[U-Boot] [PATCH v2 0/4] sunxi: Ease eMMC usage and flashing
Here is a set of patches that have been sitting in some variations for quite some time now.
This is mostly to ease the eMMC (and MMC, to some extent) flashing using fastboot that in turn rely on GPT.
The Allwinner SoCs need to have the SPL located right in the middle of a traditional GPT, at 8kB.
To deal with this, we would basically have two options: - Use the already in-tree solution to move the partition entries to another arbitrary offset in the MMC. - Use a smaller number of partitions entries
Both are non-standards, but are dealt with nicely by the regular tools and users (at least on a Linux system). However, the first solution is quite confusing for users (that needs to be aware where the partitions will be), might be less flexible because not all tools will allow to create partitions for things between the GPT main entry and the partition entries, and might confuse tools if such a setup is available.
In our case, using the first solution, gdisk will for example refuse to create a partition for the SPL.
The second solution though seems to be well handled by all the tools, and just feels the same, except that you end up with a smaller number of partitions. In our case, that number is 56 partitions (16 sectors before the SPL, 1 sector for the protective MBR, 1 sector for the GPT header, and 4 partition entries per sector) instead of 128, which doesn't sound very impractical either.
The two first patches deal with that.
We then provide a default partitionning scheme. I'd like feedback on that one. I appreciate that having a good default in such a case, but I'd like to have a reasonably simple layout that works good enough to install a distro. I'm a bit short on background on what an EFI partition is supposed to look like, and what a good size would be. I'd really like some input on this.
Finally, we enable fastboot flashing to be able to flash a pristine system just by using FEL, fastboot oem format, and then fastboot flash for the various components.
Let me know what you think, Maxime
Changes from v2: - Added Andre's tags - Rebased on 2018.01-rc1 - Changed the rootfs UUID for freedesktop's
Changes from v1: - Changed the boot partition name to ESP - Used default UUID for the rootfs and esp partitions
Maxime Ripard (4): part: efi: Add a Kconfig option for the number of partition entries part: efi: Add default number of partition entries for sunxi sunxi: Add default partition scheme fastboot: Enable flashing by default on sunxi
cmd/fastboot/Kconfig | 1 + disk/Kconfig | 14 ++++++++++++++ include/configs/sunxi-common.h | 17 +++++++++++++++++ include/part_efi.h | 2 +- 4 files changed, 33 insertions(+), 1 deletion(-)
base-commit: 9da7fb4a39149c3061cb148bfbaa76b4b52b9008
On some SoCs, the SPL needs to be located right in the middle of the GPT partition entries.
One way to work around that is to create partition entries for a smaller number of partitions to accomodate with where the SPL will be. Create a Kconfig option to allow to do that.
Reviewed-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- disk/Kconfig | 13 +++++++++++++ include/part_efi.h | 2 +- 2 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/disk/Kconfig b/disk/Kconfig index 939656212065..f82beef6e689 100644 --- a/disk/Kconfig +++ b/disk/Kconfig @@ -78,6 +78,19 @@ config EFI_PARTITION common when EFI is the bootloader. Note 2TB partition limit; see disk/part_efi.c
+config EFI_PARTITION_ENTRIES_NUMBERS + int "Number of the EFI partition entries" + depends on EFI_PARTITION + default 128 + help + Specify the number of partition entries in the GPT. This is + meant to allow less than the standard specifies for devices + that might need to place their first-stage bootloader in the + middle of a regular GPT. + + If unsure, leave at 128 entries, which is the standard + number. + config EFI_PARTITION_ENTRIES_OFF int "Offset (in bytes) of the EFI partition entries" depends on EFI_PARTITION diff --git a/include/part_efi.h b/include/part_efi.h index 31e6bc6e140f..4c8f6cc473c8 100644 --- a/include/part_efi.h +++ b/include/part_efi.h @@ -27,7 +27,7 @@ #define GPT_HEADER_SIGNATURE 0x5452415020494645ULL #define GPT_HEADER_REVISION_V1 0x00010000 #define GPT_PRIMARY_PARTITION_TABLE_LBA 1ULL -#define GPT_ENTRY_NUMBERS 128 +#define GPT_ENTRY_NUMBERS CONFIG_EFI_PARTITION_ENTRIES_NUMBERS #define GPT_ENTRY_SIZE 128
#define PARTITION_SYSTEM_GUID \
The SPL must be located at 8kB (16 sectors) offset. That's right in the middle of the GPT, so we need to define a smaller amount of partitions to accomodate for that location.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- disk/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/disk/Kconfig b/disk/Kconfig index f82beef6e689..0446bb63ca7e 100644 --- a/disk/Kconfig +++ b/disk/Kconfig @@ -81,6 +81,7 @@ config EFI_PARTITION config EFI_PARTITION_ENTRIES_NUMBERS int "Number of the EFI partition entries" depends on EFI_PARTITION + default 56 if ARCH_SUNXI default 128 help Specify the number of partition entries in the GPT. This is
The partitions variable is especially useful to create a partition table from U-Boot, either directly from the U-Boot shell, or through flashing tools like fastboot and its oem format command.
