[PATCH V2 1/2] pico-imx7d: Disable USB_ETHER support for bl33 defconfig
For DM_ETH support , it's require to disable this config. When this config is enable, This generate a error with spl in linker script
Signed-off-by: Joris Offouga offougajoris@gmail.com --- configs/pico-imx7d_bl33_defconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index e54f3b12d4..a32b4d680f 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -64,9 +64,6 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_DM_VIDEO=y CONFIG_VIDEO_BPP8=y CONFIG_VIDEO_BPP16=y
Signed-off-by: Joris Offouga offougajoris@gmail.com --- Change v1 -> v2 Disable usb ethernet support with patch : pico-imx7d: Disable USB_ETHER support for bl33
board/technexion/pico-imx7d/pico-imx7d.c | 46 ------------------------ configs/pico-dwarf-imx7d_defconfig | 5 +++ configs/pico-hobbit-imx7d_defconfig | 5 +++ configs/pico-imx7d_bl33_defconfig | 5 +++ configs/pico-imx7d_defconfig | 5 +++ configs/pico-nymph-imx7d_defconfig | 5 +++ configs/pico-pi-imx7d_defconfig | 5 +++ include/configs/pico-imx7d.h | 11 ------ 8 files changed, 30 insertions(+), 57 deletions(-)
diff --git a/board/technexion/pico-imx7d/pico-imx7d.c b/board/technexion/pico-imx7d/pico-imx7d.c index bcfc7d361e..b7ca2e1315 100644 --- a/board/technexion/pico-imx7d/pico-imx7d.c +++ b/board/technexion/pico-imx7d/pico-imx7d.c @@ -16,7 +16,6 @@ #include <common.h> #include <i2c.h> #include <miiphy.h> -#include <netdev.h> #include <power/pmic.h> #include <power/pfuze3000_pmic.h> #include "../../freescale/common/pfuze.h" @@ -26,11 +25,6 @@ DECLARE_GLOBAL_DATA_PTR; #define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) -#define ENET_PAD_CTRL_MII (PAD_CTL_DSE_3P3V_32OHM) - -#define ENET_RX_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) - #define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM)
@@ -123,44 +117,6 @@ static iomux_v3_cfg_t const uart5_pads[] = { };
#ifdef CONFIG_FEC_MXC -static iomux_v3_cfg_t const fec1_pads[] = { - MX7D_PAD_SD2_CD_B__ENET1_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), - MX7D_PAD_SD2_WP__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), - MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), - MX7D_PAD_SD3_STROBE__GPIO6_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX7D_PAD_SD3_RESET_B__GPIO6_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -#define FEC1_RST_GPIO IMX_GPIO_NR(6, 11) - -static void setup_iomux_fec(void) -{ - imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); - gpio_request(FEC1_RST_GPIO, "phy_rst"); - gpio_direction_output(FEC1_RST_GPIO, 0); - udelay(500); - gpio_set_value(FEC1_RST_GPIO, 1); -} - -int board_eth_init(bd_t *bis) -{ - setup_iomux_fec(); - - return fecmxc_initialize_multi(bis, 0, - CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); -} - static int setup_fec(void) { struct iomuxc_gpr_base_regs *const iomuxc_gpr_regs @@ -235,9 +191,7 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
#ifdef CONFIG_DM_VIDEO - setup_lcd(); - #endif #ifdef CONFIG_FEC_MXC setup_fec(); diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 5416b4581b..f328b41b8f 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -59,6 +59,11 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 57b64c632f..ea127069e9 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -59,6 +59,11 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index a32b4d680f..db9daf9d69 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -50,6 +50,11 @@ CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index aa9c935bdd..928adfa349 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -59,6 +59,11 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 5416b4581b..f328b41b8f 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -59,6 +59,11 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 61e83520d5..872834b3a8 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -59,6 +59,11 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 1d0df9dd44..4dc206566e 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -29,17 +29,6 @@
#define CONFIG_MXC_UART_BASE UART5_IPS_BASE_ADDR
-/* Network */ -#define CONFIG_FEC_MXC -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 1 - -#define CONFIG_PHY_ATHEROS - -/* ENET1 */ -#define IMX_FEC_BASE ENET_IPS_BASE_ADDR - /* MMC Config */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
- udelay(500);
- setup_lcd();
Reviewed-by: Stefano Babic sbabic@denx.de
Bext regards, Stefano Babic
Signed-off-by: Joris Offouga offougajoris@gmail.com Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
For DM_ETH support , it's require to disable this config. When this config is enable, This generate a error with spl in linker script Signed-off-by: Joris Offouga offougajoris@gmail.com Reviewed-by: Stefano Babic sbabic@denx.de
Joris Offouga
sbabic@denx.de
Stefano Babic
