[U-Boot] [PATCH v3] spi: Zap soft_spi_legacy driver-related code
Dropped - soft_spi_legacy driver - CONFIG_SOFT_SPI
Dropped due to: - no active updates - no dm conversion - multiple pings for asking dm-conversion - driver-model migration expiry
Cc: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - rebase on master
drivers/spi/Kconfig | 12 +-- drivers/spi/Makefile | 1 - drivers/spi/soft_spi_legacy.c | 168 ---------------------------------- include/configs/MPC8349EMDS.h | 3 - include/configs/zipitz2.h | 1 - 5 files changed, 6 insertions(+), 179 deletions(-) delete mode 100644 drivers/spi/soft_spi_legacy.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 4095bf5950..8a86878fee 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -213,6 +213,12 @@ config SANDBOX_SPI }; };
+config SOFT_SPI + bool "Soft SPI driver" + help + Enable Soft SPI driver. This driver is to use GPIO simulate + the SPI protocol. + config SPI_SUNXI bool "Allwinner SoC SPI controllers" help @@ -301,12 +307,6 @@ config ZYNQMP_GQSPI
endif # if DM_SPI
-config SOFT_SPI - bool "Soft SPI driver" - help - Enable Soft SPI driver. This driver is to use GPIO simulate - the SPI protocol. - config MSCC_BB_SPI bool "MSCC bitbang SPI driver" depends on SOC_VCOREIII diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index fd147447fe..be4b4c140d 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -13,7 +13,6 @@ obj-$(CONFIG_TI_QSPI) += ti_qspi.o else obj-y += spi.o obj-$(CONFIG_SPI_MEM) += spi-mem-nodm.o -obj-$(CONFIG_SOFT_SPI) += soft_spi_legacy.o endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o diff --git a/drivers/spi/soft_spi_legacy.c b/drivers/spi/soft_spi_legacy.c deleted file mode 100644 index cc5ab5f991..0000000000 --- a/drivers/spi/soft_spi_legacy.c +++ /dev/null @@ -1,168 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2002 - * Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com. - * - * Influenced by code from: - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - */ - -#include <common.h> -#include <spi.h> - -#include <malloc.h> - -/*----------------------------------------------------------------------- - * Definitions - */ - -#ifdef DEBUG_SPI -#define PRINTD(fmt,args...) printf (fmt ,##args) -#else -#define PRINTD(fmt,args...) -#endif - -struct soft_spi_slave { - struct spi_slave slave; - unsigned int mode; -}; - -static inline struct soft_spi_slave *to_soft_spi(struct spi_slave *slave) -{ - return container_of(slave, struct soft_spi_slave, slave); -} - -/*=====================================================================*/ -/* Public Functions */ -/*=====================================================================*/ - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct soft_spi_slave *ss; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ss = spi_alloc_slave(struct soft_spi_slave, bus, cs); - if (!ss) - return NULL; - - ss->mode = mode; - - /* TODO: Use max_hz to limit the SCK rate */ - - return &ss->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct soft_spi_slave *ss = to_soft_spi(slave); - - free(ss); -} - -int spi_claim_bus(struct spi_slave *slave) -{ -#ifdef CONFIG_SYS_IMMR - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; -#endif - struct soft_spi_slave *ss = to_soft_spi(slave); - - /* - * Make sure the SPI clock is in idle state as defined for - * this slave. - */ - if (ss->mode & SPI_CPOL) - SPI_SCL(1); - else - SPI_SCL(0); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - /* Nothing to do */ -} - -/*----------------------------------------------------------------------- - * SPI transfer - * - * This writes "bitlen" bits out the SPI MOSI port and simultaneously clocks - * "bitlen" bits in the SPI MISO port. That's just the way SPI works. - * - * The source of the outgoing bits is the "dout" parameter and the - * destination of the input bits is the "din" parameter. Note that "dout" - * and "din" can point to the same memory location, in which case the - * input data overwrites the output data (since both are buffered by - * temporary variables, this is OK). - */ -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ -#ifdef CONFIG_SYS_IMMR - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; -#endif - struct soft_spi_slave *ss = to_soft_spi(slave); - uchar tmpdin = 0; - uchar tmpdout = 0; - const u8 *txd = dout; - u8 *rxd = din; - int cpol = ss->mode & SPI_CPOL; - int cpha = ss->mode & SPI_CPHA; - unsigned int j; - - PRINTD("spi_xfer: slave %u:%u dout %08X din %08X bitlen %u\n", - slave->bus, slave->cs, *(uint *)txd, *(uint *)rxd, bitlen); - - if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); - - for(j = 0; j < bitlen; j++) { - /* - * Check if it is time to work on a new byte. - */ - if ((j % 8) == 0) { - if (txd) - tmpdout = *txd++; - else - tmpdout = 0; - if(j != 0) { - if (rxd) - *rxd++ = tmpdin; - } - tmpdin = 0; - } - - if (!cpha) - SPI_SCL(!cpol); - SPI_SDA(tmpdout & 0x80); - SPI_DELAY; - if (cpha) - SPI_SCL(!cpol); - else - SPI_SCL(cpol); - tmpdin <<= 1; - tmpdin |= SPI_READ; - tmpdout <<= 1; - SPI_DELAY; - if (cpha) - SPI_SCL(cpol); - } - /* - * If the number of bits isn't a multiple of 8, shift the last - * bits over to left-justify them. Then store the last byte - * read in. - */ - if (rxd) { - if ((bitlen % 8) != 0) - tmpdin <<= 8 - (bitlen % 8); - *rxd++ = tmpdin; - } - - if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); - - return(0); -} diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index bda477cc16..a54f4ca251 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -320,9 +320,6 @@ #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 #define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} }
-/* SPI */ -#undef CONFIG_SOFT_SPI /* SPI bit-banged */ - /* GPIOs. Used as SPI chip selects */ #define CONFIG_SYS_GPIO1_PRELIM #define CONFIG_SYS_GPIO1_DIR 0xC0000000 /* SPI CS on 0, LED on 1 */ diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 24fea68a11..baf3e6e130 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -59,7 +59,6 @@ * SPI and LCD */ #ifdef CONFIG_CMD_SPI -#define CONFIG_SOFT_SPI #define CONFIG_LCD_ROTATION #define CONFIG_PXA_LCD #define CONFIG_LMS283GF05
Jagan Teki
