[U-Boot] Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
thanks, Jagan.
The following changes since commit 454cf76184c65426b68033a23da086e73663f2fc:
Prepare v2018.11-rc3 (2018-10-29 16:04:26 -0400)
git://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 7d121a8ea4e0dbf0d7e105b57c3dbd7d8bd2e729:
sunxi: use 6MHz PLL_VIDEO step for DE2 for higher resolution LCD (2018-11-13 22:17:06 +0530)
---------------------------------------------------------------- Andre Przywara (4): sunxi: A64: Update .dts/.dtsi files sunxi: A64: Re-add syscon to DT node sunxi: H3/H5: Update .dts files sunxi: A64: Add Pine64-LTS board
Icenowy Zheng (1): sunxi: use 6MHz PLL_VIDEO step for DE2 for higher resolution LCD
Jagan Teki (2): arm64: allwinner: h6: Add common orangepi nodes into dtsi board: allwinner: sun50i-h6: Add Orangepi Lite2 support
Jun Nie (1): sunxi: add support for Banana Pi M2 Zero board
Marek Vasut (1): sunxi: Imply fitImage support
Vasily Khoruzhick (4): mmc: sunxi: add support for automatic delay calibration dm: video: bridge: don't fail to activate bridge if reset or sleep GPIO is missing sun50i: A64: add support for R_I2C controller sunxi: DT: add support for Pinebook
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 3 + arch/arm/dts/sun50i-a64-amarula-relic.dts | 168 ++++++++++++- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 34 ++- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 89 ++++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 103 +++++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 179 +++++++++++++- arch/arm/dts/sun50i-a64-pine64-lts.dts | 13 + arch/arm/dts/sun50i-a64-pine64.dts | 32 ++- arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi | 15 ++ arch/arm/dts/sun50i-a64-pinebook.dts | 294 ++++++++++++++++++++++ arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 32 ++- arch/arm/dts/sun50i-a64-sopine.dtsi | 15 ++ arch/arm/dts/sun50i-a64.dtsi | 312 ++++++++++++++++++++++-- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 12 + arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 2 - arch/arm/dts/sun50i-h6-orangepi-lite2.dts | 11 + arch/arm/dts/sun50i-h6-orangepi-one-plus.dts | 140 +---------- arch/arm/dts/sun50i-h6-orangepi.dtsi | 150 ++++++++++++ arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts | 121 +++++++++ arch/arm/dts/sun8i-h3.dtsi | 31 +++ arch/arm/dts/sunxi-h3-h5.dtsi | 2 - arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/include/asm/arch-sunxi/mmc.h | 6 +- arch/arm/mach-sunxi/Kconfig | 1 + arch/arm/mach-sunxi/clock_sun6i.c | 4 + board/sunxi/MAINTAINERS | 10 + board/sunxi/board.c | 6 + configs/bananapi_m2_zero_defconfig | 13 + configs/orangepi_lite2_defconfig | 12 + configs/pine64-lts_defconfig | 19 ++ configs/pinebook_defconfig | 22 ++ drivers/mmc/sunxi_mmc.c | 21 +- drivers/video/bridge/video-bridge-uclass.c | 16 +- drivers/video/sunxi/lcdc.c | 22 +- 35 files changed, 1710 insertions(+), 202 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pine64-lts.dts create mode 100644 arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-pinebook.dts create mode 100644 arch/arm/dts/sun50i-h6-orangepi-lite2.dts create mode 100644 arch/arm/dts/sun50i-h6-orangepi.dtsi create mode 100644 arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts create mode 100644 configs/bananapi_m2_zero_defconfig create mode 100644 configs/orangepi_lite2_defconfig create mode 100644 configs/pine64-lts_defconfig create mode 100644 configs/pinebook_defconfig
On Wed, Nov 14, 2018 at 12:49:45AM +0530, Jagan Teki wrote:
Hi Tom,
thanks, Jagan.
This seems to be somewhat the opposite of the SPI PR in that it's not just fixing up a few corner cases and so forth, so I assume you intend me to pull this after the release.
Hi Tom,
thanks, Jagan.
GPIO is missing
Correct.
Hi Tom,
thanks, Jagan.
Jagan Teki
