[PATCH v4 0/3] Add bitbang feature for npcm8xx and driver
I am resubmitting the patch titled "Add bitbang feature for npcm8xx and driver" for review and inclusion in the upstream project.
Driver didn't support bitbang feature. Add bb_miiphy_bus function for driver and open feature for npcm8xx
the log is as below: ------------------------------------------------- U-Boot 2024.10-g30b9cdaf2df5-dirty (Jan 09 2025 - 00:57:37 +0000)
CPU-0: NPCM845 A1 @ Model: Nuvoton npcm845 Development Board (Device Tree) DRAM: 1 GiB RNG: NPCM RNG module bind OK OTP: NPCM OTP module bind OK AES: NPCM AES module bind OK SHA: NPCM SHA module bind OK I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled Core: 649 devices, 28 uclasses, devicetree: separate WDT: Not starting watchdog@901c MMC: sdhci@f0842000: 0 Loading Environment from SPIFlash... SF: Detected w25q512jvq with page size 256 Bytes, erase size 64 KiB, total 64 MiB OK In: serial@0 Out: serial@0 Err: serial@0 Net: eth0: eth@f0802000, eth1: eth@f0804000, eth3: eth@f0808000 Hit any key to stop autoboot: 0 U-Boot> U-Boot> U-Boot>setenv ipaddr 192.168.16.3 U-Boot>ping 192.168.16.12 eth@f0802000 Waiting for PHY auto negotiation to complete ......... TIMEOUT ! Could not initialize PHY eth@f0802000 eth@f0804000 Waiting for PHY auto negotiation to complete ......... TIMEOUT ! Could not initialize PHY eth@f0804000 Speed: 100, full duplex Using eth@f0808000 device host 192.168.16.12 is alive -------------------------------------------------
Changes for v4: - Replece bitbang function prefix npcm to dw.
Changes for v3: - Support multiple buses for multiple Ethernet interfaces.
Changes for v2: - add bitbang delay dts read - modify printf to debug
Michael Chang (3): ARM: dts: nuvoton: Add bitbang delay through dts properties. ARM: configs: nuvoton: add bitbang feature for npcm8xx. net: designware: Add bitbang feature for designware driver.
arch/arm/dts/nuvoton-npcm845-evb.dts | 1 + configs/arbel_evb_defconfig | 4 + drivers/net/designware.c | 113 +++++++++++++++++++++++++++ drivers/net/designware.h | 6 +- 4 files changed, 123 insertions(+), 1 deletion(-)
Signed-off-by: Jim Liu JJLIU0@nuvoton.com Signed-off-by: Michael Chang zhang971090220@gmail.com --- arch/arm/dts/nuvoton-npcm845-evb.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/nuvoton-npcm845-evb.dts b/arch/arm/dts/nuvoton-npcm845-evb.dts index 0d3aaa0fff..1535defe38 100644 --- a/arch/arm/dts/nuvoton-npcm845-evb.dts +++ b/arch/arm/dts/nuvoton-npcm845-evb.dts @@ -190,6 +190,7 @@ snps,mdio-gpio = <&gpio2 28 GPIO_ACTIVE_HIGH>; /* gpio92 */ snps,reset-active-low; snps,reset-delays-us = <0 10000 1000000>; + snps,bitbang-delay = <1>; snps,reset-gpio = <&gpio2 29 GPIO_ACTIVE_LOW>; /* gpio93 */ status = "okay"; };
Enable bitbang and multiple bitbang feature for npcm8xx platform.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com Signed-off-by: Michael Chang zhang971090220@gmail.com --- configs/arbel_evb_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/arbel_evb_defconfig b/configs/arbel_evb_defconfig index 4a58146e61..c93fa34eb5 100644 --- a/configs/arbel_evb_defconfig +++ b/configs/arbel_evb_defconfig @@ -80,6 +80,10 @@ CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_PINCTRL_NPCM8XX=y CONFIG_DM_REGULATOR=y +CONFIG_BITBANGMII=y +CONFIG_BITBANGMII_MULTI=y +CONFIG_PHY_ADDR_ENABLE=y +CONFIG_PHY_ADDR=0 CONFIG_DM_REGULATOR_NPCM8XX=y CONFIG_RNG_NPCM=y CONFIG_DM_SERIAL=y
