[PATCH v2] mach-snapdragon: move default environment to a file
Make use of CONFIG_DEFAULT_ENV_FILE and move the default qcom environment to a file under board/qualcomm.
This is much cleaner and means we don't need to recompile on changing the environment.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Changes since v1: - Don't set bootfile - V1: https://lore.kernel.org/u-boot/20240617085629.1744017-1-caleb.connolly@linar... --- board/qualcomm/default.env | 11 +++++++++++ configs/qcom_defconfig | 2 ++ include/configs/qcom.h | 16 ---------------- 3 files changed, 13 insertions(+), 16 deletions(-) create mode 100644 board/qualcomm/default.env
diff --git a/board/qualcomm/default.env b/board/qualcomm/default.env new file mode 100644 index 000000000000..dbf6f4e72600 --- /dev/null +++ b/board/qualcomm/default.env @@ -0,0 +1,11 @@ +stdin=serial,button-kbd +stdout=serial,vidconsole +stderr=serial,vidconsole +preboot=scsi scan; usb start +fastboot=fastboot -l $fastboot_addr_r usb 0 +do_boot=bootefi bootmgr +bootmenu_0=Boot first available device=run do_boot +bootmenu_1=Enable fastboot mode=run fastboot +bootmenu_2=Reset device=reset +menucmd=bootmenu +bootcmd=run do_boot diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 25fa8b0f7d2b..4ff280fc6e7d 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -46,8 +46,10 @@ CONFIG_CMD_LOG=y CONFIG_OF_LIVE=y CONFIG_OF_UPSTREAM_BUILD_VENDOR=y CONFIG_BUTTON_QCOM_PMIC=y CONFIG_BUTTON_REMAP_PHONE_KEYS=y +CONFIG_USE_DEFAULT_ENV_FILE=y +CONFIG_DEFAULT_ENV_FILE="board/qualcomm/default.env" CONFIG_CLK=y CONFIG_CLK_STUB=y CONFIG_CLK_QCOM_APQ8016=y CONFIG_CLK_QCOM_APQ8096=y diff --git a/include/configs/qcom.h b/include/configs/qcom.h index c13a847f62f1..b7d38866c51d 100644 --- a/include/configs/qcom.h +++ b/include/configs/qcom.h @@ -10,21 +10,5 @@ #define __CONFIGS_SNAPDRAGON_H
#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600, 3000000 }
-/* Load addressed are calculated during board_late_init(). See arm/mach-snapdragon/board.c */ -#define CFG_EXTRA_ENV_SETTINGS \ - "stdin=serial,button-kbd\0" \ - "stdout=serial,vidconsole\0" \ - "stderr=serial,vidconsole\0" \ - "bootfile=/extlinux/extlinux.conf\0" \ - "preboot=scsi scan; usb start\0" \ - "fastboot=fastboot -l $fastboot_addr_r usb 0\0" \ - "do_boot=bootefi bootmgr\0" \ - "bootmenu_0=Boot first available device=run do_boot\0" \ - "bootmenu_1=Enable USB mass storage=ums 0 scsi 0,1,2,3,4,5\0" \ - "bootmenu_2=Enable fastboot mode=run fastboot\0" \ - "bootmenu_3=Reset device=reset\0" \ - "menucmd=bootmenu\0" \ - "bootcmd=run do_boot\0" /* first entry is default */ - #endif
Changes since v1:
- #endif
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Caleb Connolly
Neil Armstrong
