[U-Boot] [RFC Patch] e1000: Fix PCI memory addressing and fix for receive data polling
Sorry, you will find now my fixes in attachment
Hi all,
I had some problem when using your e1000-code on a MIPS target. Attached you will find two fixes which I would like to propose for discussion.
- Fix 1: this has the same reason as in commit f81ecb5d3300bf92d17302d3712f30585c182da9
- Fix 2: has to do with "C Language Operator Precedence". I would say the expression taken by the ! operator has precedence before the & operator. So any bit in rd->status other than E1000_RXD_STAT_DD stops correct detection of data reception. (What i do not know is, if it is possible that any other bit than E1000_RXD_STAT_DD can get active)
Please leave me in CC, because i'm not subscribed to this list.
Thanks a lot for providing u-boot.
Best regards Ralf
Hi all,
Hi Ralf,
Anyway, can you also describe *which* bug / behavior have you found ?
This seems to me a bug. However, you must send right patches for review / discussion. You find two issues, and you must send one patch for each issue that will be fixed. Please have a look at:
http://www.denx.de/wiki/U-Boot/Patches
It describes how to submit patches in the right format.
Best regards, Stefano Babic
Ralf Rösch
Stefano Babic
