[PATCH v1 0/4] USB-PD TCPM improvements
I have a couple of fixes/improvements for the TCPM code. Three are fixing actual problems I noticed on the Rock 5B, which prevented booting up the system. One of them simply adds an error print before potentially committing hara-kiri by triggering a hard reset, which helps people understanding why their boards reset themself in case there are more problems. I've recently added the same print to the kernel TCPM code.
Greetings,
-- Sebastian
Sebastian Reichel (4): usb: tcpm: improve handling of some power-supplies usb: tcpm: avoid resets for missing source capability messages usb: tcpm: print error on hard reset usb: tcpm: improve data role mismatch error recovery
drivers/usb/tcpm/tcpm-internal.h | 1 + drivers/usb/tcpm/tcpm.c | 95 ++++++++++++++++++++++++++++---- 2 files changed, 85 insertions(+), 11 deletions(-)
When the Rock 5B is booted with the current TCPM with its power supplied by a "Cambrionix PDSync-C4" port it reaches the power-supply ready state. Once that has happened the hub starts sending GetSinkCap messages, but U-Boot already stopped processing PD messages. After retrying a bunch of times the hub instead sends soft resets. Since U-Boot will also not react to them, the USB hub will follow-up with a hard reset and that cuts off the supply voltage.
Since the state machine is already prepared to handle GetSinkCap messages, try to avoid this by handling incoming messages for another 50ms after reaching the ready state.
Fixes: 1db4c0ac77e3 ("usb: tcpm: add core framework") Signed-off-by: Sebastian Reichel sebastian.reichel@collabora.com --- drivers/usb/tcpm/tcpm.c | 31 ++++++++++++++++++++++++++----- 1 file changed, 26 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/tcpm/tcpm.c b/drivers/usb/tcpm/tcpm.c index 0aee57cb2f4a..b754b4dcd0b5 100644 --- a/drivers/usb/tcpm/tcpm.c +++ b/drivers/usb/tcpm/tcpm.c @@ -2229,6 +2229,17 @@ static int tcpm_port_init(struct udevice *dev) return 0; }
+static inline void tcpm_poll_one_event(struct udevice *dev) +{ + const struct dm_tcpm_ops *drvops = dev_get_driver_ops(dev); + struct tcpm_port *port = dev_get_uclass_plat(dev); + + drvops->poll_event(dev); + port->poll_event_cnt++; + udelay(500); + tcpm_check_and_run_delayed_work(dev); +} + static void tcpm_poll_event(struct udevice *dev) { const struct dm_tcpm_ops *drvops = dev_get_driver_ops(dev); @@ -2242,15 +2253,25 @@ static void tcpm_poll_event(struct udevice *dev) (port->state == SNK_READY || port->state == SRC_READY)) break;
- drvops->poll_event(dev); - port->poll_event_cnt++; - udelay(500); - tcpm_check_and_run_delayed_work(dev); + tcpm_poll_one_event(dev); }
- if (port->state != SNK_READY && port->state != SRC_READY) + /* + * Some power-supplies send GetSinkCap shortly after they are ready. + * If they do not receive a response after a few retries they will issue + * a soft-reset followed by a hard reset, which kills the board power. + * Let's poll for 50ms after reaching the ready state to check if the + * power-supply wants something from us. + */ + if (port->state == SNK_READY) { + port->poll_event_cnt = 0; + + while (port->poll_event_cnt < 100) + tcpm_poll_one_event(dev); + } else { dev_warn(dev, "TCPM: exit in state %s\n", tcpm_states[port->state]); + }
/* * At this time, call the callback function of the respective pd chip
The current TCPM code implements source capability message handling according to the USB-PD specification. Unfortunately some USB PD sources do not properly follow the specification and do not send source capability messages after a soft reset when they already negotiated a specific contract before. The currently implemented way (and what is described in the specificiation) to resolve this problem is triggering a hard reset.
But a hard reset is fatal on batteryless platforms powered via USB-C PD, since that removes VBUS for some time. Since this is triggered at boot time, the system may get stuck in a boot loop.
