[PATCH v2 0/2] gpio: add possibility to search for gpio label name
search for gpio label if gpio name from bankname is not found.
This makes sense on boards with different hardware verions. You can now search for the gpio label name, and can give the gpio a unique name. The real gpio pin number is not needed in board code anymore.
while at it add basic gpio hog test functions in seperate patch.
Travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/644219338
Changes in v2: - add basic gpio hog test functions - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
Heiko Schocher (2): sandbox, test: add test for GPIO_HOG function gpio: search for gpio label if gpio is not found through bank name
arch/sandbox/dts/test.dts | 24 +++++++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + drivers/gpio/gpio-uclass.c | 38 ++++++++++++++++++++++++++++++ test/dm/gpio.c | 30 +++++++++++++++++++++++ 7 files changed, 96 insertions(+)
currently gpio hog function is not tested with "ut dm gpio" so add some basic tests for gpio hog functionality.
For this enable GPIO_HOG in sandbox_defconfig, add in DTS some gpio hog entries, and add testcase in "ut dm gpio" command.
Signed-off-by: Heiko Schocher hs@denx.de
arch/sandbox/dts/test.dts | 24 ++++++++++++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + test/dm/gpio.c | 23 +++++++++++++++++++++++ 6 files changed, 51 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index e529c54d8d..cff05dcf7c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1,5 +1,7 @@ /dts-v1/;
+#include <dt-bindings/gpio/gpio.h> + / { model = "sandbox"; compatible = "sandbox"; @@ -284,6 +286,28 @@ #gpio-cells = <1>; gpio-bank-name = "a"; sandbox,gpio-count = <20>; + + hog_input_active_low { + gpio-hog; + input; + gpios = <0 GPIO_ACTIVE_LOW>; + }; + hog_input_active_high { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + }; + hog_output_low { + gpio-hog; + output-low; + gpios = <2 GPIO_ACTIVE_HIGH>; + }; + hog_output_high { + gpio-hog; + output-high; + gpios = <3 GPIO_ACTIVE_HIGH>; + }; + };
gpio_b: extra-gpios { diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 7b80033c3b..f614b23666 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -92,6 +92,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fc018bdd2c..afce8050b4 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -108,6 +108,7 @@ CONFIG_BOARD_SANDBOX=y CONFIG_DMA=y CONFIG_DMA_CHANNELS=y CONFIG_SANDBOX_DMA=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_DM_HWSPINLOCK=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 2c90639ecb..0518b56fd9 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -78,6 +78,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index b78115af61..e70f2b4aa8 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -98,6 +98,7 @@ CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y CONFIG_SPL_FIRMWARE=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/test/dm/gpio.c b/test/dm/gpio.c index bb4b20cea9..9003ea82c7 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -18,6 +18,7 @@ static int dm_test_gpio(struct unit_test_state *uts) unsigned int offset, gpio; struct dm_gpio_ops *ops; struct udevice *dev; + struct gpio_desc *desc; const char *name; int offset_count; char buf[80]; @@ -102,6 +103,28 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_asserteq_str("a", name); ut_asserteq(20, offset_count);
+ /* add gpio hog tests */ + ut_assertok(gpio_hog_lookup_name("hog_input_active_low", &desc)); + ut_asserteq(GPIOD_IS_IN | GPIOD_ACTIVE_LOW, desc->flags); + ut_asserteq(0, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_input_active_high", &desc)); + ut_asserteq(GPIOD_IS_IN, desc->flags); + ut_asserteq(1, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_low", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(2, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 1)); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_high", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(3, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 0)); + ut_asserteq(0, dm_gpio_get_value(desc)); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Changes in v2:
dm_gpio_lookup_name() searches for a gpio through the bank name. But we have also gpio labels, and it makes sense to search for a gpio also in the labels we have defined, if no gpio is found through the bank name definition.
This is useful for example if you have a wp pin on different gpios on different board versions.
If dm_gpio_lookup_name() searches also for the gpio labels, you can give the gpio an unique label name and search for this label, and do not need to differ between board revisions.
Signed-off-by: Heiko Schocher hs@denx.de ---
Example on the aristainetos board:
=> gpio clear wp_spi_nor.gpio-hog gpio: pin wp_spi_nor.gpio-hog (gpio 47) value is 0 =>
before this patch, you need to know where your pin is:
=> gpio clear GPIO2_15 gpio: pin GPIO2_15 (gpio 47) value is 0 =>
travis build:
Changes in v2: - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
drivers/gpio/gpio-uclass.c | 38 ++++++++++++++++++++++++++++++++++++++ test/dm/gpio.c | 7 +++++++ 2 files changed, 45 insertions(+)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 90fbed455b..fb87ef9810 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -52,6 +52,37 @@ static int gpio_to_device(unsigned int gpio, struct gpio_desc *desc) return ret ? ret : -ENOENT; }
+/** + * dm_gpio_lookup_label() - look for name in gpio device + * + * search in uc_priv, if there is a gpio with labelname same + * as name. + * + * @name: name which is searched + * @uc_priv: gpio_dev_priv pointer. + * @offset: gpio offset within the device + * @return: 0 if found, -ENOENT if not. + */ +static int +dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, + ulong *offset) +{ + int len; + int i; + + *offset = -1; + len = strlen(name); + for (i = 0; i < uc_priv->gpio_count; i++) { + if (!uc_priv->name[i]) + continue; + if (!strncmp(name, uc_priv->name[i], len)) { + *offset = i; + return 0; + } + } + return -ENOENT; +} + int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) { struct gpio_dev_priv *uc_priv = NULL; @@ -80,6 +111,13 @@ int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) if (!strict_strtoul(name + len, 10, &offset)) break; } + + /* + * if we did not found a gpio through its bank + * name, we search for a valid gpio label. + */ + if (!dm_gpio_lookup_label(name, uc_priv, &offset)) + break; }
if (!dev) diff --git a/test/dm/gpio.c b/test/dm/gpio.c index 9003ea82c7..1f1bf680c5 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -125,6 +125,13 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_assertok(dm_gpio_set_value(desc, 0)); ut_asserteq(0, dm_gpio_get_value(desc));
+ /* Check if lookup for labels work */ + ut_assertok(gpio_lookup_name("hog_input_active_low", &dev, &offset, + &gpio)); + ut_asserteq_str(dev->name, "base-gpios"); + ut_asserteq(0, offset); + ut_asserteq(CONFIG_SANDBOX_GPIO_COUNT + 0, gpio); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
travis build:
Changes in v2:
I wonder if this should be a Kconfig so we can disable it by default in SPL?
- Simon
Hello Simon,
Am 03.02.2020 um 01:04 schrieb Simon Glass:
travis build:
Changes in v2:
Hmm.. maybe a good idea for boards which have code size restrictions. On the other hand, on such boards DM/DTS is most likely no option?
But it should be easy to add this into a Kconfig option, proposal
DM_GPIO_LOOKUP_LABEL ?
default: n for SPL and U-Boot ?
bye, Heiko
Hi Heiko,
On Sun, 2 Feb 2020 at 22:26, Heiko Schocher hs@denx.de wrote:
Hello Simon,
travis build:
Changes in v2:
The overhead of DM in SPL is pretty small, particularly if you use of-platdata.
I'd suggest y for U-Boot and n for SPL
Heiko Schocher
