed invalidate_l2_cache() when building for Thumb-1.
Makefile | 2 + arch/arm/Kconfig | 5 ++ arch/arm/cpu/arm926ejs/Makefile | 11 ++++ arch/arm/cpu/arm926ejs/cache.c | 5 ++ arch/arm/include/asm/cache.h | 4 ++ arch/arm/lib/Makefile | 24 +++++++++ arch/arm/lib/cache.c | 11 ++++ arch/arm/lib/memcpy.S | 4 +- arch/arm/lib/memset.S | 2 +- arch/arm/mach-orion5x/Makefile | 10 ++++ arch/arm/thumb1/include/asm/proc-armv/system.h | 69 ++++++++++++++++++++++++++ examples/standalone/Makefile | 10 ++++ 12 files changed, 154 insertions(+), 3 deletions(-) create mode 100644 arch/arm/thumb1/include/asm/proc-armv/system.h
diff --git a/Makefile b/Makefile index fd06024..ac207dd 100644 --- a/Makefile +++ b/Makefile @@ -605,6 +605,8 @@ KBUILD_CFLAGS += $(KCFLAGS) UBOOTINCLUDE := \ -Iinclude \ $(if $(KBUILD_SRC), -I$(srctree)/include) \ + $(if $(CONFIG_SYS_THUMB_BUILD), $(if $(CONFIG_HAS_THUMB2),, \ + -I$(srctree)/arch/$(ARCH)/thumb1/include),) \ -I$(srctree)/arch/$(ARCH)/include \ -include $(srctree)/include/linux/kconfig.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7981355..6e1eaa7 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -10,6 +10,9 @@ config ARM64 config HAS_VBAR bool
+config HAS_THUMB2 + bool + config CPU_ARM720T bool
@@ -32,9 +35,11 @@ config CPU_ARM1176 config CPU_V7 bool select HAS_VBAR + select HAS_THUMB2
config CPU_V7M bool + select HAS_THUMB2
config CPU_PXA bool diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index 63fa159..fe78922 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -20,3 +20,14 @@ obj-$(CONFIG_MX25) += mx25/ obj-$(CONFIG_MX27) += mx27/ obj-$(if $(filter mxs,$(SOC)),y) += mxs/ obj-$(if $(filter spear,$(SOC)),y) += spear/ + +# some files can only build in ARM or THUMB2, not THUMB1 + +ifdef CONFIG_SYS_THUMB_BUILD +ifndef CONFIG_HAS_THUMB2 + +CFLAGS_cpu.o := -marm +CFLAGS_cache.o := -marm + +endif +endif diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index e5c1a6a..2839c86 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -82,4 +82,9 @@ void flush_dcache_all(void) /* * Stub implementations for l2 cache operations */ + __weak void l2_cache_disable(void) {} + +#if defined CONFIG_SYS_THUMB_BUILD +__weak void invalidate_l2_cache(void) {} +#endif diff --git a/arch/arm/include/asm/cache.h b/arch/arm/include/asm/cache.h index a836e9f..1f63127 100644 --- a/arch/arm/include/asm/cache.h +++ b/arch/arm/include/asm/cache.h @@ -16,6 +16,9 @@ /* * Invalidate L2 Cache using co-proc instruction */ +#ifdef CONFIG_SYS_THUMB_BUILD +void invalidate_l2_cache(void); +#else static inline void invalidate_l2_cache(void) { unsigned int val=0; @@ -24,6 +27,7 @@ static inline void invalidate_l2_cache(void) : : "r" (val) : "cc"); isb(); } +#endif
void l2_cache_enable(void); void l2_cache_disable(void); diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 2bdfaba..f3db7b5 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -60,3 +60,27 @@ obj-$(CONFIG_DEBUG_LL) += debug.o ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) extra-y += eabi_compat.o endif + +# some files can only build in ARM or THUMB2, not THUMB1 + +ifdef CONFIG_SYS_THUMB_BUILD +ifndef CONFIG_HAS_THUMB2 + +# for C files, just apend -marm, which will override previous -mthumb* + +CFLAGS_cache.o := -marm +CFLAGS_cache-cp15.o := -marm + +# For .S, drop -mthumb* and other thumb-related options. +# CFLAGS_REMOVE_* would not have an effet, so AFLAGS_REMOVE_* +# was implemented and is used here. +# Also, define ${target}_NO_THUMB_BUILD for these two targets +# so that the code knows it should not use Thumb. + +AFLAGS_REMOVE_memset.o := -mthumb -mthumb-interwork +AFLAGS_REMOVE_memcpy.o := -mthumb -mthumb-interwork +AFLAGS_memset.o := -DMEMSET_NO_THUMB_BUILD +AFLAGS_memcpy.o := -DMEMCPY_NO_THUMB_BUILD + +endif +endif diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index cd13db3..3bd8710 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -88,3 +88,14 @@ phys_addr_t noncached_alloc(size_t size, size_t align) return next; } #endif /* CONFIG_SYS_NONCACHED_MEMORY */ + +#if defined(CONFIG_SYS_THUMB_BUILD) +void invalidate_l2_cache(void) +{ + unsigned int val = 0; + + asm volatile("mcr p15, 1, %0, c15, c11, 0 @ invl l2 cache" + : : "r" (val) : "cc"); + isb(); +} +#endif diff --git a/arch/arm/lib/memcpy.S b/arch/arm/lib/memcpy.S index eeaf003..7d9fc0f 100644 --- a/arch/arm/lib/memcpy.S +++ b/arch/arm/lib/memcpy.S @@ -13,7 +13,7 @@ #include <linux/linkage.h> #include <asm/assembler.h>
