[U-Boot] [PATCH 0/3] ARM: keystone2: Cleanup macros
As reported by Tom in [1], macros in psc definitions are just too painful to readup on.. so convert it into static inline of equivalent functionality.
Based on master 4d339a9e8a75 Merge branch 'master' of git://git.denx.de/u-boot-video
Testing: K2g: http://pastebin.ubuntu.com/15392362/ k2hk: http://pastebin.ubuntu.com/15392337/
Nishanth Menon (3): ARM: keystone2: Convert BOOTBITMASK to static inline function ARM: keystone2: Convert BOOT_READ_BITFIELD into static inline function ARM: keystone2: Convert BOOT_SET_BITFIELD into static inline function
arch/arm/mach-keystone/include/mach/psc_defs.h | 51 ++++++++++++++++---------- 1 file changed, 32 insertions(+), 19 deletions(-)
[1] https://patchwork.ozlabs.org/patch/588338/
BOOTBITMASK is almost impossible to decode, so convert it into a simpler static line functions of equivalent solution.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/mach-keystone/include/mach/psc_defs.h | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-keystone/include/mach/psc_defs.h b/arch/arm/mach-keystone/include/mach/psc_defs.h index 6e6e7fd433a1..9681175938d4 100644 --- a/arch/arm/mach-keystone/include/mach/psc_defs.h +++ b/arch/arm/mach-keystone/include/mach/psc_defs.h @@ -27,12 +27,16 @@ #define PSC_REG_MDSTAT(x) (0x800 + (4 * (x))) #define PSC_REG_MDCTL(x) (0xa00 + (4 * (x)))
-#define BOOTBITMASK(x, y) ((((((u32)1 << (((u32)x) - ((u32)y) + (u32)1)) - \ - (u32)1)) << ((u32)y)))
-#define BOOT_READ_BITFIELD(z, x, y) ((((u32)z) & BOOTBITMASK(x, y)) >> (y)) -#define BOOT_SET_BITFIELD(z, f, x, y) ((((u32)z) & ~BOOTBITMASK(x, y)) | \ - ((((u32)f) << (y)) & BOOTBITMASK(x, y))) +static inline u32 _boot_bit_mask(u32 x, u32 y) +{ + u32 val = (1 << (x - y + 1)) - 1; + return val << y; +} + +#define BOOT_READ_BITFIELD(z, x, y) ((((u32)z) & _boot_bit_mask(x, y)) >> (y)) +#define BOOT_SET_BITFIELD(z, f, x, y) ((((u32)z) & ~_boot_bit_mask(x, y)) | \ + ((((u32)f) << (y)) & _boot_bit_mask(x, y)))
/* PDCTL */ #define PSC_REG_PDCTL_SET_NEXT(x, y) BOOT_SET_BITFIELD((x), (y), 0, 0)
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Nishanth Menon nm@ti.com Reviewed-by: Tom Rini trini@konsulko.com
BOOT_READ_BITFIELD can easily be a static inline function and be a little more readable with the same functionality.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/mach-keystone/include/mach/psc_defs.h | 25 +++++++++++++++---------- 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-keystone/include/mach/psc_defs.h b/arch/arm/mach-keystone/include/mach/psc_defs.h index 9681175938d4..671b1d64d69f 100644 --- a/arch/arm/mach-keystone/include/mach/psc_defs.h +++ b/arch/arm/mach-keystone/include/mach/psc_defs.h @@ -34,7 +34,12 @@ static inline u32 _boot_bit_mask(u32 x, u32 y) return val << y; }
-#define BOOT_READ_BITFIELD(z, x, y) ((((u32)z) & _boot_bit_mask(x, y)) >> (y)) +static inline u32 boot_read_bitfield(u32 z, u32 x, u32 y) +{ + u32 val = z & _boot_bit_mask(x, y); + return val >> y; +} + #define BOOT_SET_BITFIELD(z, f, x, y) ((((u32)z) & ~_boot_bit_mask(x, y)) | \ ((((u32)f) << (y)) & _boot_bit_mask(x, y)))
@@ -43,25 +48,25 @@ static inline u32 _boot_bit_mask(u32 x, u32 y) #define PSC_REG_PDCTL_SET_PDMODE(x, y) BOOT_SET_BITFIELD((x), (y), 15, 12)
/* PDSTAT */ -#define PSC_REG_PDSTAT_GET_STATE(x) BOOT_READ_BITFIELD((x), 4, 0) +#define PSC_REG_PDSTAT_GET_STATE(x) boot_read_bitfield((x), 4, 0)
