[PATCH] efi_loader: tcg2 protocol updates
On pull reuqest https://lists.denx.de/pipermail/u-boot/2020-November/432735.html V4 of the patchset was sent instead of the v5. This is the v4->v5 missing diff
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/efi_tcg2.h | 2 - lib/efi_loader/efi_tcg2.c | 160 ++++++++++++++++++++++---------------- 2 files changed, 92 insertions(+), 70 deletions(-)
diff --git a/include/efi_tcg2.h b/include/efi_tcg2.h index 4214f767eaba..86b8fe4c01af 100644 --- a/include/efi_tcg2.h +++ b/include/efi_tcg2.h @@ -18,8 +18,6 @@ /* TPMV2 only */ #define TCG2_EVENT_LOG_FORMAT_TCG_2 0x00000002
-/* SHA1, SHA256, SHA384, SHA512, TPM_ALG_SM3_256 */ -#define MAX_HASH_COUNT 5 /* Algorithm Registry */ #define EFI_TCG2_BOOT_HASH_ALG_SHA1 0x00000001 #define EFI_TCG2_BOOT_HASH_ALG_SHA256 0x00000002 diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index f5812ed2e9f2..62f2f9427b6e 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -30,6 +30,52 @@ DECLARE_GLOBAL_DATA_PTR; #define properties_offset (offsetof(struct tpml_tagged_tpm_property, tpm_property) + \ offsetof(struct tpms_tagged_property, value))
+struct { + u16 hash_alg; + u32 hash_mask; +} hash_algo_list[] = { + { + TPM2_ALG_SHA1, + EFI_TCG2_BOOT_HASH_ALG_SHA1, + }, + { + TPM2_ALG_SHA256, + EFI_TCG2_BOOT_HASH_ALG_SHA256, + }, + { + TPM2_ALG_SHA384, + EFI_TCG2_BOOT_HASH_ALG_SHA384, + }, + { + TPM2_ALG_SHA512, + EFI_TCG2_BOOT_HASH_ALG_SHA512, + }, + { + TPM2_ALG_SM3_256, + EFI_TCG2_BOOT_HASH_ALG_SM3_256, + }, +}; + +#define MAX_HASH_COUNT ARRAY_SIZE(hash_algo_list) +/** + * alg_to_mask - Get a TCG hash mask for algorithms + * + * @hash_alg: TCG defined algorithm + * + * @Return: TCG hashing algorithm bitmaps, 0 if the algorithm is not supported + */ +static u32 alg_to_mask(u16 hash_alg) +{ + int i; + + for (i = 0; i < MAX_HASH_COUNT; i++) { + if (hash_algo_list[i].hash_alg == hash_alg) + return hash_algo_list[i].hash_mask; + } + + return 0; +} + const efi_guid_t efi_guid_tcg2_protocol = EFI_TCG2_PROTOCOL_GUID;
/** @@ -44,10 +90,12 @@ const efi_guid_t efi_guid_tcg2_protocol = EFI_TCG2_PROTOCOL_GUID; */ __weak efi_status_t platform_get_tpm2_device(struct udevice **dev) { - for_each_tpm_device((*dev)) { + for_each_tpm_device(*dev) { + /* Only support TPMv2 devices */ if (tpm_get_version(*dev) == TPM_V2) return EFI_SUCCESS; } + return EFI_NOT_FOUND; }
@@ -242,36 +290,14 @@ static int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, }
for (i = 0; i < pcrs.count; i++) { - switch (pcrs.selection[i].hash) { - case TPM2_ALG_SHA1: - *supported_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA1; - if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA1; - break; - case TPM2_ALG_SHA256: - *supported_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA256; - if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA256; - break; - case TPM2_ALG_SHA384: - *supported_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA384; - if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA384; - break; - case TPM2_ALG_SHA512: - *supported_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA512; - if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= EFI_TCG2_BOOT_HASH_ALG_SHA512; - break; - case TPM2_ALG_SM3_256: - *supported_pcr |= EFI_TCG2_BOOT_HASH_ALG_SM3_256; + u32 hash_mask = alg_to_mask(pcrs.selection[i].hash); + + if (hash_mask) { + *supported_pcr |= hash_mask; if (is_active_pcr(&pcrs.selection[i])) - *active_pcr |= EFI_TCG2_BOOT_HASH_ALG_SM3_256; - break; - default: - EFI_PRINT("Unknown algorithm %x\n", - pcrs.selection[i].hash); - break; + *active_pcr |= hash_mask; + } else { + EFI_PRINT("Unknown algorithm %x\n", pcrs.selection[i].hash); } }
@@ -283,7 +309,7 @@ out: }
/** - * get_capability() - protocol capability information and state information + * efi_tcg2_get_capability() - protocol capability information and state information * * @this: TCG2 protocol instance * @capability: caller allocated memory with size field to the size of @@ -292,8 +318,8 @@ out: * Return: status code */ static efi_status_t EFIAPI -get_capability(struct efi_tcg2_protocol *this, - struct efi_tcg2_boot_service_capability *capability) +efi_tcg2_get_capability(struct efi_tcg2_protocol *this, + struct efi_tcg2_boot_service_capability *capability) { struct udevice *dev; efi_status_t efi_ret; @@ -381,7 +407,8 @@ out: }
/** - * get_eventlog() - retrieve the the address of an event log and its last entry + * efi_tcg2_get_eventlog() - retrieve the the address of an event log and its + * last entry * * @this: TCG2 protocol instance * @log_format: type of event log format @@ -395,15 +422,16 @@ out: * Return: status code */ static efi_status_t EFIAPI -get_eventlog(struct efi_tcg2_protocol *this, - efi_tcg_event_log_format log_format, u64 *event_log_location, - u64 *event_log_last_entry, bool *event_log_truncated) +efi_tcg2_get_eventlog(struct efi_tcg2_protocol *this, + efi_tcg_event_log_format log_format, + u64 *event_log_location, u64 *event_log_last_entry, + bool *event_log_truncated) { return EFI_UNSUPPORTED; }