-#ifdef CONFIG_SYS_THUMB_BUILD +#if defined(CONFIG_SYS_THUMB_BUILD) && !defined(MEMCPY_NO_THUMB_BUILD) #define W(instr) instr.w #else #define W(instr) instr @@ -62,7 +62,7 @@
/* Prototype: void *memcpy(void *dest, const void *src, size_t n); */ .syntax unified -#ifdef CONFIG_SYS_THUMB_BUILD +#if defined(CONFIG_SYS_THUMB_BUILD) && !defined(MEMCPY_NO_THUMB_BUILD) .thumb .thumb_func #endif diff --git a/arch/arm/lib/memset.S b/arch/arm/lib/memset.S index 7208f20..df053a3 100644 --- a/arch/arm/lib/memset.S +++ b/arch/arm/lib/memset.S @@ -16,7 +16,7 @@ .align 5
.syntax unified -#ifdef CONFIG_SYS_THUMB_BUILD +#if defined(CONFIG_SYS_THUMB_BUILD) && !defined(MEMSET_NO_THUMB_BUILD) .thumb .thumb_func #endif diff --git a/arch/arm/mach-orion5x/Makefile b/arch/arm/mach-orion5x/Makefile index 546ebcb..33dcad4 100644 --- a/arch/arm/mach-orion5x/Makefile +++ b/arch/arm/mach-orion5x/Makefile @@ -16,3 +16,13 @@ obj-y += timer.o ifndef CONFIG_SKIP_LOWLEVEL_INIT obj-y += lowlevel_init.o endif + +# some files can only build in ARM or THUMB2, not THUMB1 + +ifdef CONFIG_SYS_THUMB_BUILD +ifndef CONFIG_HAS_THUMB2 + +CFLAGS_cpu.o := -marm + +endif +endif diff --git a/arch/arm/thumb1/include/asm/proc-armv/system.h b/arch/arm/thumb1/include/asm/proc-armv/system.h new file mode 100644 index 0000000..7dfbf3d --- /dev/null +++ b/arch/arm/thumb1/include/asm/proc-armv/system.h @@ -0,0 +1,69 @@ +/* + * Thumb-1 drop-in for the linux/include/asm-arm/proc-armv/system.h + * + * (C) Copyright 2015 + * Albert ARIBAUD albert.u.boot@aribaud.net + * + * The original file does not build in Thumb mode. However, in U-Boot + * we don't use interrupt context, so we can redefine these as empty + * memory barriers, which makes Thumb-1 compiler happy. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * Use the same macro name as linux/include/asm-arm/proc-armv/system.h + * here, so that if the original ever gets included after us, it won't + * try to re-redefine anything. + */ + +#ifndef __ASM_PROC_SYSTEM_H +#define __ASM_PROC_SYSTEM_H + +/* + * Redefine all original macros with static inline functions containing + * a simple memory barrier, so that they produce the same instruction + * ordering constraints as their original counterparts. + * We use static inline functions rather than macros so that we can tell + * the compiler to not complain about unused arguments. + */ + +static inline void local_irq_save( + unsigned long flags __attribute__((unused))) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void local_irq_enable(void) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void local_irq_disable(void) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void __stf(void) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void __clf(void) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void local_save_flags( + unsigned long flags __attribute__((unused))) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +static inline void local_irq_restore( + unsigned long flags __attribute__((unused))) +{ + __asm__ __volatile__ ("" : : : "memory"); +} + +#endif /* __ASM_PROC_SYSTEM_H */ diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 0863a8c..5a6ae00 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -73,3 +73,13 @@ $(obj)/%.srec: $(obj)/% FORCE $(obj)/%.bin: OBJCOPYFLAGS := -O binary $(obj)/%.bin: $(obj)/% FORCE $(call if_changed,objcopy) + +# some files can only build in ARM or THUMB2, not THUMB1 + +ifdef CONFIG_SYS_THUMB_BUILD +ifndef CONFIG_HAS_THUMB2 + +CFLAGS_stubs.o := -marm + +endif +endif
The tricorder and tricorder_flash boards have grown too big. Reduce their size by building them with CONFIG_SYS_THUMB_BUILD.
