Re: [U-Boot] Boot failure with a AT91RM9200 based custom board
Hi Peter,
On 2016-08-17 11:31, Peter Kardos wrote:
On Mon, Aug 15, 2016 at 10:43 PM, Andreas Bießmann andreas@biessmann.org wrote:
Dear Peter,
On 12.08.16 02:24, Peter Kardos wrote:
<snip>
RAM Configuration: Bank #0: 20000000 64 MiB
DRAM: 64 MiB initcall: 1000b424 New Stack Pointer is: 23f23ed0 initcall: 1000b6ac initcall: 1000b640 Relocation Offset is: 13f84000 Relocating to 23f84000, new gd at 23f23ef0, sp at 23f23ed0
Could you please check, if the RAM initialisation is working properly? AFAIR there was some problem with the u-boot RAM initialisation for this board but never fixed (shame on me). Some set of known data and read back before relocation should do the check.
Yeah, this is my guess as well, as things seem to work up to this point (continue exec from RAM).
Thanks for the pointer, i'll have a look at the init magic and compare it with the old from v1.1.4.
Would be great if you come with a solution, so I could fix the at91rm9200ek board too.
I guess the easiest way would be to mod the relocation routine and read back what was written...
sounds good as a quick test
Andreas
Andreas Bießmann
