[PATCH 1/1] lib: hang() must be __efi_runtime
On RISC-V we use hang() to stop all harts except the boot hart. The loop in which these harts run must not be overwritten by the UEFI payload after BootExit().
Extract the endless loop into a function hang_no_msg() which we define as __efi_runtime. Use it when preparing to call OpenSBI.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- common/spl/spl_opensbi.c | 2 +- include/hang.h | 10 ++++++++++ lib/hang.c | 10 ++++++++-- 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 14f335f75f0..dc129c194e6 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -93,7 +93,7 @@ void spl_invoke_opensbi(struct spl_image_info *spl_image) (ulong)spl_image->fdt_addr, (ulong)&opensbi_info, 1); if (ret) - hang(); + hang_no_msg(); #endif opensbi_entry(gd->arch.boot_hart, (ulong)spl_image->fdt_addr, (ulong)&opensbi_info); diff --git a/include/hang.h b/include/hang.h index 27cda493592..7a92f809164 100644 --- a/include/hang.h +++ b/include/hang.h @@ -17,6 +17,16 @@ * This function does not return. */ void hang(void) __attribute__ ((noreturn)); + +/** + * hang_no_msg() - stop executions + * + * This function provides an infinite loop. It is located in the __efi_runtime + * section to allow usage for letting secondary cores/harts wait until the + * UEFI payload takes care of them. + */ +void hang_no_msg(void) __attribute__ ((noreturn)); + #endif
#endif diff --git a/lib/hang.c b/lib/hang.c index 578ac78d453..d131ce7cec9 100644 --- a/lib/hang.c +++ b/lib/hang.c @@ -9,9 +9,16 @@
#include <common.h> #include <bootstage.h> +#include <efi_loader.h> #include <hang.h> #include <os.h>
+__efi_runtime void hang_no_msg(void) +{ + for(;;) + ; +} + /** * hang - stop processing by staying in an endless loop * @@ -30,6 +37,5 @@ void hang(void) bootstage_error(BOOTSTAGE_ID_NEED_RESET); if (IS_ENABLED(CONFIG_SANDBOX)) os_exit(1); - for (;;) - ; + hang_no_msg(); } -- 2.20.1
