[U-Boot-Users] [PATCH] revised word alignment fixes for word aligned NS16550 UART
The patch is created against current CVS 2005 march 1st and fixes problems
for boards that only have word access to the NS16550 UART.
OBSOLETES: From: Jean-Paul Saman Date: 23-02-2005 Subject: [PATCH] word alignment fixes for word aligned NS16550 UART peripheral
CHANGELOG: * Patch by Jean-Paul Saman, 23 Feb 2005
- include/ns16550.h Fixes alignement bug with UART that only supports word aligned access: removed "__attribute__ ((packed));" for "(CFG_NS16550_REG_SIZE == 4)" GCC generates bytes access when it encounters the packed attribute regardless if the struct is already word aligned for a platform. Peripherals that can only handle word aligned access won't work properly when accessed with byte access. The struct NS16550 is already word aligned for REG_SIZE = 4, so there is no need to packed the struct in that case.
Kind greetings,
Jean-Paul Saman
Philips Semiconductors CTO/RTG Philips HighTech Campus, building WDB 3.29 Professor van den Holstlaan 4 5655 AA Eindhoven tel: +31 (0)40 27 45131
In message OFF26F609C.4348B979-ONC1256FB7.004C4EC9-C1256FB7.0058F5C8@philips.com you wrote:
CHANGELOG:
- Patch by Jean-Paul Saman, 23 Feb 2005
- include/ns16550.h
Applied. Thanks.
jean-paul.saman@philips.com