/* MDCFG */ -#define PSC_REG_MDCFG_GET_PD(x) BOOT_READ_BITFIELD((x), 20, 16) -#define PSC_REG_MDCFG_GET_RESET_ISO(x) BOOT_READ_BITFIELD((x), 14, 14) +#define PSC_REG_MDCFG_GET_PD(x) boot_read_bitfield((x), 20, 16) +#define PSC_REG_MDCFG_GET_RESET_ISO(x) boot_read_bitfield((x), 14, 14)
/* MDCTL */ #define PSC_REG_MDCTL_SET_NEXT(x, y) BOOT_SET_BITFIELD((x), (y), 4, 0) #define PSC_REG_MDCTL_SET_LRSTZ(x, y) BOOT_SET_BITFIELD((x), (y), 8, 8) -#define PSC_REG_MDCTL_GET_LRSTZ(x) BOOT_READ_BITFIELD((x), 8, 8) +#define PSC_REG_MDCTL_GET_LRSTZ(x) boot_read_bitfield((x), 8, 8) #define PSC_REG_MDCTL_SET_RESET_ISO(x, y) BOOT_SET_BITFIELD((x), (y), \ 12, 12)
/* MDSTAT */ -#define PSC_REG_MDSTAT_GET_STATUS(x) BOOT_READ_BITFIELD((x), 5, 0) -#define PSC_REG_MDSTAT_GET_LRSTZ(x) BOOT_READ_BITFIELD((x), 8, 8) -#define PSC_REG_MDSTAT_GET_LRSTDONE(x) BOOT_READ_BITFIELD((x), 9, 9) -#define PSC_REG_MDSTAT_GET_MRSTZ(x) BOOT_READ_BITFIELD((x), 10, 10) -#define PSC_REG_MDSTAT_GET_MRSTDONE(x) BOOT_READ_BITFIELD((x), 11, 11) +#define PSC_REG_MDSTAT_GET_STATUS(x) boot_read_bitfield((x), 5, 0) +#define PSC_REG_MDSTAT_GET_LRSTZ(x) boot_read_bitfield((x), 8, 8) +#define PSC_REG_MDSTAT_GET_LRSTDONE(x) boot_read_bitfield((x), 9, 9) +#define PSC_REG_MDSTAT_GET_MRSTZ(x) boot_read_bitfield((x), 10, 10) +#define PSC_REG_MDSTAT_GET_MRSTDONE(x) boot_read_bitfield((x), 11, 11)
/* PDCTL states */ #define PSC_REG_VAL_PDCTL_NEXT_ON 1
Fix up BOOT_SET_BITFIELD to be a static inline function to be readable with the same functionality.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/mach-keystone/include/mach/psc_defs.h | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-keystone/include/mach/psc_defs.h b/arch/arm/mach-keystone/include/mach/psc_defs.h index 671b1d64d69f..18499386a321 100644 --- a/arch/arm/mach-keystone/include/mach/psc_defs.h +++ b/arch/arm/mach-keystone/include/mach/psc_defs.h @@ -40,12 +40,16 @@ static inline u32 boot_read_bitfield(u32 z, u32 x, u32 y) return val >> y; }
-#define BOOT_SET_BITFIELD(z, f, x, y) ((((u32)z) & ~_boot_bit_mask(x, y)) | \ - ((((u32)f) << (y)) & _boot_bit_mask(x, y))) +static inline u32 boot_set_bitfield(u32 z, u32 f, u32 x, u32 y) +{ + u32 mask = _boot_bit_mask(x, y); + + return (z & ~mask) | ((f << y) & mask); +}
/* PDCTL */ -#define PSC_REG_PDCTL_SET_NEXT(x, y) BOOT_SET_BITFIELD((x), (y), 0, 0) -#define PSC_REG_PDCTL_SET_PDMODE(x, y) BOOT_SET_BITFIELD((x), (y), 15, 12) +#define PSC_REG_PDCTL_SET_NEXT(x, y) boot_set_bitfield((x), (y), 0, 0) +#define PSC_REG_PDCTL_SET_PDMODE(x, y) boot_set_bitfield((x), (y), 15, 12)
/* PDSTAT */ #define PSC_REG_PDSTAT_GET_STATE(x) boot_read_bitfield((x), 4, 0) @@ -55,10 +59,10 @@ static inline u32 boot_read_bitfield(u32 z, u32 x, u32 y) #define PSC_REG_MDCFG_GET_RESET_ISO(x) boot_read_bitfield((x), 14, 14)
/* MDCTL */ -#define PSC_REG_MDCTL_SET_NEXT(x, y) BOOT_SET_BITFIELD((x), (y), 4, 0) -#define PSC_REG_MDCTL_SET_LRSTZ(x, y) BOOT_SET_BITFIELD((x), (y), 8, 8) +#define PSC_REG_MDCTL_SET_NEXT(x, y) boot_set_bitfield((x), (y), 4, 0) +#define PSC_REG_MDCTL_SET_LRSTZ(x, y) boot_set_bitfield((x), (y), 8, 8) #define PSC_REG_MDCTL_GET_LRSTZ(x) boot_read_bitfield((x), 8, 8) -#define PSC_REG_MDCTL_SET_RESET_ISO(x, y) BOOT_SET_BITFIELD((x), (y), \ +#define PSC_REG_MDCTL_SET_RESET_ISO(x, y) boot_set_bitfield((x), (y), \ 12, 12)
/* MDSTAT */
Nishanth Menon
