[U-Boot] [RFC/PATCH] allow boards to customize compiler options on a per-file/dir basis
With our Blackfin boards, we like to build the compression routines with -O2 as our tests show a pretty good size/speed tradeoff. For the rest of U-Boot though, we want to stick with the default -Os as that is mostly control code. So in our case, we would add a line like so to the board specific config.mk file: CFLAGS_dir_lib_generic += -O2
Now all files under lib_generic/ will have -O2 appended to their build.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- config.mk | 19 +++++++++++++------ 1 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/config.mk b/config.mk index b1254e9..5d442b5 100644 --- a/config.mk +++ b/config.mk @@ -206,23 +206,30 @@ export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS
+# Allow boards to use custom optimize flags on a per dir/file basis +BCURDIR := $(notdir $(CURDIR)) +cmd_compile.s.S = $(CPP) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_dir_$(BCURDIR)) -o $@ $< +cmd_compile.o.S = $(CC) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_dir_$(BCURDIR)) -o $@ $< -c +cmd_compile.o.c = $(CC) $(CFLAGS) $(CFLAGS_$(@F)) $(CFLAGS_dir_$(BCURDIR)) -o $@ $< -c + ifndef REMOTE_BUILD
%.s: %.S - $(CPP) $(AFLAGS) -o $@ $< + $(cmd_compile.s.S) %.o: %.S - $(CC) $(AFLAGS) -c -o $@ $< + $(cmd_compile.o.S) %.o: %.c - $(CC) $(CFLAGS) -c -o $@ $< + $(cmd_compile.o.c)
else
$(obj)%.s: %.S - $(CPP) $(AFLAGS) -o $@ $< + $(cmd_compile.s.S) $(obj)%.o: %.S - $(CC) $(AFLAGS) -c -o $@ $< + $(cmd_compile.o.S) $(obj)%.o: %.c - $(CC) $(CFLAGS) -c -o $@ $< + $(cmd_compile.o.c) + endif
With our Blackfin boards, we like to build the compression routines with -O2 as our tests show a pretty good size/speed tradeoff. For the rest of U-Boot though, we want to stick with the default -Os as that is mostly control code. So in our case, we would add a line like so to the board specific config.mk file: CFLAGS_lib_generic += -O2
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - dont require dir_ since the naming is already unique (all objects have a ".o" suffix while dirs do not)
diff --git a/config.mk b/config.mk index b1254e9..c3a787a 100644 --- a/config.mk +++ b/config.mk @@ -206,23 +206,30 @@ export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS
+# Allow boards to use custom optimize flags on a per dir/file basis +BCURDIR := $(notdir $(CURDIR)) +cmd_compile.s.S = $(CPP) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_$(BCURDIR)) -o $@ $< +cmd_compile.o.S = $(CC) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_$(BCURDIR)) -o $@ $< -c +cmd_compile.o.c = $(CC) $(CFLAGS) $(CFLAGS_$(@F)) $(CFLAGS_$(BCURDIR)) -o $@ $< -c + ifndef REMOTE_BUILD
else
Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Best Regards, J.
Signed-off-by: Mike Frysinger vapier@gentoo.org Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- v3 - updated to apply to next after Jean's changes
config.mk | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/config.mk b/config.mk index 8d47a8e..f5b9c28 100644 --- a/config.mk +++ b/config.mk @@ -206,11 +206,13 @@ export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS
+# Allow boards to use custom optimize flags on a per dir/file basis +BCURDIR := $(notdir $(CURDIR)) $(obj)%.s: %.S - $(CPP) $(AFLAGS) -o $@ $< + $(CPP) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_$(BCURDIR)) -o $@ $< $(obj)%.o: %.S - $(CC) $(AFLAGS) -c -o $@ $< + $(CC) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_$(BCURDIR)) -o $@ $< -c $(obj)%.o: %.c - $(CC) $(CFLAGS) -c -o $@ $< + $(CC) $(CFLAGS) $(CFLAGS_$(@F)) $(CFLAGS_$(BCURDIR)) -o $@ $< -c
v3
- $(CPP) $(AFLAGS) $(AFLAGS_$(@F)) $(AFLAGS_$(BCURDIR)) -o $@ $<
we can drop this one as there is no obj %.s
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
But since it's already present it also makes sense to keep it, so we don;t have to figure out what it needs to be in case we have to add an assembler file later.
the .s is supposed to be gcc temp file so It make sense to avoid it as assembly file suffix is .S for source
Best Regards, J.
not really. the .s file means "do not run preprocessor before sending to assembler". that is all.
usually, yes, but no need to force people to conform if they want to write pure assembly with no CPP stuff. -mike
That's not correct. ".s" has always (from the dawn of time) been normal assembler code in Unix systems. Normally you will use "as" directly on such files. ".S" is a suffix introduced much, much later and indicates files that need to be run through the C preprocessor.
$(obj)%.s: %.S
looks to me like there is: $ make lib_blackfin/memcmp.s bfin-uclinux-gcc -E -D__ASSEMBLY__ -g -Os -ffixed-P5 -fomit-frame-pointer -mno-fdpic -ffunction-sections -fdata-sections -mcpu=bf561-0.3 -D__KERNEL__ - I/usr/local/src/u-boot/blackfin/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/src/blackfin/toolchains/20090608/bfin- uclinux/lib/gcc/bfin-uclinux/4.3.3/include -pipe -DCONFIG_BLACKFIN -o lib_blackfin/memcmp.s lib_blackfin/memcmp.S
if that target is removed, this no longer works -mike
$(obj)%.s: %.S
sorry for the miss I've done a find . -name Makefile | xargs grep ".s" and miss it
Best Regards, J.
Dear Mike Frysinger,
v3
Applied, thanks.
Mike Frysinger
