[U-Boot] [PATCH 1/5] net: uec_phy: Implement TXID and RXID RGMII modes for Marvell PHYs
This will be needed for MPC8360E-MDS boards with rev. 2.1 CPUs.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com --- drivers/qe/uec.h | 1 + drivers/qe/uec_phy.c | 15 +++++++++++++-- 2 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/qe/uec.h b/drivers/qe/uec.h index 1568310..df6f7c9 100644 --- a/drivers/qe/uec.h +++ b/drivers/qe/uec.h @@ -670,6 +670,7 @@ typedef enum enet_interface { ENET_1000_RGMII, ENET_1000_RGMII_ID, ENET_1000_RGMII_RXID, + ENET_1000_RGMII_TXID, ENET_1000_TBI, ENET_1000_RTBI, ENET_1000_SGMII diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index aa4eb5e..9715183 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -429,12 +429,23 @@ static int marvell_init(struct uec_mii_info *mii_info) { struct eth_device *edev = mii_info->dev; uec_private_t *uec = edev->priv; + enum enet_interface iface = uec->uec_info->enet_interface;
- if (uec->uec_info->enet_interface == ENET_1000_RGMII_ID) { + if (iface == ENET_1000_RGMII_ID || + iface == ENET_1000_RGMII_RXID || + iface == ENET_1000_RGMII_TXID) { int temp;
temp = phy_read(mii_info, MII_M1111_PHY_EXT_CR); - temp |= (MII_M1111_RX_DELAY | MII_M1111_TX_DELAY); + if (iface == ENET_1000_RGMII_ID) { + temp |= MII_M1111_RX_DELAY | MII_M1111_TX_DELAY; + } else if (iface == ENET_1000_RGMII_RXID) { + temp &= ~MII_M1111_TX_DELAY; + temp |= MII_M1111_RX_DELAY; + } else if (iface == ENET_1000_RGMII_TXID) { + temp &= ~MII_M1111_RX_DELAY; + temp |= MII_M1111_TX_DELAY; + } phy_write(mii_info, MII_M1111_PHY_EXT_CR, temp);
temp = phy_read(mii_info, MII_M1111_PHY_EXT_SR);
Anton Vorontsov
