[U-Boot] Information regarding load address, execute address and image load address
I need one clarification regarding load address, entry point inside the Kernel image & the address to where we load the image.
Assume, the image header is as below.
Image Name: Linux-2.6.38-10700-g846a497 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2064396 Bytes = 2 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK
And I load the image using loadb to address 0x80008000.
Will this work?. Because here Image->load_address == Load_address for u-boot. Now u-boot considers this as XIP Image and will not move os data which actually will be at 0x80008040 to 0x80008000
Please correct me if I am wrong
I have attached the console output for reference.
Thanks & regards Gururaja
CON_SOLE#iminfo
## Checking Image at 80008000 ... Legacy image found Image Name: Linux-2.6.38-10700-g846a497 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2064396 Bytes = 2 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK
CON_SOLE #bootm 0x80008000 * kernel: cmdline image address = 0x80008000 Boot reached stage 1 ## Booting kernel from Legacy Image at 80008000 ... Boot reached stage 2 Boot reached stage 3 Image Name: Linux-2.6.38-10700-g846a497 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2064396 Bytes = 2 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Boot reached stage 4 Boot reached stage 5 Boot reached stage 6 kernel data at 0x80008040, len = 0x001f800c (2064396) Boot reached stage 14 ## No init Ramdisk ramdisk start = 0x00000000, ramdisk end = 0x00000000 XIP Kernel Image ... OK OK kernel loaded at 0x80008000, end = 0x8020000c Boot reached stage 7 images.os.start = 0x80008000, images.os.end = 0x8020004c images.os.load = 0x80008000, load_end = 0x8020000c Boot reached stage 8 Boot reached stage 15 ## Transferring control to Linux (at address 80008000) ...
Starting kernel ...
Dear "Hebbar, Gururaja",
In message C82BA3053CFD354AACBD25EFBD2A4EC603EFCC7991@dbde02.ent.ti.com you wrote:
This is supposed to break.
Hebbar, Gururaja
