[U-Boot] [PATCH] Revert "build: Always build the libfdt python module"
This appears to cause problems with powerpc:
+x86_64-linux-gnu-gcc: error: unrecognized command line option ‘-melf32ppclinux’ +error: command 'x86_64-linux-gnu-gcc' failed with exit status 1 +make[2]: *** [tools/_libfdt.so] Error 1 +make[1]: *** [tools] Error 2 +make: *** [sub-make] Error 2
It may need to be made ARM-specific.
This reverts commit 1905c8fc711a527ff10550425498bc77e4db9ac3. Signed-off-by: Simon Glass sjg@chromium.org ---
tools/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/Makefile b/tools/Makefile index a609d058595..5b81dde4b06 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -111,7 +111,7 @@ fit_check_sign-objs := $(dumpimage-mkimage-objs) fit_check_sign.o
# Build a libfdt Python module if swig is available # Use 'sudo apt-get install swig libpython-dev' to enable this -hostprogs-y += \ +hostprogs-$(CONFIG_SPL_OF_PLATDATA) += \ $(if $(shell which swig 2> /dev/null),_libfdt.so) _libfdt.so-sharedobjs += $(LIBFDT_OBJS) libfdt:
Hi Simon,
+x86_64-linux-gnu-gcc: error: unrecognized command line option ?-melf32ppclinux? +error: command 'x86_64-linux-gnu-gcc' failed with exit status 1 +make[2]: *** [tools/_libfdt.so] Error 1 +make[1]: *** [tools] Error 2 +make: *** [sub-make] Error 2
Why does your hostcc have this cflags ?
There is a problem where we do not check that we can build python module (I'll look at how to check this properly) as Heiko just reported but the fact that your hostcc have an ppc flags just seems wrong, there must be another problem.
# Build a libfdt Python module if swig is available # Use 'sudo apt-get install swig libpython-dev' to enable this -hostprogs-y += \ +hostprogs-$(CONFIG_SPL_OF_PLATDATA) += \ $(if $(shell which swig 2> /dev/null),_libfdt.so) _libfdt.so-sharedobjs += $(LIBFDT_OBJS) libfdt: -- 2.11.0.483.g087da7b7c-goog
On Mon, Jan 23, 2017 at 01:56:25PM +0100, Emmanuel Vadot wrote:
Hi Simon,
Looking into this, because it's python doing the building here: swig -python -o tools/libfdt_wrap.c ../lib/libfdt/libfdt.swig python ../lib/libfdt/setup.py "-Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -include ../include/libfdt_env.h -idirafterinclude -idirafter../include -idirafter../arch/powerpc/include -I../lib/libfdt -I../tools -DCONFIG_SYS_TEXT_BASE=0xFC000000 -DUSE_HOSTCC -D__KERNEL_STRICT_NAMES -D_GNU_SOURCE " ../lib/libfdt/fdt.c ../lib/libfdt/fdt_ro.c ../lib/libfdt/fdt_rw.c ../lib/libfdt/fdt_strerror.c ../lib/libfdt/fdt_wip.c ../lib/libfdt/fdt_region.c ../lib/libfdt/fdt_sw.c tools/libfdt_wrap.c gcc-4.8.real: error: unrecognized command line option ‘-melf32ppclinux’
I suspect that what's going on is that python is seeing LDFLAGS being set to $(PLATFORM_LDFLAGS) and passing that along. ARM (and sandbox) do not set PLATFORM_LDFLAGS so don't run into this problem.
Hello Simon,
Am 23.01.2017 um 13:37 schrieb Simon Glass:
Yup, I posted this issue exactly today ...
Reviewed-by: Heiko Schocher hs@denx.de
Tested on the tqm5200 board, so:
Tested-by: Heiko Schocher hs@denx.de
Why do we need this at all?
Fedora for example has no "libpython-dev" ... So at least the "if" should check for "libpython-dev" too...
# dnf install libpython-dev Last metadata expiration check: 1:50:58 ago on Mon Jan 23 07:49:26 2017. No package libpython-dev available. Error: Unable to find a match.
bye, Heiko
Emmanuel Vadot
Heiko Schocher