Changes in v6: None Changes in v5: - switched tricorder[_flash] to Thumb-1 build
Changes in v4: None Changes in v3: None Changes in v2: None
include/configs/tricorder.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index f04b572..2ac141c 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -17,6 +17,7 @@ #define __CONFIG_H
/* High Level Configuration Options */ +#define CONFIG_SYS_THUMB_BUILD #define CONFIG_OMAP /* in a TI OMAP core */ #define CONFIG_OMAP_COMMON /* Common ARM Erratas */
Kirkwood files cpu.c and cache.c cannot build in Thumb state; force them in ARM state even under CONFIG_SYS_THUMB_BUILD.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/mach-kirkwood/Makefile | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-kirkwood/Makefile b/arch/arm/mach-kirkwood/Makefile index df4756e..5abcf70 100644 --- a/arch/arm/mach-kirkwood/Makefile +++ b/arch/arm/mach-kirkwood/Makefile @@ -9,3 +9,9 @@ obj-y = cpu.o obj-y += cache.o obj-y += mpp.o + +# cpu.o and cache.o contain CP15 instructions which cannot be run in +# Thumb state, so build them for ARM state even with CONFIG_SYS_THUMB_BUILD + +CFLAGS_cpu.o := -marm +CFLAGS_cache.o := -marm
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Switch OpenRD to generic board. Switch to Thumb build.
arch/arm/mach-kirkwood/Kconfig | 4 + board/Marvell/openrd/Kconfig | 12 +++ board/Marvell/openrd/MAINTAINERS | 12 +++ board/Marvell/openrd/Makefile | 14 ++++ board/Marvell/openrd/kwbimage.cfg | 152 ++++++++++++++++++++++++++++++++++++ board/Marvell/openrd/openrd.c | 160 ++++++++++++++++++++++++++++++++++++++ board/Marvell/openrd/openrd.h | 30 +++++++ configs/openrd_base_defconfig | 7 ++ configs/openrd_client_defconfig | 7 ++ configs/openrd_ultimate_defconfig | 7 ++ include/configs/openrd.h | 140 +++++++++++++++++++++++++++++++++ 11 files changed, 545 insertions(+) create mode 100644 board/Marvell/openrd/Kconfig create mode 100644 board/Marvell/openrd/MAINTAINERS create mode 100644 board/Marvell/openrd/Makefile create mode 100644 board/Marvell/openrd/kwbimage.cfg create mode 100644 board/Marvell/openrd/openrd.c create mode 100644 board/Marvell/openrd/openrd.h create mode 100644 configs/openrd_base_defconfig create mode 100644 configs/openrd_client_defconfig create mode 100644 configs/openrd_ultimate_defconfig create mode 100644 include/configs/openrd.h
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index aab5d19..f7737bf 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -4,6 +4,9 @@ choice prompt "Marvell Kirkwood board select" optional
+config TARGET_OPENRD + bool "Marvell OpenRD Board" + config TARGET_DREAMPLUG bool "DreamPlug Board"
@@ -51,6 +54,7 @@ endchoice config SYS_SOC default "kirkwood"
+source "board/Marvell/openrd/Kconfig" source "board/Marvell/dreamplug/Kconfig" source "board/Marvell/guruplug/Kconfig" source "board/Marvell/sheevaplug/Kconfig" diff --git a/board/Marvell/openrd/Kconfig b/board/Marvell/openrd/Kconfig new file mode 100644 index 0000000..124b66d --- /dev/null +++ b/board/Marvell/openrd/Kconfig @@ -0,0 +1,12 @@ +if TARGET_OPENRD + +config SYS_BOARD + default "openrd" + +config SYS_VENDOR + default "Marvell" + +config SYS_CONFIG_NAME + default "openrd" + +endif diff --git a/board/Marvell/openrd/MAINTAINERS b/board/Marvell/openrd/MAINTAINERS new file mode 100644 index 0000000..3789a04 --- /dev/null +++ b/board/Marvell/openrd/MAINTAINERS @@ -0,0 +1,12 @@ +OPENRD BOARD +M: Albert ARIBAUD