[U-Boot] [PATCH 1/2] Fix test failure caused by bad handling of ramdisk
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if a load address is provided in the FIT. The rationale was that a load address of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk will be loaded if a non-zero load address is provided.
common/image-fit.c | 2 +- common/image.c | 3 ++- include/image.h | 1 + 3 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index c61be65..255c4ca 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1656,7 +1656,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, bootstage_error(bootstage_id + BOOTSTAGE_SUB_LOAD); return -EBADF; } - } else { + } else if (load_op != FIT_LOAD_OPTIONAL_NON_ZERO || load) { ulong image_start, image_end; ulong load_end; void *dst; diff --git a/common/image.c b/common/image.c index a2999c0..d0af597 100644 --- a/common/image.c +++ b/common/image.c @@ -951,7 +951,8 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, &fit_uname_config, arch, IH_TYPE_RAMDISK, BOOTSTAGE_ID_FIT_RD_START, - FIT_LOAD_IGNORED, &rd_data, &rd_len); + FIT_LOAD_OPTIONAL_NON_ZERO, + &rd_data, &rd_len); if (rd_noffset < 0) return 1;
diff --git a/include/image.h b/include/image.h index ca2fe86..f58e9ff 100644 --- a/include/image.h +++ b/include/image.h @@ -412,6 +412,7 @@ void genimg_print_time(time_t timestamp); enum fit_load_op { FIT_LOAD_IGNORED, /* Ignore load address */ FIT_LOAD_OPTIONAL, /* Can be provided, but optional */ + FIT_LOAD_OPTIONAL_NON_ZERO, /* Optional, a value of 0 is ignored */ FIT_LOAD_REQUIRED, /* Must be provided */ };
The host filesystem name has changed, so update the tests. The tests now run again correctly:
$ make O=b/sandbox sandbox_defconfig all ... $ test/image/test-fit.py -u b/sandbox/u-boot FIT Tests ========= Kernel load Kernel + FDT load Kernel + FDT + Ramdisk load
Tests passed Caveat: this is only a sanity check - test coverage is poor
test/image/test-fit.py | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/test/image/test-fit.py b/test/image/test-fit.py index 7394df7..b065fcb 100755 --- a/test/image/test-fit.py +++ b/test/image/test-fit.py @@ -93,13 +93,13 @@ base_fdt = ''' # then do the 'bootm' command, then save out memory from the places where # we expect 'bootm' to write things. Then quit. base_script = ''' -sb load host 0 %(fit_addr)x %(fit)s +sb load hostfs 0 %(fit_addr)x %(fit)s fdt addr %(fit_addr)x bootm start %(fit_addr)x bootm loados -sb save host 0 %(kernel_out)s %(kernel_addr)x %(kernel_size)x -sb save host 0 %(fdt_out)s %(fdt_addr)x %(fdt_size)x -sb save host 0 %(ramdisk_out)s %(ramdisk_addr)x %(ramdisk_size)x +sb save hostfs 0 %(kernel_out)s %(kernel_addr)x %(kernel_size)x +sb save hostfs 0 %(fdt_out)s %(fdt_addr)x %(fdt_size)x +sb save hostfs 0 %(ramdisk_out)s %(ramdisk_addr)x %(ramdisk_size)x reset '''