Add bb_miiphy_bus function for designware bitbang feature.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com Signed-off-by: Michael Chang zhang971090220@gmail.com --- drivers/net/designware.c | 113 +++++++++++++++++++++++++++++++++++++++ drivers/net/designware.h | 6 ++- 2 files changed, 118 insertions(+), 1 deletion(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 07b0f49ef5..94d8f1b4c0 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -784,6 +784,39 @@ int designware_eth_probe(struct udevice *dev) priv->bus = miiphy_get_dev_by_name(dev->name); priv->dev = dev;
+#if IS_ENABLED(CONFIG_BITBANGMII) && IS_ENABLED(CONFIG_DM_GPIO) + if (dev_read_bool(dev, "snps,bitbang-mii")) { + int bus_idx; + + debug("\n%s: use bitbang mii..\n", dev->name); + ret = gpio_request_by_name(dev, "snps,mdc-gpio", 0, + &priv->mdc_gpio, GPIOD_IS_OUT + | GPIOD_IS_OUT_ACTIVE); + if (ret) { + debug("no mdc-gpio\n"); + return ret; + } + ret = gpio_request_by_name(dev, "snps,mdio-gpio", 0, + &priv->mdio_gpio, GPIOD_IS_OUT + | GPIOD_IS_OUT_ACTIVE); + if (ret) { + debug("no mdio-gpio\n"); + return ret; + } + priv->bb_delay = dev_read_u32_default(dev, "snps,bitbang-delay", 1); + + for (bus_idx = 0; bus_idx < bb_miiphy_buses_num; bus_idx++) { + if (!bb_miiphy_buses[bus_idx].priv) { + bb_miiphy_buses[bus_idx].priv = priv; + strlcpy(bb_miiphy_buses[bus_idx].name, priv->bus->name, + MDIO_NAME_LEN); + priv->bus->read = bb_miiphy_read; + priv->bus->write = bb_miiphy_write; + break; + } + } + } +#endif ret = dw_phy_init(priv, dev); debug("%s, ret=%d\n", __func__, ret); if (!ret) @@ -894,3 +927,83 @@ static struct pci_device_id supported[] = { };
U_BOOT_PCI_DEVICE(eth_designware, supported); + +#if IS_ENABLED(CONFIG_BITBANGMII) && IS_ENABLED(CONFIG_DM_GPIO) +static int dw_eth_bb_mdio_active(struct bb_miiphy_bus *bus) +{ + struct dw_eth_dev *priv = bus->priv; + struct gpio_desc *desc = &priv->mdio_gpio; + + desc->flags = 0; + dm_gpio_set_dir_flags(&priv->mdio_gpio, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + + return 0; +} + +static int dw_eth_bb_mdio_tristate(struct bb_miiphy_bus *bus) +{ + struct dw_eth_dev *priv = bus->priv; + struct gpio_desc *desc = &priv->mdio_gpio; + + desc->flags = 0; + dm_gpio_set_dir_flags(&priv->mdio_gpio, GPIOD_IS_IN); + + return 0; +} + +static int dw_eth_bb_set_mdio(struct bb_miiphy_bus *bus, int v) +{ + struct dw_eth_dev *priv = bus->priv; + + if (v) + dm_gpio_set_value(&priv->mdio_gpio, 1); + else + dm_gpio_set_value(&priv->mdio_gpio, 0); + + return 0; +} + +static int dw_eth_bb_get_mdio(struct bb_miiphy_bus *bus, int *v) +{ + struct dw_eth_dev *priv = bus->priv; + + *v = dm_gpio_get_value(&priv->mdio_gpio); + + return 0; +} + +static int dw_eth_bb_set_mdc(struct bb_miiphy_bus *bus, int v) +{ + struct dw_eth_dev *priv = bus->priv; + + if (v) + dm_gpio_set_value(&priv->mdc_gpio, 1); + else + dm_gpio_set_value(&priv->mdc_gpio, 0); + + return 0; +} + +static int dw_eth_bb_delay(struct bb_miiphy_bus *bus) +{ + struct dw_eth_dev *priv = bus->priv; + + udelay(priv->bb_delay); + return 0; +} + +struct bb_miiphy_bus bb_miiphy_buses[] = { + { + .name = BB_MII_DEVNAME, + .mdio_active = dw_eth_bb_mdio_active, + .mdio_tristate = dw_eth_bb_mdio_tristate, + .set_mdio = dw_eth_bb_set_mdio, + .get_mdio = dw_eth_bb_get_mdio, + .set_mdc = dw_eth_bb_set_mdc, + .delay = dw_eth_bb_delay, + .priv = NULL, + } +}; + +int bb_miiphy_buses_num = ARRAY_SIZE(bb_miiphy_buses); +#endif diff --git a/drivers/net/designware.h b/drivers/net/designware.h index e47101ccaf..cccf9d54e0 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -229,7 +229,11 @@ struct dw_eth_dev { u32 max_speed; u32 tx_currdescnum; u32 rx_currdescnum; - +#if IS_ENABLED(CONFIG_BITBANGMII) && IS_ENABLED(CONFIG_DM_GPIO) + u32 bb_delay; + struct gpio_desc mdc_gpio; + struct gpio_desc mdio_gpio; +#endif struct eth_mac_regs *mac_regs_p; struct eth_dma_regs *dma_regs_p; #if CONFIG_IS_ENABLED(DM_GPIO)
Michael Chang