/** - * hash_log_extend_event()- extend and optionally log events + * efi_tcg2_hash_log_extend_event() - extend and optionally log events * * @this: TCG2 protocol instance * @flags: bitmap providing additional information on the @@ -418,15 +446,15 @@ get_eventlog(struct efi_tcg2_protocol *this, * Return: status code */ static efi_status_t EFIAPI -hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, - u64 data_to_hash, u64 data_to_hash_len, - struct efi_tcg2_event *efi_tcg_event) +efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, + u64 data_to_hash, u64 data_to_hash_len, + struct efi_tcg2_event *efi_tcg_event) { return EFI_UNSUPPORTED; }
/** - * submit_command() - Send command to the TPM + * efi_tcg2_submit_command() - Send command to the TPM * * @this: TCG2 protocol instance * @input_param_block_size: size of the TPM input parameter block @@ -437,15 +465,15 @@ hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, * Return: status code */ efi_status_t EFIAPI -submit_command(struct efi_tcg2_protocol *this, u32 input_param_block_size, - u8 *input_param_block, u32 output_param_block_size, - u8 *output_param_block) +efi_tcg2_submit_command(struct efi_tcg2_protocol *this, + u32 input_param_block_size, u8 *input_param_block, + u32 output_param_block_size, u8 *output_param_block) { return EFI_UNSUPPORTED; }
/** - * get_active_pcr_banks() - returns the currently active PCR banks + * efi_tcg2_get_active_pcr_banks() - returns the currently active PCR banks * * @this: TCG2 protocol instance * @active_pcr_banks: pointer for receiving the bitmap of currently @@ -454,13 +482,14 @@ submit_command(struct efi_tcg2_protocol *this, u32 input_param_block_size, * Return: status code */ efi_status_t EFIAPI -get_active_pcr_banks(struct efi_tcg2_protocol *this, u32 *active_pcr_banks) +efi_tcg2_get_active_pcr_banks(struct efi_tcg2_protocol *this, + u32 *active_pcr_banks) { return EFI_UNSUPPORTED; }
/** - * set_active_pcr_banks() - sets the currently active PCR banks + * efi_tcg2_set_active_pcr_banks() - sets the currently active PCR banks * * @this: TCG2 protocol instance * @active_pcr_banks: bitmap of the requested active PCR banks @@ -468,14 +497,15 @@ get_active_pcr_banks(struct efi_tcg2_protocol *this, u32 *active_pcr_banks) * Return: status code */ efi_status_t EFIAPI -set_active_pcr_banks(struct efi_tcg2_protocol *this, u32 active_pcr_banks) +efi_tcg2_set_active_pcr_banks(struct efi_tcg2_protocol *this, + u32 active_pcr_banks) { return EFI_UNSUPPORTED; }
/** - * get_result_of_set_active_pcr_banks() - retrieves the result of a previous - * set_active_pcr_banks() + * efi_tcg2_get_result_of_set_active_pcr_banks() - retrieve result for previous + * set_active_pcr_banks() * * @this: TCG2 protocol instance * @operation_present: non-zero value to indicate a @@ -486,20 +516,20 @@ set_active_pcr_banks(struct efi_tcg2_protocol *this, u32 active_pcr_banks) * Return: status code */ efi_status_t EFIAPI -get_result_of_set_active_pcr_banks(struct efi_tcg2_protocol *this, - u32 *operation_present, u32 *response) +efi_tcg2_get_result_of_set_active_pcr_banks(struct efi_tcg2_protocol *this, + u32 *operation_present, u32 *response) { return EFI_UNSUPPORTED; }
static const struct efi_tcg2_protocol efi_tcg2_protocol = { - .get_capability = get_capability, - .get_eventlog = get_eventlog, - .hash_log_extend_event = hash_log_extend_event, - .submit_command = submit_command, - .get_active_pcr_banks = get_active_pcr_banks, - .set_active_pcr_banks = set_active_pcr_banks, - .get_result_of_set_active_pcr_banks = get_result_of_set_active_pcr_banks, + .get_capability = efi_tcg2_get_capability, + .get_eventlog = efi_tcg2_get_eventlog, + .hash_log_extend_event = efi_tcg2_hash_log_extend_event, + .submit_command = efi_tcg2_submit_command, + .get_active_pcr_banks = efi_tcg2_get_active_pcr_banks, + .set_active_pcr_banks = efi_tcg2_set_active_pcr_banks, + .get_result_of_set_active_pcr_banks = efi_tcg2_get_result_of_set_active_pcr_banks, };
/** @@ -513,18 +543,12 @@ efi_status_t efi_tcg2_register(void) { efi_status_t ret; struct udevice *dev; - enum tpm_version tpm_ver;
ret = platform_get_tpm2_device(&dev); - if (ret != EFI_SUCCESS) - return EFI_SUCCESS; - - tpm_ver = tpm_get_version(dev); - if (tpm_ver != TPM_V2) { - log_warning("Only TPMv2 supported for EFI_TCG2_PROTOCOL\n"); + if (ret != EFI_SUCCESS) { + log_warning("Unable to find TPMv2 device\n"); return EFI_SUCCESS; } - ret = efi_add_protocol(efi_root, &efi_guid_tcg2_protocol, (void *)&efi_tcg2_protocol); if (ret != EFI_SUCCESS)
Ilias Apalodimas
