[PATCH v5 0/2] riscv: spacemit: add support for bananapi-f3
Banana Pi F3 board is a industrial grade RISC-V development board, it design with SpacemiT K1 8 core RISC-V chip, CPU integrates 2.0 TOPs AI computing power. 4G DDR and 16G eMMC onboard. 2x GbE Ethernet port, 4x USB 3.0 and PCIe for M.2 interface, support HDMI and Dual MIPI-CSI Camera.
This patch introduces fundamental support for the Banana Pi F3 board, encompassing UART, CPU, and PLIC support. This ensures that U-Boot can operate in serial console mode.
Changes in v5: - Formal the name from Bananapif3 -> Banana Pi BPI-F3 - Trailing whitespace - New blank line at EOF in spacemit/index.rst - Link to v4: https://lore.kernel.org/r/20241129-pickup-bpif3-v4-0-e99fabf66e33@gmail.com
Changes in v4: - Change uart compatible in k1.dtsi in v3, cause related driver in not implemented in u-boot. - Update doc, show how to validate the patch. - Update maintainer, remove kongyang cause he lefted. - Link to v3: https://lore.kernel.org/r/20241114-pickup-bpif3-v3-0-98a45802ab79@gmail.com
Changes in v3: - Add base commit - Clear redifinition warning while building in UART_IIR_ID - Change underscore to dash in bananapi*f3 - Update maintainer - link to v2 https://lore.kernel.org/u-boot/20240718043329.1500-1-seashell11234455@gmail....
Changes in v2: - Change license to GPL-2.0-or-later - Add memory node for dts - Add ft_board_setup function for kernel memory init - Use default prompt - links to v1 https://lore.kernel.org/u-boot/20240714150828.736-1-seashell11234455@gmail.c...
Signed-off-by: Huan Zhou pericycle.cc@gmail.com Signed-off-by: Kongyang Liu seashell11234455@gmail.com --- Kongyang Liu (2): riscv: spacemit: bananapi_f3: initial support added doc: spacemit: bananapi_f3: document Banana Pi F3 board
arch/riscv/Kconfig | 5 + arch/riscv/cpu/k1/Kconfig | 18 ++ arch/riscv/cpu/k1/Makefile | 6 + arch/riscv/cpu/k1/cpu.c | 9 + arch/riscv/cpu/k1/dram.c | 54 ++++ arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k1-bananapi-f3.dts | 25 ++ arch/riscv/dts/k1.dtsi | 459 +++++++++++++++++++++++++++++++++ board/spacemit/bananapi-f3/Kconfig | 25 ++ board/spacemit/bananapi-f3/MAINTAINERS | 6 + board/spacemit/bananapi-f3/Makefile | 5 + board/spacemit/bananapi-f3/board.c | 9 + configs/bananapi-f3_defconfig | 20 ++ doc/board/index.rst | 1 + doc/board/spacemit/bananapi-f3.rst | 86 ++++++ doc/board/spacemit/index.rst | 9 + include/configs/bananapi-f3.h | 13 + 17 files changed, 751 insertions(+) --- base-commit: 40c45a57974bdb09fffa31dde65ddf69e5de53eb change-id: 20241112-pickup-bpif3-245ab208b9a4
Add basic support for SpacemiT's Banana Pi F3 board. Update the k1.dtsi align with mainline. Note that the device tree files follow the mainline Linux source[1].
[1]. https://patches.linaro.org/project/linux-serial/patch/20240730-k1-01-basic-d...