albert-u-boot@aribaud.net +S: Maintained +F: board/Marvell/openrd/ +F: include/configs/openrd.h +F: configs/openrd_base_defconfig + +OPENRD_CLIENT BOARD +M: Albert ARIBAUD albert-u-boot@aribaud.net +S: Maintained +F: configs/openrd_client_defconfig +F: configs/openrd_ultimate_defconfig diff --git a/board/Marvell/openrd/Makefile b/board/Marvell/openrd/Makefile new file mode 100644 index 0000000..8f95b79 --- /dev/null +++ b/board/Marvell/openrd/Makefile @@ -0,0 +1,14 @@ +# +# (C) Copyright 2009 +# Net Insight <www.netinsight.net> +# Written-by: Simon Kagstrom simon.kagstrom@netinsight.net +# +# Based on sheevaplug: +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := openrd.o diff --git a/board/Marvell/openrd/kwbimage.cfg b/board/Marvell/openrd/kwbimage.cfg new file mode 100644 index 0000000..8e59937 --- /dev/null +++ b/board/Marvell/openrd/kwbimage.cfg @@ -0,0 +1,152 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Refer doc/README.kwbimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1b1b1b9b + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000c30 # DDR Configuration register +# bit13-0: 0xc30 (3120 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x37543000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 7= CL+2, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000a33 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x000000cc # DDR Address Control +# bit1-0: 00, Cs0width=x8 +# bit3-2: 11, Cs0size=1Gb +# bit5-4: 00, Cs1width=x8 +# bit7-6: 11, Cs1size=1Gb +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000C52 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000042 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 1, DDR drive strength reduced +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F17F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x0F, Size (i.e. 256MB) + +DATA 0xFFD01508 0x10000000 # CS[1]n Base address to 256Mb +DATA 0xFFD0150C 0x0FFFFFF5 # CS[1]n Size 256Mb Window enabled for CS1 + +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00120012 # DDR ODT Control (Low) +# bit3-0: 0010, (read) M_ODT[0] is asserted during read from DRAM CS1 +# bit7-4: 0001, (read) M_ODT[1] is asserted during read from DRAM CS0 +# bit19-16: 0010, (write) M_ODT[0] is asserted during write to DRAM CS1. +# bit23-20: 0001, (write) M_ODT[1] is asserted during write to DRAM CS0. +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) + +DATA 0xFFD0149C 0x0000E40f # CPU ODT Control +# bit3-0: 1111, internal ODT is asserted during read from DRAM bank 0-3 +# bit11-10: 01, M_DQ, M_DM, and M_DQS I/O buffer ODT Select: 150 ohm +# bit13-12: 10, M_STARTBURST_IN I/O buffer ODT Select: 75 ohm +# bit14: 1, M_STARTBURST_IN ODT: Enabled +# bit15: 1, DDR IO ODT Unit: Use ODT block +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/Marvell/openrd/openrd.c b/board/Marvell/openrd/openrd.c new file mode 100644 index 0000000..17a6560 --- /dev/null +++ b/board/Marvell/openrd/openrd.c @@ -0,0 +1,160 @@ +/* + * (C) Copyright 2009 + * Net Insight <www.netinsight.net> + * Written-by: Simon Kagstrom simon.kagstrom@netinsight.net + * + * Based on sheevaplug.c: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include "openrd.