Fw: ECDSA for FIT Files in U-Boot
Hi Simon,
I have forwarded these emails as requested.
Cheers, Eden
________________________________ From: Simon Glass sjg@chromium.org Sent: 06 August 2024 22:47 To: Eden Hamilton VRC7 C eden.hamilton@bt.com Subject: Re: ECDSA for FIT Files in U-Boot
Hi Eden,
Would you mind sending this to the U-Boot mailing list and cc me? There are quite a few people involved in the security side.
On Tue, 6 Aug 2024 at 08:24, eden.hamilton@bt.com wrote:
Hi there Simon!
I am Eden, currently at BT trying to get ECDSA verified boot for FIT files working on U-Boot.
I have observed that you have reviewed many patches/updates surrounding ECDSA in U-Boot.
I have been trying to get this working, but it is appearing difficult due to no examples online.
I was wondering, if you have any examples where you have managed to get this working? Perhaps examples of FIT files, DTBs etc - that you would not mind sharing with me.
If you do not, then no worries.
Kind regards, Eden
Hi Eden,
I don't see it on the mailing list yet[1].
[1] https://lists.denx.de/listinfo/u-boot
On Wed, 7 Aug 2024 at 02:21, eden.hamilton@bt.com wrote:
Hi Simon,
Cheers, Eden
Hi Eden,
Hi there Simon!
Kind regards, Eden
Hei Eden,
Am Wed, Aug 07, 2024 at 07:59:39AM -0600 schrieb Simon Glass:
Hi Eden,
FWIW in case you did not notice, there's a patch series for barebox currently worked on implementing ecdsa support for fit image verification. Maybe that can be helpful for this task?
https://lore.barebox.org/barebox/ZrG9pjqsnWBvfkE2@pengutronix.de/T/#t
Greets Alex
Hi Simon,
Cheers, Eden
Hi Eden,
Hi there Simon!
Kind regards, Eden
Hi Eden,
On Wed, 7 Aug 2024 at 07:59, Simon Glass sjg@chromium.org wrote:
Hi Eden,
Hi Simon,
Cheers, Eden
Hi Eden,
Hi there Simon!
OK, there it is, hidden under my ellipsis, thanks. Here are a few thoughts:
[1] is the general docs which I'm sure you've read [2] Describes the process for a real board (with RSA, but the idea is similar) [3] Is a test for ECDSA so you should be able to follow along with the steps there to get something working
If you have problems, then a console trace is often useful.
Regards, SImon
[1] https://docs.u-boot.org/en/latest/usage/fit/signature.htm [2] https://docs.u-boot.org/en/latest/usage/fit/beaglebone_vboot.html [3] test/py/tests/test_fit_ecdsa.py
Hi Simon and Alexander,
Thank you both for these resources.
Hopefully they will provide more indication into why I cannot get ECDSA to work.
I have seen some of these resources (Admittedly I did only look partially at the one for the beagle bone board), however the patch series for barebox is new info for me.
I'll make sure to inspect these two in depth.
Again, thanks to both of you.
Regards, Eden ________________________________ From: Simon Glass sjg@chromium.org Sent: 07 August 2024 15:36 To: Eden Hamilton VRC7 C eden.hamilton@bt.com Cc: u-boot@lists.denx.de u-boot@lists.denx.de Subject: Re: Fw: ECDSA for FIT Files in U-Boot
Hi Eden,
Hi Eden,
[1] https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.denx...https://lists.denx.de/listinfo/u-boot
Hi Simon,
Cheers, Eden
Hi Eden,
Hi there Simon!
Regards, SImon
[1] https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.u-boo...https://docs.u-boot.org/en/latest/usage/fit/signature.htm [2] https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.u-boo...https://docs.u-boot.org/en/latest/usage/fit/beaglebone_vboot.html [3] test/py/tests/test_fit_ecdsa.py
Alexander Dahl