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Signed-off-by: Huan Zhou pericycle.cc@gmail.com --- arch/riscv/Kconfig | 5 + arch/riscv/cpu/k1/Kconfig | 18 ++ arch/riscv/cpu/k1/Makefile | 6 + arch/riscv/cpu/k1/cpu.c | 9 + arch/riscv/cpu/k1/dram.c | 54 ++++ arch/riscv/dts/Makefile | 1 + arch/riscv/dts/k1-bananapi-f3.dts | 25 ++ arch/riscv/dts/k1.dtsi | 459 +++++++++++++++++++++++++++++++++ board/spacemit/bananapi-f3/Kconfig | 25 ++ board/spacemit/bananapi-f3/MAINTAINERS | 6 + board/spacemit/bananapi-f3/Makefile | 5 + board/spacemit/bananapi-f3/board.c | 9 + configs/bananapi-f3_defconfig | 20 ++ include/configs/bananapi-f3.h | 13 + 14 files changed, 655 insertions(+)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fa3b016c52728862019c426f031262c40901ee51..bf810735aa3349e511b461a89e1833948711f5c3 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -11,6 +11,9 @@ choice config TARGET_ANDES_AE350 bool "Support Andes ae350"
+config TARGET_BANANAPI_F3 + bool "Support BananaPi F3 Board" + config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board"
@@ -88,6 +91,7 @@ source "board/sifive/unleashed/Kconfig" source "board/sifive/unmatched/Kconfig" source "board/sipeed/maix/Kconfig" source "board/sophgo/milkv_duo/Kconfig" +source "board/spacemit/bananapi-f3/Kconfig" source "board/starfive/visionfive2/Kconfig" source "board/thead/th1520_lpi4a/Kconfig" source "board/xilinx/mbv/Kconfig" @@ -99,6 +103,7 @@ source "arch/riscv/cpu/fu540/Kconfig" source "arch/riscv/cpu/fu740/Kconfig" source "arch/riscv/cpu/generic/Kconfig" source "arch/riscv/cpu/jh7110/Kconfig" +source "arch/riscv/cpu/k1/Kconfig"
# architecture-specific options below
diff --git a/arch/riscv/cpu/k1/Kconfig b/arch/riscv/cpu/k1/Kconfig new file mode 100644 index 0000000000000000000000000000000000000000..d9cd8dce96426bb4cbe9ff38385a4c66116fe341 --- /dev/null +++ b/arch/riscv/cpu/k1/Kconfig @@ -0,0 +1,18 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (C) 2024, Kongyang Liu seashell11234455@gmail.com + +config SPACEMIT_K1 + bool + select BINMAN + select ARCH_EARLY_INIT_R + select SYS_CACHE_SHIFT_6 + imply CPU + imply CPU_RISCV + imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) + imply RISCV_ACLINT if RISCV_MMODE + imply SPL_RISCV_ACLINT if SPL_RISCV_MMODE + imply CMD_CPU + imply SPL_CPU + imply SPL_OPENSBI + imply SPL_LOAD_FIT diff --git a/arch/riscv/cpu/k1/Makefile b/arch/riscv/cpu/k1/Makefile new file mode 100644 index 0000000000000000000000000000000000000000..bad4f4cf46fb6eb44053dc52df1837b58046c745 --- /dev/null +++ b/arch/riscv/cpu/k1/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + +obj-y += dram.o +obj-y += cpu.o diff --git a/arch/riscv/cpu/k1/cpu.c b/arch/riscv/cpu/k1/cpu.c new file mode 100644 index 0000000000000000000000000000000000000000..41a4a1b95e6e4b6dd1580b5f714107cac6c1dc02 --- /dev/null +++ b/arch/riscv/cpu/k1/cpu.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +int cleanup_before_linux(void) +{ + return 0; +} diff --git a/arch/riscv/cpu/k1/dram.c b/arch/riscv/cpu/k1/dram.c new file mode 100644 index 0000000000000000000000000000000000000000..c477c15cbfb19f0e3a0ee72985b602f5bda352d7 --- /dev/null +++ b/arch/riscv/cpu/k1/dram.c @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +#include <asm/global_data.h> +#include <config.h> +#include <fdt_support.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_base = CFG_SYS_SDRAM_BASE; + /* TODO get ram size from ddr controller */ + gd->ram_size = SZ_4G; + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = min_t(phys_size_t, gd->ram_size, SZ_2G); + + if (gd->ram_size > SZ_2G && CONFIG_NR_DRAM_BANKS > 1) { + gd->bd->bi_dram[1].start = 0x100000000; + gd->bd->bi_dram[1].size = gd->ram_size - SZ_2G; + } + + return 0; +} + +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) +{ + if (gd->ram_size > SZ_2G) + return SZ_2G; + + return gd->ram_size; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + u64 start[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + int i; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + start[i] = gd->bd->bi_dram[i].start; + size[i] = gd->bd->bi_dram[i].size; + } + + return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); +} diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 17cda483e128996bb944f5a2b9b7676d32e45ae5..71267f96f80214e8e4b11970a5a4a79e537bf633 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb +dtb-$(CONFIG_TARGET_BANANAPI_F3) += k1-bananapi-f3.