This is especially useful on devices with an eMMC you can't take out to flash from another system, and booting a Linux system first to flash our system then is not really practical.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- include/configs/sunxi-common.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 4391a8cbc824..786155f1e15e 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -493,6 +493,20 @@ extern int soft_i2c_gpio_scl; #define SUNXI_MTDPARTS_DEFAULT #endif
+#define PARTS_DEFAULT \ + "name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};" \ + "name=loader2,size=984k,uuid=${uuid_gpt_loader2};" \ + "name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};" \ + "name=system,size=-,uuid=${uuid_gpt_system};" + +#define UUID_GPT_ESP "c12a7328-f81f-11d2-ba4b-00a0c93ec93b" + +#ifdef CONFIG_ARM64 +#define UUID_GPT_SYSTEM "b921b045-1df0-41c3-af44-4c6f280d3fae" +#else +#define UUID_GPT_SYSTEM "69dad710-2ce4-4e3c-b16c-21a1d49abed3" +#endif + #define CONSOLE_ENV_SETTINGS \ CONSOLE_STDIN_SETTINGS \ CONSOLE_STDOUT_SETTINGS @@ -511,6 +525,9 @@ extern int soft_i2c_gpio_scl; "console=ttyS0,115200\0" \ SUNXI_MTDIDS_DEFAULT \ SUNXI_MTDPARTS_DEFAULT \ + "uuid_gpt_esp=" UUID_GPT_ESP "\0" \ + "uuid_gpt_system=" UUID_GPT_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ BOOTCMD_SUNXI_COMPAT \ BOOTENV
Thanks! Andre.
- "name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};" \
- "name=loader2,size=984k,uuid=${uuid_gpt_loader2};" \
- "name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};" \
- "name=system,size=-,uuid=${uuid_gpt_system};"
- "uuid_gpt_esp=" UUID_GPT_ESP "\0" \
- "uuid_gpt_system=" UUID_GPT_SYSTEM "\0" \
- "partitions=" PARTS_DEFAULT "\0" \ BOOTCMD_SUNXI_COMPAT \ BOOTENV
Now that more and more devices are built using eMMC, providing a way to easily flash the system without too much hassle seems like a right thing to do.
Since fastboot is the most deployed tool to do that these days, we can just rely on it to provide a way to flash the various components in the system (SPL, U-Boot and the system itself) easily, especially since you can upload the U-Boot hosting the fastboot "server" through FEL.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- cmd/fastboot/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/cmd/fastboot/Kconfig b/cmd/fastboot/Kconfig index 4ce7a775e28e..cbb9183ea266 100644 --- a/cmd/fastboot/Kconfig +++ b/cmd/fastboot/Kconfig @@ -66,6 +66,7 @@ config FASTBOOT_USB_DEV
config FASTBOOT_FLASH bool "Enable FASTBOOT FLASH command" + default y if ARCH_SUNXI help The fastboot protocol includes a "flash" command for writing the downloaded image to a non-volatile storage device. Define
Merged.
Maxime
André Przywara
Maxime Ripard