For example I noticed the following behaviour on a Radxa Rock 5B combined with an affected power-supply:
1. The system is booted up with current code 2. A reboot is requested 3. U-Boot TCPM / fusb302 driver sends soft reset and waits for the source capability message 4. No new source capability message is send by the power-supply after the soft reset 5. U-Boot sends a hard reset 6. The board resets, but the fusb302 registers are not reset. This is because of a hardware glitch. The serial pins are high when no data is exchanged. Apparently the RK3588 has protection diodes, which leak some voltage into the power-domain. The Rock 5B serial pins and the fusb302 are using the same 3.3V power domain and the leaked voltage is enough to keep the fusb302 registers alive. 7. After the hard reset the power-supply sends another source capability message, which is auto-acked by fusb302 (because the register state is kept) even though the U-Boot driver has not yet probed. Once the U-Boot driver probes it sends another soft reset and waits for a new source capability message, which never arrives.
Fortunately the affected power-supplies (I have two setups showing this behaviour) support sending a source capability message when explicitly being asked. Thus an easy workaround to handle this is deviating from the USB-PD specification and sending a Get_Source_Cap message and waiting some time longer before doing the hard reset.
Note, that I recently added the same workaround to the Linux kernel with a slightly different rationale (since it needs to take over from U-Boot).
Fixes: 1db4c0ac77e3 ("usb: tcpm: add core framework") Signed-off-by: Sebastian Reichel sebastian.reichel@collabora.com --- drivers/usb/tcpm/tcpm-internal.h | 1 + drivers/usb/tcpm/tcpm.c | 32 +++++++++++++++++++++++++++++--- 2 files changed, 30 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/tcpm/tcpm-internal.h b/drivers/usb/tcpm/tcpm-internal.h index 561442090027..4861f4d13866 100644 --- a/drivers/usb/tcpm/tcpm-internal.h +++ b/drivers/usb/tcpm/tcpm-internal.h @@ -30,6 +30,7 @@ S(SNK_DISCOVERY_DEBOUNCE), \ S(SNK_DISCOVERY_DEBOUNCE_DONE), \ S(SNK_WAIT_CAPABILITIES), \ + S(SNK_WAIT_CAPABILITIES_TIMEOUT), \ S(SNK_NEGOTIATE_CAPABILITIES), \ S(SNK_TRANSITION_SINK), \ S(SNK_TRANSITION_SINK_VBUS), \ diff --git a/drivers/usb/tcpm/tcpm.c b/drivers/usb/tcpm/tcpm.c index b754b4dcd0b5..786d92fa4c6f 100644 --- a/drivers/usb/tcpm/tcpm.c +++ b/drivers/usb/tcpm/tcpm.c @@ -1424,7 +1424,8 @@ static inline enum tcpm_state hard_reset_state(struct tcpm_port *port) return ERROR_RECOVERY; if (port->pwr_role == TYPEC_SOURCE) return SRC_UNATTACHED; - if (port->state == SNK_WAIT_CAPABILITIES) + if (port->state == SNK_WAIT_CAPABILITIES || + port->state == SNK_WAIT_CAPABILITIES_TIMEOUT) return SNK_READY; return SNK_UNATTACHED; } @@ -1650,10 +1651,35 @@ static void run_state_machine(struct udevice *dev) tcpm_set_state(dev, SOFT_RESET_SEND, PD_T_SINK_WAIT_CAP); } else { - tcpm_set_state(dev, hard_reset_state(port), - PD_T_SINK_WAIT_CAP); + if (!port->self_powered) + tcpm_set_state(dev, SNK_WAIT_CAPABILITIES_TIMEOUT, + PD_T_SINK_WAIT_CAP); + else + tcpm_set_state(dev, hard_reset_state(port), + PD_T_SINK_WAIT_CAP); } break; + case SNK_WAIT_CAPABILITIES_TIMEOUT: + /* + * There are some USB PD sources in the field, which do not + * properly implement the specification and fail to start + * sending Source Capability messages after a soft reset. The + * specification suggests to do a hard reset when no Source + * capability message is received within PD_T_SINK_WAIT_CAP, + * but that might effectively kil the machine's power source. + * + * This slightly diverges from the specification and tries to + * recover from this by explicitly asking for the capabilities + * using the Get_Source_Cap control message before falling back + * to a hard reset. The control message should also be supported + * and handled by all USB PD source and dual role devices + * according to the specification. + */ + if (tcpm_pd_send_control(dev, PD_CTRL_GET_SOURCE_CAP)) + tcpm_set_state_cond(dev, hard_reset_state(port), 0); + else + tcpm_set_state(dev, hard_reset_state(port), PD_T_SINK_WAIT_CAP); + break; case SNK_NEGOTIATE_CAPABILITIES: port->pd_capable = true; port->hard_reset_count = 0;
A USB-PD hard reset involves removing the voltage from VBUS for some time. So basically it has the same effect as removing the USB-C plug for a short moment. If the machine is powered from the USB-C port and does not have a fallback supply (e.g. a battery), this will result in a full machine reset due to power loss.