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_MILKV_DUO) += cv1800b-milkv-duo.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb diff --git a/arch/riscv/dts/k1-bananapi-f3.dts b/arch/riscv/dts/k1-bananapi-f3.dts new file mode 100644 index 0000000000000000000000000000000000000000..d2486f70906143ad1f2bde753f12dea5bab2e5ab --- /dev/null +++ b/arch/riscv/dts/k1-bananapi-f3.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (C) 2024 Yangyu Chen cyy@cyyself.name + */ + +#include "k1.dtsi" +#include "binman.dtsi" + +/ { + model = "Banana Pi BPI-F3"; + compatible = "bananapi,bpi-f3", "spacemit,k1"; + + chosen { + stdout-path = "serial0"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x80000000>; + }; +}; + +&uart0 { + status = "okay"; +}; diff --git a/arch/riscv/dts/k1.dtsi b/arch/riscv/dts/k1.dtsi new file mode 100644 index 0000000000000000000000000000000000000000..514be453dbaf6713cdf4ad5a5d653488297ebb83 --- /dev/null +++ b/arch/riscv/dts/k1.dtsi @@ -0,0 +1,459 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (C) 2024 Yangyu Chen cyy@cyyself.name + */ + +/dts-v1/; +/ { + #address-cells = <2>; + #size-cells = <2>; + model = "SpacemiT K1"; + compatible = "spacemit,k1"; + + aliases { + serial0 = &uart0; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + serial5 = &uart6; + serial6 = &uart7; + serial7 = &uart8; + serial8 = &uart9; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <24000000>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu_0>; + }; + core1 { + cpu = <&cpu_1>; + }; + core2 { + cpu = <&cpu_2>; + }; + core3 { + cpu = <&cpu_3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu_4>; + }; + core1 { + cpu = <&cpu_5>; + }; + core2 { + cpu = <&cpu_6>; + }; + core3 { + cpu = <&cpu_7>; + }; + }; + }; + + cpu_0: cpu@0 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <0>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster0_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu0_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_1: cpu@1 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <1>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster0_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu1_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_2: cpu@2 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <2>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster0_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu2_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_3: cpu@3 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <3>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster0_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu3_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_4: cpu@4 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <4>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster1_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu4_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_5: cpu@5 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <5>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster1_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu5_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_6: cpu@6 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <6>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster1_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu6_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cpu_7: cpu@7 { + compatible = "spacemit,x60", "riscv"; + device_type = "cpu"; + reg = <7>; + riscv,isa = "rv64imafdcv_zicbom_zicbop_zicboz_zicntr_zicond_zicsr_zifencei_zihintpause_zihpm_zfh_zba_zbb_zbc_zbs_zkt_zvfh_zvkt_sscofpmf_sstc_svinval_svnapot_svpbmt"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c", "v", "zicbom", + "zicbop", "zicboz", "zicntr", "zicond", "zicsr", + "zifencei", "zihintpause", "zihpm", "zfh", "zba", + "zbb", "zbc", "zbs", "zkt", "zvfh", "zvkt", + "sscofpmf", "sstc", "svinval", "svnapot", "svpbmt"; + riscv,cbom-block-size = <64>; + riscv,cbop-block-size = <64>; + riscv,cboz-block-size = <64>; + i-cache-block-size = <64>; + i-cache-size = <32768>; + i-cache-sets = <128>; + d-cache-block-size = <64>; + d-cache-size = <32768>; + d-cache-sets = <128>; + next-level-cache = <&cluster1_l2_cache>; + mmu-type = "riscv,sv39"; + + cpu7_intc: interrupt-controller { + compatible = "riscv,cpu-intc"; + interrupt-controller; + #interrupt-cells = <1>; + }; + }; + + cluster0_l2_cache: l2-cache0 { + compatible = "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-size = <524288>; + cache-sets = <512>; + cache-unified; + }; + + cluster1_l2_cache: l2-cache1 { + compatible = "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-size = <524288>; + cache-sets = <512>; + cache-unified; + }; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&plic>; + #address-cells = <2>; + #size-cells = <2>; + dma-noncoherent; + ranges; + + uart0: serial@d4017000 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017000 0x0 0x100>; + interrupts = <42>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart2: serial@d4017100 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017100 0x0 0x100>; + interrupts = <44>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart3: serial@d4017200 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017200 0x0 0x100>; + interrupts = <45>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart4: serial@d4017300 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017300 0x0 0x100>; + interrupts = <46>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart5: serial@d4017400 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017400 0x0 0x100>; + interrupts = <47>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart6: serial@d4017500 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017500 0x0 0x100>; + interrupts = <48>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart7: serial@d4017600 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017600 0x0 0x100>; + interrupts = <49>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart8: serial@d4017700 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017700 0x0 0x100>; + interrupts = <50>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart9: serial@d4017800 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xd4017800 0x0 0x100>; + interrupts = <51>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + plic: interrupt-controller@e0000000 { + compatible = "spacemit,k1-plic", "sifive,plic-1.0.0"; + reg = <0x0 0xe0000000 0x0 0x4000000>; + interrupts-extended = <&cpu0_intc 11>, <&cpu0_intc 9>, + <&cpu1_intc 11>, <&cpu1_intc 9>, + <&cpu2_intc 11>, <&cpu2_intc 9>, + <&cpu3_intc 11>, <&cpu3_intc 9>, + <&cpu4_intc 11>, <&cpu4_intc 9>, + <&cpu5_intc 11>, <&cpu5_intc 9>, + <&cpu6_intc 11>, <&cpu6_intc 9>, + <&cpu7_intc 11>, <&cpu7_intc 9>; + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + riscv,ndev = <159>; + }; + + clint: timer@e4000000 { + compatible = "spacemit,k1-clint", "sifive,clint0"; + reg = <0x0 0xe4000000 0x0 0x10000>; + interrupts-extended = <&cpu0_intc 3>, <&cpu0_intc 7>, + <&cpu1_intc 3>, <&cpu1_intc 7>, + <&cpu2_intc 3>, <&cpu2_intc 7>, + <&cpu3_intc 3>, <&cpu3_intc 7>, + <&cpu4_intc 3>, <&cpu4_intc 7>, + <&cpu5_intc 3>, <&cpu5_intc 7>, + <&cpu6_intc 3>, <&cpu6_intc 7>, + <&cpu7_intc 