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + mvebu_config_gpio(OPENRD_OE_VAL_LOW, + OPENRD_OE_VAL_HIGH, + OPENRD_OE_LOW, OPENRD_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + static const u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, /* Alt UART1_TXD */ + MPP14_SD_D0, /* Alt UART1_RXD */ + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_GE1_0, + MPP21_GE1_1, + MPP22_GE1_2, + MPP23_GE1_3, + MPP24_GE1_4, + MPP25_GE1_5, + MPP26_GE1_6, + MPP27_GE1_7, + MPP28_GPIO, + MPP29_TSMP9, + MPP30_GE1_10, + MPP31_GE1_11, + MPP32_GE1_12, + MPP33_GE1_13, + MPP34_GPIO, /* UART1 / SD sel */ + MPP35_TDM_CH0_TX_QL, + MPP36_TDM_SPI_CS1, + MPP37_TDM_CH2_TX_QL, + MPP38_TDM_CH2_RX_QL, + MPP39_AUDIO_I2SBCLK, + MPP40_AUDIO_I2SDO, + MPP41_AUDIO_I2SLRC, + MPP42_AUDIO_I2SMCLK, + MPP43_AUDIO_I2SDI, + MPP44_AUDIO_EXTCLK, + MPP45_TDM_PCLK, + MPP46_TDM_FS, + MPP47_TDM_DRX, + MPP48_TDM_DTX, + MPP49_TDM_CH0_RX_QL, + 0 + }; + + kirkwood_mpp_conf(kwmpp_config, NULL); + return 0; +} + +int board_init(void) +{ + /* + * arch number of board + */ +#if defined(CONFIG_BOARD_IS_OPENRD_BASE) + gd->bd->bi_arch_number = MACH_TYPE_OPENRD_BASE; +#elif defined(CONFIG_BOARD_IS_OPENRD_CLIENT) + gd->bd->bi_arch_number = MACH_TYPE_OPENRD_CLIENT; +#elif defined(CONFIG_BOARD_IS_OPENRD_ULTIMATE) + gd->bd->bi_arch_number = MACH_TYPE_OPENRD_ULTIMATE; +#endif + + /* adress of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +/* Configure and enable MV88E1116/88E1121 PHY */ +void mv_phy_init(char *name) +{ + u16 reg; + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *)&devadr)) { + printf("Err..%s could not read PHY dev address\n", __func__); + return; + } + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf(PHY_NO" Initialized on %s\n", name); +} + +void reset_phy(void) +{ + mv_phy_init("egiga0"); + +#ifdef CONFIG_BOARD_IS_OPENRD_CLIENT + /* Kirkwood ethernet driver is written with the assumption that in case + * of multiple PHYs, their addresses are consecutive. But unfortunately + * in case of OpenRD-Client, PHY addresses are not consecutive.*/ + miiphy_write("egiga1", 0xEE, 0xEE, 24); +#endif + +#if defined(CONFIG_BOARD_IS_OPENRD_CLIENT) || \ + defined(CONFIG_BOARD_IS_OPENRD_ULTIMATE) + /* configure and initialize both PHY's */ + mv_phy_init("egiga1"); +#endif +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/Marvell/openrd/openrd.h b/board/Marvell/openrd/openrd.h new file mode 100644 index 0000000..56dfeea --- /dev/null +++ b/board/Marvell/openrd/openrd.h @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2009 + * Net Insight <www.netinsight.net> + * Written-by: Simon Kagstrom simon.kagstrom@netinsight.net + * + * Based on sheevaplug.h: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __OPENRD_BASE_H +#define __OPENRD_BASE_H + +#define OPENRD_OE_LOW (~(1<<28)) /* RS232 / RS485 */ +#define OPENRD_OE_HIGH (~(1<<2)) /* SD / UART1 */ +#define OPENRD_OE_VAL_LOW (0) /* Sel RS232 */ +#define OPENRD_OE_VAL_HIGH (1 << 2) /* Sel SD */ + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) + +#endif /* __OPENRD_BASE_H */ diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig new file mode 100644 index 0000000..1686139 --- /dev/null +++ b/configs/openrd_base_defconfig @@ -0,0 +1,7 @@ +CONFIG_ARM=y +CONFIG_KIRKWOOD=y +CONFIG_TARGET_OPENRD=y +CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig new file mode 100644 index 0000000..c342315 --- /dev/null +++ b/configs/openrd_client_defconfig @@ -0,0 +1,7 @@ +CONFIG_ARM=y +CONFIG_KIRKWOOD=y +CONFIG_TARGET_OPENRD=y +CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig new file mode 100644 index 0000000..530ba4d --- /dev/null +++ b/configs/openrd_ultimate_defconfig @@ -0,0 +1,7 @@ +CONFIG_ARM=y +CONFIG_KIRKWOOD=y +CONFIG_TARGET_OPENRD=y +CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set diff --git a/include/configs/openrd.h b/include/configs/openrd.h new file mode 100644 index 0000000..d6b1393 --- /dev/null +++ b/include/configs/openrd.h @@ -0,0 +1,140 @@ +/* + * (C) Copyright 2009 + * Net Insight <www.netinsight.net> + * Written-by: Simon Kagstrom simon.kagstrom@netinsight.net + * + * Based on sheevaplug.h: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CONFIG_OPENRD_H +#define _CONFIG_OPENRD_H + +/* + * Version number information + */ +#ifdef CONFIG_BOARD_IS_OPENRD_ULTIMATE +# define CONFIG_IDENT_STRING "\nOpenRD-Ultimate" +#else +# ifdef CONFIG_BOARD_IS_OPENRD_CLIENT +# define CONFIG_IDENT_STRING "\nOpenRD-Client" +# else +# ifdef CONFIG_BOARD_IS_OPENRD_BASE +# define CONFIG_IDENT_STRING "\nOpenRD-Base" +# else +# error Unknown OpenRD board specified +# endif +# endif +#endif + +#define CONFIG_SYS_GENERIC_BOARD + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ +#define CONFIG_KW88F6281 1 /* SOC Name */ +#define CONFIG_MACH_OPENRD_BASE /* Machine type */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ +#define CONFIG_SYS_THUMB_BUILD + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#define CONFIG_SYS_MVFS +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NAND +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_CMD_IDE + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Environment variables configurations + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif +/* + * max 4k env size is enough, but in case of nand + * it has to be rounded to sector size + */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_ADDR 0x60000 +#define CONFIG_ENV_OFFSET 0x60000 /* env starts here */ +/* + * Environment is right behind U-Boot in flash. Make sure U-Boot + * doesn't grow into the environment area. + */ +#define CONFIG_BOARD_SIZE_LIMIT CONFIG_ENV_OFFSET + +/* + * Default environment variables + */ +#define CONFIG_BOOTCOMMAND "${x_bootcmd_kernel}; " \ + "setenv bootargs ${x_bootargs} ${x_bootargs_root}; " \ + "${x_bootcmd_usb}; bootm 0x6400000;" + +#define MTDIDS_DEFAULT "nand0=nand_mtd" +#define MTDPARTS_DEFAULT "mtdparts=nand_mtd:0x100000@0x000000(uboot),"\ + "0x400000@0x100000(uImage),"\ + "0x1fb00000@0x500000(rootfs)" + +#define CONFIG_EXTRA_ENV_SETTINGS "x_bootargs=console" \ + "=ttyS0,115200 "MTDPARTS_DEFAULT " rw ubi.mtd=2,2048\0" \ + "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x300000\0" \ + "x_bootcmd_usb=usb start\0" \ + "x_bootargs_root=root=ubi0:rootfs rootfstype=ubifs\0" \ + "mtdids="MTDIDS_DEFAULT"\0" \ + "mtdparts="MTDPARTS_DEFAULT"\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +# ifdef CONFIG_BOARD_IS_OPENRD_BASE +# define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ +# else +# define CONFIG_MVGBE_PORTS {1, 1} /* enable both ports */ +# endif +# ifdef CONFIG_BOARD_IS_OPENRD_ULTIMATE +# define CONFIG_PHY_BASE_ADR 0x0 +# define PHY_NO "88E1121" +# else +# define CONFIG_PHY_BASE_ADR 0x8 +# define PHY_NO "88E1116" +# endif +#endif /* CONFIG_CMD_NET */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_MVSATA_IDE +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET +#endif /*CONFIG_MVSATA_IDE*/ + +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MVEBU_MMC +#define CONFIG_SYS_MMC_BASE KW_SDIO_BASE +#endif /* CONFIG_CMD_MMC */ + +#endif /* _CONFIG_OPENRD_BASE_H */
Albert ARIBAUD
