[PATCH] imx8m{m, n}_venice_defconfig: enable md5sum and crc32 commands
Enable the md5sum and crc32 commands.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- configs/imx8mm_venice_defconfig | 4 +++- configs/imx8mn_venice_defconfig | 4 +++- 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index a9ff5654baa3..c5cd0147f0f1 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -40,7 +40,9 @@ CONFIG_SPL_WATCHDOG=y CONFIG_SYS_PROMPT="u-boot=> " # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set -# CONFIG_CMD_CRC32 is not set +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_FUSE=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index 7628667d50ae..e998b90e2282 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -41,7 +41,9 @@ CONFIG_SPL_WATCHDOG=y CONFIG_SYS_PROMPT="u-boot=> " # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set -# CONFIG_CMD_CRC32 is not set +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_FUSE=y
Enable the md5sum and crc32 commands. Signed-off-by: Tim Harvey tharvey@gateworks.com
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