Ideally we want to avoid triggering a hard reset on these boards. A non-working USB-C port is probably better than unplanned reboots. But boards with a backup supply should do the hard reset to get everything working again.
In theory it would be enough to check the self_powered property, but it seems the property might not be configured consistently enough in system firmwares.
USB-PD hard resets should happen rarely in general, so let's at least print an error message before the potential board reset happens. This is also useful, since it immediately gives away which device triggered the hard reset.
Fixes: 1db4c0ac77e3 ("usb: tcpm: add core framework") Signed-off-by: Sebastian Reichel sebastian.reichel@collabora.com --- drivers/usb/tcpm/tcpm.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/usb/tcpm/tcpm.c b/drivers/usb/tcpm/tcpm.c index 786d92fa4c6f..909fe2ef4fcb 100644 --- a/drivers/usb/tcpm/tcpm.c +++ b/drivers/usb/tcpm/tcpm.c @@ -1711,6 +1711,8 @@ static void run_state_machine(struct udevice *dev)
/* Hard_Reset states */ case HARD_RESET_SEND: + if (!port->self_powered && port->port_type == TYPEC_PORT_SNK) + dev_err(dev, "Initiating hard-reset, which might result in machine power-loss.\n"); tcpm_pd_transmit(dev, TCPC_TX_HARD_RESET, NULL); tcpm_set_state(dev, HARD_RESET_START, 0); port->wait_dr_swap_message = false;
On Radxa ROCK 5B I managed to get U-Boot into an endless loop of printing
fusb302 usb-typec@22: TCPM: data role mismatch, initiating error recovery
messages by changing the data role in Linux and then rebooting the system. This is happening because the external device (A cheap USB-C hub powered through a USB-C PD power-supply) kept its state and the error recovery path for non self-powered devices is not enough to change it.
Avoid this by swapping our own data role when the error recovery stage is reached for a port, which is not self-powered. Right now data support is limited anyways and once proper support is added we can use the data role swap request to get the desired data direction after the initial negotiation completed.
Fixes: 1db4c0ac77e3 ("usb: tcpm: add core framework") Signed-off-by: Sebastian Reichel sebastian.reichel@collabora.com --- drivers/usb/tcpm/tcpm.c | 30 +++++++++++++++++++++++++++--- 1 file changed, 27 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/tcpm/tcpm.c b/drivers/usb/tcpm/tcpm.c index 909fe2ef4fcb..12d66d470f9a 100644 --- a/drivers/usb/tcpm/tcpm.c +++ b/drivers/usb/tcpm/tcpm.c @@ -833,6 +833,28 @@ static void tcpm_pd_ctrl_request(struct udevice *dev, } }
+static void tcpm_recover_data_role_mismatch(struct udevice *dev) +{ + struct tcpm_port *port = dev_get_uclass_plat(dev); + + dev_err(dev, "TCPM: data role mismatch, initiating error recovery\n"); + if (port->self_powered) { + tcpm_set_state(dev, ERROR_RECOVERY, 0); + return; + } + + /* + * The error recovery will not help for devices, which are not + * self-powered because the error recovery avoids killing the board + * power. Since this can happen early on sending + * a DR_SWAP request is not sensible. Instead let's change our own + * data role. It can be swapped back once USB-PD reached the ready + * state. + */ + tcpm_set_roles(dev, true, port->pwr_role, + port->data_role == TYPEC_HOST ? TYPEC_DEVICE : TYPEC_HOST); +} + static void tcpm_pd_rx_handler(struct udevice *dev, const struct pd_message *msg) { @@ -867,9 +889,11 @@ static void tcpm_pd_rx_handler(struct udevice *dev, remote_is_host = !!(le16_to_cpu(msg->header) & PD_HEADER_DATA_ROLE); local_is_host = port->data_role == TYPEC_HOST; if (remote_is_host == local_is_host) { - dev_err(dev, "TCPM: data role mismatch, initiating error recovery\n"); - tcpm_set_state(dev, ERROR_RECOVERY, 0); - } else { + tcpm_recover_data_role_mismatch(dev); + local_is_host = port->data_role == TYPEC_HOST; + } + + if (remote_is_host != local_is_host) { if (cnt) tcpm_pd_data_request(dev, msg); else
Sebastian Reichel