3>, <&cpu7_intc 7>; + }; + + sec_uart1: serial@f0612000 { + compatible = "spacemit,k1-uart", "snps,dw-apb-uart"; + reg = <0x0 0xf0612000 0x0 0x100>; + interrupts = <43>; + clock-frequency = <14857000>; + reg-shift = <2>; + reg-io-width = <4>; + status = "reserved"; /* for TEE usage */ + }; + }; +}; \ No newline at end of file diff --git a/board/spacemit/bananapi-f3/Kconfig b/board/spacemit/bananapi-f3/Kconfig new file mode 100644 index 0000000000000000000000000000000000000000..f89fa9af2c7d92e87722a54c4df9216d76376de9 --- /dev/null +++ b/board/spacemit/bananapi-f3/Kconfig @@ -0,0 +1,25 @@ +if TARGET_BANANAPI_F3 + +config SYS_BOARD + default "bananapi-f3" + +config SYS_VENDOR + default "spacemit" + +config SYS_CPU + default "k1" + +config SYS_CONFIG_NAME + default "bananapi-f3" + +config TEXT_BASE + default 0x00200000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x00000000 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select SPACEMIT_K1 + +endif diff --git a/board/spacemit/bananapi-f3/MAINTAINERS b/board/spacemit/bananapi-f3/MAINTAINERS new file mode 100644 index 0000000000000000000000000000000000000000..131bad03181021bb10b8f2189f00870f45f6dac1 --- /dev/null +++ b/board/spacemit/bananapi-f3/MAINTAINERS @@ -0,0 +1,6 @@ +BananaPi F3 +M: Huan Zhou <pericycle.cc@@gmail.com> +S: Maintained +F: board/spacemit/bananapi-f3/ +F: configs/bananapi-f3_defconfig +F: doc/board/spacemit/bananapi-f3.rst diff --git a/board/spacemit/bananapi-f3/Makefile b/board/spacemit/bananapi-f3/Makefile new file mode 100644 index 0000000000000000000000000000000000000000..2168698402b6d1d26988ca4e3a8e55367db51532 --- /dev/null +++ b/board/spacemit/bananapi-f3/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + +obj-y := board.o diff --git a/board/spacemit/bananapi-f3/board.c b/board/spacemit/bananapi-f3/board.c new file mode 100644 index 0000000000000000000000000000000000000000..2631cdd49e0eb4afde0efadb2f3014fd623f78f2 --- /dev/null +++ b/board/spacemit/bananapi-f3/board.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + */ + +int board_init(void) +{ + return 0; +} diff --git a/configs/bananapi-f3_defconfig b/configs/bananapi-f3_defconfig new file mode 100644 index 0000000000000000000000000000000000000000..6363620208757df185e3a11ee1260eb57256ac68 --- /dev/null +++ b/configs/bananapi-f3_defconfig @@ -0,0 +1,20 @@ +CONFIG_RISCV=y +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000000 +CONFIG_DEFAULT_DEVICE_TREE="k1-bananapi-f3" +CONFIG_SYS_LOAD_ADDR=0x200000 +CONFIG_TARGET_BANANAPI_F3=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_FIT=y +CONFIG_SYS_BOOTM_LEN=0xa000000 +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_CBSIZE=256 +CONFIG_SYS_PBSIZE=276 +CONFIG_HUSH_PARSER=y +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_NS16550=y +CONFIG_SYS_NS16550_MEM32=y diff --git a/include/configs/bananapi-f3.h b/include/configs/bananapi-f3.h new file mode 100644 index 0000000000000000000000000000000000000000..aecf69cd4cf8ddaea7dee57bf1a8ce8dc5db513d --- /dev/null +++ b/include/configs/bananapi-f3.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com + * + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CFG_SYS_SDRAM_BASE 0x0 +#define CFG_SYS_NS16550_IER 0x40 + +#endif /* __CONFIG_H */
Hi Huan:
Please rebase this patch on top of most recent master branch as it fail to apply due to changes of arch/riscv/dts/Makefile
suggest style: Link: https://.. [1]
- Copyright (c) 2024, Kongyang Liu seashell11234455@gmail.com
I'd suggest to keep the comment.. #define CFG_SYS_NS16550_IER 0x40 /* UART Unit Enable */
-- 2.39.5
Hi, First of all, Sorry for the previous private message.
On Tue, Dec 10, 2024 at 10:15:25AM +0800, Yixun Lan wrote:
Hi Huan:
got it.
ok, should i send next version of patch btw?
-- 2.39.5
-- Yixun Lan (dlan) Gentoo Linux Developer GPG Key ID AABEFD55
Add document for Banana Pi F3 board which based on SpacemiT's K1 SoC.
