[U-Boot] SPL variant of sunxi nand module
Hi all,
While fighting with this A20-olinuxino nand boot process I've initially found that some essential nand-related parameters are apparently missing by default, preventing reasonable nand operation, so I started debugging this gradually.
U-Boot SPL 2019.01-rc2 (Dec 20 2018 - 16:30:46 +0300) CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 DRAM: 1024 MiB Trying to boot from NAND
Now I've discovered that SPL-build variant of sunxi_nand module is missing the sunxi_nand_init() whatsoever. Apparently it is on purpose, because:
#ifndef CONFIG_SPL_BUILD sunxi_nand_init(); #endif
And I cannot simply un-ifdef sunxi_nand_init() here, because the SPL build would fail with undefined symbol then, but I'm wondering, where are all values (like ECC strength and such) are expected to come from instead? Is SPL nand loader is supposed to be usable at all currently?
Thank you,
Regards, Nikolai
Hi again,
Ok, discovered a special SPL-only sunxi_nand_spl variant, added some debugging, so the detection is visible:
In nand_detect_config(), start detection... Considering addr_cycles=5, page_size=2048 Considering ecc_size=1024, ecc_strength=0 failed(a). Considering addr_cycles=5, page_size=2048 rejected. Considering addr_cycles=5, page_size=4096 Considering ecc_size=1024, ecc_strength=3 failed(a). Considering addr_cycles=5, page_size=4096 rejected. Considering addr_cycles=5, page_size=8192 Considering ecc_size=1024, ecc_strength=4 good(b). Considering addr_cycles=5, page_size=8192 accepted.
I'm almost 100% sure that correct config would be page_size=8192, ecc_size=1024, ecc_strength=40 (from nand chip identification structure for regular linux kernel)
Now the detection routine in sunxi_nand_spl apparently comes up with a value of ecc_strength=4 instead... Why is that?
Thank you,
Regards, Nikolai
Thank you,
Regards, Nikolai _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi
On Sun, Dec 23, 2018 at 4:46 PM Nikolai Zhubr n-a-zhubr@yandex.ru wrote:
Hi again,
That is an index on an array. Am I wrong? so the max is 74
Michael
n - 1 using an index, if the code that I have is aligned so
Michael
Thank you,
Regards, Nikolai
Thank you,
Hi Michael,
23.12.2018 18:54, Michael Nazzareno Trimarchi: [...]
Indeed, its an index, and therefore it appears SPL's detection actually gives correct values! Nevertheless, SPL reads all zeroes from nand.
On the other hand, normal U-boot variant reads correct data from nand, but I'm not yet sure if it uses correct parameters and specifically, if they match those of SPL version. Need to add yet more debugging output.
Thank you,
Regards, Nikolai
Michael
Michael
Thank you,
Regards, Nikolai
Thank you,
Hi again,
23.12.2018 21:11, I wrote: [...]
Regarding the sunxi_nand_spl.c module, I can not find any mention if it implies NAND_ECC_HW, NAND_ECC_HW_SYNDROME, or rather some other mode, or if these modes are irrelevant in this case?
Can not guess browsing through the code, it looks too different from sunxi_nand.c to compare.
Thank you,
Regards, Nikolai
Thank you,
Regards, Nikolai
Michael
Michael
Thank you,
Regards, Nikolai
Thank you,
23.12.2018 21:58, I wrote: [...]
So far I'm observing that sunxi_nand_spl module refuses to load erased nand pages (500000 in the example below), which is correct, but it "successfully" loads filled nand pages as totally zeroed out, which is supposedly incorrect. This is in contrast with sunxi_nand module, that loads filled pages correctly, at least in my simple tests.
So while detection in sunxi_nand_spl seems fine, reading seems not.
I think digging deeper without some additional advice is a bit beyond my capabilities, although most probably some very tiny bits are missing...
Thank you,
Regards, Nikolai
U-Boot SPL 2019.01-rc2 (Dec 23 2018 - 23:23:57 +0300) CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 DRAM: 1024 MiB
SPL: board_init_r()
Trying to boot from NAND spl: nand - using hw ecc [zh]nand_spl_load_image(500000, 40)=-22 [zh]Read dump of page 768 (nand offs 600000, page_size 8192): 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, [zh]Read dump of page 768 (nand offs 600000, page_size 8192): 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, ===================================================== U-Boot 2019.01-rc2 (Dec 23 2018 - 22:30:35 +0300) Allwinner Technology
CPU: Allwinner A20 (SUN7I) Model: Olimex A20-Olinuxino Micro I2C: ready DRAM: 1 GiB NAND: nand_base: device found, Manufacturer ID: 0xad, Chip ID: 0xd7 nand_base: Hynix H27UBG8T2BTR-BC 32G 3.3V 8-bit nand_base: Hynix H27UBG8T2BTR-BC 32G 3.3V 8-bit nand_base: 4096 MiB, MLC, erase size: 2048 KiB, page size: 8192, OOB size: 640 Using ECC step 1024, strength 40, mode 2 4096 MiB In: serial Out: serial Err: serial SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net: Can't get reset: -524 eth0: ethernet@1c50000 Hit any key to stop autoboot: 0 => nand read 0x45000000 0x400000 0x1000
NAND read: device 0 offset 0x400000, size 0x1000 Scanning device for bad blocks Bad eraseblock 0 at 0x0000001fe000 Bad eraseblock 1 at 0x0000003fe000 4096 bytes read: OK => md.b 0x45000000 100 45000000: b8 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 ................ =====================================================
Thank you,
Regards, Nikolai
Thank you,
Regards, Nikolai
Michael
Michael
Thank you,
Regards, Nikolai
Thank you,
Hi again,
The following commit (titled "use PIO instead of DMA") apparently broke actual reading of nand pages in SPL at least for A20:
http://git.denx.de/?p=u-boot.git;a=commit;h=6ddbb1e936c78cdef1e7395039fa7020...
Instead of reading page contents, non-dma (current) version just feeds zeroes here. Tested on A20-olinuxino-micro with a Hynix 4GB nand chip.
It'd be nice to somehow fix it back eventually :)
Other than that, nand boot seems usable (with added necessary chip id).
Thank you,
Regards, Nikolai
Thank you,
Regards, Nikolai
SPL: board_init_r()
Thank you,
Regards, Nikolai
Thank you,
Regards, Nikolai
Michael
Michael
Thank you,
Regards, Nikolai
Thank you,
Its just to remind sunxi_nand_spl.c is still broken. (And probably has been for a couple releases or so). I'm unable to fix it myself (other than reverting the mentioned commit locally.)
Thank you,
Regards, Nikolai
24.12.2018 0:47, Nikolai Zhubr:
Hi again,
Thank you,
Regards, Nikolai
Nikolai Zhubr
