[PATCH] ARM: imx: soc: Add reset for non-DM case
This is another in series of patches which remove ad-hoc reset_cpu() hacks from board files. This one is for iMX7, so implement default reset_cpu() there to prevent it from showing up in board files.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx7/soc.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 798fe74a3d..e7c71dfe8e 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -18,6 +18,7 @@ #include <env.h> #include <imx_thermal.h> #include <fsl_sec.h> +#include <fsl_wdog.h> #include <asm/setup.h> #include <linux/delay.h>
@@ -419,3 +420,15 @@ void reset_misc(void) #endif }
+#if !CONFIG_IS_ENABLED(SYSRESET) +void reset_cpu(ulong addr) +{ + struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR; + + /* Clear WDA to trigger WDOG_B immediately */ + writew(SET_WCR_WT(1) | WCR_WDT | WCR_WDE | WCR_SRS, &wdog->wcr); + + while (1) + ; +} +#endif
Hi Everybody,
CC: Igor / Oleksandr from Toradex
- struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR;
- /* Clear WDA to trigger WDOG_B immediately */
- writew(SET_WCR_WT(1) | WCR_WDT | WCR_WDE | WCR_SRS, &wdog->wcr);
- while (1)
+} +#endif
The patch is in the right direction, but rather this breaks Toradex's colibri i.MX7. However, reset should not coded in a board file and boards should enable DM PMIC and simply use the provide reset functionalities. Igor / Oleksandr, could you take a look at this ? I will let this patch for a while in stand-by.
Best regards, Stefano
Subject: Re: [PATCH] ARM: imx: soc: Add reset for non-DM case
Hi Everybody,
+*)WDOG1_BASE_ADDR;
&wdog->wcr);
- while (1)
+} +#endif
It might depends on internal warm reset or external pmic reset of the board choice. And better not enable both, because there might be contention.
Regards, Peng.
stand-by.
======= DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ============================================================== =======
Peng Fan
Stefano Babic