Signed-off-by: Kongyang Liu seashell11234455@gmail.com Signed-off-by: Huan Zhou pericycle.cc@gmail.com --- doc/board/index.rst | 1 + doc/board/spacemit/bananapi-f3.rst | 86 ++++++++++++++++++++++++++++++++++++++ doc/board/spacemit/index.rst | 9 ++++ 3 files changed, 96 insertions(+)
diff --git a/doc/board/index.rst b/doc/board/index.rst index 417c128c7af6ad2267ef1bc743c7f10ae70b6de7..367da2d62316d4cab25ecc53f852ef742eba13dd 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -51,6 +51,7 @@ Board-specific doc sipeed/index socionext/index sophgo/index + spacemit/index st/index starfive/index ste/index diff --git a/doc/board/spacemit/bananapi-f3.rst b/doc/board/spacemit/bananapi-f3.rst new file mode 100644 index 0000000000000000000000000000000000000000..98a1b1d91daa897508762267e8363e7d98a0c5d0 --- /dev/null +++ b/doc/board/spacemit/bananapi-f3.rst @@ -0,0 +1,86 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +Banana Pi BPI-F3 +============ + +Building +~~~~~~~~ +1. Install the spacemit riscv cross compile toolchain_, or skip it if riscv toolchain is installed. + +.. _toolchain: https://archive.spacemit.com/toolchain/ + +2. Setup cross compilation environment variable: + +.. code-block:: console + + export CROSS_COMPILE=<riscv64 toolchain prefix, e.g /opt/spacemit/bin/riscv64-unknown-linux-gnu-> + +3. Before building U-Boot, OpenSBI should be built first. OpenSBI can be +built for SpacemiT K1 SoC as below: + +.. code-block:: console + + git clone https://github.com/cyyself/opensbi -b k1-opensbi + cd opensbi + make PLATFORM=generic + +4. Then build U-Boot as following: + +.. code-block:: console + + cd <U-Boot-dir> + make bananapi-f3_defconfig + make OPENSBI=<OpenSBI-dir>/build/platform/generic/firmware/fw_dynamic.bin + +This will generate u-boot.itb + +Booting +~~~~~~~ +Actually, we can replace the uboot part from bianbu linux which is the bsp_ to validate this patch, +use `balena etcher` to burn the bianbu-minimal.img to the sd card, +and replace the /dev/sdx4 where places the uboot_ with the `u-boot.itb` generated from this patch. + +.. _bsp: https://archive.spacemit.com/image/k1/version/bianbu/v2.0/ +.. _uboot: https://bianbu-linux.spacemit.com/en/device/boot#21-firmware-layout + +Sample boot log from Banana Pi BPI-F3 board +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +.. code-block:: none + + try sd... + bm:3 + j... + + U-Boot SPL 2022.10spacemit-dirty (Oct 21 2024 - 09:01:13 +0000) + [ 0.279] DDR type LPDDR4X + [ 0.292] lpddr4_silicon_init consume 13ms + [ 0.293] Change DDR data rate to 2400MT/s + [ 0.430] ## Checking hash(es) for config conf-1 ... OK + [ 0.432] ## Checking hash(es) for Image opensbi ... OK + [ 0.437] ## Checking hash(es) for Image uboot ... OK + [ 0.443] ## Checking hash(es) for Image fdt-1 ... OK + [ 0.488] ## Checking hash(es) for config config_1 ... OK + [ 0.490] ## Checking hash(es) for Image opensbi ... crc32+ OK + + + U-Boot 2024.10-rc4-00462-g5b138cfcc587-dirty (Nov 28 2024 - 14:56:49 +0800) + + DRAM: 4 GiB + Core: 19 devices, 8 uclasses, devicetree: separate + Loading Environment from nowhere... OK + In: serial@d4017000 + Out: serial@d4017000 + Err: serial@d4017000 + Net: No ethernet found. + => cpu list + 0: cpu@0 spacemit,x60 + 1: cpu@1 spacemit,x60 + 2: cpu@2 spacemit,x60 + 3: cpu@3 spacemit,x60 + 4: cpu@4 spacemit,x60 + 5: cpu@5 spacemit,x60 + 6: cpu@6 spacemit,x60 + 7: cpu@7 spacemit,x60 + => test + => + diff --git a/doc/board/spacemit/index.rst b/doc/board/spacemit/index.rst new file mode 100644 index 0000000000000000000000000000000000000000..e7d3d94e4599fbeb8da16c8a837e777a0be06227 --- /dev/null +++ b/doc/board/spacemit/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +SpacemiT +======== +.. toctree:: + :maxdepth: 1 + + bananapi-f3 +
Hi Huan:
- spacemit/index st/index starfive/index ste/index
- export CROSS_COMPILE=<riscv64 toolchain prefix, e.g /opt/spacemit/bin/riscv64-unknown-linux-gnu->
- git clone https://github.com/cyyself/opensbi -b k1-opensbi
- cd opensbi
- make PLATFORM=generic
- cd <U-Boot-dir>
- make bananapi-f3_defconfig
- make OPENSBI=<OpenSBI-dir>/build/platform/generic/firmware/fw_dynamic.bin
+Booting
replace it with "Burning" or "Flashing"? which document how we burn the uboot image into storage media
the procedure above is too complicated and obscure.. I would suggest to use fastboot, here is what I've tested on milkv jupitor board which burn the fw to spi nor flash, it can be flashed to emmc/sd card, and should be smiliar on BPI F3 board.
