[U-Boot] [RESEND PATCH v2] mtd: spi: Improve spi_nor_write_data() implementation
Maximum write size in a single write operation in spi_nor_write_data() function can be equal to slave tx buffer, which is adjusted in spi_mem_adjust_op_size() and write operation gets fragmented.
Previously data write for the above fragmentation didn't incorporate write enable and status checks. It was sent to flash at page offsets only.
Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com --- Changes in v2: Incorporating review comments given by Vignesh. [PATCH v1]: https://patchwork.ozlabs.org/patch/1078183/
drivers/mtd/spi/spi-nor-core.c | 28 ++++++++++------------------ 1 file changed, 10 insertions(+), 18 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index c4e2f6a08f..8e754d445d 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -116,7 +116,6 @@ static ssize_t spi_nor_write_data(struct spi_nor *nor, loff_t to, size_t len, SPI_MEM_OP_ADDR(nor->addr_width, to, 1), SPI_MEM_OP_NO_DUMMY, SPI_MEM_OP_DATA_OUT(len, buf, 1)); - size_t remaining = len; int ret;
/* get transfer protocols. */ @@ -127,22 +126,19 @@ static ssize_t spi_nor_write_data(struct spi_nor *nor, loff_t to, size_t len, if (nor->program_opcode == SPINOR_OP_AAI_WP && nor->sst_write_second) op.addr.nbytes = 0;
- while (remaining) { - op.data.nbytes = remaining < UINT_MAX ? remaining : UINT_MAX; - ret = spi_mem_adjust_op_size(nor->spi, &op); - if (ret) - return ret; + op.data.nbytes = len < UINT_MAX ? len : UINT_MAX; + ret = spi_mem_adjust_op_size(nor->spi, &op); + if (ret) + return ret;
- ret = spi_mem_exec_op(nor->spi, &op); - if (ret) - return ret; + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret;
- op.addr.val += op.data.nbytes; - remaining -= op.data.nbytes; - op.data.buf.out += op.data.nbytes; - } + op.addr.val += op.data.nbytes; + op.data.buf.out += op.data.nbytes;
- return len; + return op.data.nbytes; }
/* @@ -1101,10 +1097,6 @@ static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len, goto write_err; *retlen += written; i += written; - if (written != page_remain) { - ret = -EIO; - goto write_err; - } }
write_err:
Rajat Srivastava