collect FSBL.bin, u-boot.itb, partition_2M.json, bootinfo_spinor.bin u-boot-env-default.bin, fw_dynamic.itb from vendor sdk
fastboot stage FSBL.bin fastboot continue fastboot stage u-boot.itb-vendor # the itb from vendor uboot fastboot continue
fastboot flash mtd partition_2M.json fastboot flash bootinfo bootinfo_spinor.bin fastboot flash fsbl FSBL.bin fastboot flash env u-boot-env-default.bin fastboot flash opensbi fw_dynamic.itb
fastboot flash uboot u-boot.itb-mainline # the itb from mainline uboot
move "Booting:" here
- try sd...
- bm:3
- j...
- U-Boot SPL 2022.10spacemit-dirty (Oct 21 2024 - 09:01:13 +0000)
- [ 0.279] DDR type LPDDR4X
- [ 0.292] lpddr4_silicon_init consume 13ms
- [ 0.293] Change DDR data rate to 2400MT/s
- [ 0.430] ## Checking hash(es) for config conf-1 ... OK
- [ 0.432] ## Checking hash(es) for Image opensbi ... OK
- [ 0.437] ## Checking hash(es) for Image uboot ... OK
- [ 0.443] ## Checking hash(es) for Image fdt-1 ... OK
- [ 0.488] ## Checking hash(es) for config config_1 ... OK
- [ 0.490] ## Checking hash(es) for Image opensbi ... crc32+ OK
- U-Boot 2024.10-rc4-00462-g5b138cfcc587-dirty (Nov 28 2024 - 14:56:49 +0800)
- DRAM: 4 GiB
- Core: 19 devices, 8 uclasses, devicetree: separate
- Loading Environment from nowhere... OK
- In: serial@d4017000
- Out: serial@d4017000
- Err: serial@d4017000
- Net: No ethernet found.
- => cpu list
- 0: cpu@0 spacemit,x60
- 1: cpu@1 spacemit,x60
- 2: cpu@2 spacemit,x60
- 3: cpu@3 spacemit,x60
- 4: cpu@4 spacemit,x60
- 5: cpu@5 spacemit,x60
- 6: cpu@6 spacemit,x60
- 7: cpu@7 spacemit,x60
- => test
- :maxdepth: 1
- bananapi-f3
-- 2.39.5
Hi On Tue, Dec 10, 2024 at 10:30:28AM +0800, Yixun Lan wrote:
Hi Huan:
- cd opensbi
- cd <U-Boot-dir>
+Booting
sounds better, fixed.
the whole procedure is just install bianbu/or other bsp and replace the 4th partition of sd card, dd or fastboot just different tools for burning disk, the operation is more clear after known the partition of the disk IMO, or shall i add another section using fastboot?
the operation below can just use dd or balena etcher burn the img to the sdcard. the 'fastboot' procedure seems more complicate IMO.
vvv
gotit.
- try sd...
- bm:3
- j...
- DRAM: 4 GiB
- => cpu list
- => test
- :maxdepth: 1
- bananapi-f3
-- 2.39.5
Hi Huan:
I have a few comments.. and will put some in separated patch
First, it's always your responsibility to collect the tags when you sending out new version, as I see you missed Leo's review tag in v2 and Marcel's tested tag in v4
P.S: You can rely on maintainer to collect tags of the last version if no real changes but only tags added..
Changes in v5:
Changes in v4:
Changes in v3:
- Add base commit
- Update maintainer
Changes in v2:
On Tue, Dec 10, 2024 at 10:04:41AM +0800, Yixun Lan wrote:
Hi Huan:
gotit, thx.
thx for reminding.
Changes in v5:
Changes in v4:
Changes in v3:
- Add base commit
- Update maintainer
Changes in v2:
Huan Zhou
Yixun Lan
